  4. JavaScript
  5. HTML Tabelle für ical Adapter (mehrere Instanzen)
javascript
245 Beiträge 16 Kommentatoren 55.1k Aufrufe 15 Beobachtet
  • liv-in-skyL liv-in-sky
    @bergjet
    es wäre gut, wenn du nochmal ein log posten könntest, mit all den daten unter dem script - du erinnerst dich
    dann kann ich sehen, was da alles geliefert wird. man kann vieles im script ändern, wenn die infos da sind
    bergjetB Offline
    bergjetB Offline
    bergjet
    @liv-in-sky sagte in HTML Tabelle für ical Adapter (mehrere Instanzen):
    javascript.0 (1403) script.js.common.ical_Abfrage: [{"date":"11.01.2021 07:30-08:30","event":"Rest-M","_class":"ical_Müll ical_dayafter","_date":"2021-01-11T06:30:00.000Z","_end":"2021-01-11T07:30:00.000Z","_IDID":"21BA2701-D9DA-42DC-802F-F8F4BA2761A0","_allDay":false,"_rule":" ","location":"","_calName":"Müll","_calColor":"#f5ec00","myIDID":"MÜLL"},{"date":"21.01.2021 07:30-08:30","event":"Bio-M","_class":"ical_Müll ","_date":"2021-01-21T06:30:00.000Z","_end":"2021-01-21T07:30:00.000Z","_IDID":"D31CAEA8-25B0-4C0F-AE7F-BDF45EB8FDE7","_allDay":false,"_rule":" ","location":"","_calName":"Müll","_calColor":"#f5ec00","myIDID":"MÜLL"},{"date":"03.02.2021 07:30-08:30","event":"Verp-M","_class":"ical_Müll ","_date":"2021-02-03T06:30:00.000Z","_end":"2021-02-03T07:30:00.000Z","_IDID":"BAAE16CB-B7AA-4DE1-A497-72E78010AF25","_allDay":false,"_rule":" ","location":"","_calName":"Müll","_calColor":"#f5ec00","myIDID":"MÜLL"},{"date":"04.02.2021 07:30-08:30","event":"Bio-M","_class":"ical_Müll ","_date":"2021-02-04T06:30:00.000Z","_end":"2021-02-04T07:30:00.000Z","_IDID":"88E4FD60-92EA-43AE-86ED-1A1624CEED57","_allDay":false,"_rule":" ","location":"","_calName":"Müll","_calColor":"#f5ec00","myIDID":"MÜLL"},{"date":"08.02.2021 07:30-08:30","event":"Rest-M","_class":"ical_Müll ","_date":"2021-02-08T06:30:00.000Z","_end":"2021-02-08T07:30:00.000Z","_IDID":"65F31353-5540-437B-8431-31702B493620","_allDay":false,"_rule":" ","location":"","_calName":"Müll","_calColor":"#f5ec00","myIDID":"MÜLL"},{"date":"11.01.2021 01:00-00:00","event":"Test Geburtstag","_class":"ical_Geburtstage ical_dayafter","_date":"2021-01-11T00:00:00.000Z","_end":"2021-01-11T23:00:00.000Z","_section":"","_IDID":"o4qg8kqkhcqvpgpgq9a7u530jt@google.com","_allDay":false,"_rule":" rrule ","location":"","_calName":"Geburtstage","_calColor":"#fffc41","myIDID":"Geburtstag"}]
    homee, ioBroker, iMac, iPhone, Sonos, Alaxa
    • bergjetB bergjet
      liv-in-skyL Offline
      liv-in-skyL Offline
      @bergjet
      im ersten post ist ein neues script - dort kann nun ein filter gesetzt werden , um ein event zu manipulieren - das geburtstag - löschen ist im script als beispiel angegeben so muss es aussehen bei dir
       let myFilterRegexEvent5=[/(.*) Geburtstag/];
       let myFilterRegexEvent6=[""$1"];
      das problem mit dem alter. die info ist nicht da - d.h. die info müßte über die beschreibung des kalendereintrages kommen. ich weiß nicht, ob das mit apple funktioniert. in google kann ich in der beschreibung einfach das jahr angeben (z.b. 1978) - dann könnte ich etwas ausrechnen. würde bedeuten, du musst das jahr für alle in der beschreibung im kalender einfügen - exportieren - und dann nachsehen, ob es durchgereicht wird
      bergjetB 1 Antwort Letzte Antwort
        @bergjet
        bergjetB Offline
        bergjetB Offline
        bergjet
        @liv-in-sky Ja, danke hat geklappt. Das Alter wird nicht in den Kalender übertragen, das stammt aus den Kontakten. Das ist aber kein Problem. Wenn man die Spaltenbreite der ersten Spalte auf einen fixen Wert einstellt, erfolgt dann ein Zeilenumbruch des Inhalts?
