  2. Русский
  3. ioBroker
  4. ioBroker установка и конфигурация
  5. Инсталляция под Linux
Geplant Angeheftet Gesperrt Verschoben ioBroker установка и конфигурация
256 Beiträge 29 Kommentatoren 133.8k Aufrufe
  • BluefoxB
    #234
    @Vlad_k:
    ставлю брокер на очередную плату от планшета на процике Allwinner A33, сам брокер встал работает но при установке Javascript драйвера вываливает ошибки:
    ! android@localhost:/opt/iobroker$ sudo npm install iobroker.javascript –production --prefix "/opt/iobroker"
    ! npm WARN engine form-data@2.0.0: wanted: {"node":">= 0.12"} (current: {"node":"0.10.47","npm":"2.15.1"})
    ! npm ERR! tar.unpack untar error /root/.npm/har-validator/2.0.6/package.tgz
    ! npm ERR! tar.unpack untar error /root/.npm/node-uuid/1.4.7/package.tgz
    ! npm ERR! tar.unpack untar error /root/.npm/hawk/3.1.3/package.tgz
    ! npm ERR! tar.unpack untar error /root/.npm/http-signature/1.1.1/package.tgz
    ! npm ERR! tar.unpack untar error /root/.npm/delayed-stream/1.0.0/package.tgz
    ! npm ERR! tar.unpack untar error /root/.npm/tough-cookie/2.3.1/package.tgz
    ! npm ERR! tar.unpack untar error /root/.npm/qs/6.2.1/package.tgz
    ! npm ERR! tar.unpack untar error /root/.npm/cron-parser/1.1.0/package.tgz
    ! npm ERR! tar.unpack untar error /root/.npm/mime-db/1.24.0/package.tgz
    ! npm ERR! tar.unpack untar error /root/.npm/asynckit/0.4.0/package.tgz
    ! npm ERR! tar.unpack untar error /root/.npm/readable-stream/2.0.6/package.tgz
    ! npm ERR! Linux 3.4.39
    ! npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.javascript" "--production" "--prefix" "/opt/iobroker"
    ! npm ERR! node v0.10.47
    ! npm ERR! npm v2.15.1
    ! npm ERR! code ENOSPC
    ! npm ERR! errno 54
    ! npm ERR! nospc ENOSPC, write
    ! npm ERR! nospc This is most likely not a problem with npm itself
    ! npm ERR! nospc and is related to insufficient space on your system.
    ! npm ERR! Please include the following file with any support request:
    ! npm ERR! /opt/iobroker/npm-debug.log
    чем полечить? `
    ENOSPC => error: no space
    Так что полечи новой карточкой
    • V
      V
      Vlad_k
      #235
      @Bluefox:
      Так что полечи новой карточкой `
      linux ставил на системную флешку забыл про сд карту… но подчистил место и все зашуршало.
      ПС только счас заметил при одинаковом кол-ве работающих драйверов, линукс брокер жрет всего 100 метров а под виндой 361 оперативы, почему такая разница большая?
      и еще хотелка появилась, надо сделать экспорт списка установленных драйверов, для импорта и установки на чистую систему
      • H
        H
        Haus
        #236
        @Vlad_k:
        @Bluefox:
        и еще хотелка появилась, надо сделать экспорт списка установленных драйверов, для импорта и установки на чистую систему `
        Копируешь папку iobroker-data и все твои наработки, драйвера в новой системе.
        Если смотришь в админе то это только ioBroker данные, если перезапустишь iob ситуация может изменится.
        js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
        admin: 3.6.0
        javascript: 4.1.10
        web: 2.4.1 vis: 1.1.10
        cloud: 2.6.2
        Server: DELL FX170 / linux: Debian 9.5 Stretch
        Adapter: MegaD-2561, Mega-ES…
        • R
          R
          radon
          #237
          Ставил на виртуальные машины:
          • на Debian так и не встал, жаловался то на curl, то на https, в конце концов что-то его не устроило в python-rpi.gpio
          т.е. по сути до iobroker так и не дошло.
          • На ubuntu встало без проблем, что на версию с графическим интерфейсом. что на версию админ (хотя тут в консоли что-то страшное с кодировкой) iobroker заработал нормально
          • На Windows встал тоже без проблем.
          Вопрос:
          Как поставить на Debian? какого пакета не хватает?
