  4. Test Adapter Linux Control v1.x.x
adaptercontrolhardwarelinuxsteuern
718 Beiträge 74 Kommentatoren 255.7k Aufrufe 67 Beobachtet
  • ScroungerS Scrounger
    @Stephan-Schleich
    Ok ich bau was ein, damit man besser sieht was der ping zurück gibt.
    Edit: ok ist eingebaut, teste die aktuelle version von github. Adapter auf debug und dann log ausgabe posten (keine Screenshot, gesamte logs!)
    Stephan SchleichS Offline
    Stephan Schleich
    schrieb am zuletzt editiert von Stephan Schleich
    #251
    @Scrounger
    linux-control.0	2020-12-30 06:49:18.603	debug	(2333) getting data from ioBrokerPi (192.168.178.200:22) -> not enabled!
    linux-control.0	2020-12-30 06:49:18.603	debug	(2333) [refreshHost] Pi-hole (192.168.178.205:22): button 'linux-control.0.Pi-hole.refresh' subscribed
    linux-control.0	2020-12-30 06:49:18.549	debug	(2333) [getConnection] Host 'Pi-hole' (192.168.178.205:22) ping result: {"host":"unknown","alive":false,"output":"","time":"unknown","times":[],"min":"unknown","max":"unknown","avg":"unknown","stddev
    linux-control.0	2020-12-30 06:49:18.549	info	(2333) [getConnection] Host 'Pi-hole' (192.168.178.205:22) seems not to be online
    linux-control.0	2020-12-30 06:49:18.544	info	(2333) getting data from Pi-hole (192.168.178.205:22, Adapter start)
    linux-control.0	2020-12-30 06:49:18.544	debug	(2333) [refreshHost] ioBroker (192.168.178.200:22): button 'linux-control.0.ioBroker.refresh' subscribed
    linux-control.0	2020-12-30 06:49:18.532	debug	(2333) [getConnection] Host 'ioBroker' (192.168.178.200:22) ping result: {"host":"unknown","alive":false,"output":"","time":"unknown","times":[],"min":"unknown","max":"unknown","avg":"unknown","stdde
    linux-control.0	2020-12-30 06:49:18.531	info	(2333) [getConnection] Host 'ioBroker' (192.168.178.200:22) seems not to be online
    linux-control.0	2020-12-30 06:49:18.507	info	(2333) getting data from ioBroker (192.168.178.200:22, Adapter start)
    linux-control.0	2020-12-30 06:49:18.506	debug	(2333) [refreshHost] Proxmox (192.168.178.199:22): button 'linux-control.0.Proxmox.refresh' subscribed
    linux-control.0	2020-12-30 06:49:18.444	debug	(2333) [getConnection] Host 'Proxmox' (192.168.178.199:22) ping result: {"host":"unknown","alive":false,"output":"","time":"unknown","times":[],"min":"unknown","max":"unknown","avg":"unknown","stddev
    linux-control.0	2020-12-30 06:49:18.443	info	(2333) [getConnection] Host 'Proxmox' (192.168.178.199:22) seems not to be online
    linux-control.0	2020-12-30 06:49:18.431	info	(2333) getting data from Proxmox (192.168.178.199:22, Adapter start)
    linux-control.0	2020-12-30 06:49:18.414	info	(2333) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.linux-control, node: v12.20.0, js-controller: 3.1.6
    linux-control.0	2020-12-30 06:49:18.367	info	(2333) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    linux-control.0	2020-12-30 06:49:18.365	debug	(2333) Plugin sentry Initialize Plugin (enabled=true)
    linux-control.0	2020-12-30 06:49:18.069	debug	(2333) statesDB connected
    linux-control.0	2020-12-30 06:49:18.069	debug	(2333) States connected to redis: 127.0.0.1:9000
    linux-control.0	2020-12-30 06:49:18.063	debug	(2333) States create System PubSub Client
    linux-control.0	2020-12-30 06:49:18.062	debug	(2333) States create User PubSub Client
    linux-control.0	2020-12-30 06:49:18.058	debug	(2333) Redis States: Use Redis connection: 127.0.0.1:9000
    linux-control.0	2020-12-30 06:49:18.058	debug	(2333) objectDB connected
    linux-control.0	2020-12-30 06:49:18.055	debug	(2333) Objects connected to redis: 127.0.0.1:9001
    linux-control.0	2020-12-30 06:49:18.047	debug	(2333) Objects client initialize lua scripts
    linux-control.0	2020-12-30 06:49:18.046	debug	(2333) Objects create User PubSub Client
    linux-control.0	2020-12-30 06:49:18.046	debug	(2333) Objects create System PubSub Client
    linux-control.0	2020-12-30 06:49:18.045	debug	(2333) Objects client ready ... initialize now
    linux-control.0	2020-12-30 06:49:18.027	debug	(2333) Redis Objects: Use Redis connection: 127.0.0.1:9001
    linux-control.0	2020-12-30 06:49:14.710	info	(31817) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    linux-control.0	2020-12-30 06:49:14.710	info	(31817) terminating
    linux-control.0	2020-12-30 06:49:14.710	info	(31817) cleaned everything up...
