  4. Betatester für Backitup 2.0.0 gesucht
    6.5k
293 Beiträge 32 Kommentatoren 60.3k Aufrufe 28 Beobachtet
  • amg_666A amg_666
    @simatec Das mag Zufall sein (??) aber direkt nach Installation fing iot an rumzuzicken:
    iot.0	2021-02-09 20:34:18.029	info	(6049) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    iot.0	2021-02-09 20:34:18.021	info	(6049) terminating
    iot.0	2021-02-09 20:34:18.010	info	(6049) Got terminate signal TERMINATE_YOURSELF
    host.iomaster	2021-02-09 20:34:17.964	info	stopInstance system.adapter.iot.0 (force=false, process=true)
    backitup.0	2021-02-09 20:32:38.868	info	(7146) [ccu] backup was activated at 01:30 every 3 day(s)
    backitup.0	2021-02-09 20:32:38.723	info	(7146) [iobroker] backup was activated at 02:00 every 1 day(s)
    backitup.0	2021-02-09 20:32:38.564	info	(7146) starting. Version 2.0.0-beta.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.20.1, js-controller: 3.2.16
    Ich hab den iot Adapter neu gestartet, der bleibt gelb und sagt (7268) Connection changed: disconnect
    Wenn ich manuell ein backup mit dem Adapter starte, dann läuft das durch bringt aber den Hinweis, dass er history values "created" hat. Ich hab aber im Adapter unter "Was soll gesichert werden" kein Häkchen bei History Daten gesetzt. Ist das so richtig?
    Started iobroker ...
    [DEBUG] [iobroker] - host.iomaster 14170 states saved
    [DEBUG] [iobroker] - host.iomaster 15903 objects saved
    [DEBUG] [iobroker] - done
    [DEBUG] [zigbee] - found zigbee database: zigbee.0
    [DEBUG] [zigbee] - done
    [DEBUG] [javascripts] - done
    [DEBUG] [ftp] - FTP connected.
    [DEBUG] [ftp] - Send iobroker_2021_02_09-20_38_03_backupiobroker.tar.gz
    [ERROR] [ftp] - File "/opt/iobroker/backups/iobroker_2021_02_09-20_38_03_backupiobroker.tar.gz" not found
    [DEBUG] [ftp] - Send zigbee.0_2021_02_09-20_38_26_backupiobroker.tar.gz
    [DEBUG] [ftp] - Send javascripts_2021_02_09-20_38_27_backupiobroker.tar.gz
    [DEBUG] [ftp] - done
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [EXIT] 0
    (das mit dem Error ...file...not found ist ne Macke die ich noch zu lösen versuche, das war aber auch in der letzten stable Version so und muss irgendwie mit der iobroker Installation zusammenhängen (mal läuft das backup, mal tritt der Fehler auf)
    simatecS Offline
    simatecS Offline
    simatec
    #198
    @amg_666
    HistoryHTML und HistoryJSON sind erzeugte Datenpunkte für die VIS u d haben nix mit dem History-Daten des history-Adapters zu tun.
    IOT und Backitup haben nix miteinander zu tun
    Was meinst du mit „not found“
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • E ente34
      @simatec
      Beim IoBroker Restore ist mir noch etwas aufgefallen, trotz "Start all adapters after restore" laufen nach Restore nur admin und backitup. Alle anderen muss ich manuell starten. Js-Controller ?
      C:\Program Files\iobroker\SmartHome1>iobroker -v
      3.2.16
      simatecS Offline
      simatecS Offline
      simatec
      #199
      @ente34
      Teste mal die aktuelle Beta 8. da sollte „iobroker start all“ laufen
      E 1 Antwort Letzte Antwort
      • simatecS simatec
        @amg_666
        amg_666A Offline
        amg_666A Offline
        amg_666
        #200
        @simatec sagte in Betatester für Backitup 2.0.0 gesucht:
        Diese Zeile im Log:
        das iot und backitup nix miteinander zu tun haben ist mir eigentlich auch klar, war nur verwundert, dass der genau nach dem backup ausgestiegen ist. Ich hab nur um sicher zu gehen mal die letzte stable von backitup eingespielt, die iot Instanz ist weiter gelb, liegt also wirklich nicht am backup adapter :-)
        • amg_666A amg_666
          Diese Zeile im Log:
          simatecS Offline
          simatecS Offline
          simatec
          #201
          @amg_666 sagte in Betatester für Backitup 2.0.0 gesucht:
          Diese Zeile im Log:
          Wo genau kommt die Meldung?
          • simatecS simatec
            Diese Zeile im Log:
            amg_666A Offline
            amg_666A Offline
            amg_666
            #202
            Siehe mein Posting etwas weiter oben. Ich starte das backup, er legt lokal die backups für iobroker, zigbee und javascript an, macht dann einen ftp-connect und stellt dann fest dass die iobroker backupdatei nicht vorhanden ist.
            Wenn ich den Raspi durchstarte (sudo shutdown -r 0) und der frisch hochgefahren ist, dann funktioniert backitup ohne Probleme und legt auch die backupiobroker.tar.gz an
            • simatecS simatec
              @ente34
              ente34
              #203
              @simatec
              Adapter werden immer nocht nicht gestartet.
              Beim Restore habe ich immer noch inkonsistente Zustände bei dem Scripten, meistens liegen im Filesystem mehr als im json.
