  4. [ Geklärt ] Wie kann ich eine HDD gegen SSD tauschen
hddssdwechsel
79 Beiträge 5 Kommentatoren 4.8k Aufrufe 4 Beobachtet
    @altersrentner
    Das log file kann man ja immer mal im Auge behalten. Mach ich bei mir auch, wenn ich am System herumschraube.
    Altersrentner
    #66
    Etwas ist schief gelaufen.
    host.raspberrypi	2021-03-06 19:03:23.189	info	iobroker npm-install: gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:
    host.raspberrypi	2021-03-06 19:03:23.180	info	iobroker npm-install: make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Error 1
    host.raspberrypi	2021-03-06 19:03:22.966	info	iobroker npm-install: In file included from ../../nan/nan.h:56, from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope NODE_MODULE(a
    host.raspberrypi	2021-03-06 19:03:22.960	info	iobroker npm-install: ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’ void init(Handle<Object> exports) { ^~~~~~ rand_r../authenticate_pam.cc:170:24: error: ex
    host.raspberrypi	2021-03-06 19:03:22.954	info	iobroker npm-install: In file included from /home/iobroker/.cache/node-gyp/12.21.0/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.21.0/include/node/v8.h:27,
    host.raspberrypi	2021-03-06 19:03:22.947	info	iobroker npm-install: ^~~~~~~~~~~~../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Fun
    host.raspberrypi	2021-03-06 19:03:22.944	info	iobroker npm-install: ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>
    host.raspberrypi	2021-03-06 18:03:05.769	info	iobroker npm-install: npm install iobroker.vis-metro@1.1.2 --loglevel error --prefix "/opt/iobroker" (System call)
    host.raspberrypi	2021-03-06 18:03:05.767	info	iobroker npm-install: NPM version: 6.14.11
    host.raspberrypi	2021-03-06 18:03:02.422	info	iobroker install vis-metro@1.1.2 using installedFrom
    host.raspberrypi	2021-03-06 18:03:02.421	warn	startInstance cannot find adapter "vis-metro@1.1.2". Try to install it... 1 attempt
    host.raspberrypi	2021-03-06 18:03:01.287	info	iobroker npm-install: exit 0
    host.raspberrypi	2021-03-06 18:03:00.218	info	iobroker npm-install: Update "system.adapter.vis-materialdesign.0"
    host.raspberrypi	2021-03-06 18:03:00.132	info	iobroker npm-install: host.raspberrypi object system.adapter.vis-materialdesign created/updated
    host.raspberrypi	2021-03-06 18:02:59.850	info	iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-materialdesign/www" was not found! Nothing was uploaded or deleted.
    host.raspberrypi	2021-03-06 18:02:59.792	info	iobroker npm-install: upload [0] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/vis-materialdesign.png vis-materialdesign.png image/png
    host.raspberrypi	2021-03-06 18:02:59.734	info	iobroker npm-install: upload [1] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/vis-materialdesign_16_9.png vis-materialdesign_16_9.png image/png
    host.raspberrypi	2021-03-06 18:02:59.600	info	iobroker npm-install: upload [2] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/words.js words.js application/javascript
    host.raspberrypi	2021-03-06 18:02:59.579	info	iobroker npm-install: host.raspberrypi install adapter vis-materialdesign@0.3.19
    host.raspberrypi	2021-03-06 18:02:55.539	info	iobroker npm-install: gyp ERR! System Linux 5.4.83-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modu
    host.raspberrypi	2021-03-06 18:02:55.537	info	iobroker npm-install: gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stac
    host.raspberrypi	2021-03-06 18:02:55.535	info	iobroker npm-install: gyp ERR! build error
    host.raspberrypi	2021-03-06 18:02:55.532	info	iobroker npm-install: make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Error 1
    host.raspberrypi	2021-03-06 18:02:55.322	info	iobroker npm-install: NODE_MODULE(authenticate_pam, init); ^~~~/home/iobroker/.cache/node-gyp/12.21.0/include/node/node.h:737:36: note: in definition of macro ‘NODE_MOD
    host.raspberrypi	2021-03-06 18:02:55.320	info	iobroker npm-install: ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’
    host.raspberrypi	2021-03-06 18:02:55.318	info	iobroker npm-install: from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope NODE_MODULE(authenticate_pam, init);
    host.raspberrypi	2021-03-06 18:02:55.317	info	iobroker npm-install: In file included from ../../nan/nan.h:56,
    host.raspberrypi	2021-03-06 18:02:55.313	info	iobroker npm-install: ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’ void init(Handle<Object> exports) { ^~~~~~ rand_r../authenticate_pam.cc:170:24: error: e
    host.raspberrypi	2021-03-06 18:02:55.310	info	iobroker npm-install: Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args); ^
    host.raspberrypi	2021-03-06 18:02:55.300	info	iobroker npm-install: ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object
    host.raspberrypi	2021-03-06 18:02:34.812	info	iobroker npm-install: npm install iobroker.vis-materialdesign@0.3.19 --loglevel error --prefix "/opt/iobroker" (System call)
    host.raspberrypi	2021-03-06 18:02:34.809	info	iobroker npm-install: NPM version: 6.14.11
    host.raspberrypi	2021-03-06 18:02:32.000	info	iobroker install vis-materialdesign@0.3.19 using installedFrom
    host.raspberrypi	2021-03-06 18:02:31.998	warn	startInstance cannot find adapter "vis-materialdesign@0.3.19". Try to install it... 1 attempt
    host.raspberrypi	2021-03-06 18:02:30.994	info	iobroker npm-install: exit 0
    Es werden keine Adapter gefunden
    • A Altersrentner
      #67
      @altersrentner
      Wenn da ganz sicher über mehrere Minuten absolute Ruhe in der Konsole herrscht:
      iobroker list adapters
      iobroker list instances
        @altersrentner
        Altersrentner
        #68
        pi@raspberrypi:~ $ iobroker list adapters
        system.adapter.admin                   : admin          - v4.2.1
        system.adapter.alexa2                  : alexa2         - v3.8.1
        system.adapter.backitup                : backitup       - v2.0.1
        system.adapter.ble                     : ble            - v0.12.0
