  4. Zigbee Instanz nach update von 1.3.1 auf 1.4.4 rot
    6.6k
55 Beiträge 4 Kommentatoren 6.4k Aufrufe 4 Beobachtet
  • W wolf
    @wolf
    So, nachdem ich den Zigbee Adapter nochmal deinstalliert habe sehen die Ausgaben so aus:
    pi@raspberrypi:/opt/iobroker $ npm list zigbee-herdsman
    iobroker.inst@1.0.8 /opt/iobroker
    └── (empty)
    pi@raspberrypi:/opt/iobroker $ npm list zigbee-herdsman-converters
    └── (empty)
    pi@raspberrypi:/opt/iobroker $ npm list serialport
    ├─┬ iobroker.discovery@2.4.1
    │ └── serialport@9.0.6
    └── serialport@6.2.2  extraneous
    npm ERR! extraneous: serialport@6.2.2 /opt/iobroker/node_modules/serialport
    Passt da etwas mit dem Serialport nicht?
    @wolf Der 6.2.2. ist entbehrlich.
    Versuch jetzt mal ein
    npm prune
    Und danach den zigbee-Adapter nochmal in den ioBroker heben.
    W 2 Antworten Letzte Antwort
      npm prune
      W Offline
      W Offline
      wolf
      pi@raspberrypi:/opt/iobroker $ npm prune
      removed 419 packages in 51.892s
      37 packages are looking for funding
        run `npm fund` for details
        npm prune
        W Offline
        W Offline
        wolf
        schrieb am zuletzt editiert von wolf
        Leider noch immer...
        host.raspberrypi	2021-03-06 17:08:56.382	info	Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
        host.raspberrypi	2021-03-06 17:08:56.381	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.raspberrypi	2021-03-06 17:08:56.381	error	Caught by controller[0]: }
        host.raspberrypi	2021-03-06 17:08:56.381	error	Caught by controller[0]: ]
        host.raspberrypi	2021-03-06 17:08:56.380	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node'
        host.raspberrypi	2021-03-06 17:08:56.380	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node',
        host.raspberrypi	2021-03-06 17:08:56.380	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node',
        host.raspberrypi	2021-03-06 17:08:56.379	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node',
        host.raspberrypi	2021-03-06 17:08:56.379	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/compiled/12.21.0/linux/arm/bindings.node',
        host.raspberrypi	2021-03-06 17:08:56.378	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node',
        host.raspberrypi	2021-03-06 17:08:56.378	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node',
        host.raspberrypi	2021-03-06 17:08:56.378	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node',
        host.raspberrypi	2021-03-06 17:08:56.377	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node',
        host.raspberrypi	2021-03-06 17:08:56.377	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node',
        host.raspberrypi	2021-03-06 17:08:56.376	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node',
        host.raspberrypi	2021-03-06 17:08:56.376	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node',
        host.raspberrypi	2021-03-06 17:08:56.376	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/bindings.node',
        host.raspberrypi	2021-03-06 17:08:56.375	error	Caught by controller[0]: tries: [
        host.raspberrypi	2021-03-06 17:08:56.375	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30) {
        host.raspberrypi	2021-03-06 17:08:56.375	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22)
        host.raspberrypi	2021-03-06 17:08:56.374	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
        host.raspberrypi	2021-03-06 17:08:56.374	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
        host.raspberrypi	2021-03-06 17:08:56.374	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
        host.raspberrypi	2021-03-06 17:08:56.373	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
        host.raspberrypi	2021-03-06 17:08:56.373	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
        host.raspberrypi	2021-03-06 17:08:56.373	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
        host.raspberrypi	2021-03-06 17:08:56.372	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
        host.raspberrypi	2021-03-06 17:08:56.372	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:126:9)
        host.raspberrypi	2021-03-06 17:08:56.372	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node
        host.raspberrypi	2021-03-06 17:08:56.371	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
        host.raspberrypi	2021-03-06 17:08:56.371	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
        host.raspberrypi	2021-03-06 17:08:56.371	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
        host.raspberrypi	2021-03-06 17:08:56.370	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/compiled/12.21.0/linux/arm/bindings.node
        host.raspberrypi	2021-03-06 17:08:56.370	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node
        host.raspberrypi	2021-03-06 17:08:56.369	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node
        host.raspberrypi	2021-03-06 17:08:56.369	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node
        host.raspberrypi	2021-03-06 17:08:56.369	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node
        host.raspberrypi	2021-03-06 17:08:56.368	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node
        host.raspberrypi	2021-03-06 17:08:56.368	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
        host.raspberrypi	2021-03-06 17:08:56.367	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node
        host.raspberrypi	2021-03-06 17:08:56.367	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/bindings.node
