  4. (Frage) ioBroker stop - stoppt ioBroker nicht ?
44 Beiträge 5 Kommentatoren 4.2k Aufrufe 5 Beobachtet
  • HumidorH Humidor
    Hallo 👍
    wie löse ich das ? (Telegram zeigt mir einen Restart und ioBroker kommt auch wieder hoch)
    pi@ioBrokerPV:~ $ iobroker stop
    pi@ioBrokerPV:~ $ ps auxww|grep io
    root        11  0.0  0.0      0     0 ?        S    Feb15   0:00 [migration/0]
    root        14  0.0  0.0      0     0 ?        S    Feb15   0:00 [migration/1]
    root        19  0.0  0.0      0     0 ?        S    Feb15   0:00 [migration/2]
    root        24  0.0  0.0      0     0 ?        S    Feb15   0:00 [migration/3]
    root        55  0.0  0.0      0     0 ?        I<   Feb15   0:00 [blkcg_punt_bio]
    root        57  0.0  0.0      0     0 ?        I<   Feb15   0:00 [rpciod]
    root        59  0.0  0.0      0     0 ?        I<   Feb15   0:00 [xprtiod]
    root        61  0.0  0.0      0     0 ?        I<   Feb15   0:00 [nfsiod]
    root        69  0.0  0.0      0     0 ?        I<   Feb15   0:00 [DWC Notificatio]
    avahi      330  0.0  0.1   6156  2380 ?        Ss   Feb15   2:29 avahi-daemon: running [ioBrokerPV.local]
    message+   336  0.0  0.1   6556  2352 ?        Ss   Feb15   2:53 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
    grafana    552  0.0  1.3 972256 25412 ?        Ssl  Feb15   4:03 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/var/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana cfg:default.paths.plugins=/var/lib/grafana/plugins cfg:default.paths.provisioning=/etc/grafana/provisioning
    iobroker   901 32.3  6.2 205236 120052 ?       Ssl  07:54   0:14 iobroker.js-controller
    iobroker   920 11.0  5.2 193816 100352 ?       Sl   07:55   0:04 io.admin.0
    iobroker   935  3.9  2.5 146460 49560 ?        Sl   07:55   0:01 io.discovery.0
    iobroker   950 11.0  2.3 149120 44364 ?        Sl   07:55   0:03 io.info.0
    iobroker  1082 13.8  2.1 143852 40672 ?        Sl   07:55   0:04 io.kecontact.0
    root      1393  0.0  0.0      0     0 ?        I<   Feb15   0:00 [cifsiod]
    iobroker  1483  7.2  2.9 150048 57328 ?        Sl   07:55   0:01 io.mqtt.0
    iobroker  1500 23.5  4.2 168184 80952 ?        Sl   07:55   0:05 io.web.0
    iobroker  1515 30.9  5.9 208616 113608 ?       Sl   07:55   0:05 io.javascript.0
    iobroker  1530 17.4  3.4 155360 65700 ?        Sl   07:55   0:02 io.history.0
    iobroker  1547 20.2  2.9 149132 56104 ?        Sl   07:55   0:02 io.cloud.0
    iobroker  1562 40.0  3.2 152464 62924 ?        Sl   07:55   0:02 io.iot.0
    iobroker  1579  111  2.9 151560 56004 ?        Sl   07:55   0:02 io.telegram.0
    pi        1595  0.0  0.0   7360   504 pts/0    S+   07:55   0:00 grep --color=auto io
    arteckA Offline
    arteckA Offline
    arteck
    @humidor cd /opt/iobroker
    iobroker stop
    oder
    killall io
    HumidorH 1 Antwort Letzte Antwort
    • arteckA arteck
      iobroker stop
      oder
      killall io
      HumidorH Offline
      HumidorH Offline
      Humidor
      @arteck danke, fkt. aber leider auch nicht.
      pi@ioBrokerPV:~ $ cd /opt/iobroker
      pi@ioBrokerPV:/opt/iobroker $ iobroker stop
      pi@ioBrokerPV:/opt/iobroker $ killall io
      io: Kein Prozess gefunden
      ioBroker läuft noch immer.
