  4. Nach Update und Restore iobroker läuft VIS.0 nicht mehr
    2.6k
    4.6k
28 Beiträge 3 Kommentatoren 2.5k Aufrufe 3 Beobachtet
    @jj-duisburg
    Log file?
    JJ-Duisburg
    2021-03-07 23:00:40.038  - info: host.raspberrypi added notifications configuration of host
    2021-03-07 23:00:40.706  - info: host.raspberrypi 44 instances found
    2021-03-07 23:00:40.800  - info: host.raspberrypi starting 1 instance
    2021-03-07 23:00:41.023  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 587
    2021-03-07 23:00:43.400  - info: admin.0 (587) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.21.0, js-controller: 3.2.16
    2021-03-07 23:00:43.451  - info: admin.0 (587) requesting all states
    2021-03-07 23:00:43.452  - info: admin.0 (587) requesting all objects
    2021-03-07 23:00:45.698  - info: admin.0 (587) received all objects
    2021-03-07 23:00:46.016  - info: admin.0 (587) http server listening on port 8081
    2021-03-07 23:00:46.017  - info: admin.0 (587) Use link "http://localhost:8081" to configure.
    • J JJ-Duisburg
      JJ-Duisburg
      @jj-duisburg said in Nach Update und Restore iobroker läuft VIS.0 nicht mehr:
      • J JJ-Duisburg
        @jj-duisburg
        Das ist nicht vom Start von vis.
        iobroker list adapters
        iobroker list instances
          @jj-duisburg
          JJ-Duisburg
          @thomas-braun said in Nach Update und Restore iobroker läuft VIS.0 nicht mehr:
          system.adapter.admin                   : admin          - v4.2.1
          system.adapter.backitup                : backitup       - v1.7.0
          system.adapter.bosesoundtouch          : bosesoundtouch - v0.9.3
          system.adapter.daswetter               : daswetter      - v3.0.4
          system.adapter.discovery               : discovery      - v2.5.0
          system.adapter.dwd                     : dwd            - v2.7.5
          system.adapter.flot                    : flot           - v1.10.6
          system.adapter.hm-rega                 : hm-rega        - v3.0.16
          system.adapter.hm-rpc                  : hm-rpc         - v1.14.35
          system.adapter.ical                    : ical           - v1.7.4
          system.adapter.icons-icons8            : icons-icons8   - v0.0.1
          system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
          system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.2
          system.adapter.influxdb                : influxdb       - v1.9.4
          system.adapter.info                    : info           - v1.7.14
          system.adapter.javascript              : javascript     - v5.0.12
          system.adapter.luftdaten               : luftdaten      - v1.0.2
          system.adapter.mqtt                    : mqtt           - v2.3.4
          system.adapter.mqtt-client             : mqtt-client    - v1.3.1
          system.adapter.octoprint               : octoprint      - v1.0.8
          system.adapter.openweathermap          : openweathermap - v0.1.0
          system.adapter.ping                    : ping           - v1.4.12
          system.adapter.pollenflug              : pollenflug     - v1.0.6
          system.adapter.ring                    : ring           - v1.1.3
          system.adapter.rpi2                    : rpi2           - v1.2.0
          system.adapter.scenes                  : scenes         - v2.3.6
          system.adapter.simple-api              : simple-api     - v2.5.3
          system.adapter.socketio                : socketio       - v3.1.4
          system.adapter.sonoff                  : sonoff         - v2.4.0
          system.adapter.tankerkoenig            : tankerkoenig   - v2.0.5
          system.adapter.telegram                : telegram       - v1.7.0
          system.adapter.text2command            : text2command   - v2.0.7
          system.adapter.tr-064                  : tr-064         - v4.2.4
          system.adapter.trashschedule           : trashschedule  - v1.1.1
          system.adapter.viessmann               : viessmann      - v1.3.3
          system.adapter.vis                     : vis            - v1.3.4
          system.adapter.vis-bars                : vis-bars       - v0.1.4
          system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
          system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
          system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.7
          system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
          system.adapter.vis-metro               : vis-metro      - v1.1.2
          system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
          system.adapter.web
          • J JJ-Duisburg
            system.adapter.web
            JJ-Duisburg
            @jj-duisburg
              system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
              system.adapter.bosesoundtouch.0         : bosesoundtouch        : raspberrypi                              - disabled
              system.adapter.bosesoundtouch.1         : bosesoundtouch        : raspberrypi                              - disabled
              system.adapter.bosesoundtouch.2         : bosesoundtouch        : raspberrypi                              - disabled
              system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
              system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
              system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
              system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              - disabled
              system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              - disabled, port: 0