        host.raspberrypi	2021-03-06 17:08:56.367	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
        host.raspberrypi	2021-03-06 17:08:56.366	error	Caught by controller[0]: ^
        host.raspberrypi	2021-03-06 17:08:56.366	error	Caught by controller[0]: throw err;
        host.raspberrypi	2021-03-06 17:08:56.364	error	Caught by controller[0]: /opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:135
        host.raspberrypi	2021-03-06 17:08:33.862	info	"system.adapter.zigbee.0" disabled
        sonoff.0	2021-03-06 17:08:27.840	info	(22835) Client [Schlafzimmer_Temp] connection closed: timeout
        host.raspberrypi	2021-03-06 17:08:25.397	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.raspberrypi	2021-03-06 17:08:25.396	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.raspberrypi	2021-03-06 17:08:25.395	error	Caught by controller[0]: }
        host.raspberrypi	2021-03-06 17:08:25.395	error	Caught by controller[0]: ]
        host.raspberrypi	2021-03-06 17:08:25.395	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node'
        host.raspberrypi	2021-03-06 17:08:25.394	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node',
        host.raspberrypi	2021-03-06 17:08:25.394	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node',
        host.raspberrypi	2021-03-06 17:08:25.393	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node',
        host.raspberrypi	2021-03-06 17:08:25.393	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/compiled/12.21.0/linux/arm/bindings.node',
        host.raspberrypi	2021-03-06 17:08:25.393	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node',
        host.raspberrypi	2021-03-06 17:08:25.392	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node',
        host.raspberrypi	2021-03-06 17:08:25.392	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node',
        host.raspberrypi	2021-03-06 17:08:25.391	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node',
        host.raspberrypi	2021-03-06 17:08:25.391	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node',
        host.raspberrypi	2021-03-06 17:08:25.391	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node',
        host.raspberrypi	2021-03-06 17:08:25.390	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node',
        host.raspberrypi	2021-03-06 17:08:25.390	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/bindings.node',
        host.raspberrypi	2021-03-06 17:08:25.389	error	Caught by controller[0]: tries: [
        host.raspberrypi	2021-03-06 17:08:25.389	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30) {
        host.raspberrypi	2021-03-06 17:08:25.388	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22)
        host.raspberrypi	2021-03-06 17:08:25.388	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
        host.raspberrypi	2021-03-06 17:08:25.388	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
        host.raspberrypi	2021-03-06 17:08:25.387	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
        host.raspberrypi	2021-03-06 17:08:25.387	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
        host.raspberrypi	2021-03-06 17:08:25.386	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
        host.raspberrypi	2021-03-06 17:08:25.386	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
        host.raspberrypi	2021-03-06 17:08:25.385	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
        host.raspberrypi	2021-03-06 17:08:25.385	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:126:9)
        host.raspberrypi	2021-03-06 17:08:25.384	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node
        host.raspberrypi	2021-03-06 17:08:25.384	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
        host.raspberrypi	2021-03-06 17:08:25.384	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
        host.raspberrypi	2021-03-06 17:08:25.383	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
        host.raspberrypi	2021-03-06 17:08:25.383	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/compiled/12.21.0/linux/arm/bindings.node
        host.raspberrypi	2021-03-06 17:08:25.383	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node
        host.raspberrypi	2021-03-06 17:08:25.382	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node
        host.raspberrypi	2021-03-06 17:08:25.382	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node
        host.raspberrypi	2021-03-06 17:08:25.381	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node
        host.raspberrypi	2021-03-06 17:08:25.381	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node
        host.raspberrypi	2021-03-06 17:08:25.381	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
        host.raspberrypi	2021-03-06 17:08:25.380	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node
        host.raspberrypi	2021-03-06 17:08:25.380	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/bindings.node
        host.raspberrypi	2021-03-06 17:08:25.379	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
        host.raspberrypi	2021-03-06 17:08:25.379	error	Caught by controller[0]: ^
        host.raspberrypi	2021-03-06 17:08:25.378	error	Caught by controller[0]: throw err;
        host.raspberrypi	2021-03-06 17:08:25.377	error	Caught by controller[0]: /opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:135
        host.raspberrypi	2021-03-06 17:08:24.368	info	instance system.adapter.zigbee.0 started with pid 6057
        host.raspberrypi	2021-03-06 17:07:54.348	info	Restart adapter system.adapter.zigbee.0 because enabled
        Nur komisch, dass die Version 1.3.1 tadellos gelaufen ist...
