  4. Zigbee Instanz nach update von 1.3.1 auf 1.4.4 rot
    6.6k
55 Beiträge 4 Kommentatoren 6.4k Aufrufe 4 Beobachtet
  • W wolf
    Leider noch immer...
    host.raspberrypi	2021-03-06 17:08:56.382	info	Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
    host.raspberrypi	2021-03-06 17:08:56.381	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi	2021-03-06 17:08:56.381	error	Caught by controller[0]: }
    host.raspberrypi	2021-03-06 17:08:56.381	error	Caught by controller[0]: ]
    host.raspberrypi	2021-03-06 17:08:56.380	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node'
    host.raspberrypi	2021-03-06 17:08:56.380	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node',
    host.raspberrypi	2021-03-06 17:08:56.380	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node',
    host.raspberrypi	2021-03-06 17:08:56.379	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node',
    host.raspberrypi	2021-03-06 17:08:56.379	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/compiled/12.21.0/linux/arm/bindings.node',
    host.raspberrypi	2021-03-06 17:08:56.378	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node',
    host.raspberrypi	2021-03-06 17:08:56.378	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node',
    host.raspberrypi	2021-03-06 17:08:56.378	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node',
    host.raspberrypi	2021-03-06 17:08:56.377	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node',
    host.raspberrypi	2021-03-06 17:08:56.377	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node',
    host.raspberrypi	2021-03-06 17:08:56.376	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node',
    host.raspberrypi	2021-03-06 17:08:56.376	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node',
    host.raspberrypi	2021-03-06 17:08:56.376	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/bindings.node',
    host.raspberrypi	2021-03-06 17:08:56.375	error	Caught by controller[0]: tries: [
    host.raspberrypi	2021-03-06 17:08:56.375	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30) {
    host.raspberrypi	2021-03-06 17:08:56.375	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22)
    host.raspberrypi	2021-03-06 17:08:56.374	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.raspberrypi	2021-03-06 17:08:56.374	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.raspberrypi	2021-03-06 17:08:56.374	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi	2021-03-06 17:08:56.373	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi	2021-03-06 17:08:56.373	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi	2021-03-06 17:08:56.373	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.raspberrypi	2021-03-06 17:08:56.372	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
    host.raspberrypi	2021-03-06 17:08:56.372	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:126:9)
    host.raspberrypi	2021-03-06 17:08:56.372	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node
    host.raspberrypi	2021-03-06 17:08:56.371	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
    host.raspberrypi	2021-03-06 17:08:56.371	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
    host.raspberrypi	2021-03-06 17:08:56.371	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
    host.raspberrypi	2021-03-06 17:08:56.370	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/compiled/12.21.0/linux/arm/bindings.node
    host.raspberrypi	2021-03-06 17:08:56.370	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node
    host.raspberrypi	2021-03-06 17:08:56.369	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node
    host.raspberrypi	2021-03-06 17:08:56.369	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node
    host.raspberrypi	2021-03-06 17:08:56.369	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node
    host.raspberrypi	2021-03-06 17:08:56.368	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node
    host.raspberrypi	2021-03-06 17:08:56.368	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
    host.raspberrypi	2021-03-06 17:08:56.367	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node
    host.raspberrypi	2021-03-06 17:08:56.367	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/bindings.node
    host.raspberrypi	2021-03-06 17:08:56.367	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
    host.raspberrypi	2021-03-06 17:08:56.366	error	Caught by controller[0]: ^
    host.raspberrypi	2021-03-06 17:08:56.366	error	Caught by controller[0]: throw err;
    host.raspberrypi	2021-03-06 17:08:56.364	error	Caught by controller[0]: /opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:135
    host.raspberrypi	2021-03-06 17:08:33.862	info	"system.adapter.zigbee.0" disabled
    sonoff.0	2021-03-06 17:08:27.840	info	(22835) Client [Schlafzimmer_Temp] connection closed: timeout
