  4. (Frage) ioBroker stop - stoppt ioBroker nicht ?
44 Beiträge 5 Kommentatoren 4.2k Aufrufe 5 Beobachtet
    @humidor
    Dann maskiere den service
    sudo systemctl mask iobroker
    sudo systemctl status iobroker
    Dann reboot, vorher hier die Konsolenein- und -ausgaben posten.
    HumidorH Offline
    HumidorH Offline
    Humidor
    schrieb am zuletzt editiert von Humidor
    @thomas-braun sagte in (Frage) ioBroker stop - stoppt ioBroker nicht ?:
    pi@ioBrokerPV:~ $ sudo systemctl mask iobroker
    Created symlink /etc/systemd/system/iobroker.service → /dev/null.
    pi@ioBrokerPV:~ $ sudo systemctl status iobroker
    ● iobroker.service
       Loaded: masked (Reason: Unit iobroker.service is masked.)
       Active: active (running) since Sat 2021-02-27 10:12:16 CET; 36min ago
     Main PID: 521 (iobroker.js-con)
       CGroup: /system.slice/iobroker.service
               ├─ 521 iobroker.js-controller
               ├─ 645 io.admin.0
               ├─ 660 io.discovery.0
               ├─ 676 io.info.0
               ├─ 768 io.kecontact.0
               ├─1204 io.mqtt.0
               ├─1221 io.web.0
               ├─1236 io.javascript.0
               ├─1258 io.history.0
               ├─1279 io.cloud.0
               ├─1294 io.iot.0
               ├─1311 io.telegram.0
               ├─1326 io.backitup.0
               ├─1386 io.shelly.0
               ├─1401 io.influxdb.0
               ├─1421 io.vis-inventwo.0
               ├─1440 io.modbus.0
               └─1455 io.modbus.1
    Feb 27 10:17:57 ioBrokerPV bash[521]: hash unchanged, use cached sources
    Feb 27 10:17:59 ioBrokerPV bash[521]: Cannot send diag info: ESOCKETTIMEDOUT
    Feb 27 10:18:03 ioBrokerPV bash[521]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
    Feb 27 10:37:54 ioBrokerPV bash[521]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
    Feb 27 10:38:04 ioBrokerPV bash[521]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
    Feb 27 10:40:26 ioBrokerPV bash[521]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
    Feb 27 10:40:36 ioBrokerPV bash[521]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
    Feb 27 10:47:36 ioBrokerPV bash[521]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
    Feb 27 10:47:46 ioBrokerPV bash[521]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
    Feb 27 10:48:07 ioBrokerPV systemd[1]: iobroker.service: Current command vanished from the unit file, execution of the command list won't be resumed.
    pi@ioBrokerPV:~ $
    restart
    ● iobroker.service
       Active: inactive (dead)
    hat funktioniert 👍
    BG
    • HumidorH Humidor
      ● iobroker.service
                 ├─ 645 io.admin.0
                 ├─ 676 io.info.0
                 ├─1204 io.mqtt.0
                 ├─1221 io.web.0
                 ├─1258 io.history.0
                 ├─1279 io.cloud.0
                 ├─1294 io.iot.0
                 ├─1386 io.shelly.0
                 ├─1440 io.modbus.0
                 └─1455 io.modbus.1
      pi@ioBrokerPV:~ $
      restart
      ● iobroker.service
      hat funktioniert 👍
      @humidor
      Dann kannst du ja jetzt am System upgraden usw.
      Wenn fertig würde ich den
      iobroker fix
      final nochmal drüber laufen lassen, der sollte eigentlich den Service dann wieder aktivieren und die Maske herunterreißen.
      • HumidorH Humidor
        @thomas-braun nein, hat nicht funktioniert
        wie transportiere ich von einem raspi zum anderen die Installation von ioBroker, also nicht die Grundinstallation, nur alles was ich gemacht habe?
        iobroker backup - wie geht da ein restore?
        bzw. opt/iobroker-data einfach kopieren?
        wendy2702W Online
        wendy2702W Online
        @humidor sagte in (Frage) ioBroker stop - stoppt ioBroker nicht ?:
        iobroker backup
        oder backituo Adapter
        Dann das backup auf den neuen PI kopieren
        iobroker restore /opt/iobroker/backups/<Datei Name des Backups>
        oder mit dem Backitup Adapter
        • HumidorH Humidor
          ● iobroker.service
                     ├─ 645 io.admin.0
                     ├─ 676 io.info.0
                     ├─1204 io.mqtt.0
                     ├─1221 io.web.0
                     ├─1258 io.history.0
                     ├─1279 io.cloud.0
                     ├─1294 io.iot.0
                     ├─1386 io.shelly.0
                     ├─1440 io.modbus.0
                     └─1455 io.modbus.1
          pi@ioBrokerPV:~ $
          restart
          ● iobroker.service
          hat funktioniert 👍
          Hast du dem System den direkten Zugang ins Netz entzogen?
          Wenn ja, dann würde ich in den Einstellungen unter Statistik auch auf 'Niemals' stellen. Dann hast du die Meldung und den Vorgang aus den Füßen.
          Wenn nein, dann klemmt da irgendwas in deinem Netzwerk.
          HumidorH 1 Antwort Letzte Antwort
            HumidorH Offline
            HumidorH Offline
            Humidor
            @thomas-braun nein, der Raspi ist am Internet angeschlossen, zieht darüber seine Updates - das funktioniert.