        • W wolf
          @wolf sagte in Zigbee Instanz nach update von 1.3.1 auf 1.4.4 rot:
          Die war soweit ich weiß auch ohne bindings. Das klemmt ja bei dir. Ich weiß aber nicht wie man das fixen kann. Vermutlich mit einem rebuild davon. In meinem System habe ich aber andere Pfade, sonst würde ich das bei mir mal probieren.
          W 1 Antwort Letzte Antwort
            W Offline
            W Offline
            wolf
            Als ich aber versuchsweise im Expertenmodus auf die 1.2.0 zurück wollte, kam aber das selbe Fehlerbild. Bleibt nur noch, das System neu aufzusetzen?
            • W wolf
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              Nein.
              Bitte nochmal den Adapter deinstallieren und schauen wie dann die Ausgabe von
              npm list serialport
              aussieht.
              A.
              • AsgothianA Asgothian
                Nein.
                npm list serialport
                aussieht.
                A.
                W Offline
                W Offline
                wolf
                @asgothian
                Bitte sehr...
                └─┬ iobroker.discovery@2.5.0
                W AsgothianA 2 Antworten Letzte Antwort
                • W wolf
                  @asgothian
                  Bitte sehr...
                  W Offline
                  W Offline
                  wolf
                  @wolf
                  Niemand mehr eine Idee?
                  • W wolf
                    @asgothian
                    Bitte sehr...
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @wolf
                    das sieht erstmal gut aus.
                    nochmal installieren und dann den Befehl nochmal bitte
                      @wolf
                      W Offline
                      W Offline
                      wolf
                      @asgothian
                      ├─┬ iobroker.discovery@2.5.0
                      └─┬ iobroker.zigbee@1.4.4
                        └─┬ zigbee-herdsman@0.13.76
                          └── serialport@9.0.6  deduped
                      Adapter weiter rot miit den Fehlern im log...
                      • W wolf
                        @asgothian
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @wolf was ist mit dem gleichen Befehl für zigbee-herdsman und zigbee-herdman-converters ?
                          W Offline
                          W Offline
                          wolf
                          @asgothian
                          pi@raspberrypi:/opt/iobroker $ list zigbee-herdsman
                          -bash: list: Kommando nicht gefunden.
                            ├── zigbee-herdsman@0.13.76
                            └─┬ zigbee-herdsman-converters@14.0.78
                              └── zigbee-herdsman@0.13.76  deduped
                            └── zigbee-herdsman-converters@14.0.78
                          • W wolf
                            @asgothian
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            @wolf Hmm.. das sieht eigentlich gut aus.
                            Bitte installier mal die 1.4.5 von Github zum testen.
                            A.
                              A.
                              W Offline
                              W Offline
                              wolf
                              @asgothian
                              1.4.5 ist jetzt installiert... Aber alles unverändert...
                              • W wolf
                                @asgothian
                                @wolf
                                Poste bitte nochmal einen aktuellen Auszug aus dem log file. Vielleicht mal von einem Neustart des Adapters.
