  4. [gelöst] backup eingespielt und nichts passiert - Was nun?
restorebackup
49 Beiträge 4 Kommentatoren 5.6k Aufrufe 2 Beobachtet
  • W weimaraner
    @Thomas-Braun Auch auf die Gefahr hin, daß ich nerve. Was bedeuten folgende Meldungen? Sind zwar nur Infos, aber drin steht was mit Error. 🙄
    host.iobroker-NUC	2021-01-05 11:54:05.257	info	iobroker npm-install: exit 51
    host.iobroker-NUC	2021-01-05 11:54:04.033	info	iobroker npm-install: adapter "icons-open-icon-library-png" already installed. Use "upgrade" to upgrade to a newer version.
    host.iobroker-NUC	2021-01-05 11:54:01.890	info	iobroker install icons-open-icon-library-png@0.1.3 using installedVersion
    host.iobroker-NUC	2021-01-05 11:54:01.889	warn	startInstance cannot find adapter "icons-open-icon-library-png@0.1.3". Try to install it... 3 attempt
    host.iobroker-NUC	2021-01-05 11:54:00.887	info	iobroker npm-install: exit 0
    host.iobroker-NUC	2021-01-05 11:53:59.786	info	iobroker npm-install: Update "system.adapter.wiffi-wz.0"
    host.iobroker-NUC	2021-01-05 11:53:59.732	info	iobroker npm-install: host.iobroker-NUC object system.adapter.wiffi-wz created/updated
    host.iobroker-NUC	2021-01-05 11:53:59.644	info	iobroker npm-install: upload [0] wiffi-wz.admin /opt/iobroker/node_modules/iobroker.wiffi-wz/admin/index_m.html index_m.html text/html
    host.iobroker-NUC	2021-01-05 11:53:59.579	info	iobroker npm-install: upload [1] wiffi-wz.admin /opt/iobroker/node_modules/iobroker.wiffi-wz/admin/wiffi-wz.png wiffi-wz.png image/png
    host.iobroker-NUC	2021-01-05 11:53:59.459	info	iobroker npm-install: upload [2] wiffi-wz.admin /opt/iobroker/node_modules/iobroker.wiffi-wz/admin/words.js words.js application/javascript
    host.iobroker-NUC	2021-01-05 11:53:59.236	info	iobroker npm-install: host.iobroker-NUC install adapter wiffi-wz@2.2.0
    host.iobroker-NUC	2021-01-05 11:53:52.042	info	iobroker npm-install: gyp ERR! System Linux 4.19.0-13-amd64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/o
    host.iobroker-NUC	2021-01-05 11:53:52.038	info	iobroker npm-install: gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack
    host.iobroker-NUC	2021-01-05 11:53:52.035	info	iobroker npm-install: ERR! build error
    host.iobroker-NUC	2021-01-05 11:53:52.031	info	iobroker npm-install: gyp
    host.iobroker-NUC	2021-01-05 11:53:52.026	info	iobroker npm-install: make: *** [bcrypt_lib.target.mk:113: Release/obj.target/bcrypt_lib/src/bcrypt_node.o] Fehler 1
    host.iobroker-NUC	2021-01-05 11:53:51.796	info	iobroker npm-install: node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/n
    host.iobroker-NUC	2021-01-05 11:53:51.793	info	iobroker npm-install: node-pre-gyp ERR! build error
    host.iobroker-NUC	2021-01-05 11:53:51.775	info	iobroker npm-install: ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack
    host.iobroker-NUC	2021-01-05 11:53:51.761	info	iobroker npm-install:
    host.iobroker-NUC	2021-01-05 11:53:51.757	info	iobroker npm-install: build error gyp
    host.iobroker-NUC	2021-01-05 11:53:51.751	info	iobroker npm-install: ERR!
    host.iobroker-NUC	2021-01-05 11:53:51.748	info	iobroker npm-install:
    host.iobroker-NUC	2021-01-05 11:53:51.742	info	iobroker npm-install: gyp
    @weimaraner sagte in backup eingespielt und nichts passiert - Was nun?:
    Das sind Infos über (nicht relevante) Errors ;-)
    • W weimaraner
      @weimaraner
      Schaut soweit nicht wild aus.
      node richtig drin?