    host.raspberrypi	2021-03-06 17:08:25.397	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.raspberrypi	2021-03-06 17:08:25.396	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi	2021-03-06 17:08:25.395	error	Caught by controller[0]: }
    host.raspberrypi	2021-03-06 17:08:25.395	error	Caught by controller[0]: ]
    host.raspberrypi	2021-03-06 17:08:25.395	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node'
    host.raspberrypi	2021-03-06 17:08:25.394	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node',
    host.raspberrypi	2021-03-06 17:08:25.394	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node',
    host.raspberrypi	2021-03-06 17:08:25.393	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node',
    host.raspberrypi	2021-03-06 17:08:25.393	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/compiled/12.21.0/linux/arm/bindings.node',
    host.raspberrypi	2021-03-06 17:08:25.393	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node',
    host.raspberrypi	2021-03-06 17:08:25.392	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node',
    host.raspberrypi	2021-03-06 17:08:25.392	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node',
    host.raspberrypi	2021-03-06 17:08:25.391	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node',
    host.raspberrypi	2021-03-06 17:08:25.391	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node',
    host.raspberrypi	2021-03-06 17:08:25.391	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node',
    host.raspberrypi	2021-03-06 17:08:25.390	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node',
    host.raspberrypi	2021-03-06 17:08:25.390	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/bindings.node',
    host.raspberrypi	2021-03-06 17:08:25.389	error	Caught by controller[0]: tries: [
    host.raspberrypi	2021-03-06 17:08:25.389	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30) {
    host.raspberrypi	2021-03-06 17:08:25.388	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22)
    host.raspberrypi	2021-03-06 17:08:25.388	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.raspberrypi	2021-03-06 17:08:25.388	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.raspberrypi	2021-03-06 17:08:25.387	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi	2021-03-06 17:08:25.387	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi	2021-03-06 17:08:25.386	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi	2021-03-06 17:08:25.386	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.raspberrypi	2021-03-06 17:08:25.385	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
    host.raspberrypi	2021-03-06 17:08:25.385	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:126:9)
    host.raspberrypi	2021-03-06 17:08:25.384	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node
    host.raspberrypi	2021-03-06 17:08:25.384	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
    host.raspberrypi	2021-03-06 17:08:25.384	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
    host.raspberrypi	2021-03-06 17:08:25.383	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
    host.raspberrypi	2021-03-06 17:08:25.383	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/compiled/12.21.0/linux/arm/bindings.node
    host.raspberrypi	2021-03-06 17:08:25.383	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node
    host.raspberrypi	2021-03-06 17:08:25.382	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node
    host.raspberrypi	2021-03-06 17:08:25.382	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node
    host.raspberrypi	2021-03-06 17:08:25.381	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node
    host.raspberrypi	2021-03-06 17:08:25.381	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node
    host.raspberrypi	2021-03-06 17:08:25.381	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
    host.raspberrypi	2021-03-06 17:08:25.380	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node
    host.raspberrypi	2021-03-06 17:08:25.380	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/bindings.node
    host.raspberrypi	2021-03-06 17:08:25.379	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
    host.raspberrypi	2021-03-06 17:08:25.379	error	Caught by controller[0]: ^
    host.raspberrypi	2021-03-06 17:08:25.378	error	Caught by controller[0]: throw err;
    host.raspberrypi	2021-03-06 17:08:25.377	error	Caught by controller[0]: /opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:135
    host.raspberrypi	2021-03-06 17:08:24.368	info	instance system.adapter.zigbee.0 started with pid 6057
    host.raspberrypi	2021-03-06 17:07:54.348	info	Restart adapter system.adapter.zigbee.0 because enabled
    Nur komisch, dass die Version 1.3.1 tadellos gelaufen ist...
    @wolf sagte in Zigbee Instanz nach update von 1.3.1 auf 1.4.4 rot:
    Die war soweit ich weiß auch ohne bindings. Das klemmt ja bei dir. Ich weiß aber nicht wie man das fixen kann. Vermutlich mit einem rebuild davon. In meinem System habe ich aber andere Pfade, sonst würde ich das bei mir mal probieren.