                                  @wolf
                                  W Offline
                                  W Offline
                                  wolf
                                  Adapter neu gestartet
                                  host.raspberrypi	2021-03-06 18:39:35.964	info	Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
                                  host.raspberrypi	2021-03-06 18:39:35.964	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  host.raspberrypi	2021-03-06 18:39:35.962	error	Caught by controller[0]: }
                                  host.raspberrypi	2021-03-06 18:39:35.962	error	Caught by controller[0]: ]
                                  host.raspberrypi	2021-03-06 18:39:35.961	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node'
                                  host.raspberrypi	2021-03-06 18:39:35.960	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node',
                                  host.raspberrypi	2021-03-06 18:39:35.959	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node',
                                  host.raspberrypi	2021-03-06 18:39:35.959	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node',
                                  host.raspberrypi	2021-03-06 18:39:35.958	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/compiled/12.21.0/linux/arm/bindings.node',
                                  host.raspberrypi	2021-03-06 18:39:35.957	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node',
                                  host.raspberrypi	2021-03-06 18:39:35.957	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node',
                                  host.raspberrypi	2021-03-06 18:39:35.956	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node',
                                  host.raspberrypi	2021-03-06 18:39:35.955	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node',
                                  host.raspberrypi	2021-03-06 18:39:35.954	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node',
                                  host.raspberrypi	2021-03-06 18:39:35.954	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node',
                                  host.raspberrypi	2021-03-06 18:39:35.953	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node',
                                  host.raspberrypi	2021-03-06 18:39:35.952	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/bindings.node',
                                  host.raspberrypi	2021-03-06 18:39:35.952	error	Caught by controller[0]: tries: [
                                  host.raspberrypi	2021-03-06 18:39:35.951	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30) {
                                  host.raspberrypi	2021-03-06 18:39:35.950	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22)
                                  host.raspberrypi	2021-03-06 18:39:35.949	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
                                  host.raspberrypi	2021-03-06 18:39:35.949	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
                                  host.raspberrypi	2021-03-06 18:39:35.948	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                                  host.raspberrypi	2021-03-06 18:39:35.947	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
                                  host.raspberrypi	2021-03-06 18:39:35.946	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                                  host.raspberrypi	2021-03-06 18:39:35.946	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
                                  host.raspberrypi	2021-03-06 18:39:35.945	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
                                  host.raspberrypi	2021-03-06 18:39:35.944	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:126:9)
                                  host.raspberrypi	2021-03-06 18:39:35.943	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node
                                  host.raspberrypi	2021-03-06 18:39:35.943	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
                                  host.raspberrypi	2021-03-06 18:39:35.942	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
                                  host.raspberrypi	2021-03-06 18:39:35.941	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
                                  host.raspberrypi	2021-03-06 18:39:35.940	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/compiled/12.21.0/linux/arm/bindings.node
                                  host.raspberrypi	2021-03-06 18:39:35.939	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node
                                  host.raspberrypi	2021-03-06 18:39:35.938	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node
                                  host.raspberrypi	2021-03-06 18:39:35.937	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node
                                  host.raspberrypi	2021-03-06 18:39:35.936	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node
                                  host.raspberrypi	2021-03-06 18:39:35.934	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node
                                  host.raspberrypi	2021-03-06 18:39:35.933	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
                                  host.raspberrypi	2021-03-06 18:39:35.932	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node
                                  host.raspberrypi	2021-03-06 18:39:35.931	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/bindings.node
                                  host.raspberrypi	2021-03-06 18:39:35.930	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
                                  host.raspberrypi	2021-03-06 18:39:35.928	error	Caught by controller[0]: ^
                                  host.raspberrypi	2021-03-06 18:39:35.927	error	Caught by controller[0]: throw err;
                                  host.raspberrypi	2021-03-06 18:39:35.925	error	Caught by controller[0]: /opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:135
                                  host.raspberrypi	2021-03-06 18:39:21.539	info	"system.adapter.zigbee.0" disabled
                                  host.raspberrypi	2021-03-06 18:39:04.823	info	Restart adapter system.adapter.zigbee.0 because enabled
                                  • W wolf
                                    W Offline
                                    W Offline
                                    wolf
                                    @wolf
                                    Hab ich grad zu einem ähnlichen Fehlerbild gefunden. Könnte das etwas bringen?
                                    iobroker stop
                                    cd /opt/iobroker/node_modules/iobroker.zigbee
                                    sudo npm rebuild --unsafe-perm
                                    iobroker start
                                    • W wolf
                                      @wolf
                                      iobroker stop
                                      iobroker start
                                      @wolf
                                      Auf jedenfall OHNE sudo!
                                      Probieren kannst du es mal.
                                        @wolf
                                        W Offline
                                        W Offline
                                        wolf
                                        Hat leider auch keinen Effekt...
                                        Noch ein Lösungsansatz:
                                        kirovilya commented on 11 Feb 2020
                                        Try to completely remove the zigbee adapter and reinstall.
                                        You can also try installing the serialport inside the zigbee adapter.
                                        npm install serialport@8.0.6
                                        • W wolf
                                          W Offline
                                          W Offline
                                          wolf
                                          @wolf
                                          Kurzes Update, falls jemand das selbe Problem hat. Mit der Adapterversion 1.04 läuft Zigbee wieder. Warum? keine Ahnung! :)
                                          Wie ich zu der zuletzt funktionierenden 1.3.1 kommen soll, weiß ich leider nicht, sie wird mir bei der Expertenauswahl nicht angezeigt. Ich bedanke mich bei Thomas Braun und asgothian, die sich sehr bemüht haben, das Zigbee-Problem in den Griff zu bekommen. Vielen Dank!
                                          Liebe Grüße
                                          wolf
