  2. English
  3. ioBroker general
  4. Simple API Use SOLVED
    apollon77A
Geplant Angeheftet Gesperrt Verschoben ioBroker general
apisimple api
22 Beiträge 5 Kommentatoren 13.7k Aufrufe 4 Beobachtet
  • A
    A
    ap2017
    schrieb am zuletzt editiert von ap2017
    I would like to get motion notification from MotionEye via Simple Api using method GET
    http: // IP_ioBroker: 8087/ set / javascript.0.Pi-detection? Value = true
    I added Pi-detection user.data.0 Boolean variable. Is there special setting needed for Simple APi adapter?
    UncleSamU 1 Antwort Letzte Antwort
    • A ap2017
      UncleSamU
      UncleSamU
      UncleSam
      schrieb am zuletzt editiert von UncleSam
      @ap2017 What are you trying to do and what is your issue?
      The URL you are providing contains a lot of spaces (which is wrong).
      Also you say user.data.0 (which doesn't exist) and then try to use javascript.0. IDs must match exactly the IDs in ioBroker. Simply use the "copy" button next to the state ID to get the full ID in the correct format.
      Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
      ♡-lichen Dank an meine Sponsoren
      • UncleSamU UncleSam
        A
        A
        ap2017
        @UncleSam Thank you for quick response and good comments. My actual URL does not have extra spaces:
        http://iobrokerIP:8087/set/javascript.0.Pi-detection?Value=true
        I created PI-detection variable in javascript.0 folder and monitoring value of this variable in response to motion detection from MotionEye, but so far I am getting nothing. My MotionEye Web Hook URL is http://iobrokerIP:8087/set/javascript.0.Pi-detection?Value=true with HTTP method set as GET
        paul53P UncleSamU 2 Antworten Letzte Antwort
        • A ap2017
          paul53P
          paul53P
          @ap2017
          Link is wrong (Value --> value).
          http://iobrokerip:8087/set/javascript.0.Pi-detection?value=true
          • A ap2017
            UncleSamU
            UncleSamU
            UncleSam
            @ap2017 Thanks for the clarifications.
            What happens if you open the URL in your browser? Do you get a JSON response similar to the following or an error message?
            {"id":"javascript.0.Pi-detection","value":true}
            How do you know that you are "getting nothing"?
              A
              A
              ap2017
              @UncleSam In browser I am getting error message
              "error: datapoint "javascript.0.Pi-detection" not found"
              I monitor variable PI-detection as Boolean widget in VIS
              • A ap2017
                UncleSamU
                UncleSamU
                UncleSam
                @ap2017 Can you please share a screenshot of your object tree in ioBroker where we can see the mentioned state (and its parents)?
                  A
                  A
                  ap2017
                  @UncleSam Here the screenshot. Do I need to have subfolder variables in my URL?
                  • A ap2017
                    paul53P
                    paul53P
                    @ap2017
                    URL: http://iobrokerip:8087/set/javascript.0.variables.PI-detection?value=true
                    • A ap2017
                      UncleSamU
                      UncleSamU
                      UncleSam
                      @ap2017 So, did you copy the state ID the way I asked you to?
                      Because it seems to me that the name should be javascript.0.variables.PI-detection
                      A 2 Antworten Letzte Antwort
                        A
                        A
                        ap2017
                        @UncleSam Thank you, with subfolder "variables" added I am getting browser response
                        {"id":"javascript.0.variables.PI-detection","value":true,"val":true}
                        Now I need to figure out how MotionEye notification work, since I PI-detection does not change in response to motion
                          A
                          A
                          ap2017
                          @UncleSam Everything works now. I did not realized that I have to reset the web hook variable after motion is detected.
                          • A ap2017
                            T
                            T
                            tehMilcho
                            Hey there,
                            i got the same Error but little different problem. I have copyed the Object-Path with the little button.
                            so i build this URL:
                            http://SERVER:8087/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=false&prettyPrint
                            The Url works fine in any browser but when i try to use it in my code i get:
                            "error: no value found for "0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1". Use /set/id?value=1 or /set/id?value=1&wait=1000"
                            I will use it in a Lua Script that runs on the "Fibaro Home center lite". When i rebuild the URL to "toggle" it works fine.. i have no clue whats the issue .. because it makes no sense for me.
                            Lua Code:
                            local value = fibaro.getValue(52, "value")
                            local url
                            -- Deside if value should be true or false
                            if (fibaro.getValue(52, "value") == true) then
                            url = 'http://SERVER:8087/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=true&prettyPrint'
                            elseif (fibaro.getValue(52, "value") == false) then
                            url = 'SERVER/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=false&prettyPrint'
                            else
                            print ("No Match")
                            end
                            print(url)
                            local selfhttp = net.HTTPClient()
                            local headers = {
                                    ["Accept"] = "application/json",
                                    ["Content-Type"] = 'application/json',
                                    ["Cache-Control"] = "no-cache"
                            selfhttp:request(url, {
                              options={
                                method = 'GET',
                                headers = headers,
                                timeout = 5000
                             success = function(response)
                                        print(response.status)
                                        print(response.data)
                                end,
                                error = function(message)
                                        print("error:", message)
                                end
                            anyone knows something? i think i had the same issue by try to use something like this in Android App - Tasker, but then give out and used toggle.
                            • M
                              M
                              MCU
                              @tehmilcho sagte in Simple API Use SOLVED:
                              Try to encode the URL
                              let encodedUrl = encodeURIComponent(url);
                              • M MCU
                                T
                                T
                                tehMilcho
                                @mcu said in Simple API Use SOLVED:
                                the Lua Script in Fibaro seems not happy about it:
                                [24.11.2023] [22:43:48] [ERROR] [SCENE29]: (load):15: syntax error near 'encodedUrl
                                • T tehMilcho
                                  M
                                  M
                                  MCU
                                  @tehmilcho In LUA seems to be
                                  local encodedUrl = url.escape(url)
                                  • M MCU
                                    T
                                    T
                                    tehMilcho
                                    mhh seems like fibaro specail lua?
                                    [24.11.2023] [22:54:25] [ERROR] [SCENE29]: (load):23: attempt to call a nil value (field 'escape')
                                    • T tehMilcho
                                      M
                                      M
                                      MCU
                                      @tehmilcho Do you use it so?
                                      url = url.escape(url)
                                        options={
                                          method = 'GET',
                                          headers = headers,
                                          timeout = 5000
                                        end,
                                        end
                                      • M MCU
                                          options={
                                            method = 'GET',
                                            headers = headers,
                                            timeout = 5000
                                          end,
                                          end
                                        T
                                        T
                                        tehMilcho
                                        @mcu yep this leads to "[24.11.2023] [22:54:25] [ERROR] [SCENE29]: (load):23: attempt to call a nil value (field 'escape')"
                                        • T tehMilcho
                                          M
                                          M
                                          MCU
                                          Try this
                                          url = url:gsub("([^A-Za-z0-9_])", function(c) return string.format("%%%02X", string.byte(c)) end)
                                          83.9k
