  4. Iobroker per Browser nicht erreichbar.
48 Beiträge 4 Kommentatoren 5.1k Aufrufe 3 Beobachtet
  • wendy2702W wendy2702
    @jasimi sagte in Iobroker per Browser nicht erreichbar.:
    @wendy2702 said in Iobroker per Browser nicht erreichbar.:
    @jasimi Zuerst
    iobroker stop
    dann
    iobroker fix
    login as: pi
    pi@192.168.178.42's password:
    Linux raspberrypi4-iob 5.10.11-v7l+ #1399 SMP Thu Jan 28 12:09:48 GMT 2021 armv7        l
    permitted by applicable law.
    Last login: Fri Feb 26 20:07:31 2021 from 192.168.178.51
    pi@raspberrypi4-iob:~ $ iobroker stop
    pi@raspberrypi4-iob:~ $ iobroker fix
    library: loaded
    Library version=2021-01-23
        Welcome to the ioBroker installation fixer!
        Script version: 2020-12-07
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    OK:2 http://archive.raspberrypi.org/debian buster InRelease
    OK:3 http://packages.microsoft.com/repos/code stable InRelease
    OK:4 http://phoscon.de/apt/deconz buster InRelease
    OK:5 https://deb.nodesource.com/node_10.x buster InRelease
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    Was kommt jetzt bei
    iobroker start
    iobroker list instances
    iobroker list adapters
    Stoppe und disable Motioneye, stelle den port vom Admin wieder auf 8081, restarte das Teil komplett und schaue was dann kommt wenn es jetzt noch nicht läuft.
    jasimi
    login as: pi
    Linux raspberrypi4-iob 5.10.11-v7l+ #1399 SMP Thu Jan 28 12:09:48 GMT 2021 armv7l
    Last login: Fri Feb 26 20:48:28 2021
    pi@raspberrypi4-iob:~ $ iobroker start
    pi@raspberrypi4-iob:~ $ iobroker list instances
    + system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi4-iob                         -  enabled
    + system.adapter.deconz.0                 : deconz                : raspberrypi4-iob                         -  enabled
    + system.adapter.heos.0                   : heos                  : raspberrypi4-iob                         -  enabled
    + system.adapter.heos.1                   : heos                  : raspberrypi4-iob                         -  enabled
    + system.adapter.info.0                   : info                  : raspberrypi4-iob                         -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi4-iob                         -  enabled
    + instance is alive
    pi@raspberrypi4-iob:~ $ iobroker list adapters
    system.adapter.admin                   : admin          - v4.2.1
    system.adapter.alexa2                  : alexa2         - v3.7.1
    system.adapter.deconz                  : deconz         - v1.3.11
    system.adapter.heos                    : heos           - v1.7.5
    system.adapter.info                    : info           - v1.7.14
    system.adapter.javascript              : javascript     - v4.8.4
    Thomas BraunT wendy2702W 2 Antworten Letzte Antwort
    • J jasimi
      login as: pi
      + instance is alive
      @jasimi Am Rande: motioneye wird wohl so installiert
      https://github.com/ccrisan/motioneye/wiki/Install-On-Raspbian
        @jasimi Zuerst
        iobroker stop
        dann
        iobroker fix
        login as: pi
        library: loaded
        Installed gcc-c++
        Autostart enabled!
        Was kommt jetzt bei
        iobroker start
        jasimi
        @wendy2702
        Stoppe und disable Motioneye, stelle den port vom Admin wieder auf 8081, und schaue was dann kommt wenn es jetzt noch nicht läuft.
        Motioneye ist nicht installiert ich wollte habs aber noch nicht.
          jasimi
          @thomas-braun said in Iobroker per Browser nicht erreichbar.:
          Das habe ich jetzt auch erfahren. Danke
          • J jasimi
            login as: pi
            + instance is alive
            wendy2702W Online
            wendy2702W Online
            login as: pi
            + instance is alive
            Also entweder du hattest immer nur diese Adapter installiert oder deine Installation ist ordentlich krumm.
            Seit wann hast du das, also seit welchem Tag?
            Mal das iobroker log geschaut ob da etwas von Adapter uninstall drin steht.
            ls -la /opt/iobroker/node_modules/iobroker.*
              login as: pi
              + instance is alive
              jasimi
              login as: pi
              Last login: Fri Feb 26 21:01:05 2021 from 192.168.178.51
              + system.adapter.admin.0                  : admin                 : raspberrypi4        -iob                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
              + system.adapter.alexa2.0                 : alexa2                : raspberrypi4        -iob                         -  enabled
              + system.adapter.deconz.0                 : deconz                : raspberrypi4        -iob                         -  enabled
              + system.adapter.heos.0                   : heos                  : raspberrypi4        -iob                         -  enabled
              + system.adapter.heos.1                   : heos                  : raspberrypi4        -iob                         -  enabled
              + system.adapter.info.0                   : info                  : raspberrypi4        -iob                         -  enabled
              + system.adapter.javascript.0             : javascript            : raspberrypi4        -iob                         -  enabled
              + instance is alive
              pi@raspberrypi4-iob:~ $ ^C
              pi@raspberrypi4-iob:~ $ ls -la /opt/iobroker/node_modules/iobroker.*
              /opt/iobroker/node_modules/iobroker.admin:
              insgesamt 140
              drwxrwxr-x+   7 iobroker iobroker  4096 Feb  1 18:32 .
              drwxrwxr-x+ 613 iobroker iobroker 20480 Feb 26 19:45 ..
