  4. Iobroker startet nicht Fernlizenz-Fehler
iob startet nicht mehr
27 Beiträge 2 Kommentatoren 2.7k Aufrufe 1 Beobachtet
    @RDE wo ist da das log, dass es keine Lizenz gäbe?
    du hast deinen Cloud-Adapter nicht (korrekt) konfiguriert
    RDE
    @Homoran
    Hier ein Auszug aus dem log, nach dem ich mySWL installiert hatte
    2021-01-08 16:23:33.313  - ^[[32minfo^[[39m: host.raspberrypiiob ip addresses: 192.168.178.85 169.254.227.115 2003:ce:8f10:c900:d9a9:4e29:3da3:7ee7 2003:ce:8f10:c900:cc7e:6dc0:1433:ee8b fe80::b9de:8421:2f0d:9296 192.168.178.66 2003:ce:8$
    2021-01-08 16:23:34.280  - ^[[32minfo^[[39m: host.raspberrypiiob connected to Objects and States
    2021-01-08 16:23:34.762  - ^[[31merror^[[39m: host.raspberrypiiob uncaught exception: Cannot find module './mysql'
    Require stack:
    - /opt/iobroker/node_modules/@sentry/tracing/dist/integrations/index.js
    - /opt/iobroker/node_modules/@sentry/tracing/dist/index.js
    - /opt/iobroker/node_modules/@sentry/node/dist/handlers.js
    - /opt/iobroker/node_modules/@sentry/node/dist/integrations/onuncaughtexception.js
    - /opt/iobroker/node_modules/@sentry/node/dist/integrations/index.js
    - /opt/iobroker/node_modules/@sentry/node/dist/sdk.js
    - /opt/iobroker/node_modules/@sentry/node/dist/index.js
    - /opt/iobroker/node_modules/@iobroker/plugin-sentry/index.js
    - /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginHandler.js
    - /opt/iobroker/node_modules/@iobroker/plugin-base/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/main.js
    - /opt/iobroker/node_modules/iobroker.js-controller/controller.js
    2021-01-08 16:23:34.764  - ^[[31merror^[[39m: host.raspberrypiiob Error: Cannot find module './mysql'
    Require stack:
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
        at Function.Module._load (internal/modules/cjs/loader.js:667:27)
        at Module.require (internal/modules/cjs/loader.js:887:19)
        at require (internal/modules/cjs/helpers.js:74:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@sentry/tracing/dist/integrations/index.js:6:15)
        at Module._compile (internal/modules/cjs/loader.js:999:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
        at Module.load (internal/modules/cjs/loader.js:863:32)
        at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    2021-01-08 16:23:35.542  - ^[[32minfo^[[39m: host.raspberrypiiob iobroker _restart
    2021-01-08 16:23:35.577  - ^[[32minfo^[[39m: host.raspberrypiiob terminated
    2021-01-08 16:23:36.652  - ^[[32minfo^[[39m: host.raspberrypiiob iobroker Starting node restart.js
    2021-01-08 16:23:38.543  - ^[[32minfo^[[39m: host.raspberrypiiob iobroker.js-controller version 3.1.6 js-controller starting
    2021-01-08 16:23:38.553  - ^[[32minfo^[[39m: host.raspberrypiiob Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
    2021-01-08 16:23:38.554  - ^[[32minfo^[[39m: host.raspberrypiiob hostname: raspberrypiiob, node: v12.20.1
    2021-01-08 16:23:38.558  - ^[[32minfo^[[39m: host.raspberrypiiob ip addresses: 192.168.178.85 169.254.227.115 2003:ce:8f10:c900:d9a9:4e29:3da3:7ee7 2003:ce:8f10:c900:cc7e:6dc0:1433:ee8b fe80::b9de:8421:2f0d:9296 192.168.178.66 2003:ce:8$
    2021-01-08 16:23:39.589  - ^[[32minfo^[[39m: host.raspberrypiiob connected to Objects and States
    2021-01-08 16:23:40.078  - ^[[31merror^[[39m: host.raspberrypiiob uncaught exception: Cannot find module './mysql'
    Require stack:
    MOD-Edit: Code in code-tags gesetzt!
    Über den Browser http://IP_8081 kann ich den admin nicht mehr aufrufen
    • R RDE
      @Homoran
      Require stack:
      Require stack:
      Require stack:
      @RDE sagte in Iobroker startet nicht Fernlizenz-Fehler:
      dann kannst du ihn wahrscheinlich genau deswegen auch nicht über den Fernzugriff aufrufen.
      mit puTTY drauf und die Ausgabe von iobroker list instances hier in code-tags posten
      Übrigens: wieso hat der Raspi 3 IP-Adressen?
