  4. BlitzWolf BW-SHP13 ZigBee Leistungsanzeige?
    5.3k
blitzwolf bw-shp13
52 Beiträge 21 Kommentatoren 16.1k Aufrufe 21 Beobachtet
  • S saeft_2003
    @knoddel sagte in BlitzWolf BW-SHP13 ZigBee Leistungsanzeige?:
    @Phil-Ipp
    Also die BlitzWolf BW-SHP13 werden im Zigbee Adapter 1.40 einwandfrei erkannt und zeigen auch die momentane Leistung und die gesamt kWh an.
    Ich habe auch die 1.4.0, wenn ich ein blitzwolf shp13 anlerne kommt folgendes im log. Es wird auch kein Ordner unter zigbee.0 erstellt. Jemand eine Idee?
    20 18:16:05.930	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:16:05.728	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:16:05.530	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:16:05.329	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:16:05.131	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:16:04.934	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:16:04.744	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:16:04.537	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:16:04.336	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:16:04.151	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:16:04.077	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:16:03.849	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:16:01.783	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    host.iobroker	2021-01-20 18:16:00.135	info	instance system.adapter.weatherunderground.0 started with pid 20902
    zigbee.0	2021-01-20 18:15:59.737	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:15:59.736	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:15:59.735	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:15:58.842	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:15:58.716	info	(13052) Device '0x588e81fffed3a0d7' is supported, identified as: TuYa 10A UK or 16A EU smart plug (TS0121)
    zigbee.0	2021-01-20 18:15:58.716	info	(13052) Successfully interviewed '0x588e81fffed3a0d7', device has succesfully been paired
    zigbee.0	2021-01-20 18:15:58.712	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:15:58.647	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:15:58.574	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:15:58.507	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    host.iobroker	2021-01-20 18:15:58.481	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    zigbee.0	2021-01-20 18:15:58.444	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:15:58.379	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:15:58.285	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:15:58.218	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:15:58.149	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:15:58.148	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:15:58.147	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:15:58.083	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:15:58.078	error	(13052) Device 0x588e81fffed3a0d7 "TS0121" not described in statesMapping.
    zigbee.0	2021-01-20 18:15:57.281	info	(13052) Starting interview of '0x588e81fffed3a0d7'
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @saeft_2003 Nimm mal die 1.4.2 aus dem Latest Kanal.
    Blitz Wolf hat die Zigbee ID angepasst.
    A.
    • AsgothianA Asgothian
      A.
      saeft_2003
      @asgothian
      Im latest bekomm ich nur die 1.4.0 angeboten, oder meintest du die 1.4.2 von github?
      • S saeft_2003
        @asgothian
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @saeft_2003 ich bekomme im Latest 1.4.2 angeboten. Github ist 1.4.3dev
        A.
          A.
          saeft_2003
          @asgothian
          jetzt habe ich ein paar mal hin und her geklickt und jetzt bekomme ich die 1.4.2 auch angeboten. Hab sie gleich installiert und siehe da geht :-)
          • K Knoddel
            @Phil-Ipp
            tom2k4
            @knoddel Servus, ich habe den Blitzwolf BW-SHP13 Stecker an einem CC26X2R1 unter 1.4.2 ohne Probleme angelernt.
            Weiß jemand wie man den kWh Wert zurücksetzen kann?
            Im Vergleich zu meinem Steckdosenmessgerät zeigt dieser auch um bis zu 10% unterschiedliche Werte(Watt) an. Jemand schon mal verglichen?
            S T 2 Antworten Letzte Antwort
            • T tom2k4
              saeft_2003
              @tom2k4
              Bei mir lässt sich der Wert einfach überschreiben.
              • S saeft_2003
                @tom2k4
                tom2k4
                @saeft_2003 said in BlitzWolf BW-SHP13 ZigBee Leistungsanzeige?:
                @tom2k4
                Wie genau machst Du das? Ernste Frage. Wenn ich auf das Feld klicke und versuche etwas einzugeben, lässt sich nichts ändern.
                • T tom2k4
                  @tom2k4
                  saeft_2003
                  @tom2k4 sagte in BlitzWolf BW-SHP13 ZigBee Leistungsanzeige?:
                  @tom2k4
                  Ich muss meine Aussage wieder zurück nehmen. Ich habe folgendes festgestellt, ich kann den Wert auf 0 setzen, aber sobald die nächste aktualisierung kommt ist es wieder der "alte". Deshalb vermute ich das dies nicht möglich ist...
                  0.24 	true 	zigbee.0 	2021-01-26 22:07:46.553
                  0 	false 	admin.0 	2021-01-26 22:08:08.012
                  0.24 	true 	zigbee.0 	2021-01-26 22:12:45.617
                  I arteckA 2 Antworten Letzte Antwort
                  • S saeft_2003
                    @tom2k4
                    I Offline
                    I Offline
                    IoBreaker
                    @saeft_2003 Geht bei mir auch nicht. Wert bleibt statisch.
                    • S saeft_2003
                      @tom2k4
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @saeft_2003 ohh wie wunder.. das ist der Wert der die Dose liefert.. logisch dass dieser bei jeder Aktualisierung überschrieben wird..
                      ich schaumal wie man die zurück setzt dann bau ich da noch ein button rein...
                      nachtrag.. das wird nix.. ich seh
                      https://www.zigbee2mqtt.io/devices/TS0121_plug.html
                      da nix zum zurücksetzten der Werte
                      • arteckA arteck
                        saeft_2003
                        @arteck
                        Naja ich bin jetzt kein Developer... hätte ja sein können das man mit der 0 den Wert in der Dose überschreibt.
