  4. (gelöst)Nach Umstieg auf die CCU 3 Instanzen gelb
28 Beiträge 3 Kommentatoren 1.9k Aufrufe 1 Beobachtet
  • ostseereiterO ostseereiter
    Hallo Freunde,
    Ich habe nun auf die CCU3 gewechselt danach die gleiche IP wie alte zugewiesen aber
    hm-rpc.0 bleibt gelb bzw werden rot und dann wieder gelb
    hm Rega
    hm-rega.0	2021-03-03 11:09:49.635	error	(20419) ReGaHSS 192.168.178.95 down
    hm-rega.0	2021-03-03 11:09:49.634	error	(20419) <-- Incomplete response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-
    hm-rega.0	2021-03-03 11:09:49.633	error	(20419) The connection has been closed before fully receiving the response data
    hm-rega.0	2021-03-03 11:09:47.340	info	(20419) ReGaHSS 192.168.178.95 up
    hm-rega.0	2021-03-03 11:09:47.237	info	(20419) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
    hm-rega.0	2021-03-03 11:09:46.935	info	(20419) starting. Version 3.0.16 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v12.20.0, js-controller: 3.1.6
    HMRPC
    hm-rpc.0	2021-03-03 11:12:48.630	error	(23737) Init not possible, going to stop: response timeout
    hm-rpc.0	2021-03-03 11:12:43.612	info	(23737) binrpc client is trying to connect to 192.168.178.95:2001/ with ["xmlrpc_bin://192.168.178.109:2001","debian:hm-rpc.0"]
    hm-rpc.0	2021-03-03 11:12:43.611	info	(23737) binrpc server is trying to listen on 192.168.178.109:2001
    hm-rpc.0	2021-03-03 11:12:43.328	info	(23737) starting. Version 1.14.35 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.20.0, js-controller: 3.1.6
    hm-rpc.0	2021-03-03 11:12:09.224	info	(22534) Terminated (NO_ERROR): Without reason
    hm-rpc.0	2021-03-03 11:12:09.220	info	(22534) terminating
    hm-rpc.0	2021-03-03 11:12:08.708	error	(22534) Init not possible, going to stop: response timeout
    hm-rpc.0	2021-03-03 11:12:08.704	info	(22534) binrpc -> 192.168.178.95:2001/ init ["xmlrpc_bin://192.168.178.109:2001",""]
    hm-rpc.0	2021-03-03 11:11:38.700	error	(22534) Init not possible, going to stop: response timeout
    hm-rpc.0	2021-03-03 11:11:33.676	info	(22534) binrpc client is trying to connect to 192.168.178.95:2001/ with ["xmlrpc_bin://192.168.178.109:2001","debian:hm-rpc.0"]
    hm-rpc.0	2021-03-03 11:11:33.674	info	(22534) binrpc server is trying to listen on 192.168.178.109:2001
    hm-rpc.0	2021-03-03 11:11:33.413	info	(22534) starting. Version 1.14.35 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.20.0, js-controller: 3.1.6
    Wer kann helfen.
    @ostseereiter sagte in Nach Umstieg auf die CCU 3 Instanzen gelb:
    Von wo gewechselt?
    Das riecht nach CCU3-Firewall
    ostseereiterO 1 Antwort Letzte Antwort
      Von wo gewechselt?
      ostseereiterO Offline
      ostseereiter
      gewechselt von der CCU2 auf die 3 .die Firwwall sieht so aus.
      Gruß OSR
      Plattform
        da sind alle Ports blockiert
        die notwendigen Ports freigeben (siehe Instanzen) und dann schon eher die IPs bei xml-api blockieren und nur die ioBroker IP freigeben
          ostseereiter
          ok ich habe mal offen gemacht und ein Neustart der CCU mal sehen.
          Gruß OSR
          Plattform
            laut log hättest du nur die 2001 freigeben müssen.
            Die Meldung bei der ReGa lässt darauf schließen, dass du bei der CCU3 mit Authentifizierung arbeitest und da in der Instanz nicht aktiviert hast.
            Ich habe leider keinerlei Informationen über deine Konfigurationen 😡
              wendy2702W Online
              wendy2702W Online
              @homoran Unter Umständen muss er den Port im RPC eh auf 42001 ändern.... wenn er mit Authentifizierung arbeitet.