      R 1 Antwort Letzte Antwort
        RDE
        @Homoran said in Iobroker startet nicht Fernlizenz-Fehler:
        /opt/iobroker/log $ iobroker list instances
          system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.admin.1                 : admin                 -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
          system.adapter.alexa2.0                : alexa2                -  enabled
          system.adapter.backitup.0              : backitup              -  enabled
          system.adapter.cloud.0                 : cloud                 -  enabled
          system.adapter.coronavirus-statistics.0: coronavirus-statistics -  enabled
          system.adapter.discovery.0             : discovery             -  enabled
          system.adapter.email.0                 : email                 -  enabled
          system.adapter.fb-checkpresence.0      : fb-checkpresence      -  enabled
          system.adapter.feiertage.0             : feiertage             -  enabled
          system.adapter.fully-tablet-control.0  : fully-tablet-control  -  enabled
          system.adapter.fullybrowser.0          : fullybrowser          -  enabled
          system.adapter.history.0               : history               -  enabled
          system.adapter.hmip.0                  : hmip                  -  enabled
          system.adapter.ical.0                  : ical                  -  enabled
          system.adapter.icons-mfd-png.0         : icons-mfd-png         -  enabled
          system.adapter.icons-mfd-svg.0         : icons-mfd-svg         -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png -  enabled
          system.adapter.info.0                  : info                  -  enabled
          system.adapter.iot.0                   : iot                   -  enabled
          system.adapter.jarvis.0                : jarvis                -  enabled
          system.adapter.javascript.0            : javascript            -  enabled
          system.adapter.linux-control.0         : linux-control         -  enabled
          system.adapter.logparser.0             : logparser             -  enabled
          system.adapter.material.0              : material              -  enabled
          system.adapter.mqtt.0                  : mqtt                  -  enabled, port: 1884, bind: 0.0.0.0
          system.adapter.netatmo.0               : netatmo               -  enabled
          system.adapter.openweathermap.0        : openweathermap        -  enabled
          system.adapter.shelly.0                : shelly                -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.sonoff.0                : sonoff                -  enabled, port: 1884, bind: 0.0.0.0
          system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.terminal.0              : terminal              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
          system.adapter.tr-064.0                : tr-064                -  enabled
          system.adapter.trashschedule.0         : trashschedule         -  enabled
          system.adapter.vis-bars.0              : vis-bars              -  enabled
          system.adapter.vis-colorpicker.0       : vis-colorpicker       -  enabled
          system.adapter.vis-fancyswitch.0       : vis-fancyswitch       -  enabled
          system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
          system.adapter.vis-icontwo.0           : vis-icontwo           -  enabled
          system.adapter.vis-inventwo.0          : vis-inventwo          -  enabled
          system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          -  enabled
          system.adapter.vis-justgage.0          : vis-justgage          -  enabled
          system.adapter.vis-material-advanced.0 : vis-material-advanced -  enabled
          system.adapter.vis-metro.0             : vis-metro             -  enabled
          system.adapter.vis-players.0           : vis-players           -  enabled
          system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
          system.adapter.vis-weather.0           : vis-weather           -  enabled
          system.adapter.vis.0                   : vis                   -  enabled
          system.adapter.weatherunderground.0    : weatherunderground    -  enabled
          system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        • R RDE
          + instance is alive
          @RDE
          Da läuft ja auch überhaupt nichts
          was kommt bei iobroker status?
          Bitte in code-tags posten!
            @RDE
            RDE
            @Homoran
            pi@raspberrypiiob:/opt/iobroker/log $ iobroker status
            iobroker is not running on this host.
            No iobroker host is running.
            Objects type: file
            States  type: file
            • R RDE
              @Homoran
              Objects type: file
              States  type: file
              @RDE
              @Homoran sagte in Iobroker startet nicht Fernlizenz-Fehler:
              Was kommt bei iobroker start?
              R 2 Antworten Letzte Antwort
                @RDE
                RDE
                @Homoran
                pi@raspberrypiiob:/opt/iobroker/log $ iobroker start
                • R RDE
                  @Homoran
                  RDE
                  @RDE
                    @RDE
                    RDE
                    @Homoran
                    Soory aber das mit den MOD-Edit: Code in code-tags gesetzt! habe ich nicht verstanden, wie geht das?
                    • R RDE
                      @Homoran
                      Das bedutet, dass ein MOD sich für dich die Arbeit gemacht hat, deinen code über code-tags korrekt zu formatieren
                      • R RDE
                        @RDE
                        @RDE
                        OK!
                        was sagt jetzt iobroker list instances?
                          @RDE
                          OK!
