  4. Installation iobroker auf Raspberry 4
38 Beiträge 5 Kommentatoren 4.3k Aufrufe 4 Beobachtet
  • I Offline
    I Offline
    Int17
    schrieb am zuletzt editiert von Int17
    ich versuche auf einem RASPI 4 / 8GB / 200GB SSD auf:
    root@iobroker:~# cat /etc/os-release
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    iobroker zu installieren und bekomme im 3. Schritt des Installationscript diverse Fehler:
    root@iobroker:~# curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
    ## Installing the NodeSource Node.js 14.x repo...
    ## Populating apt-get cache...
    + apt-get update
    OK:1 http://archive.raspberrypi.org/debian buster InRelease
    Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
    OK:3 http://packages.microsoft.com/repos/code stable InRelease
    Holen:4 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
    Es wurden 13,0 MB in 6 s geholt (2.034 kB/s).
    ## Confirming "buster" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists/buster/Release'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
    OK
    ## Creating apt sources list file for the NodeSource Node.js 14.x repo...
    + echo 'deb https://deb.nodesource.com/node_14.x buster main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src https://deb.nodesource.com/node_14.x buster main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    OK:2 http://archive.raspberrypi.org/debian buster InRelease
    Holen:4 https://deb.nodesource.com/node_14.x buster InRelease [4.584 B]
    Holen:5 https://deb.nodesource.com/node_14.x buster/main armhf Packages [774 B]
    Es wurden 5.358 B in 3 s geholt (1.861 B/s).
    ## Run `sudo apt-get install -y nodejs` to install Node.js 14.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
         echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    root@iobroker:~# apt install -y nodejs
    Die folgenden NEUEN Pakete werden installiert:
      nodejs
    0 aktualisiert, 1 neu installiert, 0 zu entfernen und 2 nicht aktualisiert.
    Es müssen 22,6 MB an Archiven heruntergeladen werden.
    Nach dieser Operation werden 113 MB Plattenplatz zusätzlich benutzt.
    Holen:1 https://deb.nodesource.com/node_14.x buster/main armhf nodejs armhf 14.15.4-1nodesource1 [22,6 MB]
    Es wurden 22,6 MB in 2 s geholt (10,2 MB/s).
    Vormals nicht ausgewähltes Paket nodejs wird gewählt.
    (Lese Datenbank ... 98487 Dateien und Verzeichnisse sind derzeit installiert.)
    Vorbereitung zum Entpacken von .../nodejs_14.15.4-1nodesource1_armhf.deb ...
    Entpacken von nodejs (14.15.4-1nodesource1) ...
    nodejs (14.15.4-1nodesource1) wird eingerichtet ...
    Trigger für man-db (2.8.5-2) werden verarbeitet ...
    root@iobroker:~# curl -sLf https://iobroker.net/install.sh | bash -
    library: loaded
    Library version=2021-01-23
        Welcome to the ioBroker installer!
        Installer version: 2020-12-07
        Installing prerequisites (1/4)
    OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    OK:4 https://deb.nodesource.com/node_14.x buster InRelease
    Changing npm registry to https://registry.npmjs.org
    Installed gcc-c++
    Installed libavahi-compat-libdnssd-dev
    Installed libudev-dev
    Installed libpam0g-dev
    Installed libcairo2-dev
    Installed libpango1.0-dev
    Installed libjpeg-dev
    Installed libgif-dev
    Installed librsvg2-dev
        Creating ioBroker user and directory (2/4)
    User iobroker created
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    In file included from ../../nan/nan.h:56,
                     from ../src/main.cpp:3:
    /root/.cache/node-gyp/14.15.4/include/node/node.h:758:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_fun ’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /root/.cache/node-gyp/14.15.4/include/node/node.h:792:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(diskusage, Init)
                     from ../src/unix_dgram.cc:5:
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
     SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
     SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    In file included from ../../../nan/nan.h:56,
                     from ../src/./serialport.h:6,
                     from ../src/serialport.cpp:1:
    /root/.cache/node-gyp/14.15.4/include/node/node.h:758:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
    ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(serialport, init);
    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
    ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
    ioBroker wants to make sure to deliver the most stable smart home system.
    To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
    THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
    For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
    If you want to disable the error reporting you can use the command
    'iobroker plugin disable sentry'
    This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
        Finalizing installation (4/4)
    Enabling autostart...
    Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.178.41:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    root@iobroker:~# node -v
    v14.15.4
    root@iobroker:~# nodejs -v
    v14.15.4
    root@iobroker:~# npm -v
    6.14.10
    Kann mir jemand bitte sagen, was iobroker da für ein Problem hat und wie ich es beheben kann?
    Auf meinem Spielsystem (raspi3+) hatte ich mit identischem Ablauf keine Probleme.