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb  1 18:32 admin
              -rw-rwxr--+   1 iobroker iobroker 24999 Okt 26  1985 CHANGELOG_OLD.md
              -rw-rwxr--+   1 iobroker iobroker     1 Feb  1 18:32 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker 21976 Feb  1 18:32 io-package.json
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb  1 18:32 lib
              -rw-rwxr--+   1 iobroker iobroker  1120 Okt 26  1985 LICENSE
              -rw-rwxr--+   1 iobroker iobroker 18730 Okt 26  1985 main.js
              -rw-rwxr--+   1 iobroker iobroker  3347 Feb  1 18:32 package.json
              -rw-rwxr--+   1 iobroker iobroker  7130 Okt 26  1985 README.md
              -rw-rwxr--+   1 iobroker iobroker    90 Okt 26  1985 .releaseconfig.json
              drwxrwxr-x+   3 iobroker iobroker  4096 Feb  1 18:32 src-rx
              drwxrwxr-x+   8 iobroker iobroker  4096 Feb  1 18:32 www
              drwxrwxr-x+   7 iobroker iobroker  4096 Feb  1 18:32 www-react
              /opt/iobroker/node_modules/iobroker.alexa2:
              insgesamt 284
              drwxrwxr-x+   5 iobroker iobroker   4096 Feb 26 19:54 .
              drwxrwxr-x+   3 iobroker iobroker   4096 Feb  5 18:24 admin
              -rw-rwxr--+   1 iobroker iobroker    777 Feb 26 19:54 formerDataStorealexa2.0.js        on
              -rw-rwxr--+   1 iobroker iobroker      1 Feb  5 18:24 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker  30140 Feb  5 18:24 io-package.json
              drwxrwxr-x+   2 iobroker iobroker   4096 Feb  5 18:24 lib
              -rw-rwxr--+   1 iobroker iobroker   1140 Okt 26  1985 LICENSE
              -rwxrwxr-x+   1 iobroker iobroker 167669 Okt 26  1985 main.js
              drwxrwxr-x+   4 iobroker iobroker   4096 Feb  5 18:24 node_modules
              -rw-rwxr--+   1 iobroker iobroker   2265 Feb  5 18:24 package.json
              -rw-rwxr--+   1 iobroker iobroker  36112 Okt 26  1985 README.md
              /opt/iobroker/node_modules/iobroker.cloud:
              insgesamt 128
              drwxrwxr-x+   7 iobroker iobroker  4096 Feb 13 07:04 .
              drwxrwxr-x+   4 iobroker iobroker  4096 Feb 13 07:04 admin
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 13 07:04 doc
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 13 07:04 img
              -rw-rwxr--+   1 iobroker iobroker     1 Feb 13 07:04 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker 20947 Feb 13 07:04 io-package.json
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 13 07:04 lib
              -rw-rwxr--+   1 iobroker iobroker  1122 Okt 26  1985 LICENSE
              -rw-rwxr--+   1 iobroker iobroker 33949 Okt 26  1985 main.js
              drwxrwxr-x+  13 iobroker iobroker  4096 Feb 13 07:04 node_modules
              -rw-rwxr--+   1 iobroker iobroker  2402 Feb 13 07:04 package.json
              -rw-rwxr--+   1 iobroker iobroker 10499 Okt 26  1985 README.md
              /opt/iobroker/node_modules/iobroker.deconz:
              insgesamt 204
              drwxrwxr-x+   7 iobroker iobroker   4096 Feb 17 10:48 .
              drwxrwxr-x+   2 iobroker iobroker   4096 Feb 17 10:48 admin
              drwxrwxr-x+   3 iobroker iobroker   4096 Feb 17 10:48 .github
              -rw-rwxr--+   1 iobroker iobroker      1 Feb 17 10:48 iob_npm.done
              -rwxrwxr-x+   1 iobroker iobroker  27601 Feb 17 10:48 io-package.json
              drwxrwxr-x+   2 iobroker iobroker   4096 Feb 17 10:48 lib
              -rwxrwxr-x+   1 iobroker iobroker   9107 Okt 26  1985 LICENSE
              -rwxrwxr-x+   1 iobroker iobroker 100013 Okt 26  1985 main.js
              drwxrwxr-x+   4 iobroker iobroker   4096 Feb 17 10:48 node_modules
              -rwxrwxr-x+   1 iobroker iobroker     29 Okt 26  1985 npmlink.sh
              -rw-rwxr--+   1 iobroker iobroker   2174 Feb 17 10:48 package.json
              -rw-rwxr--+   1 iobroker iobroker   7044 Okt 26  1985 README.md
              drwxrwxr-x+   2 iobroker iobroker   4096 Feb 17 10:48 .run
              /opt/iobroker/node_modules/iobroker.denon:
              insgesamt 220
              drwxrwxr-x+   4 iobroker iobroker  4096 Feb 16 11:04 .
