  5. Bewegungsmelder und Lampe an
27 Beiträge 2 Kommentatoren 2.3k Aufrufe 2 Beobachtet
  • R Robbi12
    @paul53 Direkt
    @robbi12 sagte: Direkt
    Dann mache es so:
     <variables>
       <variable id="0P;(IUxU@MDEpVISA(VH">manuell_ein</variable>
     </variables>
     <block type="comment" id="c[U%4#_No#2D.si-X{p[" x="62" y="38">
       <field name="COMMENT">BWM</field>
       <next>
         <block type="on_ext" id="VphuGjX^E1q,NemBf;ax">
           <value name="OID0">
             <shadow type="field_oid" id="u.HAzh3?]P.yNDTfJ=}]">
             </shadow>
           </value>
           <statement name="STATEMENT">
             <block type="controls_if" id="ABEh;3^k+k}]gT_9i:`r">
               <value name="IF0">
                 <block type="logic_negate" id="Txz0rEAwbx0{T=[H9J$B">
                   <value name="BOOL">
                     <block type="variables_get" id="+JuSAVvJs.]r=ofnYVtc">
                       <field name="VAR" id="0P;(IUxU@MDEpVISA(VH">manuell_ein</field>
                     </block>
                   </value>
                 </block>
               </value>
               <statement name="DO0">
                 <block type="comment" id="V3,gkD:Lihm=RwG.-rNw">
                   <field name="COMMENT">Schalten per BWM</field>
                 </block>
               </statement>
             </block>
           </statement>
           <next>
             <block type="comment" id="Z=qBc/`M6x;{bm:5Hj0N">
               <field name="COMMENT">Shelly</field>
               <next>
                 <block type="on_ext" id="5.xjU_Mh5N4tYE$@n^C~">
                   <value name="OID0">
                     <shadow type="field_oid" id="Adix?bbi|~#S3:%{cqzr">
                     </shadow>
                   </value>
                     <block type="variables_set" id="|+UXU+01y_Z`RT[[;u@O">
                       <value name="VALUE">
                         <block type="logic_operation" id=":27N,aPZ2@1|L[bW`I.s" inline="false">
                           <field name="OP">AND</field>
                           <value name="A">
                             <block type="on_source" id="Xn])du+2S%h2Jj6];-,`">
                             </block>
                           </value>
                           <value name="B">
                             <block type="logic_compare" id="ijW/j,|HDfvUTG@#hT7k">
                               <field name="OP">NEQ</field>
                               <value name="A">
                                 <block type="on_source" id="M;6Y#A@Fzp/h[7vE{16@">
                                   <field name="ATTR">state.from</field>
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="text" id="c1X?E)xX:_KW_HkUc9Yf">
                                   <field name="TEXT">system.adapter.javascript.0</field>
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </next>
     </block>
    </xml>
    • R Robbi12
      @robbi12 Ich würde ja mein Script posten. Bekomme es aber nicht hin, wie ich es hier im Forum als Blockly anzeigen kann
      @robbi12 sagte: hier im Forum als Blockly anzeigen kann
      "Bild hoch laden": Dritter Button von rechts.
      R 1 Antwort Letzte Antwort
        Robbi12
        @paul53 Danke für deine Mühe. Ich bin blutiger Anfänger. Wie bekomm ich ein Bild vom Blockly gemacht? Da bekomme ich von mir nicht alles rauf.Unbenannt.JPG
        R paul53P 2 Antworten Letzte Antwort
        • R Robbi12
          Robbi12
          @robbi12 Da fehlt noch etliches. Bin noch überfragt mit den Werten
          • R Robbi12
            @robbi12
            So schaltet der BWM das Licht nur ein und nicht wieder aus.
              @robbi12
              Robbi12
              @paul53 Momentan schaltet er nicht einmal ein
              • R Robbi12
                @robbi12 sagte: Momentan schaltet er nicht einmal ein
                Poste mal den erzeugten Javascript-Code ohne die letzte Zeile in Code tags. </>
                  Robbi12
                  @paul53 ```
                  var manuell_ein;
                  // BWM
                  on({id: 'deconz.0.Sensors.12.presence', change: "ne"}, async function (obj) {
                  var value = obj.state.val;
                  if (!manuell_ein) {
                  // Schalten per BWM
                  if (getState("deconz.0.Sensors.12.presence").val == true) {
                  setState("shelly.0.SHSW-1#E0980696842C#1.Relay0.Switch"/Switch/, true, true);
                  // Shelly
                  on({id: 'shelly.0.SHSW-1#E0980696842C#1.Relay0.Switch', change: "ne"}, async function (obj) {
                  manuell_ein = (obj.state ? obj.state.val : "") && (obj.state ? obj.state.from : "") != 'system.adapter.javascript.0';
                  • R Robbi12
                    @paul53 ```
                    var manuell_ein;
                    // BWM
                    if (!manuell_ein) {
                    // Schalten per BWM
                    // Shelly
                    Nimm den Block "steuere" anstelle von "aktualisiere".
                      Robbi12
                      schrieb am zuletzt editiert von Robbi12
                      @paul53 Ok. Lampe geht nun ein.
                      Das wären meine Werte:
                      • R Robbi12
                        Robbi12
                        @robbi12 Ich danke dir schon mal für deine Mühe. Schwierig mit mir
                        • R Robbi12
                          @robbi12 sagte: Lampe geht nun ein.
                          Vorschlag mit Ausschaltverzögerung nach "keine Bewegung mehr":
                            Robbi12
                            • R Robbi12
                              @robbi12 sagte: Nun schaltet er nicht mehr aus.
                              Das kann ich anhand des Bildes nicht nachvollziehen. Bau mal eine Log-Ausgabe ein, um zu sehen, woran es liegen kann.
                              Es hat zwar nichts mit dem Ausschalten zu tun, aber ergänze noch "stop timeout" unten, wie in meinem Bild oben.
                                Robbi12
                                @paul53 Ich probiere es nochmal morgen. Momentan habe ich es so.
                                Vielleicht ist das Problem, dass der Bewegungsmelder von Ikea 3 Minuten an ist. Das ist voreingestellt.
                                So wie es jetzt ist funktioniert es. Da muss ich noch verfeinern. Danke für die Mühe. Ich melde mich und probiere es morgen mit dem LOG
                                • R Robbi12
                                  @robbi12 sagte: der Bewegungsmelder von Ikea 3 Minuten an ist.
                                  Wenn der BWM eine eigene Verzögerung enthält, kann man es vereinfachen:
                                  Wert wieder aus "Trigger".
                                    Robbi12
                                    @paul53 Hallo ich melde mich nochmal, verspätet. Danke aber für die Hilfe. Mit dem Button Wert hat es nicht funktioniert. Ich habe es nun so umgesetzt.
                                    Nun hätte ich noch eine Idee, bekomme es aber nicht hin.
                                    Ich würde zusätzlich gerne im Zeitraum 21.00 Uhr bis 05.00 Uhr das Einschalten der Lampe mit einem anderen Wert (10) für 2 Minuten machen und dann wieder auf den ursprünglichen WErt von 25 gehen.
                                    Außerhalb dieser Zeit, jedoch im Bereich Nacht oder wenn es dunkel ist, einschalten für 2 Minuten mit dem Wert von 25.
                                    Meine Werte sind: Nachtcheck, hier habe ich die Werte aus Astro aus einem erstellten DAtenpunkt.
                                    Lightlevel Dark kommt vom Helligkeitssensor Bewegungsmelder