    MfG
    Klaus
    • I Int17
      VERSION_ID="10"
      ID=raspbian
      ID_LIKE=debian
      + apt-get update
      OK
      + apt-get update
        nodejs
      library: loaded
      Installed gcc-c++
      Autostart enabled!
      v14.15.4
      v14.15.4
      6.14.10
      MfG
      Klaus
      @int17 sagte in Installation iobroker auf Raspberry 4:
      Nö,
      das sind nur WARN, dass optionale Pakete nicht passen
      Keins - nix
      da steht ja:
      ioBroker was installed successfully Open http://192.168.178.41:8081 in a browser and start configuring!
      • I Int17
        VERSION_ID="10"
        ID=raspbian
        ID_LIKE=debian
        + apt-get update
        OK
        + apt-get update
          nodejs
        library: loaded
        Installed gcc-c++
        Autostart enabled!
        v14.15.4
        v14.15.4
        6.14.10
        MfG
        Klaus
        @int17
        Nicht als root anmelden!
        Die Installation ist jetzt 'krumm'.
        I 1 Antwort Letzte Antwort
          @int17
          I Offline
          I Offline
          Int17
          Die Verz.-Rechte waren aber schon bei der Installation auf iobroker:iobroker gesetzt.
          klu@iobroker:~ $ ls -l /opt/iobroker
          insgesamt 360
          drwxrwxr-x+   2 iobroker iobroker   4096 Jan 30 19:20 backups
          -rwxrwxrwx+   1 iobroker iobroker    237 Jan 31 14:56 INSTALLER_INFO.txt
          lrwxrwxrwx    1 iobroker iobroker     22 Jan 31 14:56 iob -> /opt/iobroker/iobroker
          -rwxr-xr-x+   1 iobroker iobroker    309 Jan 31 14:56 iobroker
          drwxrwxr-x+   5 iobroker iobroker   4096 Jan 30 21:38 iobroker-data
          drwxrwxr-x+   2 iobroker iobroker   4096 Jan 31 14:58 log
          drwxrwxr-x+ 754 iobroker iobroker  20480 Jan 31 14:03 node_modules
          -rw-rwxr--+   1 iobroker iobroker   1082 Jan 31 14:03 package.json
          -rw-rwxr--+   1 iobroker iobroker 314839 Jan 31 14:03 package-lock.json
          -rw-rwxr--+   1 iobroker iobroker   5728 Jan 30 18:47 reinstall.js
          klu@iobroker:~ $
          Hatte mittlerweile das Feb. 2019 Newsletter und "curl -sL https://iobroker.net/fix.sh | bash -" ausgeführt.
          Trotzdem Danke für den Hinweis.
          Noch eine andere Frage: Wenn ich mich als "klu" ans WebUI anmelde und die Info-Seite aufrufe,
          bekomme ich:
          obwohl "klu" zur Admin-Gruppe gehört:
          Woran könnte das liegen?
          MfG
          Klaus
          • I Int17
            insgesamt 360
            klu@iobroker:~ $
            bekomme ich:
            MfG
            Klaus
            @int17
            Das ist ja auch logisch, der Systemuser 'iobroker' wird ja extra dafür angelegt.
            Nicht richtig ist es aber, das im Verzeichnis
            /root/.cache/
            rumgemacht wird. Und ganz grundsätzlich meldet man sich nie als root an. Nicht 'mal kurz' und auch nicht 'nur für die Aktion' oder weil 'sudo eingeben so umständlich ist'.
              @int17
              /root/.cache/
              I Offline
              I Offline
              Int17
              @thomas-braun Hallo Thomas, hast du noch eine Idee zu dem Permission Porblem? MfG Klaus
              • I Int17
                @int17
                Hast du die Installation jetzt 'gefixt'?
                iobroker fix
                (Als user absetzen!)
                  @int17
                  iobroker fix
                  I Offline
                  I Offline
                  Int17
                  @thomas-braun Ich hatte als "klu" "curl -sL https://iobroker.net/fix.sh | bash -" abgesetzt.
                  J Thomas BraunT 2 Antworten Letzte Antwort
                  • I Int17
                    Jan1
                    @int17
                    Das ist aber der alte Befehl, kann man machen, aber mehr bringt das auch nicht ;)
                    • J Jan1
                      @int17
                      @jan1 sagte in Installation iobroker auf Raspberry 4:
                      ???? wieso alt ????
                      iobroker vorher gestoppt?
                        ???? wieso alt ????
                        Jan1
                        Weil über curl das doch vor "IOBroker fix" war. Also warum soll ich mir ein Wolf tippen, wenn es mit der kurzen Variante auch geht?
                        • I Int17
                          @int17
                          Was liegt eigentlich in dem Repo
                          drin? Hab ich ja noch nie gesehen.
                          [Edit:] visual-studio-code
                          Braucht man das?
                          • J Jan1
                            I Offline
                            I Offline
                            Int17
                            @jan1 Also den "kurzen" Befehl genommen:
                            klu@iobroker:~ $ iobroker stop
                            klu@iobroker:~ $ iobroker fix
                            library: loaded
                                Welcome to the ioBroker installation fixer!
