  4. Blink Camera System
Blink Camera System
blink xtcamera
407 Beiträge 63 Kommentatoren 166.1k Aufrufe 65 Beobachtet
  • I IceD112
    @Pischleuder
    ich komm da irgendwie nicht weiter 😧
    PischleuderP Offline
    Pischleuder
    #111
    @IceD112
    Moin,
    das hast du alles vorher gemacht ?
    sudo apt-get install gcc libpq-dev -y
    sudo apt-get install python-dev python-pip -y
    sudo apt-get install python3-dev python3-pip python3-venv python3-wheel -y
    pip3 install wheel
    I 2 Antworten Letzte Antwort
    • PischleuderP Pischleuder
      @IceD112
      Moin,
      pip3 install wheel
      I Offline
      I Offline
      IceD112
      #112
      @Pischleuder
      Ich denke nicht 🤦🏽‍♂️
        @IceD112
        Moin,
        pip3 install wheel
        I Offline
        I Offline
        IceD112
        #113
        @Pischleuder
        Ich hab echt keine Ahnung was ich falsch mache...😖
        Frohe Weihnachten euch allen 🌲 🌨
        JayRJ 1 Antwort Letzte Antwort
        • I IceD112
          @Pischleuder
          JayRJ Offline
          JayRJ Offline
          JayR
          #114
          blink4home.0	2021-01-07 15:30:37.514	warn	(11932) Terminated (UNCAUGHT_EXCEPTION): Without reason
          blink4home.0	2021-01-07 15:30:36.509	error	at internal/main/run_main_module.js:17:47
          blink4home.0	2021-01-07 15:30:36.509	error	at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
          blink4home.0	2021-01-07 15:30:36.509	error	at Function.Module._load (internal/modules/cjs/loader.js:708:14)
          blink4home.0	2021-01-07 15:30:36.509	error	at Module.load (internal/modules/cjs/loader.js:863:32)
          blink4home.0	2021-01-07 15:30:36.509	error	at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
          blink4home.0	2021-01-07 15:30:36.509	error	at Module._compile (internal/modules/cjs/loader.js:999:30)
          blink4home.0	2021-01-07 15:30:36.509	error	at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.blink4home/main.js:235:2)
          blink4home.0	2021-01-07 15:30:36.509	error	at new Blink4home (/opt/iobroker/node_modules/iobroker.blink4home/main.js:24:12)
          blink4home.0	2021-01-07 15:30:36.509	error	(11932) TypeError: Cannot read property 'debug' of undefined
          blink4home.0	2021-01-07 15:30:36.505	error	(11932) uncaught exception: Cannot read property 'debug' of undefined
          blink4home.0	2021-01-07 15:30:02.943	warn	(11898) Terminated (UNCAUGHT_EXCEPTION): Without reason
          blink4home.0	2021-01-07 15:30:01.941	error	at internal/main/run_main_module.js:17:47
          blink4home.0	2021-01-07 15:30:01.941	error	at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
          blink4home.0	2021-01-07 15:30:01.941	error	at Function.Module._load (internal/modules/cjs/loader.js:708:14)
          blink4home.0	2021-01-07 15:30:01.941	error	at Module.load (internal/modules/cjs/loader.js:863:32)
          blink4home.0	2021-01-07 15:30:01.941	error	at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
          blink4home.0	2021-01-07 15:30:01.941	error	at Module._compile (internal/modules/cjs/loader.js:999:30)
          blink4home.0	2021-01-07 15:30:01.941	error	at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.blink4home/main.js:235:2)
          blink4home.0	2021-01-07 15:30:01.941	error	at new Blink4home (/opt/iobroker/node_modules/iobroker.blink4home/main.js:24:12)
          blink4home.0	2021-01-07 15:30:01.941	error	(11898) TypeError: Cannot read property 'debug' of undefined
          blink4home.0	2021-01-07 15:30:01.937	error	(11898) uncaught exception: Cannot read property 'debug' of undefined
          blink4home.0	2021-01-07 15:29:29.661	info	(11831) starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.blink4home, node: v12.20.0, js-controller: 3.1.6
          blink4home.0	2021-01-07 15:29:29.583	warn	(11831) Terminated (UNCAUGHT_EXCEPTION): Without reason
          Ich bekomme folgenden Fehler hat jemand eine Idee?
          PischleuderP 1 Antwort Letzte Antwort
          • JayRJ JayR
            Pischleuder
            #115
            @JayR
            Blink4home funktioniert noch nicht, seitdem die Verschlüsselungsmethode geändert wurde.
            Albert KA 1 Antwort Letzte Antwort
              @JayR
              Albert KA Offline
              Albert KA Offline
              Albert K
              #116
              Nur zur Info:
              Seit kurzem (Dank sei @apollon77 !!! ) kann man das Blink System über den Alexa2 Adapter und den textCommand Befehl steuern. Ich verwende nur aktivieren/deaktivieren in einem Blockly und das klappt ganz gut.
