Blink Camera System
blink4home.0 2021-01-07 15:30:37.514 warn (11932) Terminated (UNCAUGHT_EXCEPTION): Without reason blink4home.0 2021-01-07 15:30:36.509 error at internal/main/run_main_module.js:17:47 blink4home.0 2021-01-07 15:30:36.509 error at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12) blink4home.0 2021-01-07 15:30:36.509 error at Function.Module._load (internal/modules/cjs/loader.js:708:14) blink4home.0 2021-01-07 15:30:36.509 error at Module.load (internal/modules/cjs/loader.js:863:32) blink4home.0 2021-01-07 15:30:36.509 error at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10) blink4home.0 2021-01-07 15:30:36.509 error at Module._compile (internal/modules/cjs/loader.js:999:30) blink4home.0 2021-01-07 15:30:36.509 error at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.blink4home/main.js:235:2) blink4home.0 2021-01-07 15:30:36.509 error at new Blink4home (/opt/iobroker/node_modules/iobroker.blink4home/main.js:24:12) blink4home.0 2021-01-07 15:30:36.509 error (11932) TypeError: Cannot read property 'debug' of undefined blink4home.0 2021-01-07 15:30:36.505 error (11932) uncaught exception: Cannot read property 'debug' of undefined blink4home.0 2021-01-07 15:30:02.943 warn (11898) Terminated (UNCAUGHT_EXCEPTION): Without reason blink4home.0 2021-01-07 15:30:01.941 error at internal/main/run_main_module.js:17:47 blink4home.0 2021-01-07 15:30:01.941 error at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12) blink4home.0 2021-01-07 15:30:01.941 error at Function.Module._load (internal/modules/cjs/loader.js:708:14) blink4home.0 2021-01-07 15:30:01.941 error at Module.load (internal/modules/cjs/loader.js:863:32) blink4home.0 2021-01-07 15:30:01.941 error at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10) blink4home.0 2021-01-07 15:30:01.941 error at Module._compile (internal/modules/cjs/loader.js:999:30) blink4home.0 2021-01-07 15:30:01.941 error at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.blink4home/main.js:235:2) blink4home.0 2021-01-07 15:30:01.941 error at new Blink4home (/opt/iobroker/node_modules/iobroker.blink4home/main.js:24:12) blink4home.0 2021-01-07 15:30:01.941 error (11898) TypeError: Cannot read property 'debug' of undefined blink4home.0 2021-01-07 15:30:01.937 error (11898) uncaught exception: Cannot read property 'debug' of undefined blink4home.0 2021-01-07 15:29:29.661 info (11831) starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.blink4home, node: v12.20.0, js-controller: 3.1.6 blink4home.0 2021-01-07 15:29:29.583 warn (11831) Terminated (UNCAUGHT_EXCEPTION): Without reasonIch bekomme folgenden Fehler hat jemand eine Idee?
@JayR
Blink4home funktioniert noch nicht, seitdem die Verschlüsselungsmethode geändert wurde.
@JayR
Nur zur Info:
Seit kurzem (Dank sei @apollon77 !!! ) kann man das Blink System über den Alexa2 Adapter und den textCommand Befehl steuern. Ich verwende nur aktivieren/deaktivieren in einem Blockly und das klappt ganz gut.
Nur zur Info:
Ich brauche dies hier nicht zu installieren mehr? Bin davor immer zurück geschreckt, dies hier durchzuführen. Kannst du mal da ein Beispiel zeigen, wie es jetzt gesteuert wird.
In den geschwärzten Bereich kommt die PIN zum deaktivieren rein (zB "eins zwei drei vier")
Alexa fordert zwar bei der Deaktivierung zur Eingabe des Pins auf, was man aber nicht beantworten muss
@albert-k
Wo im Alexa Adapter finde ich denn den entsprechenden State?Interpretiere ich dein Blockly richtig, dass du deine Kamera mit Sprache de- und aktivierst? Anstelle dessen kann ich ja auch einen An- und Abwesenheitsstate nehmen?
- Bei jedem Echo Gerät unter Commands, textCommand
- Als Trigger kannst Du natürlich einen Anwesenheits Status nehmen. Ich habs in meinem Blockly nur schnell auf ein VIS Schaltelement gelegt zum testen
- steuern geht allerdings nur über Spracheingabe bei Blink. deshalb ist der neue textCommand Befehl ja so toll, das löst mir einige Probleme die ich mit Alexa hatte.
@albert-k
Verstehe ich dass dann korrekt, dass wenn der Trigger (welcher auch immer) aktiviert wird, aktiviert sich die Kamera über den textCommand?
Welcher Befehl muss denn genau enthalten sein? "sag Bllink ... aktivieren"?- Richtig
- genau so wie es in meinem Blockly steht, wobei "Aussenkameras" der Name meines Blink Systems ist (das muss also entsprechend dem System Namen in Deiner Blink App oder der Alexa App angepasst werden)
Die möglichen Sprachbefehle kann man auch im Alexa Blink Skill nachsehen.
- Richtig
Ei, dann werde ich morgen mal ne Blockly basteln...
Ähm. der Name vom Blinksystem? Du meinst den Namen der jeweiligen Kamera oder der des Sync-Moduls? Der Kamera nehme ich an?
In meinem Blockly schalte ich das System, also alle Kameras die mit dem Sync Modul verbunden sind. Einzeln geht aber glaube ich auch. Musst Du im Skill nachsehen.