                                Script version: 2020-12-07
                                You might need to enter your password a couple of times.
                                Installing prerequisites (1/3)
                            [sudo] Passwort für klu:
                            OK:2 http://packages.microsoft.com/repos/code stable InRelease
                            OK:3 http://archive.raspberrypi.org/debian buster InRelease
                            Installed gcc-c++
                                Checking ioBroker user and directory permissions (2/3)
                                Checking autostart (3/3)
                            Autostart enabled!
                                Your installation was fixed successfully
                                Run iobroker start to start ioBroker again!
                            klu@iobroker:~ $ iobroker start
                            klu@iobroker:~ $
                            Fehler bleibt.
                            • I Int17
                              library: loaded
                              Installed gcc-c++
                              Autostart enabled!
                              klu@iobroker:~ $
                              Fehler bleibt.
                              Jan1
                              @int17
                              der kurze macht ja auch nichts andere als der lange, nur schneller getippt ;)
                              Edit:
                              Ich würde das einfach noch mal von vorne machen und die scourcelist so, dass da kein Microsoft Zeig drin ist.
                              Dann nur den IOBroker installieren und wenn gewünscht danach NODE14. NODE12 wird automatisch mit installiert.
                              Das ganze als User und nicht als root.
                              • wendy2702W Offline
                                wendy2702W Offline
                                Welchen Fehler genau meinst du eigentlich?
                                Den error bei serial Port?
                                Mal versucht ob der Admin läuft?
                                iobroker list instances
                                I 2 Antworten Letzte Antwort
                                  @int17
                                  Braucht man das?
                                  I Offline
                                  I Offline
                                  Int17
                                  @thomas-braun Hab ich nicht bewusst installiert. Habe das Raspy Image Buster per PI Imager geholt und dann iobroker installiert.
                                  Thomas BraunT J 2 Antworten Letzte Antwort
                                  • I Int17
                                    @int17
                                    Welches Image woher?
                                    • wendy2702W wendy2702
                                      I Offline
                                      I Offline
                                      Int17
                                      @wendy2702
                                      klu@iobroker:~ $ iobroker list instances
                                      + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        system.adapter.backitup.0              : backitup              - disabled
                                      + system.adapter.chromecast.0            : chromecast            -  enabled
                                      + system.adapter.discovery.0             : discovery             -  enabled
                                        system.adapter.echarts.0               : echarts               - disabled
                                      + system.adapter.fritzdect.0             : fritzdect             -  enabled
                                        system.adapter.fullybrowser.0          : fullybrowser          - disabled
                                      + system.adapter.hm-rega.0               : hm-rega               -  enabled
                                      + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
                                      + system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 0
                                      + system.adapter.hm-rpc.2                : hm-rpc                -  enabled, port: 18701
                                      + system.adapter.hm-rpc.4                : hm-rpc                -  enabled, port: 12010
                                        system.adapter.ical.0                  : ical                  -  enabled
                                      + system.adapter.info.0                  : info                  -  enabled
                                      + system.adapter.javascript.0            : javascript            -  enabled
                                        system.adapter.luftdaten.0             : luftdaten             -  enabled
                                        system.adapter.mobile.0                : mobile                -  enabled
                                      + system.adapter.nut.0                   : nut                   -  enabled
                                        system.adapter.openweathermap.0        : openweathermap        -  enabled
                                      + system.adapter.ping.0                  : ping                  -  enabled
                                      + system.adapter.synology.0              : synology              -  enabled, port: 5000
                                      + system.adapter.tankerkoenig.0          : tankerkoenig          -  enabled
                                        system.adapter.telegram.0              : telegram              - disabled, port: 8443, bind: 0.0.0.0
                                      + system.adapter.tr-064.0                : tr-064                -  enabled
                                      + system.adapter.tr-064.1                : tr-064                -  enabled
                                      + system.adapter.tr-064.2                : tr-064                -  enabled
                                      + system.adapter.tr-064.3                : tr-064                -  enabled
                                      + system.adapter.trashschedule.0         : trashschedule         -  enabled
                                      + system.adapter.upnp.0                  : upnp                  -  enabled
                                        system.adapter.vis.0                   : vis                   -  enabled
                                      + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + instance is alive
                                      klu@iobroker:~ $
                                        @int17
                                        I Offline
                                        I Offline
                                        Int17
                                        @thomas-braun Na ja, der "PI Imager" holt sie wohl von der offiziellen Seite:
                                        • I Int17
                                          Jan1
                                          @int17 jetzt kommt der Zeitpunkt wo ich meine Lieblings Raspi Doku vorschlage und auch die darin enthalten Links zu den offiziellen Images empfehle ;)
                                          Wobei wenn Du den Imager verwendet hast, das passen sollte.
                                          Thomas BraunT I 2 Antworten Letzte Antwort
