  2. English
  3. ioBroker general
  4. Simple API Use SOLVED
Geplant Angeheftet Gesperrt Verschoben ioBroker general
apisimple api
22 Beiträge 5 Kommentatoren 13.9k Aufrufe 4 Beobachtet
  • A ap2017
    @UncleSam In browser I am getting error message
    "error: datapoint "javascript.0.Pi-detection" not found"
    I monitor variable PI-detection as Boolean widget in VIS
    UncleSamU
    UncleSamU
    UncleSam
    @ap2017 Can you please share a screenshot of your object tree in ioBroker where we can see the mentioned state (and its parents)?
    Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
    ♡-lichen Dank an meine Sponsoren
    • UncleSamU UncleSam
      A
      A
      ap2017
      @UncleSam Here the screenshot. Do I need to have subfolder variables in my URL?
      paul53P UncleSamU 2 Antworten Letzte Antwort
      • A ap2017
        paul53P
        paul53P
        @ap2017
        URL: http://iobrokerip:8087/set/javascript.0.variables.PI-detection?value=true
        Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
        • A ap2017
          UncleSamU
          UncleSamU
          UncleSam
          @ap2017 So, did you copy the state ID the way I asked you to?
          Because it seems to me that the name should be javascript.0.variables.PI-detection
          A 2 Antworten Letzte Antwort
            A
            A
            ap2017
            schrieb am zuletzt editiert von ap2017
            @UncleSam Thank you, with subfolder "variables" added I am getting browser response
            {"id":"javascript.0.variables.PI-detection","value":true,"val":true}
            Now I need to figure out how MotionEye notification work, since I PI-detection does not change in response to motion
              A
              A
              ap2017
              @UncleSam Everything works now. I did not realized that I have to reset the web hook variable after motion is detected.
              • A ap2017
                T
                T
                tehMilcho
                Hey there,
                i got the same Error but little different problem. I have copyed the Object-Path with the little button.
                so i build this URL:
                http://SERVER:8087/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=false&prettyPrint
                The Url works fine in any browser but when i try to use it in my code i get:
                "error: no value found for "0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1". Use /set/id?value=1 or /set/id?value=1&wait=1000"
                I will use it in a Lua Script that runs on the "Fibaro Home center lite". When i rebuild the URL to "toggle" it works fine.. i have no clue whats the issue .. because it makes no sense for me.
                Lua Code:
                local value = fibaro.getValue(52, "value")
                local url
                -- Deside if value should be true or false
                if (fibaro.getValue(52, "value") == true) then
                url = 'http://SERVER:8087/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=true&prettyPrint'
                elseif (fibaro.getValue(52, "value") == false) then
                url = 'SERVER/set/0_userdata.0.VirtualDevices.hc3lite.FlurPIR-1?value=false&prettyPrint'
                else
                print ("No Match")
                end
                print(url)
                local selfhttp = net.HTTPClient()
                local headers = {
                        ["Accept"] = "application/json",
                        ["Content-Type"] = 'application/json',
                        ["Cache-Control"] = "no-cache"
                selfhttp:request(url, {
                  options={
                    method = 'GET',
                    headers = headers,
                    timeout = 5000
                 success = function(response)
                            print(response.status)
                            print(response.data)
                    end,
                    error = function(message)
                            print("error:", message)
                    end
                anyone knows something? i think i had the same issue by try to use something like this in Android App - Tasker, but then give out and used toggle.
                • M
                  M
                  MCU
                  @tehmilcho sagte in Simple API Use SOLVED:
                  Try to encode the URL
                  let encodedUrl = encodeURIComponent(url);
                  • M MCU
                    T
                    T
                    tehMilcho
                    @mcu said in Simple API Use SOLVED:
                    the Lua Script in Fibaro seems not happy about it:
                    [24.11.2023] [22:43:48] [ERROR] [SCENE29]: (load):15: syntax error near 'encodedUrl
                    • T tehMilcho
                      M
                      M
                      MCU
                      @tehmilcho In LUA seems to be
                      local encodedUrl = url.escape(url)
                      • M MCU
                        T
                        T
                        tehMilcho
                        mhh seems like fibaro specail lua?
                        [24.11.2023] [22:54:25] [ERROR] [SCENE29]: (load):23: attempt to call a nil value (field 'escape')
                        • T tehMilcho
                          M
                          M
                          MCU
                          @tehmilcho Do you use it so?
                          url = url.escape(url)
                            options={
                              method = 'GET',
                              headers = headers,
                              timeout = 5000
                            end,
                            end
                          • M MCU
                              options={
                                method = 'GET',
                                headers = headers,
                                timeout = 5000
                              end,
                              end
                            T
                            T
                            tehMilcho
                            @mcu yep this leads to "[24.11.2023] [22:54:25] [ERROR] [SCENE29]: (load):23: attempt to call a nil value (field 'escape')"
                            • T tehMilcho
                              M
                              M
                              MCU
                              Try this
                              url = url:gsub("([^A-Za-z0-9_])", function(c) return string.format("%%%02X", string.byte(c)) end)
                              • M MCU
                                Try this
                                T
                                T
                                tehMilcho
                                then it seems to get stuck, no error but will not finsh and also the state in iobroker is not changed, when you Output the new string you will get:
                                http%3A%2F%2F192%2E168%2E178%2E37%3A8087%2Fset%2F0_userdata%2E0%2EVirtualDevices%2Ehc3lite%2EFlurPIR%2D1%3Fvalue%3Dtrue%26prettyPrint
                                • T tehMilcho
                                  T
                                  T
                                  tehMilcho
                                  @MCU but this brings me on track, i now swap the "?" with "%3F" now it works .. damn @MCU you are f****** smart :) Thanks a lot. spend already hours on this :)
                                  84.1k