      BG
      • HumidorH Humidor
        @humidor
        sudo -u iobroker kill -9 901
          @humidor
          HumidorH Offline
          HumidorH Offline
          Humidor
          schrieb am zuletzt editiert von Humidor
          pi@ioBrokerPV:/ $ sudo -u iobroker kill -9 901
          kill: (901): Kein passender Prozess gefunden
          BG
          • HumidorH Humidor
            @humidor
            Dann hat sich die PID geändert.
              @humidor
              HumidorH Offline
              HumidorH Offline
              Humidor
              @thomas-braun OK, was ist eine PID, wie finde ich diese raus?
              BG
              • HumidorH Humidor
                @humidor
                Ist die Zahl in der zweiten Spalte. Aber versuch mal
                sudo killall -u iobroker
                  @humidor
                  HumidorH Offline
                  HumidorH Offline
                  Humidor
                  @thomas-braun ach, so einfach ;)
                  ja hat sich geändert, werden diese bei jedem Neustart neu vergeben?
                  pi@ioBrokerPV:/ $ ps auxww|grep io
                  avahi      330  0.0  0.1   6156  2380 ?        Ss   Feb15   2:31 avahi-daemon: running [ioBrokerPV.local]
                  message+   336  0.0  0.1   6556  2352 ?        Ss   Feb15   2:56 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                  grafana    552  0.0  1.4 972256 28248 ?        Ssl  Feb15   4:08 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/var/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana cfg:default.paths.plugins=/var/lib/grafana/plugins cfg:default.paths.provisioning=/etc/grafana/provisioning
                  iobroker  2353 10.1  5.1 199400 98856 ?        Ssl  08:12   6:33 iobroker.js-controller
                  iobroker  2372  0.4  3.9 180120 75864 ?        Sl   08:12   0:15 io.admin.0
                  iobroker  2387  0.1  2.1 145436 42272 ?        Sl   08:12   0:07 io.discovery.0
                  iobroker  2402  0.2  2.6 154296 50784 ?        Sl   08:12   0:09 io.info.0
                  iobroker  2508  2.6  2.6 154444 51568 ?        Sl   08:12   1:41 io.kecontact.0
                  iobroker  2929  0.3  2.5 153156 49344 ?        Sl   08:12   0:14 io.mqtt.0
                  iobroker  2946  4.8  3.3 165820 64328 ?        Sl   08:12   3:04 io.web.0
                  iobroker  2961  3.1  5.1 202056 99424 ?        Sl   08:13   2:01 io.javascript.0
                  iobroker  2976  0.7  2.9 158628 56632 ?        Sl   08:13   0:28 io.history.0
                  iobroker  2993  0.2  2.4 152948 47748 ?        Sl   08:13   0:09 io.cloud.0
                  iobroker  3008  0.2  2.7 156016 52164 ?        Sl   08:13   0:08 io.iot.0
                  iobroker  3033  0.2  2.6 154544 51572 ?        Sl   08:13   0:10 io.telegram.0
                  iobroker  3048  0.2  3.5 171136 68572 ?        Sl   08:13   0:10 io.backitup.0
                  iobroker  3087  0.8  3.4 167504 65568 ?        Sl   08:13   0:34 io.shelly.0
                  iobroker  3103  1.2  3.1 163500 60424 ?        Sl   08:13   0:47 io.influxdb.0
                  iobroker  3123  0.1  2.1 143604 40480 ?        Sl   08:13   0:06 io.vis-inventwo.0
                  iobroker  3144  0.5  2.5 151640 48160 ?        Sl   08:13   0:22 io.modbus.0
                  iobroker  3159  0.5  2.5 152924 49848 ?        Sl   08:13   0:22 io.modbus.1
                  iobroker  7972 82.0  2.5 109464 48176 ?        Sl   09:17   0:00 /usr/bin/node /opt/iobroker/node_modules/iobroker.history/lib/getHistory.js {"id":"0_userdata.0.AMIS.Power","path":"/opt/iobroker/iobroker-data/history/","start":1613679423337,"end":1613722623337,"step":null,"count":300,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":21}
                  pi        7980  0.0  0.0   7360   524 pts/0    R+   09:17   0:00 grep --color=auto io
                  iobroker  7981  0.0  0.8  79040 16400 ?        Rl   09:17   0:00 /usr/bin/node /opt/iobroker/node_modules/iobroker.history/lib/getHistory.js {"id":"0_userdata.0.AMIS.PVPower","path":"/opt/iobroker/iobroker-data/history/","start":1613679423337,"end":1613722623337,"step":null,"count":300,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":21}
                  dh ich muss 2353 abdrehen?