    W 1 Antwort Letzte Antwort
      W Offline
      W Offline
      wolf
      Als ich aber versuchsweise im Expertenmodus auf die 1.2.0 zurück wollte, kam aber das selbe Fehlerbild. Bleibt nur noch, das System neu aufzusetzen?
      • W wolf
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        Nein.
        Bitte nochmal den Adapter deinstallieren und schauen wie dann die Ausgabe von
        npm list serialport
        aussieht.
        A.
        • AsgothianA Asgothian
          Nein.
          npm list serialport
          aussieht.
          A.
          W Offline
          W Offline
          wolf
          @asgothian
          Bitte sehr...
          pi@raspberrypi:/opt/iobroker $ npm list serialport
          iobroker.inst@1.0.8 /opt/iobroker
          └─┬ iobroker.discovery@2.5.0
            └── serialport@9.0.6
          W AsgothianA 2 Antworten Letzte Antwort
          • W wolf
            @asgothian
            Bitte sehr...
            W Offline
            W Offline
            wolf
            @wolf
            Niemand mehr eine Idee?
            • W wolf
              @asgothian
              Bitte sehr...
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @wolf
              das sieht erstmal gut aus.
              nochmal installieren und dann den Befehl nochmal bitte
                @wolf
                W Offline
                W Offline
                wolf
                schrieb am zuletzt editiert von wolf
                @asgothian
                ├─┬ iobroker.discovery@2.5.0
                │ └── serialport@9.0.6
                └─┬ iobroker.zigbee@1.4.4
                  └─┬ zigbee-herdsman@0.13.76
                    └── serialport@9.0.6  deduped
                Adapter weiter rot miit den Fehlern im log...
                • W wolf
                  @asgothian
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @wolf was ist mit dem gleichen Befehl für zigbee-herdsman und zigbee-herdman-converters ?
                    W Offline
                    W Offline
                    wolf
                    @asgothian
                    pi@raspberrypi:/opt/iobroker $ list zigbee-herdsman
                    -bash: list: Kommando nicht gefunden.
                    pi@raspberrypi:/opt/iobroker $ npm list zigbee-herdsman
                      ├── zigbee-herdsman@0.13.76
                      └─┬ zigbee-herdsman-converters@14.0.78
                        └── zigbee-herdsman@0.13.76  deduped
                    pi@raspberrypi:/opt/iobroker $ npm list zigbee-herdsman-converters
                      └── zigbee-herdsman-converters@14.0.78
                    • W wolf
                      @asgothian
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      @wolf Hmm.. das sieht eigentlich gut aus.
                      Bitte installier mal die 1.4.5 von Github zum testen.
                      A.
                        A.
                        W Offline
                        W Offline
                        wolf
                        @asgothian
                        1.4.5 ist jetzt installiert... Aber alles unverändert...
                        • W wolf
                          @asgothian
                          @wolf
                          Poste bitte nochmal einen aktuellen Auszug aus dem log file. Vielleicht mal von einem Neustart des Adapters.
