  4. Adapter Update funktioniert nicht
adapter installieren fehler
60 Beiträge 5 Kommentatoren 8.0k Aufrufe 3 Beobachtet
  • M Matthias I
    @thomas-braun: ich habe das Nodeupdate hinbekommen...danke :-)
    @matthias-i Okay, was bekommst du denn jetzt jeweils hier zurück:
    uname -a
    sudo apt update
    iob -v
    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      Matthias I
      @thomas-braun die node-version ist v12.21.0
      Leider habe ich jetzt Probleme mit einer Instanz meines Froniusadapters:
      fronius.1	2021-02-27 19:06:53.035	error	(4282) The id "inverter." is invalid. Ids are not allowed to end in "."
      fronius.1	2021-02-27 19:06:53.034	error	at Object.onceWrapper (events.js:420:28)
      fronius.1	2021-02-27 19:06:53.034	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
      fronius.1	2021-02-27 19:06:53.034	error	at Request.emit (events.js:314:20)
      fronius.1	2021-02-27 19:06:53.034	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
      fronius.1	2021-02-27 19:06:53.034	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
      fronius.1	2021-02-27 19:06:53.034	error	at Request._callback (/opt/iobroker/node_modules/iobroker.fronius/main.js:652:21)
      fronius.1	2021-02-27 19:06:53.034	error	at createInverterObjects (/opt/iobroker/node_modules/iobroker.fronius/main.js:150:13)
      fronius.1	2021-02-27 19:06:53.034	error	at Adapter.setObjectNotExists (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3298:17)
      fronius.1	2021-02-27 19:06:53.034	error	at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:532:23)
      fronius.1	2021-02-27 19:06:53.034	error	(4282) Error: The id "inverter." is invalid. Ids are not allowed to end in "."
      fronius.1	2021-02-27 19:06:53.030	error	(4282) unhandled promise rejection: The id "inverter." is invalid. Ids are not allowed to end in "."
      fronius.1	2021-02-27 19:06:53.030	error	(4282) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      fronius.1	2021-02-27 19:06:53.028	warn	(4282) TypeError: Cannot read property 'Value' of undefined
      fronius.1	2021-02-27 19:06:53.020	warn	(4282) TypeError: Cannot read property 'Details' of undefined
      fronius.1	2021-02-27 19:06:52.990	warn	(4282) TypeError: Cannot read property 'HWVersion' of undefined
      Kannst du mir sagen wie ich das wieder in den Griff bekomme?
      • M Matthias I
        @matthias-i
        Die Ausgaben?
        Zum Adapter: Da muss wohl der Maintainer ran. Mach ein Issue auf, falls es noch keins gibt.
          @matthias-i
          Die Ausgaben?
          Matthias I
          @thomas-braun ja, das sind die Ausgaben im Log. Auch wenn ich eine weitere Instanz installiere, dann wird diese in der Übersicht kurz grün und wird dann wieder rot.
          • M Matthias I
            @matthias-i
            Ich würde gerne die Ausgaben der obigen vier Befehlszeilen sehen.
              Matthias I
              /usr/bin/nodejs
              v12.21.0
              /usr/bin/node
              v12.21.0
              /usr/bin/npm
              6.14.11
              nodejs:
                Installed: 12.21.0-1nodesource1
                Candidate: 12.21.0-1nodesource1
                Version table:
               *** 12.21.0-1nodesource1 500
                      500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                   10.24.0~dfsg-1~deb10u1 500
              • M Matthias I
                /usr/bin/nodejs
                v12.21.0
                /usr/bin/node
                v12.21.0
                /usr/bin/npm
                6.14.11
                nodejs:
                  Version table:
                @matthias-i
                Und der Rest?
                  @matthias-i
                  Und der Rest?
                  Matthias I
                  @thomas-braun iob - v liefert: 3.2.16
                  uname -a:
                  Linux raspberrypi 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
                  und sudo apt update:
                  Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                  Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
                  Reading package lists... Done
                  Building dependency tree
                  113 packages can be upgraded. Run 'apt list --upgradable' to see them.
                  • M Matthias I
                    uname -a:
                    @matthias-i
                    Dringend das System upgraden
                    sudo apt dist-upgrade
                    sudo reboot
                      @matthias-i
                      sudo reboot
                      Matthias I
                      @thomas-braun Systemupgrade ist durch, der Fehler der Froniusinstanz besteht weiterhin. Bringt es was den ganzen Adapter neu zu installieren?
                      • M Matthias I
                        @matthias-i https://github.com/iobroker-community-adapters/ioBroker.fronius/issues
                          Matthias I
                          @thomas-braun ich versuche morgen mal den Adapter neu zu installieren. Wenn das auch nicht hilft, dann werde ich ein issue eröffnen. Danke für den Link
                          • M Matthias I
                            @matthias-i Gibt doch schon issues dazu.
                            Was soll denn eine Neuinstallation der gleichen Version bringen?
                              Matthias I
                              @thomas-braun issues gibt es zu den warning-Meldungen, aber wenn ich das richtig sehe nicht zu meinen error-Meldungen.
                              Merkwürdig finde ich, dass die erste Froniusinstanz 0 problemlos läuft und die zweite Instanz 1 die o.g. error-Meldungen liefert.
                              Das zeigt ja, dass der Adapter "grundsätzlich" funktioniert, aber bei dem Update des js-controllers ein Fehler nur in der zweiten Instanz produziert...daher dachte ich, dass die Neuinstallation des Adapters evtl. den Fehler in der zweiten Instanz beheben könnte.
                              • M Matthias I
                                @matthias-i
                                Ist die ID von dir gesetzt oder kommt die aus dem Adapter?
                                  @matthias-i
                                  Matthias I
                                  @thomas-braun die kommt von dem Adapter selbst.
                                  • M Matthias I
                                    @matthias-i Da muss dann der Maintainer ran.
                                    Issue eröffnet?
                                      Issue eröffnet?
                                      Matthias I
                                      @thomas-braun Nach dem Update aus git heraus auf die Version 1.1.0 läuft alles. Vielen Dank für deine Hilfe Thomas!!!