                  BG
                  • HumidorH Humidor
                    @humidor
                    Logisch. Neuer Prozess = Neue PID (process ID)
                    Hau mal alles vom iobroker weg:
                    • HumidorH Humidor
                      Hallo 👍
                      UncleSamU Offline
                      UncleSamU Offline
                      UncleSam
                      @humidor Du bist aber nicht etwa unter Docker?
                      Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
                      ♡-lichen Dank an meine Sponsoren
                      • UncleSamU UncleSam
                        wendy2702W Online
                        wendy2702W Online
                        @unclesam Bei dem Prompt eher nicht, oder:
                        @humidor sagte in (Frage) ioBroker stop - stoppt ioBroker nicht ?:
                        pi@ioBrokerPV:
                        • wendy2702W wendy2702
                          pi@ioBrokerPV:
                          HumidorH Offline
                          HumidorH Offline
                          Humidor
                          @wendy2702 @UncleSam @Thomas-Braun
                          Nein, kein Docker, std. Raspi4
                          sudo killall -u iobroker - stoppt es auch nicht.
                          auch der direkte kill macht einen restart. Cronjob?
                          avahi      330  0.0  0.1   6156  2416 ?        Ss   Feb15   2:31 avahi-daemon: running [ioBrokerPV.local]
                          grafana    552  0.0  1.5 972256 28992 ?        Ssl  Feb15   4:08 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/var/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana cfg:default.paths.plugins=/var/lib/grafana/plugins cfg:default.paths.provisioning=/etc/grafana/provisioning
                          iobroker 10169 24.0  4.7 190896 90444 ?        Ssl  09:29   0:23 iobroker.js-controller
                          iobroker 10187  6.2  3.1 162348 61096 ?        Sl   09:29   0:05 io.admin.0
                          iobroker 10204  1.7  2.5 146972 49920 ?        Sl   09:29   0:01 io.discovery.0
                          iobroker 10219  4.5  2.3 149000 45024 ?        Sl   09:29   0:03 io.info.0
                          iobroker 10325  7.9  2.2 145484 42332 ?        Sl   09:29   0:06 io.kecontact.0
                          iobroker 10743  2.7  2.6 149068 51020 ?        Sl   09:30   0:02 io.mqtt.0
                          iobroker 10758 11.9  2.6 152696 51032 ?        Sl   09:30   0:08 io.web.0
                          iobroker 10776 12.3  4.7 201520 90592 ?        Sl   09:30   0:08 io.javascript.0
                          iobroker 10791  6.6  2.2 146660 43572 ?        Sl   09:30   0:04 io.history.0
                          iobroker 10827  3.5  2.9 148616 56436 ?        Sl   09:30   0:02 io.cloud.0
                          iobroker 10886  4.7  2.6 154880 50608 ?        Sl   09:30   0:02 io.iot.0
                          iobroker 10901  5.4  2.4 152548 46972 ?        Sl   09:30   0:03 io.telegram.0
                          iobroker 10960  9.0  3.4 170008 65676 ?        Sl   09:30   0:04 io.backitup.0
                          iobroker 11039  8.3  2.4 150824 47296 ?        Sl   09:30   0:03 io.shelly.0
                          iobroker 11098  9.6  2.5 153880 48488 ?        Sl   09:30   0:03 io.influxdb.0
                          iobroker 11123  4.0  2.4 135576 47492 ?        Sl   09:30   0:01 io.vis-inventwo.0