    linux-control.0	2020-12-30 06:49:14.709	info	(31817) Got terminate signal TERMINATE_YOURSELF
    ScroungerS 1 Antwort Letzte Antwort
    • Stephan SchleichS Stephan Schleich
      @Scrounger
      ScroungerS Offline
      ScroungerS Offline
      Scrounger
      #252
      @Stephan-Schleich
      Leider nicht das vollständige log, das brauch ich aber...
      Funktioniert bei Dir der ping adapter?
      Stephan SchleichS 1 Antwort Letzte Antwort
        @Stephan-Schleich
        Stephan Schleich
        #253
        @Scrounger Ich hatte nicht mehr zum kopieren, war 1:1 ausm Log nachm Restart
        Den Ping Adapter hab ich gerade mal installiert, und dieser kann auch nicht pingen O_o
        Nach "sudo apt-get install iputils-ping --reinstall" an allen LXC Debian Buster Containern + Reboot funktioniert es nun.
        ScroungerS 2 Antworten Letzte Antwort
          ScroungerS Offline
          ScroungerS Offline
          Scrounger
          #254
          @Stephan-Schleich sagte in Test Adapter Linux Control v1.x.x:
          Nö das ist der log ausm admin, deshlab abgeschnitten. Ich brauch das log aus iobroker/log/xy.log.
            Stephan Schleich
            #255
            @Scrounger alles klar, merk ich mir für die Zukunft. Aber nun gehts ja :)
              ScroungerS Offline
              ScroungerS Offline
              Scrounger
              #256
              Perfekt, habs gleich mal mit in die Doku aufgenommen.
                Stephan Schleich
                #257
                @Scrounger Bei mir war aber scheinbar zwingend ein reboot erforderlich, vllt sollte man das noch mit ergänzen?
                  Aktuelle Test Version 1.1.2
                  Veröffentlichungsdatum 12.08.2020
                  Github Link https://github.com/Scrounger/ioBroker.linux-control
                  ich habe einen kleinen Adapter geschrieben, mit dem Ihr Eure Linux Geräte / VMs / LXCs mittels ssh Zugriff steuern und Informationen auslesen.
                  Folgende Funktionen bietet der Adapter:
                  • ssh login über Benutzer und Passwort oder per RSA Key (empfohlen!)
                  • vordefinierte Datenpunkte, um das System zu steuern (Stopp, Reboot, Updates starten, etc.) und Informationen (Services, Updates, Neustart notwendig, etc.) auszulesen
                    Wichtig: Da es viele verschiedene Linux Distrubutionen gibt, ist es mir nicht möglich diese Funktionen für alle bereitzustellen, Support und Test von mir gibt es nur für Debian 10 und Ubuntu 18 / 20 LTS!
                  • Informationen zu Ordner (Größe, Anzahl Dateien, letzte Änderung) auslesen
                  • Meine Befehle - hier könnt Ihr Eure eigenen ganz individuellen Befehle ausführen lassen und z.B. einen Befehl ausführen oder Informationen in einen selbstdefinierten Datenpunkt zu schreiben.