              SlowmanS 1 Antwort Letzte Antwort
              • Albert KA Albert K
                Nur zur Info:
                SlowmanS Offline
                SlowmanS Offline
                Slowman
                #117
                @albert-k
                Ich brauche dies hier nicht zu installieren mehr? Bin davor immer zurück geschreckt, dies hier durchzuführen. Kannst du mal da ein Beispiel zeigen, wie es jetzt gesteuert wird.
                • SlowmanS Slowman
                  @albert-k
                  Albert KA Offline
                  Albert KA Offline
                  Albert K
                  schrieb am zuletzt editiert von Albert K
                  #118
                  @slowman
                  In den geschwärzten Bereich kommt die PIN zum deaktivieren rein (zB "eins zwei drei vier")
                  Alexa fordert zwar bei der Deaktivierung zur Eingabe des Pins auf, was man aber nicht beantworten muss
                  I D4RKKN1GHT84D 2 Antworten Letzte Antwort
                    @slowman
                    I Offline
                    I Offline
                    IceD112
                    #119
                    @albert-k
                    Wo im Alexa Adapter finde ich denn den entsprechenden State?
                    Interpretiere ich dein Blockly richtig, dass du deine Kamera mit Sprache de- und aktivierst? Anstelle dessen kann ich ja auch einen An- und Abwesenheitsstate nehmen?
                    • I IceD112
                      @albert-k
                      Albert KA Offline
                      Albert KA Offline
                      Albert K
                      #120
                      @iced112
                      • Bei jedem Echo Gerät unter Commands, textCommand
                      • Als Trigger kannst Du natürlich einen Anwesenheits Status nehmen. Ich habs in meinem Blockly nur schnell auf ein VIS Schaltelement gelegt zum testen
                      • steuern geht allerdings nur über Spracheingabe bei Blink. deshalb ist der neue textCommand Befehl ja so toll, das löst mir einige Probleme die ich mit Alexa hatte.
                      I 1 Antwort Letzte Antwort
                        @iced112
                        I Offline
                        I Offline
                        IceD112
                        #121
                        @albert-k
                        Verstehe ich dass dann korrekt, dass wenn der Trigger (welcher auch immer) aktiviert wird, aktiviert sich die Kamera über den textCommand?
                        Welcher Befehl muss denn genau enthalten sein? "sag Bllink ... aktivieren"?
                        • I IceD112
                          @albert-k
                          Albert KA Offline
                          Albert KA Offline
                          Albert K
                          #122
                          @iced112
                          • Richtig
                          • genau so wie es in meinem Blockly steht, wobei "Aussenkameras" der Name meines Blink Systems ist (das muss also entsprechend dem System Namen in Deiner Blink App oder der Alexa App angepasst werden)
                          Die möglichen Sprachbefehle kann man auch im Alexa Blink Skill nachsehen.
                            @iced112
                            • Richtig
                            I Offline
                            I Offline
                            IceD112
                            #123
                            @albert-k
                            Ei, dann werde ich morgen mal ne Blockly basteln...
                            Ähm. der Name vom Blinksystem? Du meinst den Namen der jeweiligen Kamera oder der des Sync-Moduls? Der Kamera nehme ich an?
                            • I IceD112
                              @albert-k
                              Albert KA Offline
                              Albert KA Offline
                              Albert K
                              #124
                              @iced112
                              In meinem Blockly schalte ich das System, also alle Kameras die mit dem Sync Modul verbunden sind. Einzeln geht aber glaube ich auch. Musst Du im Skill nachsehen.
                                @iced112
                                I Offline
                                I Offline
                                IceD112
                                #125
                                @albert-k
                                Prima,,, ich werde berichten...
                                  @iced112
                                  I Offline
                                  I Offline
                                  IceD112
                                  #126
                                  @albert-k
                                  Aktivieren nach Anwesenheit funktioniert prima.
                                  Blockly ist, bis auf den Trigger identisch mit deinem. Danke für den Tipp. Jetzt mache ich noch die Zeitsteuerung.
                                  Plan ist, wie weiter oben im Beitrag schon mal erwähnt, dass trotz Anwesenheit true, ab 23 Uhr das System wieder aktiviert werden soll.
