  3. Entwicklung
  4. ZigBee neue Version 1.4.0
    6.3k
zigbeeneugitalpha
393 Beiträge 62 Kommentatoren 125.9k Aufrufe 68 Beobachtet
  • AsgothianA Asgothian
    @skydream
    • Log bitte in Code tags (</>) stellen.
    • was passiert wenn du 0 oder 1 setzt ?
    A.
    Skydream
    schrieb am zuletzt editiert von Skydream
    #312
    @asgothian
    Alles einmal probiert in der Reihenfolge 0,1,2 d.h. 0 ist die älteste Logausgabe unten
    zigbee.0	2021-01-21 18:33:19.222	error	at process._tickCallback (internal/process/next_tick.js:68:7)
    zigbee.0	2021-01-21 18:33:19.222	error	at stateList.forEach (/opt/iobroker/node_modules/iobroker.zigbee/main.js:395:48)
    zigbee.0	2021-01-21 18:33:19.222	error	at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js:1359:27)
    zigbee.0	2021-01-21 18:33:19.222	error	(4597) Error on send command to 0x001788010648d906. Error: TypeError: value.toLowerCase is not a function
    zigbee.0	2021-01-21 18:33:11.619	error	at process._tickCallback (internal/process/next_tick.js:68:7)
    zigbee.0	2021-01-21 18:33:11.619	error	at stateList.forEach (/opt/iobroker/node_modules/iobroker.zigbee/main.js:395:48)
    zigbee.0	2021-01-21 18:33:11.619	error	at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js:1359:27)
    zigbee.0	2021-01-21 18:33:11.619	error	(4597) Error on send command to 0x001788010648d906. Error: TypeError: value.toLowerCase is not a function
    zigbee.0	2021-01-21 18:33:02.199	error	at process._tickCallback (internal/process/next_tick.js:68:7)
    zigbee.0	2021-01-21 18:33:02.199	error	at stateList.forEach (/opt/iobroker/node_modules/iobroker.zigbee/main.js:395:48)
    zigbee.0	2021-01-21 18:33:02.199	error	at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js:1359:27)
    zigbee.0	2021-01-21 18:33:02.199	error	(4597) Error on send command to 0x001788010648d906. Error: TypeError: value.toLowerCase is not a function
    Danke das du drauf schaust.
    Nachtrag: Ich habe drei von den teilen, alle verhalten sich gleich bei dem Versuch
      @skydream
      A.
      Skydream
      #313
      @asgothian
      Ich habe zwar keine Ahnung, aber
      wenn ich mir die Stelle anschaue wo laut Log der Fehler auftaucht
       hue_motion_sensitivity: {
              // motion detect sensitivity, philips specific
              key: ['motion_sensitivity'],
              convertSet: async (entity, key, value, meta) => {
                  // hue_sml:
                  // 0: low, 1: medium, 2: high (default)
                  // make sure you write to second endpoint!
                  const lookup = {'low': 0, 'medium': 1, 'high': 2};
                  value = value.toLowerCase();
                  utils.validateValue(value, Object.keys(lookup));
                  const payload = {48: {value: lookup[value], type: 32}};
                  await entity.write('msOccupancySensing', payload, manufacturerOptions.hue);
                  return {state: {motion_sensitivity: value}};
              convertGet: async (entity, key, meta) => {
                  await entity.read('msOccupancySensing', [48], manufacturerOptions.hue);
      Dann mecker er ja das es kein toLowerCase() gibt...was ja richtig ist wenn es eine Zahl ist.
      und im ioBroker ist das Feld als nummer definiert.
      Ich habe jetzt einfach mal den Type auf string gestellt und dann "low" eingetragen.....
      das scheint durchzugehen und ich sehe keine fehler mehr im log. low wird auch grün nach der eingabe...
      Kann das funktionieren oder ist das dummfug von meiner seite?
      • S Skydream
        @asgothian
                    // hue_sml:
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #314
        @skydream
        Das ist kein Dummfug, aber natürlich keine echte Lösung.
        Ich kann 2 Lösungen anbieten:
        • Steuerung über "number" mit 0, 1, 2
        • Steuerung über "Auswahl" mit "low, medium, high"
        Was ist besser ?
        btw. Der Fehler ist entstanden weil im Herdsman von 0,1,2 auf low, medium, high umgestellt wurde.
        A.
          @docgame
          Bitte die Ergebnisse:
          • als Text kopieren (und in Code tags posten)
          • Kombinieren damit welche Attribute du versucht hast abzufragen
          • sicherstellen das der BWM beim Abfragen auch ausgelöst hat.
          DocGame
          #315
          @asgothian Konntest du was mit den Datenpunkten des BWM abfangen?
          • ? Offline
            #316
            Hallo ich habe den Zigbee Adapter Version 1.4.2 installiert weil ich Probleme mit Steckdosen hatte. Diese laufen nun. Seitdem ich diese Version nutze lässt sich der Tradfri Bewegungsmelder vom Ikea nichtmehr anmelden.