                  Alle notwendigen Informationen findet ihr in der Dokumentation.
                  Vielen Dank fürs Testen!
                  P.S.: Sollte die Tage auch im Latest sein.
                  SegwayS Offline
                  SegwayS Offline
                  Segway
                  #258
                  @Scrounger
                  So, ich habe mal die Export / Import genutzt, da ich den Adapter auf ein anderes System umziehe !
                  Dabei sind mir 2 Sachen aufgefallen:
                  1. Wenn ich den json importiert habe, dann gibt die Oberfläche mir NICHT den Button speichern und schliessen frei ! Somit wird die geladene Konfiguration gar nicht abgespeichert. (Workaround: einfach unter Meine Befehle einen DP anlegen dann kommt der Button)
                  2. Anscheinend werden Username / Passwörter nicht richtig übernommen. Er kann sich mit den Clients nicht verbinden. Gebe ich manuell nochmal Username / Passwort ein, dann kann er sich connecten. Scheint aber auch nicht bei Allen zu sein ?
                  Gruß Dirk
                  • SegwayS Segway
                    @Scrounger
                    ScroungerS Offline
                    ScroungerS Offline
                    Scrounger
                    #259
                    @Segway sagte in Test Adapter Linux Control v1.x.x:
                    Kann ich bestätigen, bitte erstell dazu ein issue
                    1. Anscheinend werden Username / Passwörter nicht richtig übernommen. Er kann sich mit den Clients nicht verbinden. Gebe ich manuell nochmal Username / Passwort ein, dann kann er sich connecten. Scheint aber auch nicht bei Allen zu sein ?
                    Passwörter werden nicht übernommen, da diese nicht im klartext abgespeichert werden sollten - Sicherheit!
                    Wenn das System gewechselt wird, ist auch der iob Schlüssel anders und deshalb werden die PWs nicht korrekt entschlüsselt.
                    • U Offline
                      U Offline
                      UncleB
                      #260
                      Mahlzeit zusammen, genialer Adapter :)
                      Ich versetze meinen Rechner im die Bereitschaft "suspend"
                      Das funktioniert mit einem eigenen Befehl auch sehr gut "sudo -S pm-suspend"
                      Nun würde ich den Rechner über einen einfachen Taster gerne "wecken" finde hierzu keinen Befehl..
                      Vermutlich funktioniert das nur über WOL? Oder horcht der Rechner im Bereitschaftsmodus auf iwelche Befehle?
                      • U UncleB
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        #261
                        @UncleB sollte nur über wol gehen oder geräte schalter
                        • dirk1962D Offline
                          dirk1962D Offline
                          dirk1962
                          #262
                          Hallo @Scrounger, ich habe unter Proxmox einmal ioBroker in einer VM und einmal im Container installiert.
                          In der VM zeigt linux-control an, dass Proxmox online ist.
                          2021-01-27 13:01:53.783 - info: host.ioBroker stopInstance system.adapter.linux-control.0 (force=false, process=true)
                          2021-01-27 13:01:53.787 - info: linux-control.0 (10410) Got terminate signal TERMINATE_YOURSELF
                          2021-01-27 13:01:53.787 - info: linux-control.0 (10410) cleaned everything up...
