  4. Test Coronavirus Statistics for ioBroker
    6.3k
adapter installationadapterentwicklungtesten
1.2k Beiträge 120 Kommentatoren 498.6k Aufrufe 94 Beobachtet
  • DutchmanD Offline
    DutchmanD Offline
    Dutchman
    schrieb am zuletzt editiert von Dutchman
    #752
    @andyb
    E HomoranH 2 Antworten Letzte Antwort
    • DutchmanD Dutchman
      @andyb
      ebu
      #753
      @Dutchman danke, funktioniert :)
      • E ebu
        NashraN Offline
        NashraN Offline
        Nashra
        Most Active Forum Testing
        #754
        @ebu sagte in Test Coronavirus Statistics for ioBroker:
        Schließe mich an, danke @Dutchman 👍
        Gruß Ralf
          Aktuelle Test Version 0.6.9
          Veröffentlichungsdatum 22-03-2021
          Github Link https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/blob/master/README.md
          NPM npm i ioBroker.coronavirus-statistics@latest
          Adapter to show Global Corona Virus information and current reports
          Coronavirus Live Statistics adapter for ioBroker
          There is no configuration required, after installation it will :
          • Receive global information world-wide and write it to "global_totals"
          • Create a folder for each country with all relevant information regarding COVID-19
          • Update the information every 15 minutes
          The following information is available :
          Datapoint Details
          active Amount of current infected people
          cases Amount of totally known cases
          casesPerOneMillion Amount of totally known cases per million citizen
          critical Amount of critical situation (Hospitalized)
          deaths Amount of current registered deaths
          deathsPerOneMillion Amount of current registered deaths per million citizen
          recovered Amount of totally known recovered cases
          todayCases New Cases by Today
          todayDeaths Amount of totally known people died today
          test Total number of covid-19 tests taken globally
          tests per one million counties Total number of covid-19 tests taken globally per one million
          Please be aware this adapter uses as much as possible up-to-date information but there can be an delay of several hours depending on the country's report.
          German Federal States : https://npgeo-corona-npgeo-de.hub.arcgis.com/ s
          Generic Source : https://coronavirus-19-api.herokuapp.com
          Advanced settings
          Option Description
          All Countries Get data for all countries World-Wide (Default: false)
          Continents Group total amounts by continent in seperate state (Default: false)
          Delete unused States Delete data when countries are deselected (Default: false)
          German counties Get counties data for Germany (Selected only, Default false)
          German federal states Get federal state data for Germany (Selected only, Default false)
          Get all German federal states Get federal state data for Germany (Default false)
          Get all German counties Get all counties data for Germany (Default false)
          For Germany only
          It's possible to get data for federal states (Bundesländer) and counties (Landeskreise).
          You can choose to recieve all data or just select specific regions in advanced settings.
          Please note : After activation the the adapter must run 1 time to get all federal states and counties before table loads !
          Add missing countries
          It may happen that countries are not recognized correctly because the API delivers some country names not ISO conform. In such a case you will get a warning message in the log, which looks like this
          coronavirus-statistics.0	2020-03-21 09:05:31.328	warn	(22937) Timor-Leste not found in lib! Must be added to the country name translator.
          Using the datapoint coronavirus-statistics.0.countryTranslator you can assign a country yourself. Look for the name of the corresponding country here:
          List with country names
          With the selected country name you have to create a JSON string and enter it in the datapoint coronavirus-statistics.0.countryTranslator.
          The JSON string then looks like this, for example:
          	"Cabo_Verde": "Cape Verde",
          	"Timor-Leste": "East Timor"
          As first value the name from the warning message must be taken from the log. The name of the country from the List with country names is then assigned to this.
          Changelog
          deta
          #755
          Schon jemand was gebastelt an VIS für die Impfungen?
            @andyb
            #756
            @Dutchman
            Hallo Dutch!
            ist da noch ein kleiner Bug drin?
              @Dutchman
              Hallo Dutch!
              DutchmanD Offline
              DutchmanD Offline
              Dutchman
              #757
              @Homoran sagte in Test Coronavirus Statistics for ioBroker:
              @Dutchman
              Hallo Dutch!
              jup behoben in 0.6.6, danke !
              Da wurde noch ein channel erstellt welcher dort nicht hingehört
              • NashraN Offline
                NashraN Offline
                Nashra
                #758
                Hallo @Dutchman
                im Widget werden bei UK und Netherlands keine Daten angezeigt
                Gruß Ralf
                • NashraN Nashra
                  Hallo @Dutchman
                  DutchmanD Offline
                  DutchmanD Offline
                  Dutchman
                  #759
                  @Nashra sagte in Test Coronavirus Statistics for ioBroker:
                  Hallo @Dutchman
                  beim widget bin ich leider machtlos da hatte BF mal geholfen ich Kappiere das frontend zeug aber nicht :/
                  • D deta
                    sigi234S Online
                    sigi234S Online
                    #760
                    @deta sagte in Test Coronavirus Statistics for ioBroker:
                    Bin gerade dabei:
                    View Import:
                    VIEW_Corona_Impfungen_sigi234.txt
                      Hallo @Dutchman
                      NashraN Offline
                      NashraN Offline
                      Nashra
                      #761
                      @Dutchman sagte in Test Coronavirus Statistics for ioBroker:
                      Hallo @Dutchman
                      kein Problem, so wichtig ist das nicht 😁
                      Gruß Ralf
                      • sigi234S sigi234
                        Bin gerade dabei:
                        View Import:
                        deta
                        #762
                        @sigi234 Sieht gut aus, geht warscheinlich nicht wieder ohne das Matterial Adapter..
                        • D deta
                          sigi234S Online
                          sigi234S Online
                          #763
                          Jupp 😀
                          • sigi234S sigi234
                            Jupp 😀
                            deta
                            #764
                            @sigi234 schade
                            • D deta
                              @sigi234 schade
                              sigi234S Online
                              sigi234S Online
                              #765
                              @sigi234 schade
                              Extra für Dich.Ohne MD. 🙂
                              VIEW_Corona_Impfungen_2_sigi234.txt
                              DutchmanD D 2 Antworten Letzte Antwort
                              • sigi234S sigi234
                                @sigi234 schade
                                DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                #766
                                @sigi234
                                Darf ich das als Template in die GitHub repo übernehmen?
                                  @sigi234
                                  sigi234S Online
                                  sigi234S Online
                                  #767
                                  @sigi234
                                  Natürlich
                                  • sigi234S sigi234
                                    @sigi234 schade
                                    deta
                                    schrieb am zuletzt editiert von deta
                                    #768
                                    Passende Flaggen hier
                                    • DutchmanD Offline
                                      DutchmanD Offline
                                      Dutchman
                                      #769
                                      schonmal als Vorwarnung, einige werde Probleme mit der neuen version haben darum hab ich soeben n bugfix released !
                                      sigi234S E 2 Antworten Letzte Antwort
                                        sigi234S Online
                                        sigi234S Online
                                        #770
                                        Läuft. 👍
                                        Ich lasse meine View aber so wie sie ist. Solltest du es in das Template in die GitHub repo übernehmen.
                                          ebu
                                          #771
                                          @Dutchman die aktuelle 0.6.8 stürzt immer ab und aktualisiert nicht?
                                           instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
