  4. Yet another HomeKit adapter
1.8k Beiträge 206 Kommentatoren 1.1m Aufrufe 68 Beobachtet
  • T TheAriba
    @Asgothian scheint so dass dann kein Status in der Home App ankommt. Gibt es dafür abhilfe?
    loverz
    #1098
    @EnoceanEltako wann kommt kein Status in der HomeApp an?
    • T TDCroPower
      @Asgothian mit deinen Formeln erhalte ich beim starten vom Adapter folgende error Logmeldung...
      yahka.0	2020-12-14 15:50:29.796	error	at _loop_1 (/opt/iobroker/node_modules/iobroker.yahka/main.js:2874:40)
      yahka.0	2020-12-14 15:50:29.796	error	at THomeKitBridge../yahka.homekit-bridge.ts.THomeKitBridge.createDevice (/opt/iobroker/node_modules/iobroker.yahka/main.js:2960:33)
      yahka.0	2020-12-14 15:50:29.796	error	at YahkaServiceInitializer../yahka.homekit-service.ts.YahkaServiceInitializer.initServices (/opt/iobroker/node_modules/iobroker.yahka/main.js:3366:22)
      yahka.0	2020-12-14 15:50:29.796	error	at YahkaServiceInitializer../yahka.homekit-service.ts.YahkaServiceInitializer.initService (/opt/iobroker/node_modules/iobroker.yahka/main.js:3414:22)
      yahka.0	2020-12-14 15:50:29.796	error	at YahkaServiceInitializer../yahka.homekit-service.ts.YahkaServiceInitializer.initCharacteristic (/opt/iobroker/node_modules/iobroker.yahka/main.js:3460:57)
      yahka.0	2020-12-14 15:50:29.796	error	at TIOBrokerAdapter../yahka.ioBroker-adapter.ts.TIOBrokerAdapter.CreateBinding (/opt/iobroker/node_modules/iobroker.yahka/main.js:3722:64)
      yahka.0	2020-12-14 15:50:29.796	error	at Object.createConversionFunction (/opt/iobroker/node_modules/iobroker.yahka/main.js:2055:61)
      yahka.0	2020-12-14 15:50:29.796	error	at Object../yahka.functions/functions.import.ts.functions_factory_1.conversionFactory.script (/opt/iobroker/node_modules/iobroker.yahka/main.js:2110:86)
      yahka.0	2020-12-14 15:50:29.796	error	at new TIoBrokerConversion_Script (/opt/iobroker/node_modules/iobroker.yahka/main.js:1919:30)
      yahka.0	2020-12-14 15:50:29.796	error	at new Function (<anonymous>)
      yahka.0	2020-12-14 15:50:29.796	error	(27929) SyntaxError: Unexpected token '}'
      yahka.0	2020-12-14 15:50:29.795	error	(27929) unhandled promise rejection: Unexpected token '}'
      Unhandled	2020-12-14 15:50:29.794	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      yahka.0
      edit:
      muss das Ergebnis nicht vielleicht noch am Ende gerundet werden mit math.round() um die Nachkommastellen zu eliminieren?
      Denn mit dem Kelvin Wert 6500 und der ersten Min formel erhalte ich...
      Math.min(1000000/6500,500) = 153.84615384615384
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      #1099
      @TDCroPower du kannst noch ein "math.floor(...) drum setzen.
      entscheidend ist.. ich hab eine ) vergessen :)
      • AsgothianA Asgothian
        TDCroPower
        #1100
        @Asgothian irgendwas stimmt weiterhin noch nicht.
        HomeKit
        return (math.floor(math.max(math.min(1000000/value,500),150)))
        und ioBroker...
        return (math.floor(math.max(math.min(100000/value,6500),2000)))
        • T TDCroPower
          HomeKit
          und ioBroker...
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          #1101
          @TDCroPower sagte in Yet another HomeKit adapter:
          Ich hab nochmal nachgeschaut. Versuch mal bitte folgendes :
          HomeKit
          return Math.floor(Math.max(Math.min(1000000/value,500),150))
          und ioBroker...
          return Math.floor(Math.max(Math.min(100000/value,6500),2000))
          • L loverz
            TheAriba
            schrieb am zuletzt editiert von TheAriba
            #1102
            @loverz
            Das tritt bspw. auf bei:
            • ich öffne Home und habe vorher extern etwas geschalten
            • ich steuere etwas über Home und schließe die App und öffne sie danach wieder
            Beide Male bleiben die Lichter oder Zwischenstecker, was auch immer, ausgegraut.