                          2021-01-27 13:01:53.788 - info: linux-control.0 (10410) terminating
                          2021-01-27 13:01:53.788 - debug: linux-control.0 (10410) Plugin sentry destroyed
                          2021-01-27 13:01:53.788 - info: linux-control.0 (10410) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2021-01-27 13:01:53.827 - info: host.ioBroker stopInstance system.adapter.linux-control.0 send kill signal
                          2021-01-27 13:01:54.312 - info: host.ioBroker instance system.adapter.linux-control.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2021-01-27 13:01:56.851 - info: host.ioBroker instance system.adapter.linux-control.0 started with pid 10426
                          2021-01-27 13:01:57.208 - debug: linux-control.0 (10426) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2021-01-27 13:01:57.219 - debug: linux-control.0 (10426) Objects client ready ... initialize now
                          2021-01-27 13:01:57.220 - debug: linux-control.0 (10426) Objects create System PubSub Client
                          2021-01-27 13:01:57.221 - debug: linux-control.0 (10426) Objects create User PubSub Client
                          2021-01-27 13:01:57.221 - debug: linux-control.0 (10426) Objects client initialize lua scripts
                          2021-01-27 13:01:57.225 - debug: linux-control.0 (10426) Objects connected to redis: 127.0.0.1:9001
                          2021-01-27 13:01:57.229 - debug: linux-control.0 (10426) objectDB connected
                          2021-01-27 13:01:57.230 - debug: linux-control.0 (10426) Redis States: Use Redis connection: 127.0.0.1:9000
                          2021-01-27 13:01:57.237 - debug: linux-control.0 (10426) States create System PubSub Client
                          2021-01-27 13:01:57.238 - debug: linux-control.0 (10426) States create User PubSub Client
                          2021-01-27 13:01:57.240 - debug: linux-control.0 (10426) States connected to redis: 127.0.0.1:9000
                          2021-01-27 13:01:57.241 - debug: linux-control.0 (10426) statesDB connected
                          2021-01-27 13:01:57.300 - debug: linux-control.0 (10426) Plugin sentry Initialize Plugin (enabled=true)
                          2021-01-27 13:01:57.370 - info: linux-control.0 (10426) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.linux-control, node: v12.20.1, js-controller: 3.2.11
                          2021-01-27 13:01:57.397 - info: linux-control.0 (10426) getting data from Proxmox (192.168.1.102:22, Adapter start)
                          2021-01-27 13:01:57.464 - debug: linux-control.0 (10426) [distributionInfo] Proxmox (192.168.1.102:22): send command: 'cat /etc/os-release'
                          2021-01-27 13:01:57.571 - debug: linux-control.0 (10426) [distributionInfo] Proxmox (192.168.1.102:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
                          NAME="Debian GNU/Linux"
                          VERSION_ID="10"
                          VERSION="10 (buster)"
                          VERSION_CODENAME=buster
                          ID=debian
                          HOME_URL="https://www.debian.org/"
                          SUPPORT_URL="https://www.debian.org/support"
                          BUG_REPORT_URL="https://bugs.debian.org/"
                          2021-01-27 13:01:57.580 - debug: linux-control.0 (10426) [distributionInfo] Proxmox (192.168.1.102:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
                          2021-01-27 13:01:57.588 - debug: linux-control.0 (10426) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'apt-get update'
                          2021-01-27 13:01:58.831 - debug: linux-control.0 (10426) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout: Hit:1 http://security.debian.org buster/updates InRelease
                          Hit:2 http://ftp.de.debian.org/debian buster InRelease
                          Hit:3 http://security.debian.org/debian-security buster/updates InRelease
                          Hit:4 http://ftp.de.debian.org/debian buster-updates InRelease
                          Hit:5 http://download.proxmox.com/debian/pve buster InRelease
                          Reading package lists...