              Vielleicht sollte man mal folgendes versuchen:
              • IoBroker Restore
                Wenn der javascript Adapter die Scripte ins Dateisystem spiegelt, dann bei bei inaktivem
                javascript Adapter den Script-Pfad komplett löschen
                (Scripte kommen beim Restore allein durch die json Datei)
              • javascript Restore
                Auch zuerst den Script-Pfad komplett löschen, sonst bleiben auch "alte" Scripts (nicht im
                Restore) stehen
                Es sei denn, das Verhalten wäre gewünscht, dann wäre es aber kein echter Restore, sondern
                mehr ein Merge alt mit neu.
              • E ente34
                @simatec
                • IoBroker Restore
                  Restore) stehen
                simatecS Offline
                simatecS Offline
                simatec
                #204
                @ente34 Zeige mal bitte die Konfiguration deines Javascript-Adapters?
                • simatecS simatec
                  ente34
                  #205
                  @simatec
                  Hier:
                  und hier:
                  • lobomauL lobomau
                    https://github.com/simatec/ioBroker.backitup.git
                    Moin, ich habe mir mal backitup installiert. finde ich ganz sinnvoll für meinen Pi3 als slave.
                    Zuerst habe ich normal 1.8.5 installiert und ein backup auf google drive gesichert.
                    Dann habe ich auf 2.0.0.beta geupdatet. Hier habe ich das Problem, dass der Adapter immer sagt ich solle erst sichern, dann wird der Bachup Knopf jedoch grau. Kann ich immer und immer wiederholen.
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #206
                    @lobomau
                    Konntest du den Fehler mit dem speichern durch eine Neuinstallation beheben?
                    • simatecS simatec
                      @lobomau
                      simatecS Offline
                      simatecS Offline
                      simatec
                      #207
                      Ich würde gerne in den nächsten Tagen die 2.0.0 ins latest geben.
                      Gibt es noch Fehler die aufgefallen sind?
                      • JackDanielJ Online
                        JackDanielJ Online
                        JackDaniel
                        #208
                        mir ist noch eine kleinigkeit bei der benachrichtigung aufgefallen, zwischen erstellt und sollte ein leerzeichen sein.
                        Carpe diem
                        • JackDanielJ JackDaniel
                          simatecS Offline
                          simatecS Offline
                          simatec
                          #209
                          @jackdaniel Danke für den Hinweis ...
                          • simatecS Offline
                            simatecS Offline
                            simatec
                            #210
                            Ab sofort steht die Version 2.0.0-beta.10 auf Github zur Verfügung.
                            amg_666A JackDanielJ liv-in-skyL 3 Antworten Letzte Antwort
                            • simatecS simatec
                              amg_666A Offline
                              amg_666A Offline
                              amg_666
                              #211
                              @simatec Das Upgrade hat gefühlt "ewig" gedauert, lief aber ohne Probleme durch.
                              1 Master, 2*Slave, alle auf js-controller 3.2.16 und node.js v12.20.1
                              Manuell angestoßenes Backup (iobroker, homematic, javascript und zigbee) lief problemlos durch inkl Sicherung auf ein NAS per FTP.
                              • simatecS simatec
                                JackDanielJ Online
                                JackDanielJ Online
                                JackDaniel
                                #212
                                @simatec
                                danke das mit dem fehler in der benachrichtigung ist geschichte 👍
                                Carpe diem
                                • simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #213
                                  Ab sofort steht die Version 2.0.0-beta.11 auf Github zur Verfügung.
                                  • simatecS simatec
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    #214
                                    @simatec
                                    hi.
                                    wollt mal fragen- wenn tägliches backup (1) eingestellt ist, hatte ich heute morgen diese anzeige
                                    warum wird als nächstes erst morgen angezeigt
                                    ich bin jetzt in die settings der beiden ersten instanzen gegangen und habe die zeit um eine minute verändert - jetzt stimmt die zeit im dp wieder. es wird heute eingetragen ? warum stand heute morgen ein falsches datum drin?
                                    und noch eine weitere frage:
                                    wenn ein fehler auftritt und ich den dann im setting bereinige (z.b. falsches cifs eingegeben), bleiben die datenpunkte stehen
                                    obwohl ja die instanz neugestartet wurde - ich muss dann erst die datenpunkte löschen, damit die wieder überschrieben/aktualisiert werden oder ein backup starten - doof für mein tabellen script - könntest du beim adapterstart die beiden datenpunkte aktualisieren?
                                    und wäre es möglich auch hier einen [ERROR] auszugeben - mein script bleibt dort mit der anzeige stehen und ich muss erst im log nachsehen, was los ist aber dieses könnte schön überschrieben sein.
                                    momentan sieht es so aus (ohne fehler) - mit fehler bleit es beim letzten erfolgreichen part stehen - leider sehe ich nicht warum
                                    • liv-in-skyL liv-in-sky
                                      @simatec
                                      hi.
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #215
                                      @liv-in-sky sagte in Betatester für Backitup 2.0.0 gesucht:
                                      Welche Objekte meinst du genau?
                                      • simatecS simatec
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        #216
                                        @simatec
                                        output.line
                                        oneClick.iobroker
                                        • simatecS simatec
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          #217
                                          @simatec
                                          hier mal mit fehler - cifs pfad falsch
                                          tabelle bleibt hier stehen
                                          fehler nur im log
                                          im moment kann behelfe ich mir mit der zeit des startes - wenn diese über 15 min ist -wird es rot