                                  Das mache ich ja am besten im selben Blockly. Wie könnte dann der weitere Aufbau aussehen? Bin da leider noch nicht tief genug drin um von alleine drauf zu kommen
                                    <block type="on_ext" id="]#+6zkIh:u;)}kYFH/F=" x="-812" y="-512">
                                      <value name="OID0">
                                        <shadow type="field_oid" id="O8C-SG3qcTRSy.t:x@~I">
                                          <field name="oid">tr-064.0.devices.Davids-iPhone.active</field>
                                        </shadow>
                                      </value>
                                      <statement name="STATEMENT">
                                        <block type="controls_if" id="2wEz;@;p_Og*M0V07obY">
                                          <value name="IF0">
                                            <block type="logic_compare" id="GX#c*l+e;{tAo)i*5x:|">
                                              <field name="OP">EQ</field>
                                              <value name="A">
                                                <block type="get_value" id="k1TEs6QDMnrf(17?vT8d">
                                                  <field name="OID">tr-064.0.devices.Davids-iPhone.active</field>
                                                </block>
                                              </value>
                                              <value name="B">
                                                <block type="logic_boolean" id="f|J3PMU5d%F:4%;|K]A1">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <statement name="DO0">
                                            <block type="control" id="Ulvg6{XK}A]WX`z{jd80">
                                              <field name="OID">alexa2.0.Echo-Devices.G2A0P3077474013G.Commands.textCommand</field>
                                              <value name="VALUE">
                                                <block type="text" id="J+dODeY8}2HH?nY}PUWa">
                                                  <field name="TEXT">sag Blink Home aktivieren</field>
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                          <value name="IF1">
                                            <block type="logic_compare" id="t]a8Eh+Po!bhl|Vxi_-W">
                                              <value name="A">
                                                <block type="get_value" id="VUN+TzR,j=bjo6%)U8i1">
                                                </block>
                                              </value>
                                              <value name="B">
                                                <block type="logic_boolean" id="E.M2m97+r}0}9RvwfCz0">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <statement name="DO1">
                                            <block type="control" id="B,|l9lBGr~F3Qgosc#^}">
                                                <block type="text" id="*[.hxHC/$8@G;`|Ti0i0">
                                                  <field name="TEXT">sag Blink deaktiviere Home</field>
                                                </block>
                                              </value>
                                              <next>
                                                <block type="control" id=")vgm[xBB[N:o8sFeJ9E)">
                                                  <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation>
                                                  <field name="DELAY_MS">5</field>
                                                    <block type="text" id="tz[al}l37R(Py1x2+*,5">
                                                      <field name="TEXT">3619</field>
                                                    </block>
                                                  </value>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                        </block>
                                      </statement>
                                    </block>
                                  </xml>
                                  Andere Frage noch zum "Aktiv-Status der Kamera. Ich habe sonst nirgends eine Info im Adapter, ob das System läuft oder nicht? Als Status würde ich das auch gerne in der VIS anzeigen lassen...
                                    @slowman
                                    D4RKKN1GHT84D Offline
                                    D4RKKN1GHT84
                                    #127
                                    @albert-k Danke für den Tipp! Endlich kann man mal weg von IFTTT um die Blink Module zu steuern! Bin ganz begeistert das ich auf diesen Post gestoßen bin aber eine Sache bekomme ich leider nicht hin :-( Habe das Script exakt nach dem von Dir gebaut und aktivieren klappt ohne Probleme aber das System wird nicht deaktiviert. Habe auch den PIN Block drin wie du aber klappt nicht. Bastel schon seit 2 Stunden rum.....hat jemand einen Tipp?? Bei PIN kommt halt z.B. 3457 rein richtig? geht bei mir mit PIN nicht und auch ohne nicht :-(
                                    • I IceD112
                                      @albert-k
                                          <value name="OID0">
                                            </shadow>
                                          </value>
                                              <value name="IF0">
                                                  <value name="A">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                              <value name="IF1">
                                                  <value name="A">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </next>
                                                </block>
                                              </statement>
                                            </block>
                                          </statement>
                                        </block>
                                      </xml>
                                      Albert KA Offline
                                      Albert KA Offline
                                      Albert K
                                      #128
                                      @iced112
                                      • am einfachsten einen festen Zeitplan in der Blink App eintragen 😊 . Hab ich bei mir auch so.
                                      • Da ja keine Verbindung zum Blink System besteht welche eine Rückmeldung geben kann, kannst Du das nur simulieren. Ich habe dazu ja einen eigenen Datenpunkt "Virtueller_Schalter_Blink" angelegt. Den verwende ich in der VIS. Das Blockly das meine anderen Kameras und BWMs anhand des Anwesenheits Status scharf schaltet, schaltet praktisch nur diesen Datenpunkt.
                                      • D4RKKN1GHT84D D4RKKN1GHT84
                                        Albert KA Offline
                                        Albert KA Offline
                                        Albert K
                                        #129
                                        @d4rkkn1ght84
                                        Hast Du denn die 5 Sekunden Verzögerung in dem zweiten "steuere.." Block bei der deaktivierung?
                                        D4RKKN1GHT84D 1 Antwort Letzte Antwort
                                          @iced112
                                          I Offline
                                          I Offline
                                          IceD112
                                          #130
                                          @albert-k
                                          Ja, ok, aber wenn er in der Blinkapp den Zeitplan schaltet, dann müsst er doch... ah, ne, mein Trigger ändert sich ja nicht. Aaaaber, die Zeitsteuerung bezieht sich doch auf die Kamera und nicht auf das system. Wenn das System offline ist, kann die Kamera denn dann überhaupt aktiviert werden...😕