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      mal zeigen.
      W 1 Antwort Letzte Antwort
        @weimaraner
        node richtig drin?
        mal zeigen.
        W Offline
        W Offline
        weimaraner
        @Thomas-Braun
        /usr/bin/nodejs
        v12.20.1
        /usr/bin/node
        v12.20.1
        /usr/bin/npm
        6.14.10
        nodejs:
          Installiert:           12.20.1-1nodesource1
          Installationskandidat: 12.20.1-1nodesource1
          Versionstabelle:
         *** 12.20.1-1nodesource1 500
                500 https://deb.nodesource.com/node_12.x buster/main amd64 Packages
             10.21.0~dfsg-1~deb10u1 500
                500 http://ftp.de.debian.org/debian buster/main amd64 Packages
                500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
        • W weimaraner
          @Thomas-Braun
          /usr/bin/nodejs
          v12.20.1
          /usr/bin/node
          v12.20.1
          /usr/bin/npm
          6.14.10
          nodejs:
            Versionstabelle:
          @weimaraner Passt.
          Wegen der Meldungen würde ich mir keine Gedanken machen.
            @weimaraner Passt.
            W Offline
            W Offline
            weimaraner
            schrieb am zuletzt editiert von weimaraner
            @Thomas-Braun
            Okay. Habe jetzt alles aktualisert über die Konsole mit
            iobroker upgrade all
            Den Vis-Adapter hat es nicht aktualisert, ohne etwas dazu zu sagen. Ich sehe es nur im Admin -> installiert 1.1.7 verfügbar 1.3.4. Meine Vis startet auch nicht. 😧 Ich sehe nur den Bildschirm "Verbinde mit dem Server, Warte auf Werte..."
            Im Log steht folgendes
            vis.0	2021-01-05 13:40:21.571	info	(22723) Terminated (NO_ERROR): Without reason
            vis.0	2021-01-05 13:40:19.896	info	(22723) vis license is OK.
            vis.0	2021-01-05 13:40:19.641	info	(22723) starting. Version 1.1.7 in /opt/iobroker/node_modules/iobroker.vis, node: v12.20.1, js-controller: 3.1.6
            vis.0	2021-01-05 13:40:19.182	debug	(22723) statesDB connected
            vis.0	2021-01-05 13:40:19.180	debug	(22723) States connected to redis: 127.0.0.1:9000
            vis.0	2021-01-05 13:40:19.153	debug	(22723) States create System PubSub Client
            vis.0	2021-01-05 13:40:19.147	debug	(22723) States create User PubSub Client
            vis.0	2021-01-05 13:40:19.124	debug	(22723) Redis States: Use Redis connection: 127.0.0.1:9000
            vis.0	2021-01-05 13:40:19.120	debug	(22723) objectDB connected
            vis.0	2021-01-05 13:40:19.109	debug	(22723) Objects connected to redis: 127.0.0.1:9001
            vis.0	2021-01-05 13:40:19.066	debug	(22723) Objects client initialize lua scripts
            vis.0	2021-01-05 13:40:19.064	debug	(22723) Objects create User PubSub Client
            vis.0	2021-01-05 13:40:19.061	debug	(22723) Objects create System PubSub Client
            vis.0	2021-01-05 13:40:19.055	debug	(22723) Objects client ready ... initialize now
            vis.0	2021-01-05 13:40:18.904	debug	(22723) Redis Objects: Use Redis connection: 127.0.0.1:9001
            Hätte ich den Redis Server installieren müssen? Wußte nicht, daß ich den hatte...
            Muß ich von vorne anfangen???
            Thomas BraunT HomoranH 3 Antworten Letzte Antwort
            • W weimaraner
              @Thomas-Braun
              Ist soweit ich weiß auch der falsche Port. Da läuft eigentlich die ioBroker eigene Datenbank.
              Keine Ahnung ob da was falsch läuft.
                W Offline
                W Offline
                weimaraner
                @Thomas-Braun mmhhh. Das entwickelt sich ja zur unendlichen Geschichte...
                @simatec und @Homoran habt ihr eine Idee, was ich jetzt machen soll?