          Образ брал с официального сайта, DVD
          • H
            H
            Haus
            #238
            @radon:
            Вопрос:
            Образ брал с официального сайта, DVD `
            Голый Debian всё под root
            apt-get update
            apt-get upgrade
            apt-get install curl build-essential
            curl -sL https://deb.nodesource.com/setup_4.x | bash -
            apt-get install -y nodejs
            mkdir /opt/iobroker
            cd /opt/iobroker
            npm install iobroker --unsafe-perm
            как то так
            admin: 3.6.0
            javascript: 4.1.10
            cloud: 2.6.2
            • E
              E
              evgeny_nd
              #239
              @Haus:
              @radon:
              Вопрос:
              apt-get update
              apt-get upgrade
              mkdir /opt/iobroker
              cd /opt/iobroker
              как то так `
              Подтверждаю что на Debian это рабочая инструкция, за исключением того что нужно добавить еще одну строку до "npm istall iobroker…"
              ln -s /usr/bin/nodejs /usr/bin/node
              и было бы хорошо, если бы это все выложили на оф. сайт (русскоязычный) в разделе установка.
              • BluefoxB
                #240
                http://www.iobroker.net/docu/?page_id=5637&lang=ru
                • E
                  E
                  evgeny_nd
                  #241
                  @Bluefox:
                  http://www.iobroker.net/docu/?page_id=5637&lang=ru `
                  Спасибо.
                  • L
                    L
                    lexa
                    #242
                    Коллеги, что-то не заводится по такой простой инструкции. После запуска порт не слушает, и вебка не открывается соответственно:
                    root@iobroker:/# ps xa
                      PID TTY      STAT   TIME COMMAND
                        1 ?        Ss     0:00 init -z
                        2 ?        S      0:00 [kthreadd/108]
                        3 ?        S      0:00 [khelper/108]
                       80 ?        Ssl    0:04 iobroker.js-controller
                       90 ?        Sl     0:05 /usr/bin/nodejs /opt/iobroker/node_modules/iobroker.admin/admin.js 0 info
                      419 ?        Zs     0:00 [bash] <defunct>6790 ?        Ss     0:00 vzctl: pts/0
                     6791 pts/0    Ss     0:00 -bash
                     6803 pts/0    R+     0:00 ps xa</defunct>
                    root@iobroker:/# netstat -plant
                    Active Internet connections (servers and established)
                    Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
                    tcp        0      1 192.168.0.108:56188     127.0.0.1:9001          SYN_SENT    90/nodejs
                    tcp        0      1 192.168.0.108:56240     127.0.0.1:9001          SYN_SENT    90/nodejs
                    tcp6       0      0 :::9000                 :::*                    LISTEN      80/iobroker.js-cont
                    tcp6       0      0 :::9001                 :::*                    LISTEN      80/iobroker.js-cont
                    Ubuntu 16.04.1 LTS
                    • BluefoxB
                      #243
                      @lexa:
                          1 ?        Ss     0:00 init -z
                      Ubuntu 16.04.1 LTS `
                      Node версия? Странно, что admin 2 раза с 9001 содиняется.
                      А что за платформа?
                      И что кажет netstat -n -a
                      • E
                        E
                        evgeny_nd
                        #244
                        @lexa:
                            1 ?        Ss     0:00 init -z
                        На Ubuntu можно попробовать NPM через менеджер пакетов установить.
                        И еще в идеале, если вы включите возможность зайти под именем root.
                        И залогинится в консоль и уже от туда все установить под root.
                        У меня через sudo вставало криво на Linux Mint.
                        • L
                          L
                          lexa
                          #245
                          root@iobroker:~# netstat -n -a
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
                          tcp        0      1 192.168.0.108:32900     127.0.0.1:9001          SYN_SENT
                          tcp        0      1 192.168.0.108:32862     127.0.0.1:9001          SYN_SENT
                          tcp        0      0 192.168.0.108:22        192.168.0.1:51673     ESTABLISHED
                          tcp        0      1 192.168.0.108:32882     127.0.0.1:9001          SYN_SENT
                          tcp6       0      0 :::22                   :::*                    LISTEN
                          Active UNIX domain sockets (servers and established)
                          Proto RefCnt Flags       Type       State         I-Node   Path
                          unix  3      [ ]         STREAM     CONNECTED     1914048268
                          unix  3      [ ]         STREAM     CONNECTED     1914048267
                          root@iobroker:~# node -v
                          v4.7.0
                          это openvz контейнер с шаблонной Ubuntu Server - ubuntu-16.04-x86_64
                          Установка через apt-get вываливает кучу зависимостей у node* и решает их. Сейчас подниму новый контейнер.
                          • L
                            L
                            lexa
                            #246
                            Мда, на новом контейнере еще хуже. node и npm через apt-get поставил.
                            iobroker не ставится:
                            > iobroker@0.7.1 install /opt/iobroker/node_modules/iobroker
                            > node lib/setup.js
                            sh: 1: node: not found
                            npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
                            npm WARN iobroker No description
                            npm WARN iobroker No repository field.
                            npm WARN iobroker No README data
                            npm WARN iobroker No license field.
