  4. (gelöst)Nach Umstieg auf die CCU 3 Instanzen gelb
    5.9k
    1.5k
28 Beiträge 3 Kommentatoren 1.1k Aufrufe 1 Beobachtet
  • ostseereiterO Offline
    ostseereiter
    schrieb am zuletzt editiert von ostseereiter
    Hallo Freunde,
    Ich habe nun auf die CCU3 gewechselt danach die gleiche IP wie alte zugewiesen aber
    hm-rpc.0 bleibt gelb bzw werden rot und dann wieder gelb
    hm Rega
    hm-rega.0	2021-03-03 11:09:49.635	error	(20419) ReGaHSS 192.168.178.95 down
    hm-rega.0	2021-03-03 11:09:49.634	error	(20419) <-- Incomplete response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-
    hm-rega.0	2021-03-03 11:09:49.633	error	(20419) The connection has been closed before fully receiving the response data
    hm-rega.0	2021-03-03 11:09:47.340	info	(20419) ReGaHSS 192.168.178.95 up
    hm-rega.0	2021-03-03 11:09:47.237	info	(20419) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
    hm-rega.0	2021-03-03 11:09:46.935	info	(20419) starting. Version 3.0.16 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v12.20.0, js-controller: 3.1.6
    HMRPC
    hm-rpc.0	2021-03-03 11:12:48.630	error	(23737) Init not possible, going to stop: response timeout
    hm-rpc.0	2021-03-03 11:12:43.612	info	(23737) binrpc client is trying to connect to 192.168.178.95:2001/ with ["xmlrpc_bin://192.168.178.109:2001","debian:hm-rpc.0"]
    hm-rpc.0	2021-03-03 11:12:43.611	info	(23737) binrpc server is trying to listen on 192.168.178.109:2001
    hm-rpc.0	2021-03-03 11:12:43.328	info	(23737) starting. Version 1.14.35 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.20.0, js-controller: 3.1.6
    hm-rpc.0	2021-03-03 11:12:09.224	info	(22534) Terminated (NO_ERROR): Without reason
    hm-rpc.0	2021-03-03 11:12:09.220	info	(22534) terminating
    hm-rpc.0	2021-03-03 11:12:08.708	error	(22534) Init not possible, going to stop: response timeout
    hm-rpc.0	2021-03-03 11:12:08.704	info	(22534) binrpc -> 192.168.178.95:2001/ init ["xmlrpc_bin://192.168.178.109:2001",""]
    hm-rpc.0	2021-03-03 11:11:38.700	error	(22534) Init not possible, going to stop: response timeout
    hm-rpc.0	2021-03-03 11:11:33.676	info	(22534) binrpc client is trying to connect to 192.168.178.95:2001/ with ["xmlrpc_bin://192.168.178.109:2001","debian:hm-rpc.0"]
    hm-rpc.0	2021-03-03 11:11:33.674	info	(22534) binrpc server is trying to listen on 192.168.178.109:2001
    hm-rpc.0	2021-03-03 11:11:33.413	info	(22534) starting. Version 1.14.35 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.20.0, js-controller: 3.1.6
    Wer kann helfen.
    Gruß OSR
    Plattform
    • ostseereiterO ostseereiter
      Hallo Freunde,
      hm Rega
      HMRPC
      Wer kann helfen.
      HomoranH Offline
      HomoranH Offline
      @ostseereiter sagte in Nach Umstieg auf die CCU 3 Instanzen gelb:
      Von wo gewechselt?
      Das riecht nach CCU3-Firewall
      ostseereiterO 1 Antwort Letzte Antwort
        Von wo gewechselt?
        ostseereiter
        gewechselt von der CCU2 auf die 3 .die Firwwall sieht so aus.
        Gruß OSR
        Plattform
          HomoranH Offline
          HomoranH Offline
          da sind alle Ports blockiert
          die notwendigen Ports freigeben (siehe Instanzen) und dann schon eher die IPs bei xml-api blockieren und nur die ioBroker IP freigeben
            ostseereiter
            ok ich habe mal offen gemacht und ein Neustart der CCU mal sehen.
            Gruß OSR
            Plattform
              HomoranH Offline
              HomoranH Offline
              laut log hättest du nur die 2001 freigeben müssen.
              Die Meldung bei der ReGa lässt darauf schließen, dass du bei der CCU3 mit Authentifizierung arbeitest und da in der Instanz nicht aktiviert hast.