                • W weimaraner
                  @Thomas-Braun
                  das scheint nicht das "normale" Redis zu sein. Dort würdest du nur die states speichern
                  • W weimaraner
                    @Thomas-Braun
                    mach mal ein upload
                      mach mal ein upload
                      W Offline
                      W Offline
                      weimaraner
                      @Homoran meinst du in der Konsole ein
                      Iobroker upload
                      Oder was spezielles mit vis?
                      • W weimaraner
                        Iobroker upload
                        iobroker upload vis
                        oder über den admin im Expertenmodus
                          iobroker upload vis
                          W Offline
                          W Offline
                          weimaraner
                          @Homoran okay, habe ich gemacht. Das log bleibt jetzt leer. Allerdings startet der Vis Editor trotzdem nicht.
                          Mal ne blöde Frage und ich weiß nicht, ob sie zur Lösungsfindung beiträgt. Ich habe seit meiner Startzeit mit einem Pi3 die Instanz vis-beta immer mit dabei. Ich kann diese auch nicht löschen. Sie erscheint immer wieder. Kann die was damit zu tun haben? Ich habe sie im Moment deaktiviert. Die ist nun schon dreimal mit umgezogen. Vom Pi auf ein NAS und dann zum NUC.
                          • W weimaraner
                            @weimaraner Wo hast du denn die vis-beta her????
                            Adapter loschen, nicht nur die Instanz
                            und dann das "echte" vis neu installieren!
                            W 2 Antworten Letzte Antwort
                              W Offline
                              W Offline
                              weimaraner
                              @Homoran Das weiß ich eben nicht. Ich habe damals mit einem Raspi-Image gestartet. Ich kann mir nicht erklären, wann ich mir das mal aus Versehen installiert habe.
                                W Offline
                                W Offline
                                weimaraner
                                @Homoran Das ist ja mein Problem. In der Adapterliste beim Admin taucht der Adapter Vis-beta nicht auf. Wie kann ich ihn noch löschen?
                                Wenn ich die "echte" vis neu installiere, bleiben dann meine vis Projekte erhalten?
                                • W weimaraner
                                  wahrscheinlich weil es den schon Jahre nicht mehr gibt
                                  Was sagt
                                  iobroker list adapters
                                  iobroker list instances
                                  Da müsste der Adapter dann zu sehen sein
                                  Ansonsten würde ich denken, dass es mit iobroker del vis-beta zu löschen gehen könnte
                                    Was sagt
                                    W Offline
                                    W Offline
                                    weimaraner
                                    @Homoran Vis-beta erfolgreich gelöscht. 👍 Ein upgrade des Vis-Adapters und eine anschließende Aktualisierung der Instanz haben geholfen!!!
                                    Ich sehe meine VIS wieder! 😀 Danke! Danke! Danke!
                                    Jetzt muß ich nur noch meine homematic wieder zum Laufen bringen. Irgendwie scheint das schiefgegangene iobroker update meine CCU2 ausser Gefecht gesetzt zu haben.
                                    • W weimaraner
                                      sagst du auch wie?
                                        sagst du auch wie?
                                        W Offline
                                        W Offline
                                        weimaraner
                                        @Homoran Aber gerne! 😀 Mit dem von dir vorgeschlagenen
                                        Nach einem update meiner CCU2 läuft nun auch der hm-rega wieder. Auch der Shelly meckert nicht mehr. Dort hatte ich bei einem shelly die Weboberfläche mit login versehen. Damit wollte der Adapter trotz entsprechendem Eintrag in den Einstellungen nicht arbeiten. Habe das Login rausgenommen. Die Shelly dürfen eh nicht nach draussen. Jetzt geht alles.
                                        @Homoran @simatec und vor allem @Thomas-Braun vielen, vielen Dank für Eure Engelsgeduld. Die Hilfsbereitschaft hier ist wirklich spitze. Nach "nur" knapp 30 Stunden downtime läuft alles wieder. 😂 😂 😂 Ich habe mich teils echt bekloppt angestellt... Naja, dafür doch viel dazugelernt. Also DANKE!
                                        Grüße Andreas
                                        • W weimaraner
                                          Grüße Andreas
                                          @weimaraner sagte in [gelöst] backup eingespielt und nichts passiert - Was nun?:
                                          dann hat es sich ja gelohnt!