                            @wolf
                            W Offline
                            W Offline
                            wolf
                            Adapter neu gestartet
                            host.raspberrypi	2021-03-06 18:39:35.964	info	Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
                            host.raspberrypi	2021-03-06 18:39:35.964	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.raspberrypi	2021-03-06 18:39:35.962	error	Caught by controller[0]: }
                            host.raspberrypi	2021-03-06 18:39:35.962	error	Caught by controller[0]: ]
                            host.raspberrypi	2021-03-06 18:39:35.961	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node'
                            host.raspberrypi	2021-03-06 18:39:35.960	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node',
                            host.raspberrypi	2021-03-06 18:39:35.959	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node',
                            host.raspberrypi	2021-03-06 18:39:35.959	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node',
                            host.raspberrypi	2021-03-06 18:39:35.958	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/compiled/12.21.0/linux/arm/bindings.node',
                            host.raspberrypi	2021-03-06 18:39:35.957	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node',
                            host.raspberrypi	2021-03-06 18:39:35.957	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node',
                            host.raspberrypi	2021-03-06 18:39:35.956	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node',
                            host.raspberrypi	2021-03-06 18:39:35.955	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node',
                            host.raspberrypi	2021-03-06 18:39:35.954	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node',
                            host.raspberrypi	2021-03-06 18:39:35.954	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node',
                            host.raspberrypi	2021-03-06 18:39:35.953	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node',
                            host.raspberrypi	2021-03-06 18:39:35.952	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/bindings.node',
                            host.raspberrypi	2021-03-06 18:39:35.952	error	Caught by controller[0]: tries: [
                            host.raspberrypi	2021-03-06 18:39:35.951	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30) {
                            host.raspberrypi	2021-03-06 18:39:35.950	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22)
                            host.raspberrypi	2021-03-06 18:39:35.949	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
                            host.raspberrypi	2021-03-06 18:39:35.949	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
                            host.raspberrypi	2021-03-06 18:39:35.948	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                            host.raspberrypi	2021-03-06 18:39:35.947	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
                            host.raspberrypi	2021-03-06 18:39:35.946	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                            host.raspberrypi	2021-03-06 18:39:35.946	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
                            host.raspberrypi	2021-03-06 18:39:35.945	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
                            host.raspberrypi	2021-03-06 18:39:35.944	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:126:9)
                            host.raspberrypi	2021-03-06 18:39:35.943	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node
                            host.raspberrypi	2021-03-06 18:39:35.943	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
                            host.raspberrypi	2021-03-06 18:39:35.942	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
                            host.raspberrypi	2021-03-06 18:39:35.941	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
                            host.raspberrypi	2021-03-06 18:39:35.940	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/compiled/12.21.0/linux/arm/bindings.node
                            host.raspberrypi	2021-03-06 18:39:35.939	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node
                            host.raspberrypi	2021-03-06 18:39:35.938	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node
                            host.raspberrypi	2021-03-06 18:39:35.937	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node
                            host.raspberrypi	2021-03-06 18:39:35.936	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node
                            host.raspberrypi	2021-03-06 18:39:35.934	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node
                            host.raspberrypi	2021-03-06 18:39:35.933	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
                            host.raspberrypi	2021-03-06 18:39:35.932	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node
                            host.raspberrypi	2021-03-06 18:39:35.931	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/bindings.node
                            host.raspberrypi	2021-03-06 18:39:35.930	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
                            host.raspberrypi	2021-03-06 18:39:35.928	error	Caught by controller[0]: ^
                            host.raspberrypi	2021-03-06 18:39:35.927	error	Caught by controller[0]: throw err;
                            host.raspberrypi	2021-03-06 18:39:35.925	error	Caught by controller[0]: /opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:135
                            host.raspberrypi	2021-03-06 18:39:21.539	info	"system.adapter.zigbee.0" disabled
                            host.raspberrypi	2021-03-06 18:39:04.823	info	Restart adapter system.adapter.zigbee.0 because enabled
                            • W wolf
                              W Offline
                              W Offline
                              wolf
                              @wolf
                              Hab ich grad zu einem ähnlichen Fehlerbild gefunden. Könnte das etwas bringen?
                              iobroker stop
                              cd /opt/iobroker/node_modules/iobroker.zigbee
                              sudo npm rebuild --unsafe-perm
                              iobroker start
                              • W wolf
                                @wolf
                                iobroker stop
                                iobroker start
                                @wolf
                                Auf jedenfall OHNE sudo!
                                Probieren kannst du es mal.
                                  @wolf
                                  W Offline
                                  W Offline
                                  wolf
                                  Hat leider auch keinen Effekt...
                                  Noch ein Lösungsansatz:
                                  kirovilya commented on 11 Feb 2020
                                  Try to completely remove the zigbee adapter and reinstall.
                                  You can also try installing the serialport inside the zigbee adapter.