              • wendy2702W wendy2702
                ostseereiter
                @wendy2702
                also dann den Haken rausnehmen.
                Gruß OSR
                Plattform
                  @wendy2702
                  wendy2702W Online
                  wendy2702W Online
                  @ostseereiter Entweder das, oder den Port ändern.
                  Hier gibt es aber etliche Beiträge dazu wenn ich nur mal die Begriffe aus dem Titel in der Suche einsetze.
                  https://forum.iobroker.net/search?term=ccu3 rpc gelb&in=titlesposts
                    ostseereiter
                    @wendy2702
                    ja ich habe gesucht aber das passende nicht gefunden.
                    derf Rega adapter ist grün nur die RPC noch nicht.
                    Gruß OSR
                    Plattform
                    HomoranH wendy2702W 2 Antworten Letzte Antwort
                      @wendy2702
                      Was steht denn im
                      • Konfig?
                      • log?
                        • ggf. im debug mode
                        @wendy2702
                        wendy2702W Online
                        wendy2702W Online
                        @ostseereiter Dann zeige doch mal Screenshot der RPC Konfigs wie von @Homoran angefragt.
                          ostseereiter
                          @wendy2702
                          ok zwei sind grün Rega und RPC1 das ist CUXD
                          nur der RPC0 nicht
                           close	Zeit
                          debug
                          Meldung
                          hm-rpc.0	2021-03-03 12:02:30.946	info	(15459) Terminated (NO_ERROR): Without reason
                          hm-rpc.0	2021-03-03 12:02:30.942	info	(15459) terminating
                          hm-rpc.0	2021-03-03 12:02:30.433	error	(15459) Init not possible, going to stop: response timeout
                          hm-rpc.0	2021-03-03 12:02:30.427	info	(15459) binrpc -> 192.168.178.95:2001/ init ["xmlrpc_bin://192.168.178.109:2001",""]
                          hm-rpc.0	2021-03-03 12:02:00.423	error	(15459) Init not possible, going to stop: response timeout
                          hm-rpc.0	2021-03-03 12:01:55.402	info	(15459) binrpc client is trying to connect to 192.168.178.95:2001/ with ["xmlrpc_bin://192.168.178.109:2001","debian:hm-rpc.0"]
                          hm-rpc.0	2021-03-03 12:01:55.399	info	(15459) binrpc server is trying to listen on 192.168.178.109:2001
                          hm-rpc.0	2021-03-03 12:01:53.791	info	(15459) starting. Version 1.14.35 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.20.0, js-controller: 3.1.6
                          Gruß OSR
                          Plattform
                            @wendy2702
                            nur der RPC0 nicht
                             close	Zeit
                            debug
                            Meldung
                            @ostseereiter warum steht da BIN-RPC?
                            das kann auch mit der CCU2 nicht geklappt haben.
                            Auf xml umstellen
                              @wendy2702
                              nur der RPC0 nicht
                               close	Zeit
                              debug
                              Meldung
                              wendy2702W Online
                              wendy2702W Online
                              @ostseereiter Warum schneidest du den Screenshot ab, machst die IP Adressen unkenntlich mit denen eigentlich die wenigstens etwas anfangen können lässt sie aber im logfile sichtbar .... (kopfkratz....)
                              Alles andere hat @Homoran geschrieben.
                                ostseereiter
                                @wendy2702 ja stimmt auch wieder
                                Gruß OSR
                                Plattform
                                  @ostseereiter und die zweite Seite fehlt ganz
                                    Auf xml umstellen
                                    ostseereiter
                                    @homoran ja das war es ist schon komisch mit der CCU 2 war es so eingestellt.
                                    Danke allen für die Hilfe ich bin froh.
                                    Gruß OSR
                                    Plattform
                                    • wendy2702W Online
                                      wendy2702W Online
                                      Achja, hast du denn jetzt den Port umgestellt oder den Haken entfernt ?
                                      Bitte das Thema nochauf [Gelöst] ändern!!!
                                        ich bin froh.
                                        Heisst das, dass es jetzt läuft?
                                          ich bin froh.
                                          ostseereiter
                                          ja läuft.
                                          ich habe den haken entfernt und die Ports offen
                                          Gruß OSR
                                          Plattform