                          iobroker 11179  6.9  2.6 148228 51816 ?        Sl   09:30   0:02 io.modbus.0
                          iobroker 11215  7.7  2.7 147260 52200 ?        Sl   09:30   0:02 io.modbus.1
                          iobroker 11405  0.0  2.1 100476 41412 ?        Rl   09:31   0:00 /usr/bin/node /opt/iobroker/node_modules/iobroker.history/lib/getHistory.js {"id":"0_userdata.0.AMIS.Power","path":"/opt/iobroker/iobroker-data/history/","start":1613680279818,"end":1613723479818,"step":null,"count":300,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":48}
                          pi       11414  0.0  0.0   7360   476 pts/0    S+   09:31   0:00 grep --color=auto io
                          pi@ioBrokerPV:/ $ sudo -u iobroker kill -9 10169
                          iobroker 11502 29.1  7.1 222320 137948 ?       Ssl  09:31   0:16 iobroker.js-controller
                          iobroker 11520  8.9  5.3 192728 102004 ?       Sl   09:31   0:05 io.admin.0
                          iobroker 11535  2.9  2.5 145960 49744 ?        Sl   09:31   0:01 io.discovery.0
                          iobroker 11552  8.0  2.3 148488 45376 ?        Sl   09:31   0:03 io.info.0
                          iobroker 11671 12.0  2.1 144616 41300 ?        Sl   09:31   0:05 io.kecontact.0
                          iobroker 12079  4.9  3.0 148512 57980 ?        Sl   09:32   0:01 io.mqtt.0
                          iobroker 12094 16.2  4.1 167072 79320 ?        Sl   09:32   0:05 io.web.0
                          iobroker 12109 18.8  5.1 208616 98716 ?        Sl   09:32   0:06 io.javascript.0
                          iobroker 12126 11.2  2.2 148160 42532 ?        Sl   09:32   0:03 io.history.0
                          iobroker 12141  8.8  2.9 148616 56032 ?        Sl   09:32   0:02 io.cloud.0
                          iobroker 12172 13.1  2.8 152312 54424 ?        Sl   09:32   0:02 io.iot.0
                          iobroker 12194 14.3  2.9 152544 56656 ?        Sl   09:32   0:02 io.telegram.0
                          iobroker 12209 33.1  4.1 168396 79852 ?        Sl   09:32   0:03 io.backitup.0
                          iobroker 12269 56.5  3.0 150316 59316 ?        Sl   09:32   0:02 io.shelly.0
                          iobroker 12285  0.0  1.3  83796 25496 ?        Rl   09:32   0:00 /usr/bin/node /opt/iobroker/node_modules/iobroker.influxdb/main.js 0 info
                          pi       12293  0.0  0.0   7360   512 pts/0    S+   09:32   0:00 grep --color=auto io
                          BG
                          • arteckA Offline
                            arteckA Offline
                            arteck
                            da gabs mal ein BUG dass der iobroker immer neu gestartet wurde
                            • HumidorH Humidor
                              @humidor
                              sudo systemctl stop iobroker
                              Dann muss aber Ruhe sein...
                                @humidor
                                HumidorH Offline
                                HumidorH Offline
                                Humidor
                                @thomas-braun sagte in (Frage) ioBroker stop - stoppt ioBroker nicht ?:
                                gerade probiert, auch damit macht er einen Restart.
                                BG
                                • HumidorH Humidor
                                  HumidorH Offline
                                  HumidorH Offline
                                  Humidor
                                  keine Idee mehr?