                                  npm install serialport@8.0.6
                                  • W wolf
                                    W Offline
                                    W Offline
                                    wolf
                                    @wolf
                                    Kurzes Update, falls jemand das selbe Problem hat. Mit der Adapterversion 1.04 läuft Zigbee wieder. Warum? keine Ahnung! :)
                                    Wie ich zu der zuletzt funktionierenden 1.3.1 kommen soll, weiß ich leider nicht, sie wird mir bei der Expertenauswahl nicht angezeigt. Ich bedanke mich bei Thomas Braun und asgothian, die sich sehr bemüht haben, das Zigbee-Problem in den Griff zu bekommen. Vielen Dank!
                                    Liebe Grüße
                                    wolf
                                    • W wolf
                                      @wolf
                                      Liebe Grüße
                                      wolf
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      Das sollte nicht die Lösung sein.
                                      Ich würde vorschlagen das wir uns das gemeinsam per anydesk / discord anschauen um dafür zu sorgen das Du auf den aktuellen Stand gehen kannst.
                                      Alles andere ist nicht gut.
                                      Insbesondere der weg zurück auf 1.0.x, da damit im Zweifelsfall auch der Wechsel zurück zum Zigbee-Shepherd dabei ist.
                                      A.
                                      B W 2 Antworten Letzte Antwort
                                        A.
                                        bishop
                                        schrieb am zuletzt editiert von bishop
                                        @asgothian
                                        ich habe das selbe Problem!
                                        host.iobroker-slave	2021-03-07 14:41:35.480	info	"system.adapter.zigbee.0" disabled
                                        host.iobroker-slave	2021-03-07 14:41:30.721	info	Restart adapter system.adapter.zigbee.0 because enabled
                                        host.iobroker-slave	2021-03-07 14:41:30.720	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        host.iobroker-slave	2021-03-07 14:41:30.719	error	Caught by controller[0]: }
                                        host.iobroker-slave	2021-03-07 14:41:30.718	error	Caught by controller[0]: ]
                                        host.iobroker-slave	2021-03-07 14:41:30.717	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node'
                                        host.iobroker-slave	2021-03-07 14:41:30.716	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node',
                                        host.iobroker-slave	2021-03-07 14:41:30.715	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node',
                                        host.iobroker-slave	2021-03-07 14:41:30.714	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node',
                                        host.iobroker-slave	2021-03-07 14:41:30.713	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/compiled/12.21.0/linux/arm/bindings.node',
                                        host.iobroker-slave	2021-03-07 14:41:30.712	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/default/bindings.node',
                                        host.iobroker-slave	2021-03-07 14:41:30.712	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Release/bindings.node',
                                        host.iobroker-slave	2021-03-07 14:41:30.711	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Release/bindings.node',
                                        host.iobroker-slave	2021-03-07 14:41:30.710	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Debug/bindings.node',
                                        host.iobroker-slave	2021-03-07 14:41:30.709	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Debug/bindings.node',
                                        host.iobroker-slave	2021-03-07 14:41:30.708	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node',
                                        host.iobroker-slave	2021-03-07 14:41:30.707	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Debug/bindings.node',
                                        host.iobroker-slave	2021-03-07 14:41:30.706	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/bindings.node',
                                        host.iobroker-slave	2021-03-07 14:41:30.705	error	Caught by controller[0]: tries: [
                                        host.iobroker-slave	2021-03-07 14:41:30.705	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30) {
                                        host.iobroker-slave	2021-03-07 14:41:30.704	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/index.js:14:22)
                                        host.iobroker-slave	2021-03-07 14:41:30.703	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
                                        host.iobroker-slave	2021-03-07 14:41:30.702	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
                                        host.iobroker-slave	2021-03-07 14:41:30.701	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                                        host.iobroker-slave	2021-03-07 14:41:30.700	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
                                        host.iobroker-slave	2021-03-07 14:41:30.699	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                                        host.iobroker-slave	2021-03-07 14:41:30.698	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