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 16 11:04 admin
              -rw-rwxr--+   1 iobroker iobroker     1 Feb 16 11:04 iob_npm.done
              -rwxrwxr-x+   1 iobroker iobroker 23637 Feb 16 11:04 io-package.json
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 16 11:04 lib
              -rwxrwxr-x+   1 iobroker iobroker  1117 Okt 26  1985 LICENSE
              -rwxrwxr-x+   1 iobroker iobroker 82374 Okt 26  1985 main.js
              -rw-rwxr--+   1 iobroker iobroker  2096 Feb 16 11:04 package.json
              -rw-rwxr--+   1 iobroker iobroker 33492 Okt 26  1985 README.md
              /opt/iobroker/node_modules/iobroker.discovery:
              insgesamt 112
              drwxrwxr-x+   4 iobroker iobroker  4096 Feb  1 18:33 .
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb  1 18:33 admin
              -rw-rwxr--+   1 iobroker iobroker     1 Feb  1 18:33 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker 27599 Feb  1 18:33 io-package.json
              drwxrwxr-x+   4 iobroker iobroker  4096 Feb  1 18:33 lib
              -rw-rwxr--+   1 iobroker iobroker  1100 Okt 26  1985 LICENSE
              -rw-rwxr--+   1 iobroker iobroker 28344 Okt 26  1985 main.js
              -rw-rwxr--+   1 iobroker iobroker  2204 Feb  1 18:33 package.json
              -rw-rwxr--+   1 iobroker iobroker  8407 Okt 26  1985 README.md
              /opt/iobroker/node_modules/iobroker.email:
              insgesamt 72
              drwxrwxr-x+   4 iobroker iobroker  4096 Feb  1 18:35 .
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb  1 18:35 admin
              -rw-rwxr--+   1 iobroker iobroker     1 Feb  1 18:35 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker  9049 Feb  1 18:35 io-package.json
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb  1 18:35 lib
              -rw-rwxr--+   1 iobroker iobroker  1099 Okt 26  1985 LICENSE
              -rw-rwxr--+   1 iobroker iobroker  6941 Okt 26  1985 main.js
              -rw-rwxr--+   1 iobroker iobroker  2096 Feb  1 18:35 package.json
              -rw-rwxr--+   1 iobroker iobroker  5175 Okt 26  1985 README.md
              /opt/iobroker/node_modules/iobroker.fakeroku:
              insgesamt 72
              drwxrwxr-x+   4 iobroker iobroker  4096 Feb  5 18:05 .
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb  5 18:05 admin
              -rw-rwxr--+   1 iobroker iobroker     1 Feb  5 18:05 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker  1490 Feb  5 18:05 io-package.json
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb  5 18:05 lib
              -rw-rwxr--+   1 iobroker iobroker  1091 Feb  4  2017 LICENSE
              -rw-rwxr--+   1 iobroker iobroker 13573 Feb  8  2017 main.js
              -rw-rwxr--+   1 iobroker iobroker    92 Feb  4  2017 .npmignore
              -rw-rwxr--+   1 iobroker iobroker  1943 Feb  5 18:05 package.json
              -rw-rwxr--+   1 iobroker iobroker  2194 Feb 13  2017 README.md
              /opt/iobroker/node_modules/iobroker.fritzdect:
              insgesamt 168
              drwxrwxr-x+   7 iobroker iobroker  4096 Jan 29 14:38 .
              drwxrwxr-x+   3 iobroker iobroker  4096 Jan 29 14:38 admin
              drwxrwxr-x+   3 iobroker iobroker  4096 Jan 29 14:38 docs
              -rw-rwxr--+   1 iobroker iobroker     1 Jan 29 14:38 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker 17429 Jan 29 14:38 io-package.json
              drwxrwxr-x+   2 iobroker iobroker  4096 Jan 29 14:38 lib
              -rw-rwxr--+   1 iobroker iobroker  1085 Okt 26  1985 LICENSE
              -rw-rwxr--+   1 iobroker iobroker 84825 Okt 26  1985 main.js
              drwxrwxr-x+   4 iobroker iobroker  4096 Jan 29 14:38 node_modules
              -rw-rwxr--+   1 iobroker iobroker  1848 Jan 29 14:38 package.json
              -rw-rwxr--+   1 iobroker iobroker  7682 Okt 26  1985 README.md
              drwxrwxr-x+   2 iobroker iobroker  4096 Jan 29 14:38 widgets
              /opt/iobroker/node_modules/iobroker.harmony:
              insgesamt 88
              drwxrwxr-x+   4 iobroker iobroker  4096 Jan 29 14:41 .