                                  BG
                                  • HumidorH Humidor
                                    keine Idee mehr?
                                    @humidor
                                    sudo systemctl disable iobroker
                                    Dann einmal durchstarten.
                                    sudo reboot
                                    Dann schauen ob da noch irgendwelche ioBroker-Prozesse laufen. Eigentlich sollte da dann nichts mehr laufen.
                                    iobroker update
                                    iobroker upgrade self
                                    iobroker upgrade
                                    iobroker fix
                                    iobroker start
                                      @humidor
                                      sudo reboot
                                      iobroker update
                                      iobroker upgrade
                                      iobroker fix
                                      iobroker start
                                      HumidorH Offline
                                      HumidorH Offline
                                      Humidor
                                      @thomas-braun tja, ich verstehe es nicht, nein er stoppt auch damit nicht.
                                      Bildschirmfoto 2021-02-26 um 11.12.23.png Bildschirmfoto 2021-02-26 um 11.12.25.png
                                      BG
                                      UncleSamU 1 Antwort Letzte Antwort
                                      • HumidorH Humidor
                                        UncleSamU Offline
                                        UncleSamU Offline
                                        UncleSam
                                        @humidor Kannst du mal pstree verwenden? Ich möchte wissen, wer der Vater von dem Prozess ist. Bitte ohne irgendeingrep.
                                          HumidorH Offline
                                          HumidorH Offline
                                          Humidor
                                          @unclesam sagte in (Frage) ioBroker stop - stoppt ioBroker nicht ?:
                                          pstree
                                          Morgen!
                                          pi@ioBrokerPV:~ $ pstree
                                          systemd─┬─agetty
                                                  ├─alsactl
                                                  ├─avahi-daemon───avahi-daemon
                                                  ├─bluetoothd
                                                  ├─cron
                                                  ├─dbus-daemon
                                                  ├─dhcpcd
                                                  ├─grafana-server───13*[{grafana-server}]
                                                  ├─hciattach
                                                  ├─influxd───14*[{influxd}]
                                                  ├─iobroker.js-con─┬─io.admin.0───10*[{io.admin.0}]
                                                  │                 ├─io.backitup.0───10*[{io.backitup.0}]
                                                  │                 ├─io.cloud.0───10*[{io.cloud.0}]
                                                  │                 ├─io.discovery.0───10*[{io.discovery.0}]
                                                  │                 ├─io.history.0───10*[{io.history.0}]
                                                  │                 ├─io.influxdb.0───10*[{io.influxdb.0}]
                                                  │                 ├─io.info.0───10*[{io.info.0}]
                                                  │                 ├─io.iot.0───10*[{io.iot.0}]
                                                  │                 ├─io.javascript.0───10*[{io.javascript.0}]
                                                  │                 ├─io.kecontact.0───10*[{io.kecontact.0}]
                                                  │                 ├─io.modbus.0───10*[{io.modbus.0}]
                                                  │                 ├─io.modbus.1───10*[{io.modbus.1}]
                                                  │                 ├─io.mqtt.0───10*[{io.mqtt.0}]
                                                  │                 ├─io.shelly.0───10*[{io.shelly.0}]
                                                  │                 ├─io.telegram.0───10*[{io.telegram.0}]
                                                  │                 ├─io.vis-inventwo───10*[{io.vis-inventwo}]
                                                  │                 ├─io.web.0───10*[{io.web.0}]
                                                  │                 └─10*[{iobroker.js-con}]
                                                  ├─rngd───3*[{rngd}]
                                                  ├─rsyslogd───3*[{rsyslogd}]
                                                  ├─sleep
                                                  ├─sshd───sshd───sshd───bash───pstree
                                                  ├─systemd───(sd-pam)
                                                  ├─systemd-journal
                                                  ├─systemd-logind
                                                  ├─systemd-timesyn───{systemd-timesyn}
                                                  ├─systemd-udevd
                                                  ├─thd
                                                  └─2*[wpa_supplicant]
                                          BG