                        H 1 Antwort Letzte Antwort
                        • S saeft_2003
                          @arteck
                          Holzlenkrad
                          @saeft_2003 sagte in BlitzWolf BW-SHP13 ZigBee Leistungsanzeige?:
                          @arteck
                          It’s not possible to write (/set) this value.
                          Ne, das geht wohl nicht.
                          Aber, wird der Wert resettet, wenn die Steckdose zurück gesetzt und neu angelernt wird? Das ist dann wohl der Weg.
                            Bloody
                            gibt es die Möglichkeit den Wert von dem DP "consumption" einzustellen? Habe nämlich ein Gerät getauscht und würde gerne für sourceanalytix, mit den alten Werten weiter rechnen.
                            Ändere ich den Wert händisch, springt er wiede rzurück.
                            • B Bloody
                              arteckA Offline
                              arteckA Offline
                              arteck
                              @bloody nein
                              • arteckA arteck
                                @bloody nein
                                Bloody
                                @arteck
                                Okay, Danke. Ist schade aber kann man nichts machen.
                                Habe es jetzt mit einem Blockly und weiteren DPs gelöst.
                                • T tom2k4
                                  tom2k4
                                  @tom2k4 said in BlitzWolf BW-SHP13 ZigBee Leistungsanzeige?:
                                  Ich frage meine zweite Frage erneut, da ich gerade mein Balkonkraftwerk messe und gleichzeitig mit einem FritzDect210 und einen handelsüblichen Steckdosenmessgerät(15 Euro) vergleiche.
                                  Ergebnis Leistung : BW-SHP13 = 555 Watt / FritzDect210 = 462 Watt / Steckdosenmessgerät = 460 Watt
                                  Das sind schon erhebliche unterschiede, welche ich an allen meiner ingesamt 8 BW-SHP13-Steckdosen feststelle.
                                  H S I 4 Antworten Letzte Antwort
                                  • T tom2k4
                                    Holzlenkrad
                                    @tom2k4
                                    Ne noch nicht. Ich hätte aber auch ein DECT 200 als "Referenz" hier.
                                    Aber wenn die Abweichung wirklich so hoch ist, dann wäre der BW-SHP13 ja leider völlig ungeeignet für solche Dinge wie Abrechnung von Stromverbrauch, Berechnungen von Kosten. Dann würden die nur für automatisierte Schaltungen/Routinen mit großen Unterschieden (Standby/On, Waschmaschine fertig usw) taugen.
                                    Das ist dann wohl der Nachteil mit dem günstigen China-Kram, es kontrolliert einfach niemand was die Dinger überhaupt messen...
                                    Weiß jemand, wie genau die jetzt EOL Innr-Plugs mit Verbrauchsmessung waren? Oder was es derzeit sonst an Alternativen gibt?
                                    • T tom2k4
                                      saeft_2003
                                      @tom2k4
                                      Mir persönlich ist die Genauigkeit eigentlich wurscht, da ich nur feststellen will ob ein Gerät z.b. die Waschmaschine läuft oder nicht.
                                      • T tom2k4
                                        I Offline
                                        I Offline
                                        IoBreaker
                                        @tom2k4 Meine Referenz ist der Homematic IP HMIP-PS Steckdosenaktor. Während der HMIP-PS 54,25 Watt anzeigt, zeigt der SPH-13 56-58 Watt an.
                                        • T tom2k4
                                          Holzlenkrad
                                          @tom2k4
                                          So, ich habe mittlerweile mal meine BW-SHP13 mit dem FritzBox Zwischenstecker verglichen. (Also zumindest eine, da fällt mir ein, dass meine Ergebnisse ggf. gar nicht auf meine anderen BW-SHP13 übertragbar sind :( )
                                          Gemessen habe ich mit einem Staubsauger, den ich auf verschiedene Stufen gestellt habe und somit einen Verbrauch bis zu 2000 Watt darstellen konnte. Ja, die Blitzwolf Dinger messen deutlich zu viel. Aber es ist immer im gleichen Maße zu viel, das ist die positive Nachricht. Bei der Steckdose die ich ausprobiert habe waren es etwa 12,5%. Wenn man den Datenpunkt also mit 0,875 multipliziert kommen ziemlich brauchbare Ergebnisse raus.
                                          Allerdings ist das so ohnehin nicht geeignet um einen Gesamtenergieverbrauch zu messen, da die Werte nur 1 mal pro Minute aktualisiert werden.
                                          Ich kann als nächstes mal ausprobieren, ob man vom Gesamtenergieverbrauch einfach auch die 12,5% abziehen kann. Dafür würde ich über einen längeren Zeitraum messen müssen, das kann ich nicht mit dem Staubsauger machen^^
                                          Mein Problem ist, dass ich neben dem PC eigentlich keine anderen Geräte haben, die deutlich über 10 Watt verbrauchen. An den Kühlschrank z.B. komme ich nicht ran, die "Server" gönnen sich auch alle nur ca. 10 Watt :D
