  4. [Gelöst] Zigbee Adapter bleibt gelb
44 Beiträge 2 Kommentatoren 5.5k Aufrufe 2 Beobachtet
  • Masterg 23M Masterg 23
    Der Adapter ist jetzt auf 1.4.2 jedoch bleibt er bei gelb stehen.
    Ich bekomme den Adapter einfach nicht mehr zum laufen.
    @masterg-23
    Bitte keine Screenshots von Text Files.
    Masterg 23M 1 Antwort Letzte Antwort
      @masterg-23
      Masterg 23M Offline
      Masterg 23M Offline
      Masterg 23
      schrieb am zuletzt editiert von Masterg 23
      zigbee.0	2021-02-04 15:35:01.215	error	at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8270:22)
      zigbee.0	2021-02-04 15:35:01.215	error	at Zigbee.emit (events.js:314:20)
      zigbee.0	2021-02-04 15:35:01.215	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:465:41)
      zigbee.0	2021-02-04 15:35:01.215	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:306:20)
      zigbee.0	2021-02-04 15:35:01.215	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:189:42)
      zigbee.0	2021-02-04 15:35:01.215	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:180:43)
      zigbee.0	2021-02-04 15:35:01.215	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:203:49)
      zigbee.0	2021-02-04 15:35:01.215	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:255:31)
      zigbee.0	2021-02-04 15:35:01.215	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:236:16)
      zigbee.0	2021-02-04 15:35:01.215	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:216:55)
      zigbee.0	2021-02-04 15:35:01.215	error	(17924) TypeError: Cannot read property 'getEntries' of null
      zigbee.0	2021-02-04 15:35:01.212	error	(17924) unhandled promise rejection: Cannot read property 'getEntries' of null
      Unhandled	2021-02-04 15:35:01.212	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0	2021-02-04 15:35:01.211	info	(17924) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0	2021-02-04 15:35:01.210	info	(17924) terminating
      zigbee.0	2021-02-04 15:35:01.209	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:310:33))
      zigbee.0	2021-02-04 15:35:01.209	error	at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:202:16)
      zigbee.0	2021-02-04 15:35:01.209	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:23:12)
      zigbee.0	2021-02-04 15:35:01.209	error	at new Promise (<anonymous>)
      zigbee.0	2021-02-04 15:35:01.209	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:27:71
      zigbee.0	2021-02-04 15:35:01.209	error	at Generator.next (<anonymous>)
      zigbee.0	2021-02-04 15:35:01.209	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:203:18)
      zigbee.0	2021-02-04 15:35:01.209	error	at Controller.databaseSave (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:222:45)
      zigbee.0	2021-02-04 15:35:01.209	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:88:15)
      zigbee.0	2021-02-04 15:35:01.209	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:55)
      zigbee.0	2021-02-04 15:35:01.209	error	(17924) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
      zigbee.0	2021-02-04 15:35:01.206	info	(17924) Zigbee: disabling joining new devices.
      zigbee.0	2021-02-04 15:35:01.201	info	(17924) cleaned everything up...
      zigbee.0	2021-02-04 15:35:01.200	info	(17924) Got terminate signal TERMINATE_YOURSELF
      host.raspberrypi	2021-02-04 15:35:01.192	info	stopInstance system.adapter.zigbee.0 send kill signal
      host.raspberrypi	2021-02-04 15:35:01.189	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
        @masterg-23
        Deine Zeitzone scheint auch falsch zu sein.
        date && date -u
          @masterg-23
          date && date -u
          Masterg 23M Offline
          Masterg 23M Offline
          Masterg 23
          @thomas-braun said in Zigbee Adapter bleibt gelb:
          @masterg-23
          date && date -u
          jap habs korrigiert danke.
          Ist der Stick so mist und zickt so viel rum? Ist es besser auf einen besseren Zigbee Stick zu setzen? Ich hab den CC2531
            @masterg-23
            date && date -u
            @masterg-23
            Der Stick ist dafür bekannt nicht gerade ein Powerhorse zu sein.
            Ausgabe von
            date && date -u
            Masterg 23M 2 Antworten Letzte Antwort
              @masterg-23
              Ausgabe von
              date && date -u
              Masterg 23M Offline
              Masterg 23M Offline
              Masterg 23
              date && date -u
              pi@raspberrypi:~ $ sudo timedatectl set-timezone Europe/Berlin
              pi@raspberrypi:~ $ date && date -u
              Do 4. Feb 16:41:54 CET 2021
              Do 4. Feb 15:41:54 UTC 2021
              pi@raspberrypi:~ $
                @masterg-23
                Ausgabe von
                date && date -u
                Masterg 23M Offline
                Masterg 23M Offline
                Masterg 23
                @thomas-braun hast du eine Idee was ich noch ausprobieren kann?
                  @masterg-23
                  Nein, keine Idee mehr.
                    @masterg-23
                    Masterg 23M Offline
                    Masterg 23M Offline
                    Masterg 23
                    @masterg-23
                    Ok trotzdem vielen Dank für deine Zeit.
                    Welchen Zigbee Stick würdest du empfehlen? Der CC26X2R1 soll gut sein laut dem YT Kanal haus-automatisierung.com
                      @masterg-23
                      @masterg-23
                      Ja, das ist glaube ich im Moment 'state-of-the-art' im Zigbee-Bereich.
                        @masterg-23
                        Masterg 23M Offline
                        Masterg 23M Offline
                        Masterg 23
                        Ich habe es endlich lösen können. In einem anderen Thread habe ich gelesen, dass es davon gesprochen wurde, dass man ein USB Kabel dazwischen schalten sollte und den Stick nicht direkt in Pi betreiben sollte. Jetzt funktioniert der Adapter UND der Bewegungsmelder liefert nun alle Werte (Batterie, Temperatur). Diese Werte konnte ich vorher nicht auslesen.
                        EDIT: Das geile ist, dass der BWM jetzt instant reagiert. Das war vorher nicht der Fall. Der BWM hat immer mit 2 Sekunden Verzögerung reagiert, seitdem ich den mit ioBroker betreibe. Ich bin gerade so happy :)
                        Vielen Dank noch einmal an @Thomas-Braun für deine Zeit.