              drwxrwxr-x+   2 iobroker iobroker  4096 Jan 29 14:41 admin
              -rw-rwxr--+   1 iobroker iobroker   677 Okt 26  1985 .eslintrc.json
              -rw-rwxr--+   1 iobroker iobroker 20617 Okt 26  1985 harmony.js
              -rw-rwxr--+   1 iobroker iobroker     1 Jan 29 14:41 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker  5639 Jan 29 14:41 io-package.json
              -rw-rwxr--+   1 iobroker iobroker  1095 Okt 26  1985 LICENSE
              drwxrwxr-x+   4 iobroker iobroker  4096 Jan 29 14:41 node_modules
              -rw-rwxr--+   1 iobroker iobroker  2065 Jan 29 14:41 package.json
              -rw-rwxr--+   1 iobroker iobroker  5154 Okt 26  1985 README.md
              /opt/iobroker/node_modules/iobroker.heos:
              insgesamt 152
              drwxrwxr-x+   6 iobroker iobroker  4096 Feb 16 11:03 .
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 16 11:03 admin
              drwxrwxr-x+   4 iobroker iobroker  4096 Feb 16 11:03 docs
              drwxrwxr-x+   4 iobroker iobroker  4096 Feb 16 11:03 .github
              -rw-rwxr--+   1 iobroker iobroker     1 Feb 16 11:03 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker 17731 Feb 16 11:03 io-package.json
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 16 11:03 lib
              -rw-rwxr--+   1 iobroker iobroker  1173 Okt 26  1985 LICENSE
              -rw-rwxr--+   1 iobroker iobroker 65135 Okt 26  1985 main.js
              -rw-rwxr--+   1 iobroker iobroker   773 Okt 26  1985 main.test.js
              -rw-rwxr--+   1 iobroker iobroker  2546 Feb 16 11:03 package.json
              -rw-rwxr--+   1 iobroker iobroker  9057 Okt 26  1985 README.md
              /opt/iobroker/node_modules/iobroker.history:
              insgesamt 136
              drwxrwxr-x+   7 iobroker iobroker  4096 Feb 22 21:54 .
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 22 21:54 admin
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 22 21:54 converter
              drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 21:54 docs
              drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 21:54 .github
              -rw-rwxr--+   1 iobroker iobroker     1 Feb 22 21:54 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker 20016 Feb 22 21:54 io-package.json
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 22 21:54 lib
              -rw-rwxr--+   1 iobroker iobroker  1175 Okt 26  1985 LICENSE
              -rw-rwxr--+   1 iobroker iobroker 51961 Okt 26  1985 main.js
              -rw-rwxr--+   1 iobroker iobroker  1980 Feb 22 21:54 package.json
              -rw-rwxr--+   1 iobroker iobroker  7812 Okt 26  1985 README.md
              /opt/iobroker/node_modules/iobroker.hue:
              insgesamt 180
              drwxrwxr-x+   6 iobroker iobroker  4096 Feb  8 15:32 .
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb  8 15:32 admin
              drwxrwxr-x+   4 iobroker iobroker  4096 Feb  8 15:32 .github
              drwxrwxr-x+   4 iobroker iobroker  4096 Feb  8 15:32 .idea
              -rw-rwxr--+   1 iobroker iobroker     1 Feb  8 15:32 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker 27503 Feb  8 15:32 io-package.json
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb  8 15:32 lib
              -rw-rwxr--+   1 iobroker iobroker  9107 Okt 26  1985 LICENSE
              -rw-rwxr--+   1 iobroker iobroker 77646 Okt 26  1985 main.js
              -rw-rwxr--+   1 iobroker iobroker  2426 Feb  8 15:32 package.json
              -rw-rwxr--+   1 iobroker iobroker 14299 Okt 26  1985 README.md
              /opt/iobroker/node_modules/iobroker.hue-extended:
              insgesamt 180
              drwxrwxr-x+   6 iobroker iobroker  4096 Jan 29 14:39 .