        system.adapter.cloud                   : cloud          - v4.0.10
        system.adapter.cul                     : cul            - v1.3.4
        system.adapter.daswetter               : daswetter      - v3.0.4
        system.adapter.discovery               : discovery      - v2.6.1
        system.adapter.dwd                     : dwd            - v2.7.5
        system.adapter.fakeroku                : fakeroku       - v0.2.1
        system.adapter.feiertage               : feiertage      - v1.0.19
        system.adapter.fhem                    : fhem           - v1.5.3
        system.adapter.flot                    : flot           - v1.10.6
        system.adapter.harmony                 : harmony        - v1.2.2
        system.adapter.history                 : history        - v1.9.10
        system.adapter.hm-rega                 : hm-rega        - v3.0.16
        system.adapter.hm-rpc                  : hm-rpc         - v1.14.35
        system.adapter.hmm                     : hmm            - v1.0.1
        system.adapter.ical                    : ical           - v1.9.1
        system.adapter.icons-icons8            : icons-icons8   - v0.0.1
        system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
        system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.3
        system.adapter.influxdb                : influxdb       - v1.9.4
        system.adapter.info                    : info           - v1.7.15
        system.adapter.iot                     : iot            - v1.8.13
        system.adapter.jarvis                  : jarvis         - v2.2.0
        system.adapter.javascript              : javascript     - v5.0.7
        system.adapter.js2fs                   : js2fs          - v0.1.5
        system.adapter.mihome                  : mihome         - v1.3.7
        system.adapter.mihome-plug             : mihome-plug    - v0.2.0
        system.adapter.mihome-vacuum           : mihome-vacuum  - v1.1.5
        system.adapter.mobile                  : mobile         - v0.5.0
        system.adapter.ping                    : ping           - v1.3.2
        system.adapter.pushover                : pushover       - v2.0.3
        system.adapter.rpi2                    : rpi2           - v1.2.0
        system.adapter.samsung                 : samsung        - v0.2.9
        system.adapter.scenes                  : scenes         - v2.3.6
        system.adapter.shelly                  : shelly         - v4.0.7-beta-1
        system.adapter.shuttercontrol          : shuttercontrol - v1.1.5
        system.adapter.simple-api              : simple-api     - v2.5.3
        system.adapter.socketio                : socketio       - v3.1.4
        system.adapter.tankerkoenig            : tankerkoenig   - v2.0.10
        system.adapter.telegram                : telegram       - v1.8.0
        system.adapter.terminal                : terminal       - v0.1.2
        system.adapter.text2command            : text2command   - v2.0.7
        system.adapter.tr-064-community        : tr-064-community - v1.0.0
        system.adapter.trashschedule           : trashschedule  - v1.1.1
        system.adapter.vis                     : vis            - v1.3.7
        system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
        system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.7
        system.adapter.vis-material-webfont    : vis-material-webfont - v0.0.3
        system.adapter.vis-materialdesign      : vis-materialdesign - v0.3.19
        system.adapter.vis-metro               : vis-metro      - v1.1.2
        system.adapter.vis-plumb               : vis-plumb      - v1.0.2
        system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
        system.adapter.vis-weather             : vis-weather    - v2.5.2
        system.adapter.weatherunderground      : weatherunderground - v3.1.3
        system.adapter.web                     : web            - v3.3.0
        system.adapter.yr                      : yr             - v2.0.3
        system.adapter.zigbee                  : zigbee         - v1.4.4
        pi@raspberrypi:~ $ iobroker list instances
        + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
        + system.adapter.cul.0                    : cul                   : raspberrypi                              -  enabled, port: 23
          system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
          system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
          system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
        + system.adapter.fhem.0                   : fhem                  : raspberrypi                              -  enabled, port: 7072
        + system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
        + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
        + system.adapter.mihome.0                 : mihome                : raspberrypi                              -  enabled, port: 9898, bind: 0.0.0.0
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        + system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
        + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
        + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
        + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8090, bind: 0.0.0.0, run as: admin
        + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
          system.adapter.tr-064-community.0       : tr-064-community      : raspberrypi                              -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
          system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
          system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
          system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
          system.adapter.yr.0                     : yr                    : raspberrypi                              -  enabled
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0012013B01-if00
        + instance is alive
        Habe die Adapter jetzt per Hand gestartet.