              Ich habe leider keinerlei Informationen über deine Konfigurationen 😡
                wendy2702W Offline
                wendy2702W Offline
                @homoran Unter Umständen muss er den Port im RPC eh auf 42001 ändern.... wenn er mit Authentifizierung arbeitet.
                • wendy2702W wendy2702
                  ostseereiter
                  @wendy2702
                  also dann den Haken rausnehmen.
                  Gruß OSR
                  Plattform
                    @wendy2702
                    wendy2702W Offline
                    wendy2702W Offline
                    @ostseereiter Entweder das, oder den Port ändern.
                    Hier gibt es aber etliche Beiträge dazu wenn ich nur mal die Begriffe aus dem Titel in der Suche einsetze.
                    https://forum.iobroker.net/search?term=ccu3 rpc gelb&in=titlesposts
                      ostseereiter
                      @wendy2702
                      ja ich habe gesucht aber das passende nicht gefunden.
                      derf Rega adapter ist grün nur die RPC noch nicht.
                      Gruß OSR
                      Plattform
                      HomoranH wendy2702W 2 Antworten Letzte Antwort
                        @wendy2702
                        HomoranH Offline
                        HomoranH Offline
                        Was steht denn im
                        • Konfig?
                        • log?
                          • ggf. im debug mode
                          @wendy2702
                          wendy2702W Offline
                          wendy2702W Offline
                          @ostseereiter Dann zeige doch mal Screenshot der RPC Konfigs wie von @Homoran angefragt.
                            ostseereiter
                            @wendy2702
                            ok zwei sind grün Rega und RPC1 das ist CUXD
                            nur der RPC0 nicht
                             close	Zeit
                            debug
                            Meldung
                            hm-rpc.0	2021-03-03 12:02:30.946	info	(15459) Terminated (NO_ERROR): Without reason
                            hm-rpc.0	2021-03-03 12:02:30.942	info	(15459) terminating
                            hm-rpc.0	2021-03-03 12:02:30.433	error	(15459) Init not possible, going to stop: response timeout
                            hm-rpc.0	2021-03-03 12:02:30.427	info	(15459) binrpc -> 192.168.178.95:2001/ init ["xmlrpc_bin://192.168.178.109:2001",""]
                            hm-rpc.0	2021-03-03 12:02:00.423	error	(15459) Init not possible, going to stop: response timeout
                            hm-rpc.0	2021-03-03 12:01:55.402	info	(15459) binrpc client is trying to connect to 192.168.178.95:2001/ with ["xmlrpc_bin://192.168.178.109:2001","debian:hm-rpc.0"]
                            hm-rpc.0	2021-03-03 12:01:55.399	info	(15459) binrpc server is trying to listen on 192.168.178.109:2001
                            hm-rpc.0	2021-03-03 12:01:53.791	info	(15459) starting. Version 1.14.35 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.20.0, js-controller: 3.1.6
                            Gruß OSR
                            Plattform
                              @wendy2702
                              nur der RPC0 nicht
                               close	Zeit
                              debug
                              Meldung
                              HomoranH Offline
                              HomoranH Offline
                              @ostseereiter warum steht da BIN-RPC?
                              das kann auch mit der CCU2 nicht geklappt haben.
                              Auf xml umstellen
                                @wendy2702
                                nur der RPC0 nicht
                                 close	Zeit
                                debug
                                Meldung
                                wendy2702W Offline
                                wendy2702W Offline
                                @ostseereiter Warum schneidest du den Screenshot ab, machst die IP Adressen unkenntlich mit denen eigentlich die wenigstens etwas anfangen können lässt sie aber im logfile sichtbar .... (kopfkratz....)
                                Alles andere hat @Homoran geschrieben.
                                  ostseereiter
                                  @wendy2702 ja stimmt auch wieder
                                  Gruß OSR
                                  Plattform
                                    HomoranH Offline
                                    HomoranH Offline
                                    @ostseereiter und die zweite Seite fehlt ganz
                                      Auf xml umstellen
                                      ostseereiter
                                      @homoran ja das war es ist schon komisch mit der CCU 2 war es so eingestellt.
                                      Danke allen für die Hilfe ich bin froh.
                                      Gruß OSR
                                      Plattform
                                      • wendy2702W Offline
                                        wendy2702W Offline
                                        Achja, hast du denn jetzt den Port umgestellt oder den Haken entfernt ?
                                        Bitte das Thema nochauf [Gelöst] ändern!!!
                                          HomoranH Offline
                                          HomoranH Offline
                                          ich bin froh.
                                          Heisst das, dass es jetzt läuft?
                                          32.7k
                                          82.6k