              system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              - disabled, port: 0
              system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              - disabled, port: 0
              system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
              system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
              system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
              system.adapter.info.0                   : info                  : raspberrypi                              - disabled
              system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
              system.adapter.javascript.1             : javascript            : raspberrypi                              - disabled
              system.adapter.luftdaten.0              : luftdaten             : raspberrypi                              - disabled
              system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
              system.adapter.octoprint.0              : octoprint             : raspberrypi                              - disabled
              system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              - disabled
              system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
              system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              - disabled
              system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
              system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
              system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              - disabled
              system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
              system.adapter.text2command.0           : text2command          : raspberrypi                              - disabled
              system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
              system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
              system.adapter.viessmann.0              : viessmann             : raspberrypi                              - disabled, port: 3002
              system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
              system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
              system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
              system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
            + instance is alive
            • J JJ-Duisburg
              @jj-duisburg
              + instance is alive
              JJ-Duisburg
              @jj-duisburg
              Der Admin lädt nicht, ich komme nicht weiter.
              • J JJ-Duisburg
                @jj-duisburg
                JJ-Duisburg
                @jj-duisburg
                und somit kann ich VIS nicht starten.
                • J JJ-Duisburg
                  @jj-duisburg
                  @jj-duisburg
                  CodeTags...
                  • J JJ-Duisburg
                    @jj-duisburg
                    @jj-duisburg
                    iobroker start web
                      @jj-duisburg
                      iobroker start web
                      JJ-Duisburg
                      instance is alive
                      iobroker start web und ...start vis gemacht, jetzt kann ich vis edit aufrufen
                      iobroker.web funktioniert auch aber der admin leider nicht, der läuft und läuft und läuft und kommt nicht hoch.
                      • J JJ-Duisburg
                        instance is alive
                        JJ-Duisburg
                        @jj-duisburg
                        + system.adapter.admin.1                  : admin                 : raspberrypi                              -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
                        + instance is alive
                        Ich habe auch schon einen 2. admin unter 8089 angelegt, das gleiche bild. läuft und läuft und kommt nicht durch.
                        • J JJ-Duisburg
                          @jj-duisburg
                          + instance is alive
                          JJ-Duisburg
                          @jj-duisburg
                          Verrückte Welt.
                          Hier auf meinem Laptop dreht der admin und kommt nicht hoch.
                          Auf dem Tablet funktioniert es, es muss wohl an meinem WLAN liegen, Tablet geht über 5 GHz, Laptop über 2,4 GHz Netz.
                          Nächste Baustelle.
                          Erst mal danke für heute und noch gute Restnacht.
                          Josef
                          • J JJ-Duisburg
                            @jj-duisburg
                            Verrückte Welt.
                            Nächste Baustelle.
                            Josef
                            wendy2702W Online
                            wendy2702W Online
                            @jj-duisburg Welcher Browser?
                            Force Reload und Cache mal gelöscht?
                            • wendy2702W wendy2702
                              JJ-Duisburg
                              @wendy2702 ich arbeite auf dem Laptop mit Microsoft Edge.
                              Zwischenzeitlich läuft wieder alles. Es war auch u. a. ein Problem mit meinem WLAN.
                              Noch einmal danke an alle.
                              Ich würde mich gerne intensiver mit iobroker beschäftigen, nicht nur als Anwender bzw. Nachmacher von Lösungen. Hat jemand einen Tipp, wo und wie ich Informationen, Tutorials oder bücher hierzu bekomme und was für den Einstieg geeignet ist?
                              Gruß aus Duisburg
                              Josef