        Wie schon gedacht, Influx startet nicht.
        Thomas BraunT wendy2702W 2 Antworten Letzte Antwort
        • A Altersrentner
          + instance is alive
          #69
          @altersrentner
          Passt doch soweit.
          Zu influxdb kann ich nix sagen.
          A 2 Antworten Letzte Antwort
            @altersrentner
            Passt doch soweit.
            Altersrentner
            #70
            Danke,
            Die blaue LED am USB Adapter der SSD blinkt ständig,
            und am Pi die grüne. ist das normal?
            MfG Michael
            • A Altersrentner
              Danke,
              MfG Michael
              #71
              @altersrentner
              Klar. Da passiert ja auch was.
              • A Altersrentner
                + instance is alive
                wendy2702W Online
                wendy2702W Online
                #72
                @altersrentner sagte in Wie kann ich eine HDD gegen SSD tauschen:
                Hast du denn Influx schon installiert? Also die Datenbank, nicht den Adapter.
                  @altersrentner
                  Passt doch soweit.
                  Altersrentner
                  #73
                  Danke😊 👍
                  Wünsche noch eine schönen Abend
                  Mit freundlichen Grüßen
                  Michael
                  • wendy2702W wendy2702
                    Altersrentner
                    #74
                    @wendy2702
                    Auf der HDD ist alles prima gelaufen.
                    Ich denke dann sollte es doch auch gesichert worden sein,
                    oder?
                    MfG Michael
                    • A Altersrentner
                      @wendy2702
                      oder?
                      MfG Michael
                      wendy2702W Online
                      wendy2702W Online
                      #75
                      @altersrentner Wir hast du denn das Backup der HDD gemacht und auf die SSD übertragen?
                        Altersrentner
                        #76
                        @wendy2702
                        HDD über Backitup in Google Drive gesichert und dann
                        die Sicherung wieder hergestellt auf der SSD
                        • A Altersrentner
                          Mein ioBroker läuft seit einiger Zeit auf einer 2,5" HDD 750 GB in Verbindung mit dem PI 4.
                          Heute ist der Broker 2x ausgestiegen und die HDD ist sehr schwer gestartet.
                          Ich vermute einen Defekt der HDD.
                          Wie kann ich über die Konsole prüfen, ob die HDD i.O. ist.
                          Sicherheitshalber möchte ich sie gegen eine SSD austauschen.
                          Ist das problemlos möglich?
                          Michael
                          Altersrentner
                          #77
                          @altersrentner
                          Muss mich leider für heute verabschieden,
                          meine Geburtstag(71)sgäste sind eingetroffen.
                          Wünsche einen schönen Abend
                          und DANKE
                          Michael
                          • A Altersrentner
                            @wendy2702
                            wendy2702W Online
                            wendy2702W Online
                            #78
                            @altersrentner Backitup sichert doch bestimmt nicht die Installation von InfluxDB mit. Maximal die DB.
                            Ich denke die Datenbank SW an sich musst du schon selber wieder installieren.
                            • A Altersrentner
                              @altersrentner
                              und DANKE
                              Michael
                              wendy2702W Online
                              wendy2702W Online
                              #79
                              @altersrentner
                              HAAPY BIRTHDAY
                              Und schönen Abend im Kreise deine Gäste