Aktivieren nach Anwesenheit funktioniert prima.
Blockly ist, bis auf den Trigger identisch mit deinem. Danke für den Tipp. Jetzt mache ich noch die Zeitsteuerung.
Plan ist, wie weiter oben im Beitrag schon mal erwähnt, dass trotz Anwesenheit true, ab 23 Uhr das System wieder aktiviert werden soll.
Das mache ich ja am besten im selben Blockly. Wie könnte dann der weitere Aufbau aussehen? Bin da leider noch nicht tief genug drin um von alleine drauf zu kommen<xml xmlns="https://developers.google.com/blockly/xml"> <block type="on_ext" id="]#+6zkIh:u;)}kYFH/F=" x="-812" y="-512"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="O8C-SG3qcTRSy.t:x@~I"> <field name="oid">tr-064.0.devices.Davids-iPhone.active</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="2wEz;@;p_Og*M0V07obY"> <mutation elseif="1"></mutation> <value name="IF0"> <block type="logic_compare" id="GX#c*l+e;{tAo)i*5x:|"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="k1TEs6QDMnrf(17?vT8d"> <field name="ATTR">val</field> <field name="OID">tr-064.0.devices.Davids-iPhone.active</field> </block> </value> <value name="B"> <block type="logic_boolean" id="f|J3PMU5d%F:4%;|K]A1"> <field name="BOOL">FALSE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="Ulvg6{XK}A]WX`z{jd80"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alexa2.0.Echo-Devices.G2A0P3077474013G.Commands.textCommand</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="J+dODeY8}2HH?nY}PUWa"> <field name="TEXT">sag Blink Home aktivieren</field> </block> </value> </block> </statement> <value name="IF1"> <block type="logic_compare" id="t]a8Eh+Po!bhl|Vxi_-W"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="VUN+TzR,j=bjo6%)U8i1"> <field name="ATTR">val</field> <field name="OID">tr-064.0.devices.Davids-iPhone.active</field> </block> </value> <value name="B"> <block type="logic_boolean" id="E.M2m97+r}0}9RvwfCz0"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO1"> <block type="control" id="B,|l9lBGr~F3Qgosc#^}"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alexa2.0.Echo-Devices.G2A0P3077474013G.Commands.textCommand</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="*[.hxHC/$8@G;`|Ti0i0"> <field name="TEXT">sag Blink deaktiviere Home</field> </block> </value> <next> <block type="control" id=")vgm[xBB[N:o8sFeJ9E)"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation> <field name="OID">alexa2.0.Echo-Devices.G2A0P3077474013G.Commands.textCommand</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">5</field> <field name="UNIT">sec</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"> <block type="text" id="tz[al}l37R(Py1x2+*,5"> <field name="TEXT">3619</field> </block> </value> </block> </next> </block> </statement> </block> </statement> </block> </xml>Andere Frage noch zum "Aktiv-Status der Kamera. Ich habe sonst nirgends eine Info im Adapter, ob das System läuft oder nicht? Als Status würde ich das auch gerne in der VIS anzeigen lassen...
@albert-k Danke für den Tipp! Endlich kann man mal weg von IFTTT um die Blink Module zu steuern! Bin ganz begeistert das ich auf diesen Post gestoßen bin aber eine Sache bekomme ich leider nicht hin :-( Habe das Script exakt nach dem von Dir gebaut und aktivieren klappt ohne Probleme aber das System wird nicht deaktiviert. Habe auch den PIN Block drin wie du aber klappt nicht. Bastel schon seit 2 Stunden rum.....hat jemand einen Tipp?? Bei PIN kommt halt z.B. 3457 rein richtig? geht bei mir mit PIN nicht und auch ohne nicht :-(
- am einfachsten einen festen Zeitplan in der Blink App eintragen
. Hab ich bei mir auch so. - Da ja keine Verbindung zum Blink System besteht welche eine Rückmeldung geben kann, kannst Du das nur simulieren. Ich habe dazu ja einen eigenen Datenpunkt "Virtueller_Schalter_Blink" angelegt. Den verwende ich in der VIS. Das Blockly das meine anderen Kameras und BWMs anhand des Anwesenheits Status scharf schaltet, schaltet praktisch nur diesen Datenpunkt.
Hast Du denn die 5 Sekunden Verzögerung in dem zweiten "steuere.." Block bei der deaktivierung?
Ja, ok, aber wenn er in der Blinkapp den Zeitplan schaltet, dann müsst er doch... ah, ne, mein Trigger ändert sich ja nicht. Aaaaber, die Zeitsteuerung bezieht sich doch auf die Kamera und nicht auf das system. Wenn das System offline ist, kann die Kamera denn dann überhaupt aktiviert werden...
@albert-k jap habe ich genau so... hab dann den text auch mal direkt in die Command Zeile bei dem Alexa Adapter eingegeben um auszuschließen das es am Blockly liegt. Also erst sage Blink deaktiviere Aussenbereich und dann nach 5 Sekunden noch 2584
So ist es doch auch bei dir oder? Vor der PIN steht ja kein Text oder? Laut Alexa Skill soll ja meine PIN lautet #### sagen....
@d4rkkn1ght84 Wie alt ist dein PIN denn, ich glaub der ist nur vier wochen aktive, oder?