            Ich bekomme diese Meldungen:
            Ich habe es 4 Mal versucht. Keine Chance.
            Jemand eine Idee?
            Mfg
            David
              Jemand eine Idee?
              Mfg
              David
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #317
              @david83
              Versuch mal bitte den Bewegungsmelder "Wach" zu halten, damit er mit dem Koordinator kommunizieren kann.
              A.
              • D DocGame
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                #318
                @docgame Dazu bin ich am WE nicht mehr gekommen.
                A.
                • ? Offline
                  #319
                  Leider bringt das Wach halten auch nichts. Ich habe jetzt eine Blitzwolf Steckdose eingebunden und konnte den Bewegungsmelder pairen. Sobald ich die Steckdose entferne funktioniert der Bewegungsmelder nichtmehr, auch wenn er direkt neben dem CC2652P liegt.
                  Auch der Akkustand vom BM funktioniert mit der Steckdose im Zigbee Netz nicht....
                  Edit: Erledigt, nutze nun eine andere Steckdose nun geht alles.
                    A.
                    DocGame
                    #320
                    @asgothian kein Thema..... Bin die nächsten 2 Tage eh auf Geschäftsreise. Wenn du irgendwann dazu kommst wäre es toll. Temperatur ist eher ein nicht to have. Die greife ich eh in jedem Raum mit den Aquarasensoren ab. Die Helligkeit ist bei einem BWM schon eher wichtig. Wenn das nämlich nicht funktionieren sollte klebe ich mir wie an allen anderen Stellen einen Aqara BWM ran und schneide kein Loch in die Deckenpaneele.
                    WOllte diese Variante mal testen da die Hochauflösenden von Aqara(zum Einbau) schon in den Startlöchern stehen und sicherlich bald lieferbar sind.
                      Tschaeens
                      #321
                      Erstmal rießen Dank für den tolllen Adapter.
                      Ich stelle gerade meine ganzen Sensoren auf zigbee um, um die Hue Bridge in Rente zu schicken.
                      Eine Frage habe ich dazu. Gibt es ein fertiges Skript für den Hue Lightstrip vorallem in Bezug auf die RGB Bedienung und zum Beispiel um auch die Szenen von Hue zu nutzen?
                      Lg
                      • T Tschaeens
                        Lg
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #322
                        @tschaeens szenen sind eine Besonderheit der hue bridge.. da musst du selber in die Tasten hauen..oder im forum schauen
                        • arteckA arteck
                          Tschaeens
                          #323
                          @arteck ja ich würde es mit einem Blockly lösen aber die hue lightsrip hat andere Datenpunkte im zigbee als mit dem hue adapter. Jetzt dachte ich ich muss die color umrechnen lassen?
                          • T Tschaeens
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #324
                            @tschaeens klar hat es andere Datenpunkte...
                            aber da ist alles was du brauchst
                            K T 2 Antworten Letzte Antwort
                            • arteckA arteck
                              Kueppert
                              #325
                              @arteck wieso habe ich denn diesen Punkt "effect type" nicht? Hab auch HUE-Lampen am Stick angelernt? Und ich hab leider keine Erläuterung gefunden, was man da reinschreiben kann (mangels dem Objekt konnte ich nicht selber rumprobieren ^^)
                              Danke dir und vG, Thorsten
                              IdleBitI 1 Antwort Letzte Antwort
                              • K Kueppert
                                IdleBitI Offline
                                IdleBitI Offline
                                IdleBit
                                #326
                                @kueppert Hast Du den da schon mal reingeklickt dann sollte diese Auswahl kommen:
                                • IdleBitI IdleBit
                                  Kueppert
                                  #327
                                  @idlebit ich habe leider - wie oben geschrieben - nicht mal das Auswahlfeld bei meinen Lämpchen ;)
                                  • arteckA arteck
                                    Tschaeens
                                    #328
                                    @arteck kay danke dir. Das heißt ich kann nicht 1:1 umrechnen, schade. Ich probier jetzt mal mein bestes mit die Szenen.
                                      Muchul
                                      schrieb am zuletzt editiert von Muchul
                                      #329
                                      Hallöchen,
                                      ich habe heute 3 Tuya Zigbee 3.0 Smart Strip Light Driver RGB RGBW bekommen.
                                      Adapter Version ist 1.4.3
                                      Können diese eingebunden werden?
                                      ist wohl dieser hier:
                                      https://github.com/Koenkk/zigbee-herdsman-converters/commit/805b0d9d823ebac82fd2b611a12f239c5717f7f0#
                                      • M Muchul
                                        Hallöchen,
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #330
                                        @muchul installier mal nochmal von GIT
                                          Muchul
                                          #331
                                          @arteck
                                          Dankeschön, ist zwar kein Bild dabei, aber wird schon mal erkannt und die Datenpunkte sind da