                                        host.iobroker-slave	2021-03-07 14:41:30.697	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
                                        host.iobroker-slave	2021-03-07 14:41:30.697	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:126:9)
                                        host.iobroker-slave	2021-03-07 14:41:30.696	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node
                                        host.iobroker-slave	2021-03-07 14:41:30.695	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
                                        host.iobroker-slave	2021-03-07 14:41:30.694	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
                                        host.iobroker-slave	2021-03-07 14:41:30.693	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
                                        host.iobroker-slave	2021-03-07 14:41:30.692	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/compiled/12.21.0/linux/arm/bindings.node
                                        host.iobroker-slave	2021-03-07 14:41:30.691	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/default/bindings.node
                                        host.iobroker-slave	2021-03-07 14:41:30.691	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Release/bindings.node
                                        host.iobroker-slave	2021-03-07 14:41:30.690	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Release/bindings.node
                                        host.iobroker-slave	2021-03-07 14:41:30.689	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Debug/bindings.node
                                        host.iobroker-slave	2021-03-07 14:41:30.688	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Debug/bindings.node
                                        host.iobroker-slave	2021-03-07 14:41:30.687	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node
                                        host.iobroker-slave	2021-03-07 14:41:30.686	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Debug/bindings.node
                                        host.iobroker-slave	2021-03-07 14:41:30.685	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/bindings.node
                                        host.iobroker-slave	2021-03-07 14:41:30.684	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
                                        host.iobroker-slave	2021-03-07 14:41:30.683	error	Caught by controller[0]: ^
                                        host.iobroker-slave	2021-03-07 14:41:30.682	error	Caught by controller[0]: throw err;
                                        host.iobroker-slave	2021-03-07 14:41:30.680	error	Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:135
                                        host.iobroker-slave	2021-03-07 14:41:28.072	info	instance system.adapter.zigbee.0 started with pid 1626
                                        host.iobroker-slave	2021-03-07 14:41:27.969	info	"system.adapter.zigbee.0" enabled
                                        Habe ein frisches raspian lite auf eine Karte gemacht dort mit apt-get update und upgrade alles aktualisiert.
                                        Danach IoBroker frisch installiert, diesen als Slave an mein Master gehängt.
                                        Jetzt würde ich gerne den Zigbee Adapter installieren.
                                        pi@iobroker-slave:/opt/iobroker/node_modules $ ls -la /dev/serial/by-id
                                        total 0
                                        drwxr-xr-x 2 root root 60 Mar  7 14:07 .
                                        drwxr-xr-x 4 root root 80 Mar  7 14:07 ..
                                        lrwxrwxrwx 1 root root 13 Mar  7 14:07 usb-Texas_Instruments_CC2538_USB_CDC-if00 -> ../../ttyACM0
                                        pi@iobroker-slave:/opt/iobroker/node_modules $ npm list serialport
                                        iobroker.inst@3.0.0 /opt/iobroker
                                        │ └── serialport@9.0.7  deduped
                                        ├─┬ iobroker.zigbee@1.4.4
                                        │ ├── serialport@9.0.7  deduped
                                        │ ├─┬ zigbee-herdsman@0.13.76
                                        │ │ └── serialport@9.0.6
                                        │ └─┬ zigbee-herdsman-converters@14.0.78
                                        │   └─┬ zigbee-herdsman@0.13.72
                                        Stick wird denke ich mal auch korrekt erkannt.
                                        Habe alles gemacht was hier stand, außer die Version 1.04 installiert würde schon gerne die Aktuelle verwenden.
                                        Vorher lief alles mit der selben Hardware, problem war das ich den js controller nicht updaten konnte.
                                        Somit habe ich komplett alles neu gemacht.
                                        Jetzt bekomme ich den Zigbee Adapter nicht zum laufen :(
                                        • B bishop
                                          @asgothian
                                          total 0
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          @bishop Bitte poste die Ausgaben der folgenden 3 Befehle von der Konsole (aus dem Verzeichnis /opt/iobroker
                                          npm list serialport
                                          A.