        const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
        • bergjetB bergjet
          liv-in-skyL Offline
          liv-in-skyL Offline
          @bergjet
          ja, wenn es zu kurz ist
          • bergjetB bergjet
            liv-in-skyL Offline
            liv-in-skyL Offline
            @bergjet
            es gibt auch noch eine variable "weite" - damit kannst du die ganze breite definieren - damit die stabil bleibt, wenn mal längere oder nur kürzere namen dabei sind. ansonsten kann sich die breite immer ändern.
            bergjetB Stephan SchleichS 2 Antworten Letzte Antwort
              @bergjet
              bergjetB Offline
              bergjetB Offline
              bergjet
              Noch besser.
                @bergjet
                Stephan SchleichS Offline
                Stephan Schleich
                @liv-in-sky Bei mir verschwindet nach einiger Zeit die Instanz Gruppierung, erst wenn ich das Script neustarte ist diese wieder vorhanden, weißt du dazu was?
                • Stephan SchleichS Stephan Schleich
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  @Stephan-Schleich weißt du ungefähr wie lange das dauert ?
                  Stephan SchleichS 1 Antwort Letzte Antwort
                    Stephan Schleich
                    #66
                    @liv-in-sky innerhalb von 2 stunden aufjedenfall - ich beobachte es mal
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      #67
                      @Stephan-Schleich ich stell auch um und schau mal
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        #68
                        @Stephan-Schleich
                        zufällig script doppelt am laufen - zur sicherheit einmal die javascript instanz neustarten
                        vom script her gibt es eigentlich keine möglichkeit, dass sich das ändert
                          @Stephan-Schleich
                          Stephan Schleich
                          schrieb am zuletzt editiert von Stephan Schleich
                          #69
                          @liv-in-sky der Wert verschwindet wenn deine 15 & 45 Scheduler durchgeführt wurden. (Reboot brachte nix)
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            #70
                            @Stephan-Schleich
                            ich habe einen fehler gefunden - der war aber bei dem neuen datenpunkt mit dem nächsten termin - hat also mit der tabelle nix zu tun
                            es wird die selbe function aufgerufen, wenn du script startest oder nach 15 oder 45 minuten - ist mir im moment völlig unklar - habe mal ale 5 minuten beim schedule eingetragen und beobachte weiter
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              #71
                              @Stephan-Schleich
                              du meinst schon " let sortedByInstanz=true;"
                                @Stephan-Schleich
                                Stephan Schleich
                                #72
                                @liv-in-sky jup genau
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #73
                                  @Stephan-Schleich sollen wir mal anydesken ? - hab gerade zeit - wenn ja im chat telefonnummer
                                  • liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    #74
                                    dank @Stephan-Schleich haben wir noch einen fehler gefunden, war nur sichtbar, wenn eine ical instanz keine werte hatte
                                    update - script - erster post
                                    SlowmanS 1 Antwort Letzte Antwort
                                      SlowmanS Offline
                                      SlowmanS Offline
                                      Slowman
                                      #75
                                      @liv-in-sky
                                      Die Anleitung ist wirklich sehr gut geschrieben, nur bekomme ich dies nicht gebacken. Das die HTML Seite läuft. Denke mal bei der Aktivierung scheitere ich.
                                      Alles geändert, wie beschrieben. Datei liegt in /vis.0 Pfad und Name nicht geändert. Und jetzt? In Vis in Eigenschaften -> Allgemein html die Datei angegeben, die Datei mit vis.0/ vor aber nur das was ich dort rein gestellt habe erscheint.
                                      Auch der Anleitung hat mir hier nicht wirklich weiter geholfen: https://www.iobroker.net/#de/documentation/viz/basic.md
                                      Danke für einen Tipp
                                      • SlowmanS Slowman
                                        @liv-in-sky
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        #76
                                        @slowman hi- willst du wirklich das file haben ? mittlerweile gibt es fast keinen gebrauch mehr dafür - war damals für icontrol - adapter eingeführt, weil man dort kein html einfügen konnte - mittlerweile kann man das
                                        wenn du die tabelle nur in der vis sehen willst, brauchst du das file nicht
                                          SlowmanS Offline
                                          SlowmanS Offline
                                          Slowman
                                          #77
                                          @liv-in-sky
                                          Ich wollte dies für das JarVis haben. Du verwirrst mich, ist doch was aktuelles hier? 🙄 Habe bisher die Termine nur untereinander stehen und nicht in einer Tabelle. Gibt es da bessere Lösungen?