                          RDE
                          @Homoran
                          ob:/opt/iobroker/log $ iobroker list instances
                          • R RDE
                            @Homoran
                            @RDE Fast hast du es geschafft ;-)
                            jetzt noch einen Zeilenumpruch nach dem Namen und vor den Code-Tags - dann wird das schon
                            Da läuft immer noch nichts.
                            Was hast du für ein System?
                            Was kommt bei iobroker list adapters?
                            Bei dir laufen mqtt und sonoff auf dem selben port - das kann nicht gut gehen
                              RDE
                              @Homoran ```
                              pi@raspberrypiiob:/opt/iobroker/log $ iobroker list adapters
                              Cannot parse /opt/iobroker/iobroker-data/objects.json: SyntaxError: Unexpected end of JSON input
                              system.adapter.admin : admin - v4.1.11
                              system.adapter.discovery : discovery - v2.4.1
                              system.adapter.info : info - v1.7.10
                              system.adapter.cloud : cloud - v3.1.0
                              system.adapter.web : web - v3.1.0
                              system.adapter.terminal : terminal - v0.1.2
                              system.adapter.hmip : hmip - v1.5.0
                              system.adapter.mqtt : mqtt - v2.1.14
                              system.adapter.sonoff : sonoff - v2.3.3
                              system.adapter.netatmo : netatmo - v1.3.3
                              system.adapter.telegram : telegram - v1.6.0
                              system.adapter.javascript : javascript - v4.8.4
                              system.adapter.shelly : shelly - v4.0.3
                              system.adapter.vis-bars : vis-bars - v0.1.4
                              system.adapter.vis-hqwidgets : vis-hqwidgets - v1.1.7
                              system.adapter.vis-timeandweather : vis-timeandweather - v1.1.7
                              system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.2
                              system.adapter.vis-fancyswitch : vis-fancyswitch - v1.1.0
                              system.adapter.vis-colorpicker : vis-colorpicker - v1.2.0
                              system.adapter.iot : iot - v1.8.5
                              system.adapter.alexa2 : alexa2 - v3.3.5
                              system.adapter.vis : vis - v1.3.4
                              system.adapter.device-reminder : device-reminder - v0.7.4
                              system.adapter.fb-checkpresence : fb-checkpresence - v1.1.0
                              system.adapter.tr-064 : tr-064 - v4.2.1
                              system.adapter.openweathermap : openweathermap - v0.1.0
                              system.adapter.backitup : backitup - v1.7.0
                              system.adapter.fully-tablet-control : fully-tablet-control - v0.3.0-beta.5
                              system.adapter.logparser : logparser - v1.1.0
                              system.adapter.vis-jqui-mfd : vis-jqui-mfd - v1.0.12
                              system.adapter.vis-metro : vis-metro - v1.1.2
                              system.adapter.vis-justgage : vis-justgage - v1.0.2
                              system.adapter.icons-mfd-png : icons-mfd-png - v1.0.2
                              system.adapter.fullybrowser : fullybrowser - v2.0.1
                              system.adapter.jarvis : jarvis - v2.0.0
                              system.adapter.history : history - v1.9.10
                              system.adapter.vis-players : vis-players - v0.1.6
                              system.adapter.material : material - v0.13.9
                              system.adapter.vis-inventwo : vis-inventwo - v2.5.11
                              system.adapter.vis-icontwo : vis-icontwo - v0.35.0
                              system.adapter.icons-mfd-svg : icons-mfd-svg - v1.0.2
                              system.adapter.vis-material-advanced : vis-material-advanced - v1.3.0
                              system.adapter.linux-control : linux-control - v1.1.0
                              system.adapter.weatherunderground : weatherunderground - v3.2.1
                              system.adapter.vis-weather : vis-weather - v2.5.2
                              system.adapter.email : email - v1.0.7
                              system.adapter.feiertage : feiertage - v1.0.17
                              system.adapter.ical : ical - v1.7.4
                              system.adapter.coronavirus-statistics : coronavirus-statistics - v0.6.3
                              system.adapter.trashschedule : trashschedule - v1.0.3
                              Unable to increase LUA script timeout: Error: Connection is closed.
                              • R RDE
                                @Homoran ```
                                das klingt nicht gut
                                Bitte code-tags korrigieren
                                  RDE
                                  @Homoran Ja, was kann man machen?
                                  R HomoranH 2 Antworten Letzte Antwort
                                  • R RDE
                                    RDE
                                    @RDE Ein backupfile habe ich
                                    • R RDE
                                        RDE
                                        @Homoran Himbeer Pi OS Lite
                                          RDE
                                          @Homoran
                                          • Was meinst du mit code-tags korrigieren?