                            npm ERR! Linux 2.6.32-29-pve
                            npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker" "--unsafe-perm"
                            npm ERR! node v4.2.6
                            npm ERR! npm  v3.5.2
                            npm ERR! file sh
                            npm ERR! code ELIFECYCLE
                            npm ERR! errno ENOENT
                            npm ERR! syscall spawn
                            npm ERR! iobroker@0.7.1 install: `node lib/setup.js`
                            npm ERR! spawn ENOENT
                            npm ERR!
                            npm ERR! Failed at the iobroker@0.7.1 install script 'node lib/setup.js'.
                            npm ERR! Make sure you have the latest version of node.js and npm installed.
                            npm ERR! If you do, this is most likely a problem with the iobroker package,
                            npm ERR! not with npm itself.
                            npm ERR! Tell the author that this fails on your system:
                            npm ERR!     node lib/setup.js
                            npm ERR! You can get information on how to open an issue for this project with:
                            npm ERR!     npm bugs iobroker
                            npm ERR! Or if that isn't available, you can get their info via:
                            npm ERR!     npm owner ls iobroker
                            npm ERR! There is likely additional logging output above.
                            npm 3.5.2
                            node v4.2.6
                            • L
                              L
                              lexa
                              #247
                              взял еще один контейнер, зашел в него по ssh и поставил по инструкции:
                              точно такой же эффект, как в первом посте:
                              Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
                              iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
                              iobroker@0.7.1 node_modules/iobroker
                              └── yargs@4.8.1 (get-caller-file@1.0.2, lodash.assign@4.2.0, decamelize@1.2.0, y18n@3.2.1, which-module@1.0.0, set-blocking@2.0.0, window-size@0.2.0, require-main-filename@1.0.1, require-directory@2.1.1, yargs-parser@2.4.1, os-locale@1.4.0, cliui@3.2.0, string-width@1.0.2, read-pkg-up@1.0.1)
                              только вот порт не открыт:
                              ` > root@iobroker3:/# netstat -na
                              STREAM CONNECTED 1917940775
                              STREAM CONNECTED 1917940774 `
                              ` > root@iobroker3:/# node -v
                              v4.7.0 `
                              • L
                                L
                                lexa
                                #248
                                Короче на дебиане никак не заводится.
                                За то установилось на centos6, вроде без проблем, пробую)
                                • R
                                  R
                                  radon
                                  #249
                                  @lexa:
                                  За то установилось на centos6, вроде без проблем, пробую) `
                                  У меня проблема с debianom была в том что скачан был дистрибутив CD 200 с чем-то мегов, там небыло половины нужных пакетов потому ничего не ставилось, после установки с DVD всё стало нормально
                                  • L
                                    L
                                    lexa
                                    #250
                                    @radon:
                                    У меня проблема с debianom была в том что скачан был дистрибутив CD 200 с чем-то мегов, там небыло половины нужных пакетов потому ничего не ставилось, после установки с DVD всё стало нормально `
                                    да, это почти "minimal" дистриб, пакетов там мало (wget, curl, mc не установлены). Почему тогда в зависимостях не вылезает?
                                    Ну в любом случае, на таком же минимальном дистрибутиве в centos запустилось без проблем.
                                    • S
                                      S
                                      sscorpio
                                      #251
                                      Нужна подсказка коллективного разума.
                                      Ставлю на CentOS 7
                                      node -v
                                      v6.10.3
                                      npm -v
                                      3.10.10
                                      Вот лог установки
                                      ! sudo npm install iobroker –unsafe-perm
                                      ! > iobroker@1.0.0 install /opt/iobroker/node_modules/iobroker
                                      ! > node lib/setup.js
                                      ! npm install iobroker.discovery --production --prefix /opt/iobroker
                                      ! In file included from ../src/dns_sd.cpp:1:0:
                                      ! ../src/mdns.hpp:32:20: фатальная ошибка: dns_sd.h: Нет такого файла или каталога
                                      ! #include <dns_sd.h>^
                                      ! компиляция прервана.
                                      ! make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Ошибка 1
                                      ! gyp ERR! build error
                                      ! gyp ERR! stack Error: make failed with exit code: 2
                                      ! gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules.bundled/node-gyp/lib/build.js:276:23)
                                      ! gyp ERR! stack at emitTwo (events.js:106:13)
                                      ! gyp ERR! stack at ChildProcess.emit (events.js:191:7)
                                      ! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
                                      ! gyp ERR! System Linux 3.10.0-514.26.2.el7.x86_64
                                      ! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                      ! gyp ERR! cwd /opt/iobroker/node_modules/mdns
                                      ! gyp ERR! node -v v6.10.3
                                      ! gyp ERR! node-gyp -v v3.4.0
                                      ! gyp ERR! not ok
                                      ! npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
                                      ! npm WARN iobroker No description
                                      ! npm WARN iobroker No repository field.