              drwxrwxr-x+   3 iobroker iobroker  4096 Jan 29 14:39 admin
              -rw-rwxr--+   1 iobroker iobroker   477 Okt 26  1985 eslintrc.js
              drwxrwxr-x+   3 iobroker iobroker  4096 Jan 29 14:39 .github
              -rw-rwxr--+   1 iobroker iobroker 15503 Okt 26  1985 gulpfile.js
              -rw-rwxr--+   1 iobroker iobroker 49203 Okt 26  1985 hue-extended.js
              -rw-rwxr--+   1 iobroker iobroker     1 Jan 29 14:39 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker 21000 Jan 29 14:39 io-package.json
              drwxrwxr-x+   2 iobroker iobroker  4096 Jan 29 14:39 lib
              -rw-rwxr--+   1 iobroker iobroker  1067 Okt 26  1985 LICENSE
              drwxrwxr-x+   4 iobroker iobroker  4096 Jan 29 14:39 node_modules
              -rw-rwxr--+   1 iobroker iobroker 19307 Okt 26  1985 _NODES.js
              -rw-rwxr--+   1 iobroker iobroker  2238 Jan 29 14:39 package.json
              -rw-rwxr--+   1 iobroker iobroker  8456 Okt 26  1985 README.md
              /opt/iobroker/node_modules/iobroker.info:
              insgesamt 148
              drwxrwxr-x+   6 iobroker iobroker  4096 Jan 29 15:33 .
              drwxrwxr-x+   3 iobroker iobroker  4096 Jan 29 15:33 admin
              drwxrwxr-x+  12 iobroker iobroker  4096 Jan 29 15:33 docs
              -rw-rwxr--+   1 iobroker iobroker     1 Jan 29 15:33 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker 39303 Jan 29 15:33 io-package.json
              drwxrwxr-x+   2 iobroker iobroker  4096 Jan 29 15:33 lib
              -rw-rwxr--+   1 iobroker iobroker  1104 Okt 26  1985 LICENSE
              -rw-rwxr--+   1 iobroker iobroker 38291 Okt 26  1985 main.js
              -rw-rwxr--+   1 iobroker iobroker  2752 Jan 29 15:33 package.json
              -rw-rwxr--+   1 iobroker iobroker  9249 Okt 26  1985 README.md
              drwxrwxr-x+   3 iobroker iobroker  4096 Jan 29 15:33 widgets
              /opt/iobroker/node_modules/iobroker.iot:
              insgesamt 152
              drwxrwxr-x+   8 iobroker iobroker  4096 Feb 22 16:43 .
              drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 16:43 admin
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 22 16:43 doc
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 22 16:43 img
              -rw-rwxr--+   1 iobroker iobroker     1 Feb 22 16:43 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker 24292 Feb 22 16:43 io-package.json
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 22 16:43 keys
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 22 16:43 lib
              -rw-rwxr--+   1 iobroker iobroker 42507 Okt 26  1985 main.js
              drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 16:43 node_modules
              -rw-rwxr--+   1 iobroker iobroker  2158 Feb 22 16:43 package.json
              -rw-rwxr--+   1 iobroker iobroker 21248 Okt 26  1985 README.md
              /opt/iobroker/node_modules/iobroker.javascript:
              insgesamt 148
              drwxrwxr-x+   7 iobroker iobroker  4096 Jan 29 15:51 .
              drwxrwxr-x+   5 iobroker iobroker  4096 Jan 29 15:50 admin
              drwxrwxr-x+   5 iobroker iobroker  4096 Jan 29 15:50 docs
              drwxrwxr-x+   2 iobroker iobroker  4096 Jan 29 15:50 install
              -rw-rwxr--+   1 iobroker iobroker     1 Jan 29 15:51 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker 14383 Jan 29 15:51 io-package.json
              drwxrwxr-x+   2 iobroker iobroker  4096 Jan 29 15:50 lib
              -rw-rwxr--+   1 iobroker iobroker  1137 Okt 26  1985 LICENSE
              -rw-rwxr--+   1 iobroker iobroker 66247 Okt 26  1985 main.js
              drwxrwxr-x+   3 iobroker iobroker  4096 Jan 29 15:51 node_modules
              -rw-rwxr--+   1 iobroker iobroker  3079 Jan 29 15:51 package.json
              -rw-rwxr--+   1 iobroker iobroker   380 Jan 29 15:51 package-lock.json
              -rw-rwxr--+   1 iobroker iobroker  2499 Okt 26  1985 README.md
              /opt/iobroker/node_modules/iobroker.js-controller:
              insgesamt 484
              drwxrwxr-x+   6 iobroker iobroker   4096 Feb 26 20:48 .