                          2021-01-27 13:01:58.832 - debug: linux-control.0 (10426) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'apt-get --just-print upgrade 2>&1 | perl -ne 'if (/Inst\s([\w,\-,\d,\.,~,:,\+]+)\s\[([\w,\-,\d,\.,~,:,\+]+)\]\s\(([\w,\-,\d,\.,~,:,\+]+)\)? /i) {print "$1,$2,$3\n"}' | column -s " " -t'
                          2021-01-27 13:01:59.145 - debug: linux-control.0 (10426) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout:
                          2021-01-27 13:01:59.145 - debug: linux-control.0 (10426) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.newPackages: 0
                          2021-01-27 13:01:59.148 - debug: linux-control.0 (10426) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.upgradable: false
                          2021-01-27 13:01:59.152 - debug: linux-control.0 (10426) [cmdAptUpdate] Proxmox (192.168.1.102:22): send command: 'dpkg-query -f '${db-fsys:Last-Modified}
                          ' -W | sort -nr | head -1'
                          2021-01-27 13:01:59.165 - debug: linux-control.0 (10426) [cmdAptUpdate] Proxmox (192.168.1.102:22): response stdout: 1611500573
                          2021-01-27 13:01:59.166 - debug: linux-control.0 (10426) [cmdAptUpdate] Proxmox (192.168.1.102:22): Proxmox.updates.lastUpdate: 1611500573000 -> 24.01.2021 16:02
                          2021-01-27 13:01:59.213 - debug: linux-control.0 (10426) [servicesInfo] Proxmox (192.168.1.102:22): no datapoints selected -> removing existing datapoints
                          2021-01-27 13:01:59.218 - debug: linux-control.0 (10426) [needrestart] Proxmox (192.168.1.102:22): no datapoints selected -> removing existing datapoints
                          2021-01-27 13:01:59.222 - info: linux-control.0 (10426) successful received data from Proxmox (192.168.1.102:22)
                          2021-01-27 13:01:59.228 - debug: linux-control.0 (10426) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.refresh' subscribed
                          2021-01-27 13:01:59.229 - debug: linux-control.0 (10426) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.aptUpdate' subscribed
                          2021-01-27 13:01:59.229 - debug: linux-control.0 (10426) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.control.aptUpgrade' subscribed
                          Im Container zeigt linux-control an, dass Proxmox offline ist.
                          2021-01-27 12:07:20.066 - info: host.ioBroker stopInstance system.adapter.linux-control.0 (force=false, process=true)
                          2021-01-27 12:07:20.070 - info: host.ioBroker stopInstance system.adapter.linux-control.0 send kill signal
                          2021-01-27 12:07:20.070 - info: linux-control.0 (22741) Got terminate signal TERMINATE_YOURSELF
                          2021-01-27 12:07:20.070 - info: linux-control.0 (22741) cleaned everything up...
                          2021-01-27 12:07:20.071 - info: linux-control.0 (22741) terminating
                          2021-01-27 12:07:20.071 - debug: linux-control.0 (22741) Plugin sentry destroyed
                          2021-01-27 12:07:20.071 - info: linux-control.0 (22741) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2021-01-27 12:07:20.638 - info: host.ioBroker instance system.adapter.linux-control.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2021-01-27 12:07:23.148 - info: host.ioBroker instance system.adapter.linux-control.0 started with pid 22795
                          2021-01-27 12:07:23.494 - debug: linux-control.0 (22795) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2021-01-27 12:07:23.507 - debug: linux-control.0 (22795) Objects client ready ... initialize now
                          2021-01-27 12:07:23.508 - debug: linux-control.0 (22795) Objects create System PubSub Client
                          2021-01-27 12:07:23.509 - debug: linux-control.0 (22795) Objects create User PubSub Client
                          2021-01-27 12:07:23.509 - debug: linux-control.0 (22795) Objects client initialize lua scripts
                          2021-01-27 12:07:23.524 - debug: linux-control.0 (22795) Objects connected to redis: 127.0.0.1:9001
                          2021-01-27 12:07:23.528 - debug: linux-control.0 (22795) objectDB connected
                          2021-01-27 12:07:23.529 - debug: linux-control.0 (22795) Redis States: Use Redis connection: 127.0.0.1:9000
                          2021-01-27 12:07:23.536 - debug: linux-control.0 (22795) States create System PubSub Client
                          2021-01-27 12:07:23.537 - debug: linux-control.0 (22795) States create User PubSub Client
                          2021-01-27 12:07:23.546 - debug: linux-control.0 (22795) States connected to redis: 127.0.0.1:9000
                          2021-01-27 12:07:23.546 - debug: linux-control.0 (22795) statesDB connected
                          2021-01-27 12:07:23.714 - debug: linux-control.0 (22795) Plugin sentry Initialize Plugin (enabled=true)
                          2021-01-27 12:07:23.784 - info: linux-control.0 (22795) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.linux-control, node: v12.20.1, js-controller: 3.2.11
                          2021-01-27 12:07:23.806 - info: linux-control.0 (22795) getting data from Proxmox (192.168.1.102:22, Adapter start)
                          2021-01-27 12:07:23.814 - info: linux-control.0 (22795) [getConnection] Host 'Proxmox' (192.168.1.102:22) seems not to be online
                          2021-01-27 12:07:23.815 - debug: linux-control.0 (22795) [getConnection] Host 'Proxmox' (192.168.1.102:22) ping result: {"host":"unknown","alive":false,"output":"","time":"unknown","times":[],"min":"unknown","max":"unknown","avg":"unknown","stddev":"unknown","packetLoss":"unknown"}
                          2021-01-27 12:07:23.872 - debug: linux-control.0 (22795) [refreshHost] Proxmox (192.168.1.102:22): button 'linux-control.0.Proxmox.refresh' subscribed
                          VM und Container sind mit Debian 10.7.0-amd64.
