  2. English
  3. ioBroker general
  4. Simple API Use SOLVED
    6.6k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
apisimple api
22 Beiträge 5 Kommentatoren 13.3k Aufrufe 4 Beobachtet
  • UncleSamU UncleSam
    @ap2017 So, did you copy the state ID the way I asked you to?
    Because it seems to me that the name should be javascript.0.variables.PI-detection
    ap2017
    @UncleSam Everything works now. I did not realized that I have to reset the web hook variable after motion is detected.
    • A ap2017
      tehMilcho
      Hey there,
      i got the same Error but little different problem. I have copyed the Object-Path with the little button.
      so i build this URL:
      http://SERVER:8087/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=false&prettyPrint
      The Url works fine in any browser but when i try to use it in my code i get:
      "error: no value found for "0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1". Use /set/id?value=1 or /set/id?value=1&wait=1000"
      I will use it in a Lua Script that runs on the "Fibaro Home center lite". When i rebuild the URL to "toggle" it works fine.. i have no clue whats the issue .. because it makes no sense for me.
      Lua Code:
      local value = fibaro.getValue(52, "value")
      local url
      -- Deside if value should be true or false
      if (fibaro.getValue(52, "value") == true) then
      url = 'http://SERVER:8087/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=true&prettyPrint'
      elseif (fibaro.getValue(52, "value") == false) then
      url = 'SERVER/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=false&prettyPrint'
      else
      print ("No Match")
      end
      print(url)
      local selfhttp = net.HTTPClient()
      local headers = {
              ["Accept"] = "application/json",
              ["Content-Type"] = 'application/json',
              ["Cache-Control"] = "no-cache"
      selfhttp:request(url, {
        options={
          method = 'GET',
          headers = headers,
          timeout = 5000
       success = function(response)
                  print(response.status)
                  print(response.data)
          end,
          error = function(message)
                  print("error:", message)
          end
      anyone knows something? i think i had the same issue by try to use something like this in Android App - Tasker, but then give out and used toggle.
      • M Online
        M Online
        MCU
        @tehmilcho sagte in Simple API Use SOLVED:
        Try to encode the URL
        let encodedUrl = encodeURIComponent(url);
        • M MCU
          tehMilcho
          @mcu said in Simple API Use SOLVED:
          the Lua Script in Fibaro seems not happy about it:
          [24.11.2023] [22:43:48] [ERROR] [SCENE29]: (load):15: syntax error near 'encodedUrl
          • T tehMilcho
            M Online
            M Online
            MCU
            @tehmilcho In LUA seems to be
            local encodedUrl = url.escape(url)
            • M MCU
              tehMilcho
              mhh seems like fibaro specail lua?
              [24.11.2023] [22:54:25] [ERROR] [SCENE29]: (load):23: attempt to call a nil value (field 'escape')
              • T tehMilcho
                M Online
                M Online
                MCU
                @tehmilcho Do you use it so?
                url = url.escape(url)
                  options={
                    method = 'GET',
                    headers = headers,
                    timeout = 5000
                  end,
                  end
                • M MCU
                    options={
                      method = 'GET',
                      headers = headers,
                      timeout = 5000
                    end,
                    end
                  tehMilcho
                  @mcu yep this leads to "[24.11.2023] [22:54:25] [ERROR] [SCENE29]: (load):23: attempt to call a nil value (field 'escape')"
                  • T tehMilcho
                    M Online
                    M Online
                    MCU
                    Try this
                    url = url:gsub("([^A-Za-z0-9_])", function(c) return string.format("%%%02X", string.byte(c)) end)
                    • M MCU
                      Try this
                      tehMilcho
                      then it seems to get stuck, no error but will not finsh and also the state in iobroker is not changed, when you Output the new string you will get:
                      http%3A%2F%2F192%2E168%2E178%2E37%3A8087%2Fset%2F0_userdata%2E0%2EVirtualDevices%2Ehc3lite%2EFlurPIR%2D1%3Fvalue%3Dtrue%26prettyPrint
                      • T tehMilcho
                        tehMilcho
                        @MCU but this brings me on track, i now swap the "?" with "%3F" now it works .. damn @MCU you are f****** smart :) Thanks a lot. spend already hours on this :)