              -rw-rwxr--+   1 iobroker iobroker  85298 Okt 26  1985 CHANGELOG.md
              -rw-rwxr--+   1 iobroker iobroker    420 Okt 26  1985 compactgroupController.js
              drwxrwxr-x+   2 iobroker iobroker   4096 Feb 26 19:45 conf
              -rw-rwxr--+   1 iobroker iobroker    158 Okt 26  1985 controller.js
              -rw-rwxr--+   1 iobroker iobroker   8341 Okt 26  1985 gulpfile.js
              -rw-rwxr--+   1 iobroker iobroker     74 Okt 26  1985 iob
              -rwxrwxr-x+   1 iobroker iobroker     33 Okt 26  1985 iobroker.js
              -rw-rwxr--+   1 iobroker iobroker  59094 Okt 26  1985 io-package.json
              drwxrwxr-x+  10 iobroker iobroker   4096 Feb 26 19:45 lib
              -rw-rwxr--+   1 iobroker iobroker   1135 Okt 26  1985 LICENSE
              -rw-rwxr--+   1 iobroker iobroker 207764 Okt 26  1985 main.js
              drwxrwxr-x+   6 iobroker iobroker   4096 Feb 26 19:45 node_modules
              -rw-rwxr--+   1 iobroker iobroker   4853 Feb 26 19:45 package.json
              -rw-rw-r--+   1 iobroker iobroker     41 Feb 26 21:08 pids.txt
              -rw-rwxr--+   1 iobroker iobroker  45055 Okt 26  1985 README.md
              -rw-rwxr--+   1 iobroker iobroker   5693 Okt 26  1985 reinstall.js
              drwxrwxr-x+   2 iobroker iobroker   4096 Feb 26 19:45 tmp
              /opt/iobroker/node_modules/iobroker.lightify:
              insgesamt 88
              drwxrwxr-x+   4 iobroker iobroker  4096 Jan 29 18:21 .
              drwxrwxr-x+   2 iobroker iobroker  4096 Jan 29 18:21 admin
              -rw-rwxr--+   1 iobroker iobroker   395 Aug 25  2017 .gitattributes
              -rw-rwxr--+   1 iobroker iobroker     1 Jan 29 18:21 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker  3719 Jan 29 18:21 io-package.json
              drwxrwxr-x+   2 iobroker iobroker  4096 Jan 29 18:21 lib
              -rw-rwxr--+   1 iobroker iobroker  1112 Aug 25  2017 LICENSE
              -rw-rwxr--+   1 iobroker iobroker 25420 Aug 25  2017 lightify.js
              -rw-rwxr--+   1 iobroker iobroker   100 Aug 25  2017 .npmignore
              -rw-rwxr--+   1 iobroker iobroker  1907 Jan 29 18:21 package.json
              -rw-rwxr--+   1 iobroker iobroker  3440 Aug 25  2017 README.md
              /opt/iobroker/node_modules/iobroker.mihome:
              insgesamt 100
              drwxrwxr-x+   3 iobroker iobroker  4096 Feb  8 15:32 admin
              drwxrwxr-x+   4 iobroker iobroker  4096 Feb  8 15:32 doc
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb  8 15:32 img
              -rw-rwxr--+   1 iobroker iobroker 19203 Feb  8 15:32 io-package.json
              drwxrwxr-x+   3 iobroker iobroker  4096 Feb  8 15:32 lib
              -rw-rwxr--+   1 iobroker iobroker 12788 Okt 26  1985 main.js
              -rw-rwxr--+   1 iobroker iobroker  1847 Feb  8 15:32 package.json
              -rw-rwxr--+   1 iobroker iobroker 10744 Okt 26  1985 README.md
              /opt/iobroker/node_modules/iobroker.ping:
              insgesamt 84
              drwxrwxr-x+   4 iobroker iobroker  4096 Jan 29 18:19 .
              drwxrwxr-x+   2 iobroker iobroker  4096 Jan 29 18:19 admin
              -rw-rwxr--+   1 iobroker iobroker     1 Jan 29 18:19 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker 11630 Jan 29 18:19 io-package.json
              drwxrwxr-x+   2 iobroker iobroker  4096 Jan 29 18:19 lib
              -rw-rwxr--+   1 iobroker iobroker 19004 Okt 26  1985 main.js
              -rw-rwxr--+   1 iobroker iobroker  1843 Jan 29 18:19 package.json
              -rw-rwxr--+   1 iobroker iobroker  4455 Okt 26  1985 README.md
              /opt/iobroker/node_modules/iobroker.pushover:
              insgesamt 76
              drwxrwxr-x+   4 iobroker iobroker  4096 Feb  1 19:42 .
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb  1 19:42 admin
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb  1 19:42 img
              -rw-rwxr--+   1 iobroker iobroker     1 Feb  1 19:42 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker 11701 Feb  1 19:42 io-package.json
              -rw-rwxr--+   1 iobroker iobroker  9165 Okt 26  1985 main.js
              -rw-rwxr--+   1 iobroker iobroker  2102 Feb  1 19:42 package.json
              -rw-rwxr--+   1 iobroker iobroker  6344 Okt 26  1985 README.md
              /opt/iobroker/node_modules/iobroker.simple-api:
              insgesamt 96
              drwxrwxr-x+   5 iobroker iobroker  4096 Jan 29 14:40 .
              drwxrwxr-x+   2 iobroker iobroker  4096 Jan 29 14:40 admin
              drwxrwxr-x+   2 iobroker iobroker  4096 Jan 29 14:40 img
              -rw-rwxr--+   1 iobroker iobroker 22856 Okt 26  1985 io-package.json
              drwxrwxr-x+   2 iobroker iobroker  4096 Jan 29 14:40 lib
              -rw-rwxr--+   1 iobroker iobroker  7127 Okt 26  1985 main.js
              -rw-rwxr--+   1 iobroker iobroker  1937 Jan 29 14:40 package.json
              -rw-rwxr--+   1 iobroker iobroker 20046 Okt 26  1985 README.md
              /opt/iobroker/node_modules/iobroker.socketio:
              insgesamt 108
              drwxrwxr-x+   4 iobroker iobroker  4096 Jan 29 14:40 .