                          Du hast doch iobroker auch im Container und bei Dir funktioniert es wie ich am Material Design Widget von Dir gesehen habe. Hast Du eine Idee, warum es bei mir nicht funktioniert?
                          NUC8i5 mit Proxmox; Raspberrymatic in VM, iobroker, Motioneye, infuxDB und Grafana in CT.
                          • dirk1962D dirk1962
                            VERSION_ID="10"
                            ID=debian
                            ScroungerS Offline
                            ScroungerS Offline
                            Scrounger
                            schrieb am zuletzt editiert von Scrounger
                            #263
                            @dirk1962
                            Ja ber mein lxc läuft auf ubunut 20 basis.
                            Schätze es dieses Problem, da er den nicht anpingen kann, gleiches wird auch beim ping adapter wahscheinlich der Fall sein:
                            https://github.com/Scrounger/ioBroker.linux-control#known-issues
                            Schau mal weiter oben hier, da gabs das thema schon.
                            dirk1962D 1 Antwort Letzte Antwort
                              @dirk1962
                              dirk1962D Offline
                              dirk1962D Offline
                              dirk1962
                              #264
                              @scrounger Danke für die schnelle Rückmeldung. Dann mach ich den Container mit Ubuntu.
                                ScroungerS Offline
                                ScroungerS Offline
                                Scrounger
                                #265
                                @dirk1962 installiert doch einfach iputils-ping. Dann sollte es gehen
                                  dirk1962D Offline
                                  dirk1962D Offline
                                  dirk1962
                                  #266
                                  @scrounger das ist schon installiert. Muss ich dann noch was machen?
                                    ScroungerS Offline
                                    ScroungerS Offline
                                    Scrounger
                                    #267
                                    @dirk1962
                                    Da ich das problem nicht kenne, kann ich nicht viel dazu sagen, aber hier gabs genau das gleiche thema:
                                    https://forum.iobroker.net/topic/35870/test-adapter-linux-control-v1-x-x/253?_=1611757704506
                                      @dirk1962
                                      dirk1962D Offline
                                      dirk1962D Offline
                                      dirk1962
                                      #268
                                      @scrounger ... und damit hat es auch bei mir funktioniert.
                                      Vielen Dank 👍 .
                                      • wendy2702W Online
                                        wendy2702W Online
                                        #269
                                        Abend zusammen.
                                        Ich ziehe gerade meine Wanddisplays von WIN nach Linux um und wollte den Adpater nutzen um display off / on zu schalten.
                                        Dazu habe ich den befehl hier eingetragen:
                                        Ich hatte gedacht einen Datenpunkt mit einem Button dafür zu erhalten, oder wie rufe ich den Befehl sonst auf?
                                        Muss ich an anderer Stelle noch etwas im Adapter konfigurieren?
                                        Danke und Gruß
                                        • wendy2702W wendy2702
                                          Abend zusammen.
                                          Danke und Gruß
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          #270
                                          @wendy2702 sagte in Test Adapter Linux Control v1.x.x:
                                          du musst button auswählen anstatt zeichenkette