                                      ! npm WARN iobroker No README data
                                      ! npm WARN iobroker No license field.
                                      ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 (node_modules/mdns):
                                      ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 install: node-gyp rebuild
                                      ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                      ! npm install iobroker.admin –production --prefix /opt/iobroker
                                      ! gyp ERR! not ok
                                      ! npm install iobroker.js-controller –production --prefix /opt/iobroker
                                      ! gyp ERR! not ok
                                      ! Write "./iobroker start" to start the ioBroker
                                      ! /opt/iobroker/node_modules/iobroker/lib/../install/linux/install.sh: line 61: update-rc.d: команда не найдена
                                      ! : Нет такого файла или каталога
                                      ! Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
                                      ! iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
                                      ! /opt/iobroker
                                      ! └─┬ iobroker@1.0.0
                                      ! └─┬ yargs@7.1.0
                                      ! ├── camelcase@3.0.0
                                      ! ├─┬ cliui@3.2.0
                                      ! │ ├─┬ strip-ansi@3.0.1
                                      ! │ │ └── ansi-regex@2.1.1
                                      ! │ └── wrap-ansi@2.1.0
                                      ! ├── decamelize@1.2.0
                                      ! ├── get-caller-file@1.0.2
                                      ! ├─┬ os-locale@1.4.0
                                      ! │ └─┬ lcid@1.0.0
                                      ! │ └── invert-kv@1.0.0
                                      ! ├─┬ read-pkg-up@1.0.1
                                      ! │ ├─┬ find-up@1.1.2
                                      ! │ │ ├── path-exists@2.1.0
                                      ! │ │ └─┬ pinkie-promise@2.0.1
                                      ! │ │ └── pinkie@2.0.4
                                      ! │ └─┬ read-pkg@1.1.0
                                      ! │ ├─┬ load-json-file@1.1.0
                                      ! │ │ ├── graceful-fs@4.1.11
                                      ! │ │ ├─┬ parse-json@2.2.0
                                      ! │ │ │ └─┬ error-ex@1.3.1
                                      ! │ │ │ └── is-arrayish@0.2.1
                                      ! │ │ ├── pify@2.3.0
                                      ! │ │ └─┬ strip-bom@2.0.0
                                      ! │ │ └── is-utf8@0.2.1
                                      ! │ ├─┬ normalize-package-data@2.4.0
                                      ! │ │ ├── hosted-git-info@2.5.0
                                      ! │ │ ├─┬ is-builtin-module@1.0.0
                                      ! │ │ │ └── builtin-modules@1.1.1
                                      ! │ │ ├── semver@5.3.0
                                      ! │ │ └─┬ validate-npm-package-license@3.0.1
                                      ! │ │ ├─┬ spdx-correct@1.0.2
                                      ! │ │ │ └── spdx-license-ids@1.2.2
                                      ! │ │ └── spdx-expression-parse@1.0.4
                                      ! │ └── path-type@1.1.0
                                      ! ├── require-directory@2.1.1
                                      ! ├── require-main-filename@1.0.1
                                      ! ├── set-blocking@2.0.0
                                      ! ├─┬ string-width@1.0.2
                                      ! │ ├── code-point-at@1.1.0
                                      ! │ └─┬ is-fullwidth-code-point@1.0.0
                                      ! │ └── number-is-nan@1.0.1
                                      ! ├── which-module@1.0.0
                                      ! ├── y18n@3.2.1
                                      ! └── yargs-parser@5.0.0
                                      ! npm WARN iobroker No license field.</dns_sd.h></dns_sd.h></dns_sd.h>
                                      чего не хватает ?
                                      как установить ?
                                      • P
                                        P
                                        Pooh
                                        #252
                                        Не знает чем компилировать?
                                        перешли в целевую папку?
                                        на дебианообразных:
                                        apt-get install build-essential libavahi-compat-libdnssd-dev
                                        на центось тоже есть что-то наверное….
                                        https://play.google.com/store/apps/details?id=com.roy.royclub - код: UMI201155
                                        https://play.google.com/store/apps/details?id=com.blockchainvault - код приглашения: Freepooh
                                        https://play.google.com/store/apps/details?id=games.bee.app - код приглашения: freepooh
                                        https://www.timestope.com/freepooh - witness code: freepooh
                                        • S
                                          S
                                          sscorpio
                                          #253
                                          @Pooh:
                                          не дебианообразных:
                                          по центось тоже есть что-то наверное…. `
                                          с компиляцией всё в порядке.
                                          make отрабатывает нормально
                                          g++ так же в системе присутствует.
                                          посмотрите лог - там нет ругани на них.
                                          84.2k
