  4. Home connect Widget
Home connect Widget
home connect
16 Beiträge 3 Kommentatoren 2.2k Aufrufe 3 Beobachtet
  • M mario.blass
    @Glasfaser ok, ich versuche es.
    mario.blass
    @mario-blass Nö, hat auch nicht geklappt, hatte jetzt ein jqui-mfd-control-socket.
    Keine Ahnung was da ist.
    ioBroker auf QNAP NAS
    Visualisiert wird das ganze über ein Galaxy View 18,4"
    • M mario.blass
      GlasfaserG Offline
      GlasfaserG Offline
      @mario-blass
      Nimm mal ein normales HTML Widget und lass dir mal die Werte im Runtime anzeigen , was eigentlich geschieht.
      Bei
      {hiermeinDatenpunktrein}
      dein Datenpunkt reinschreiben .
      Widget :
      [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"{hiermeinDatenpunktrein}"},"style":{"left":"400px","top":"319px","height":"59px","width":"280px"},"widgetSet":"basic"}]
      • GlasfaserG Glasfaser
        @mario-blass
        Bei
        Widget :
        mario.blass
        @Glasfaser Ich muss morgen weiter machen, bekomm grad besuch.
        Trotzdem DANKE
        • M mario.blass
          Trotzdem DANKE
          mario.blass
          schrieb am zuletzt editiert von mario.blass
          Das ist der Datenpunkt wie gesagt, er ändert sich auch in "true" sobald ich einschalte.
          • M mario.blass
            GlasfaserG Offline
            GlasfaserG Offline
            @mario-blass
            Meine Vermutung ist ....
            hinter dem false steht noch etwas ... deshalb reagiert das Widget nicht auf true/false
            • M mario.blass
              GlasfaserG Offline
              GlasfaserG Offline
              @mario-blass sagte in Home connect Widget:
              Ich kenne den Adapter nicht ... aber laut Screenshot zeigst du Settings.
              Ist das nicht ein anderer Datenpunkt wie z.b .
              wie aus dem Thread :
              Test Adapter homeconnect (BSH Home-Connect) v0.0.x
                mario.blass
                @Glasfaser Hallo,
                ja, ich hab diesen gewählt, ich habe sonst keinen Datenpunkt der mir nur true und false anzeigt, der Punkt Connected zeigt mir nur an, ob das Kochfeld mit WLAN verbunden ist.
                  @mario-blass
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @Glasfaser sagte in Home connect Widget:
                  @mario-blass
                  Wie schon oben Erwähnt .... meine Vermutung.
                  Teste mal bei dem Widget ob bei dem Wert false also im Feld Wert min/max dann : false(BSH.Common.EnumType.PowerState.Off) reagiert , bzw. bei true ( ............. )
                  Kann dir da nicht weiterhelfen , da ich den Adapter nicht nutze ... wie der Datenpunkt aufgebaut ist .
                  Wenn nicht ... Frage im zuvor genannten Thread mal nach .....
                    @mario-blass
                    mario.blass
                    @Glasfaser gelöst. Musste den Status" lokale Bedienung aktiv" nehmen, jetzt klappt es.
                    Danke für die Hilfe
                    • M mario.blass
                      Danke für die Hilfe
                      GlasfaserG Offline
                      GlasfaserG Offline
                      jetzt klappt es
                      Freut mich .. das es jetzt funktioniert.
                        jetzt klappt es
                        mario.blass
                        @Glasfaser Kommando zurück, geht nur wenn ich am Feld etwas bediene. Steht ja auch "lokale Bedienung aktiv". Ich habe keinen Status mit true/false, nur der o.g. Mit dem Zusatz.