            Nach dem fix bleibt es maskiert
            @wendy2702 danke! ich habe es mit dem Filezilla kopiert und dann ioBroker gestartet, schaut alles gut aus.
            BG
            • HumidorH Offline
              HumidorH Offline
              Humidor
              @Thomas-Braun trotz dass der service disabled ist, startet ioBroker nach einem reboot
              ● iobroker.service - ioBroker Server
                 Loaded: loaded (/lib/systemd/system/iobroker.service; disabled; vendor preset: enabled)
                 Active: active (running) since Sat 2021-02-27 12:56:34 CET; 1min 35s ago
                   Docs: http://iobroker.net
               Main PID: 518 (node)
                  Tasks: 198 (limit: 3886)
                         ├─ 518 iobroker.js-controller
                         ├─ 647 io.admin.0
                         ├─ 706 io.discovery.0
                         ├─ 721 io.info.0
                         ├─ 908 io.kecontact.0
                         ├─1249 io.mqtt.0
                         ├─1266 io.web.0
                         ├─1281 io.javascript.0
                         ├─1298 io.history.0
                         ├─1325 io.cloud.0
                         ├─1338 io.iot.0
                         ├─1355 io.telegram.0
                         ├─1374 io.backitup.0
                         ├─1434 io.shelly.0
                         ├─1449 io.influxdb.0
                         ├─1469 io.vis-inventwo.0
                         ├─1488 io.modbus.0
                         └─1503 io.modbus.1
              Feb 27 12:57:30 ioBrokerPV bash[518]: Send diag info: {"uuid":"767fc1e4-aa98-4c8f-dc46-daccf93cd3a3","language":"de","country":"Austria","hosts":[{"versio
              Feb 27 12:57:32 ioBrokerPV bash[518]: Send diag info: {"uuid":"767fc1e4-aa98-4c8f-dc46-daccf93cd3a3","language":"de","country":"Austria","hosts":[{"versio
              Feb 27 12:57:33 ioBrokerPV bash[518]: hash unchanged, use cached sources
              Feb 27 12:57:36 ioBrokerPV bash[518]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
              Feb 27 12:57:46 ioBrokerPV sudo[1397]: iobroker : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/mount -t cifs -o username=iobackup,password=xxxx,d
              Feb 27 12:57:46 ioBrokerPV sudo[1397]: pam_unix(sudo:session): session opened for user root by (uid=0)
              Feb 27 12:57:48 ioBrokerPV sudo[1397]: pam_unix(sudo:session): session closed for user root
              Feb 27 12:57:58 ioBrokerPV sudo[1477]: iobroker : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/umount /opt/iobroker/backups
              Feb 27 12:57:58 ioBrokerPV sudo[1477]: pam_unix(sudo:session): session opened for user root by (uid=0)
              Feb 27 12:57:58 ioBrokerPV sudo[1477]: pam_unix(sudo:session): session closed for user root
              Node.js
              v12.21.0 (Es gibt eine neuere Version: v12.20.2)
              NPM
              6.14.11
              ein iobroker stop fkt. weiterhin nicht.
              BG
              • HumidorH Humidor
                           ├─ 647 io.admin.0
                           ├─ 721 io.info.0
                           ├─1249 io.mqtt.0
                           ├─1266 io.web.0
                           ├─1298 io.history.0
                           ├─1325 io.cloud.0
                           ├─1338 io.iot.0
                           ├─1434 io.shelly.0
                           ├─1488 io.modbus.0
                           └─1503 io.modbus.1
                Node.js
                NPM
                6.14.11
                @humidor Ja, das da irgendwas bei dir krumm ist wussten wir ja bereits.
                Nimm aber Mal dein Passwort aus der Ausgabe.
                  HumidorH Offline
                  HumidorH Offline
                  Humidor
                  @thomas-braun hab viel gelernt, danke!
                  nachdem es aber nach Update noch immer nicht funktioniert, werde ich mit der Neuinstallation weiter machen
                  dort habe ich nur 1 Problem.
                  der Shelly Adater (trotz de/installation) meldet einen Fehler
                  BG
                  • HumidorH Humidor
                    wendy2702W Online
                    wendy2702W Online
                    @humidor Ja.
                    Logs noch immer als Text Files posten und bezüglich dieses Fehlers mal die Suche bemühen.
                    • wendy2702W wendy2702
                      @humidor Ja.
                      HumidorH Offline
                      HumidorH Offline
                      Humidor
                      @wendy2702
                      das ist kein Text sondern Bild
                      shelly.0	2021-02-27 14:54:43.481	error	(1501) Cannot find search "folder" in "system"
                      finde dazu ein paar Einträge, aber mit anderer Nummer und Fehlerursache meist 3.2.x, aktuell ist der 4.x
                      Intersssant, dass sich die Nr. geändert hat.
                      BG
                      • HumidorH Humidor
                        @wendy2702
                        wendy2702W Online
                        wendy2702W Online
                        Mir ist durchaus bewusst das es ein Bild ist. Deshalb ja mein Post es als TEXT zu Posten wie du es jetzt ja auch gemacht hast.
                        Und woher willst du wissen das es eine andere Fehlerursache ist?
                        Unabhängig davon hat es mit deinem Initialen Problem nichts zu tun. Solltest wenn es in den Zahlreichen anderen Beiträgen wirklich nicht den Hauch einer Lösung gibt eh ein neues Thema aufmachen und das hier als Gelöst markieren.
