  2. English
  3. ioBroker general
  4. Simple API Use SOLVED
    apollon77A
Geplant Angeheftet Gesperrt Verschoben ioBroker general
apisimple api
22 Beiträge 5 Kommentatoren 13.6k Aufrufe 4 Beobachtet
  • A ap2017
    I would like to get motion notification from MotionEye via Simple Api using method GET
    http: // IP_ioBroker: 8087/ set / javascript.0.Pi-detection? Value = true
    I added Pi-detection user.data.0 Boolean variable. Is there special setting needed for Simple APi adapter?
    UncleSamU
    UncleSamU
    UncleSam
    schrieb am zuletzt editiert von UncleSam
    @ap2017 What are you trying to do and what is your issue?
    The URL you are providing contains a lot of spaces (which is wrong).
    Also you say user.data.0 (which doesn't exist) and then try to use javascript.0. IDs must match exactly the IDs in ioBroker. Simply use the "copy" button next to the state ID to get the full ID in the correct format.
    Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
    ♡-lichen Dank an meine Sponsoren
    • UncleSamU UncleSam
      A
      A
      ap2017
      @UncleSam Thank you for quick response and good comments. My actual URL does not have extra spaces:
      http://iobrokerIP:8087/set/javascript.0.Pi-detection?Value=true
      I created PI-detection variable in javascript.0 folder and monitoring value of this variable in response to motion detection from MotionEye, but so far I am getting nothing. My MotionEye Web Hook URL is http://iobrokerIP:8087/set/javascript.0.Pi-detection?Value=true with HTTP method set as GET
      paul53P UncleSamU 2 Antworten Letzte Antwort
      • A ap2017
        paul53P
        paul53P
        @ap2017
        Link is wrong (Value --> value).
        http://iobrokerip:8087/set/javascript.0.Pi-detection?value=true
        • A ap2017
          UncleSamU
          UncleSamU
          UncleSam
          @ap2017 Thanks for the clarifications.
          What happens if you open the URL in your browser? Do you get a JSON response similar to the following or an error message?
          {"id":"javascript.0.Pi-detection","value":true}
          How do you know that you are "getting nothing"?
            A
            A
            ap2017
            @UncleSam In browser I am getting error message
            "error: datapoint "javascript.0.Pi-detection" not found"
            I monitor variable PI-detection as Boolean widget in VIS
            UncleSamU 1 Antwort Letzte Antwort
            • A ap2017
              UncleSamU
              UncleSamU
              UncleSam
              @ap2017 Can you please share a screenshot of your object tree in ioBroker where we can see the mentioned state (and its parents)?
                A
                A
                ap2017
                @UncleSam Here the screenshot. Do I need to have subfolder variables in my URL?
                • A ap2017
                  paul53P
                  paul53P
                  @ap2017
                  URL: http://iobrokerip:8087/set/javascript.0.variables.PI-detection?value=true
                  • A ap2017
                    UncleSamU
                    UncleSamU
                    UncleSam
                    @ap2017 So, did you copy the state ID the way I asked you to?
                    Because it seems to me that the name should be javascript.0.variables.PI-detection
                    A 2 Antworten Letzte Antwort
                      A
                      A
                      ap2017
                      schrieb am zuletzt editiert von ap2017
                      @UncleSam Thank you, with subfolder "variables" added I am getting browser response
                      {"id":"javascript.0.variables.PI-detection","value":true,"val":true}
                      Now I need to figure out how MotionEye notification work, since I PI-detection does not change in response to motion
                        A
                        A
                        ap2017
                        @UncleSam Everything works now. I did not realized that I have to reset the web hook variable after motion is detected.
                        • A ap2017
                          T
                          T
                          tehMilcho
                          Hey there,
                          i got the same Error but little different problem. I have copyed the Object-Path with the little button.
                          so i build this URL:
                          http://SERVER:8087/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=false&prettyPrint
                          The Url works fine in any browser but when i try to use it in my code i get:
                          "error: no value found for "0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1". Use /set/id?value=1 or /set/id?value=1&wait=1000"
                          I will use it in a Lua Script that runs on the "Fibaro Home center lite". When i rebuild the URL to "toggle" it works fine.. i have no clue whats the issue .. because it makes no sense for me.
                          Lua Code:
                          local value = fibaro.getValue(52, "value")
                          local url
                          -- Deside if value should be true or false
                          if (fibaro.getValue(52, "value") == true) then
                          url = 'http://SERVER:8087/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=true&prettyPrint'
                          elseif (fibaro.getValue(52, "value") == false) then
                          url = 'SERVER/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=false&prettyPrint'
                          else
                          print ("No Match")
                          end
                          print(url)
                          local selfhttp = net.HTTPClient()
                          local headers = {
                                  ["Accept"] = "application/json",
                                  ["Content-Type"] = 'application/json',
                                  ["Cache-Control"] = "no-cache"
                          selfhttp:request(url, {
                            options={
                              method = 'GET',
                              headers = headers,
                              timeout = 5000
                           success = function(response)
                                      print(response.status)
                                      print(response.data)
                              end,
                              error = function(message)
                                      print("error:", message)
                              end
                          anyone knows something? i think i had the same issue by try to use something like this in Android App - Tasker, but then give out and used toggle.
                          • M
                            M
                            MCU
                            @tehmilcho sagte in Simple API Use SOLVED:
                            Try to encode the URL
                            let encodedUrl = encodeURIComponent(url);
                            • M MCU
                              T
                              T
                              tehMilcho
                              @mcu said in Simple API Use SOLVED:
                              the Lua Script in Fibaro seems not happy about it:
                              [24.11.2023] [22:43:48] [ERROR] [SCENE29]: (load):15: syntax error near 'encodedUrl
                              • T tehMilcho
                                M
                                M
                                MCU
                                @tehmilcho In LUA seems to be
                                local encodedUrl = url.escape(url)
                                • M MCU
                                  T
                                  T
                                  tehMilcho
                                  mhh seems like fibaro specail lua?
                                  [24.11.2023] [22:54:25] [ERROR] [SCENE29]: (load):23: attempt to call a nil value (field 'escape')
                                  • T tehMilcho
                                    M
                                    M
                                    MCU
                                    @tehmilcho Do you use it so?
                                    url = url.escape(url)
                                      options={
                                        method = 'GET',
                                        headers = headers,
                                        timeout = 5000
                                      end,
                                      end
                                    • M MCU
                                        options={
                                          method = 'GET',
                                          headers = headers,
                                          timeout = 5000
                                        end,
                                        end
                                      T
                                      T
                                      tehMilcho
                                      @mcu yep this leads to "[24.11.2023] [22:54:25] [ERROR] [SCENE29]: (load):23: attempt to call a nil value (field 'escape')"
                                      • T tehMilcho
                                        M
                                        M
                                        MCU
                                        Try this
                                        url = url:gsub("([^A-Za-z0-9_])", function(c) return string.format("%%%02X", string.byte(c)) end)
                                        • M MCU
                                          Try this
                                          T
                                          T
                                          tehMilcho
                                          then it seems to get stuck, no error but will not finsh and also the state in iobroker is not changed, when you Output the new string you will get:
                                          http%3A%2F%2F192%2E168%2E178%2E37%3A8087%2Fset%2F0_userdata%2E0%2EVirtualDevices%2Ehc3lite%2EFlurPIR%2D1%3Fvalue%3Dtrue%26prettyPrint
                                          83.9k