              -rw-rwxr--+   1 iobroker iobroker 12794 Okt 26  1985 gulpfile.js
              -rw-rwxr--+   1 iobroker iobroker 23180 Okt 26  1985 io-package.json
              -rw-rwxr--+   1 iobroker iobroker  7396 Okt 26  1985 main.js
              -rw-rwxr--+   1 iobroker iobroker  1876 Jan 29 14:40 package.json
              -rw-rwxr--+   1 iobroker iobroker 17199 Okt 26  1985 README.md
              /opt/iobroker/node_modules/iobroker.tr-064:
              insgesamt 136
              drwxrwxr-x+   4 iobroker iobroker  4096 Feb 19 11:28 .
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 19 11:28 admin
              -rw-rwxr--+   1 iobroker iobroker     1 Feb 19 11:28 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker 32442 Feb 19 11:28 io-package.json
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 19 11:28 lib
              -rw-rwxr--+   1 iobroker iobroker  1091 Okt 26  1985 LICENSE
              -rw-rwxr--+   1 iobroker iobroker 45359 Okt 26  1985 main.js
              -rw-rwxr--+   1 iobroker iobroker  2158 Feb 19 11:28 package.json
              -rw-rwxr--+   1 iobroker iobroker 12079 Okt 26  1985 README.md
              /opt/iobroker/node_modules/iobroker.type-detector:
              insgesamt 124
              drwxrwxr-x+   4 iobroker iobroker  4096 Feb 13 06:53 .
              drwxrwxr-x+   3 iobroker iobroker  4096 Feb 13 06:53 .github
              -rw-rwxr--+   1 iobroker iobroker 76551 Okt 26  1985 index.js
              -rw-rwxr--+   1 iobroker iobroker  1089 Okt 26  1985 LICENSE
              -rw-rwxr--+   1 iobroker iobroker  1703 Feb 13 06:53 package.json
              -rw-rwxr--+   1 iobroker iobroker  2911 Okt 26  1985 README.md
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 13 06:53 test
              -rw-rwxr--+   1 iobroker iobroker   447 Okt 26  1985 .travis.yml
              /opt/iobroker/node_modules/iobroker.vis:
              insgesamt 148
              drwxrwxr-x+   7 iobroker iobroker  4096 Feb 22 16:15 .
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 22 16:15 admin
              drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 16:15 .github
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 22 16:15 img
              -rw-rwxr--+   1 iobroker iobroker     1 Feb 22 16:15 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker 19359 Feb 22 16:15 io-package.json
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb 22 16:15 lib
              -rw-rwxr--+   1 iobroker iobroker 14485 Okt 26  1985 LICENSE
              -rw-rwxr--+   1 iobroker iobroker 15373 Okt 26  1985 main.js
              -rw-rwxr--+   1 iobroker iobroker 15653 Okt 26  1985 OLD_CHANGELOG.md
              -rw-rwxr--+   1 iobroker iobroker  2112 Feb 22 16:15 package.json
              -rw-rwxr--+   1 iobroker iobroker 18432 Okt 26  1985 README.md
              -rw-rwxr--+   1 iobroker iobroker    97 Okt 26  1985 .releaseconfig.json
              -rw-rwxr--+   1 iobroker iobroker   249 Okt 26  1985 ROADMAP.md
              drwxrwxr-x+   9 iobroker iobroker  4096 Feb 22 16:15 www
              /opt/iobroker/node_modules/iobroker.web:
              insgesamt 144
              drwxrwxr-x+   4 iobroker iobroker  4096 Feb  1 18:34 .
              drwxrwxr-x+   2 iobroker iobroker  4096 Feb  1 18:34 admin
              -rw-rwxr--+   1 iobroker iobroker     1 Feb  1 18:34 iob_npm.done
              -rw-rwxr--+   1 iobroker iobroker 23013 Feb  1 18:34 io-package.json
              -rw-rwxr--+   1 iobroker iobroker 57746 Okt 26  1985 main.js
              -rw-rwxr--+   1 iobroker iobroker  2158 Feb  1 18:34 package.json
              -rw-rwxr--+   1 iobroker iobroker 12976 Okt 26  1985 README.md
              drwxrwxr-x+   5 iobroker iobroker  4096 Feb  1 18:34 www
              wenn ich richtig zähle hatte ich ca. 14 Adapter .
              • J jasimi
                login as: pi
                + instance is alive
                insgesamt 140
                insgesamt 284
                insgesamt 128
                insgesamt 204
                insgesamt 220
                insgesamt 112
                insgesamt 72
                insgesamt 72
                insgesamt 168
                insgesamt 88
                insgesamt 152
                insgesamt 136
                insgesamt 180
                insgesamt 180
                insgesamt 148
                insgesamt 152
                insgesamt 148
                insgesamt 484
                insgesamt 88
                insgesamt 100
                insgesamt 84
                insgesamt 76
                insgesamt 96
                insgesamt 108
                insgesamt 136
                insgesamt 124
                insgesamt 148
                insgesamt 144
                wendy2702W Online
                wendy2702W Online
                @jasimi Ja. Habe sie nicht gezählt, scheinen aber mehr gewesen zu sein.
                Hast du den Admin Port zurück geändert?
                Ändere den mal bitte zurück.
                Dann neustart vom Pi.
                Wenn keine Änderung auf der Konsole:
                iobroker upload all
                Ach, du hast nicht zufällig ein Backup ?
                Dann könnten wir uns das sparen und etwas abkürzen :-)
                J 2 Antworten Letzte Antwort
                  iobroker upload all
                  jasimi
                  schrieb am zuletzt editiert von jasimi
                  Ja auf 8081.
                  Habe ca. 14 Adapter gehabt.
                  • J jasimi
                    Ja auf 8081.
                    wendy2702W Online
                    wendy2702W Online
                    @jasimi Hatte meinen Beitrag editiert. Gesehen?
                      iobroker upload all
                      jasimi
                      iobroker upload all
                      Backup habe ich leider nicht. Ich habe auch kein problem damit alles neu zu machen.
                      • wendy2702W Online
                        wendy2702W Online
                        @jasimi Kannst für einen Adapter mal das probieren:
                        cd /opt/iobroker/node_modules/iobroker.deconz/
                        npm rebuild
                          npm rebuild
                          jasimi
                          npm rebuild
                          login as: pi
                          Last login: Fri Feb 26 21:28:56 2021
                          pi@raspberrypi4-iob:~ $ cd /opt/iobroker/node_modules/iobroker.deconz/
                          pi@raspberrypi4-iob:/opt/iobroker/node_modules/iobroker.deconz $
                          pi@raspberrypi4-iob:/opt/iobroker/node_modules/iobroker.deconz $ npm rebuild
                          @sentry/integrations@5.30.0 /opt/iobroker/node_modules/iobroker.deconz/node_modules/@sentry/integrations
                          @sentry/types@5.30.0 /opt/iobroker/node_modules/iobroker.deconz/node_modules/@sentry/types
                          @sentry/utils@5.30.0 /opt/iobroker/node_modules/iobroker.deconz/node_modules/@sentry/utils
                          @sentry/node@5.30.0 /opt/iobroker/node_modules/iobroker.deconz/node_modules/@sentry/node
                          @sentry/core@5.30.0 /opt/iobroker/node_modules/iobroker.deconz/node_modules/@sentry/core
                          @sentry/hub@5.30.0 /opt/iobroker/node_modules/iobroker.deconz/node_modules/@sentry/hub
                          @sentry/minimal@5.30.0 /opt/iobroker/node_modules/iobroker.deconz/node_modules/@sentry/minimal
                          @sentry/tracing@5.30.0 /opt/iobroker/node_modules/iobroker.deconz/node_modules/@sentry/tracing
                          cookie@0.4.1 /opt/iobroker/node_modules/iobroker.deconz/node_modules/cookie
                             │      New major version of npm available! 6.14.11 → 7.6.0      │
                             │   Changelog: https://github.com/npm/cli/releases/tag/v7.6.0   │
                             │               Run npm install -g npm to update!               │
                            npm rebuild
                            jasimi
                            npm rebuild
                            Was ich jetzt bemerkt habe das deconz auch im app menue nicht startbar ist.
                            • J jasimi
                              npm rebuild
                              auch im app menue
                              Was für ein 'App Menü'?
                              In welchem Terminal gibt es denn sowas?
                                auch im app menue
                                jasimi
                                auch im app menue
                                Doch nicht im Terminal, habe ich nicht gesagt. Im Desktop unter Entwicklung steht deConz. um das gehts.
                                • J jasimi
                                  auch im app menue
                                  @jasimi
                                  Auf einem Server läuft kein Desktop.
                                    @jasimi
                                    jasimi
                                    @jasimi
                                    Vielleicht ist das mein Problem.
                                    • J jasimi
                                      @jasimi
                                      wendy2702W Online
                                      wendy2702W Online
                                      @jasimi Poste mal ein Bild der Adapter und Instanz Seite
                                        jasimi
                                        Ist mir jetzt auch aufgefallen, bei info sind alle Adapter da nur bei Instanzen nicht. Wie geht das ?
                                        • J jasimi
                                          wendy2702W Online
                                          wendy2702W Online
                                          @jasimi Hast du den Upload gemacht?