            Edit: meine Fenstersensoren werden immer korrekt und direkt angezeigt
            E 1 Antwort Letzte Antwort
              TheAriba
              #1103
              Bin ich tatsächlich der Einzige mit diesem Problem?
              L 1 Antwort Letzte Antwort
              • T TheAriba
                loverz
                #1104
                @EnoceanEltako ich würde dir gerne helfen, weil es bei mir super funktioniert.
                Kannst du mal die betroffenen Eigenschaften von YAHKA posten?
                Also wie hast du deine Lampe in YAHKA eingebunden?
                -iOS Aktuell?
                -Jailbreak?
                -Bridge AppleTV? iPad? LAN? WLAN?
                • L loverz
                  -iOS Aktuell?
                  -Jailbreak?
                  TheAriba
                  #1105
                  @loverz
                  also im Yahka folgendes eingestellt:
                  Das Objekt dazu sieht so aus:
                  iOS ist aktuell, kein Jailbreak, pi4 mit 8gb und Yahka per LAN angeschlossen.
                  Meinst du es bringt was eine Steuerzentrale zu definieren?
                  • T TheAriba
                    @loverz
                    el_malto
                    #1106
                    @EnoceanEltako sagte in Yet another HomeKit adapter:
                    Zeig mal die Datenpunkte von deinen Fensterkontakten. Haben die nur "true" und "false"?
                    @loverz
                    Könnte mir vorstellen, dass Yahka vielleicht nicht mit dem Status "Off(0)" klar kommt. Deswegen auch die Frage nach den Datenpunkten von deinen Fensterkontakten.
                    Vielleicht kannst du ja auch mal einen Datenpunkt zum testen erstellen der nur "true" und "false" kann. Diesen dann einfach also Leuchte oder Steckdose in Yahka einbinden und dann mal den Datenpunkt in ioBroker auf "true" oder "false" stellen und gucken wie sich das in Yahka verhält. Wenn der korrekt dargestellt wird und deine Fensterkontakte auch, würde ich auf den komischen status "Off(0)" tippen.
                    Nein denke ich nicht.
                    • T TheAriba
                      @loverz
                      loverz
                      #1107
                      @EnoceanEltako ich tippe im Moment auch auf diesen komischen Off(0) Status.
                      Kannst du im Yahka im Map auch mal so eintragen: „Off(0)“ statt nur „0“
                      Eine Steuerzentrale ist doch für Homekit zwingend oder nicht?
                      AppleTV oder iPad muss als Zentrale dienen.
                      Ich hatte mal das Problem, dass beide als Zentrale eingerichtet waren, das AppleTV dabei immer im Hintergrund auf „Standby“ stand und es beim iPad Kommunikationsprobleme gab. Meine Home App war da sehr träge...
                      • L loverz
                        el_malto
                        #1108
                        @loverz eine Steuerzentrale ist nicht zwingend notwendig. Die brauchst du nur wenn du von außerhalb deines Netzwerks was steuern willst (VPN funktioniert mit Homekit nicht).
                        • E el_malto
                          @loverz
                          TheAriba
                          #1109
                          @el_malto @loverz
                          ja, die haben nur true und false als Werte.
                          siehe:
                          Bei "on" sieht das Ganze so aus
                          Bei "off" entsprechend wie oben zu sehen.
                          Habe nun das Mapping angepasst, leider erfolglos.
                          Ich weiss echt nicht weiter :)
                          Edit: was benötige ich denn alles um einen Datenpunkt zu erzeugen welcher sich entsprechend der Werte "1" und "Off(0)" auf true und false setzt und an yahka einfach durchreicht? Wie macht man so etwas denn?
                          Edit2: folgendes kommt beim Schalten ins Log:
                          an:
                          enocean.0	2020-12-17 20:53:07.040	warn	(9065) The data length for a 4BS telegram is incorrect. The length is 0
                          enocean.0	2020-12-17 20:53:07.029	info	(9065) state 0586f7ac.CMD changed: On(1) (ack = false) state: {"val":"On(1)","ack":false,"ts":1608234787026,"q":0,"from":"system.adapter.yah
                          aus:
                          enocean.0	2020-12-17 20:54:10.987	warn	(9065) The data length for a 4BS telegram is incorrect. The length is 0
                          enocean.0	2020-12-17 20:54:10.977	info	(9065) state 0586f7ac.CMD changed: Off(0) (ack = false) state: {"val":"Off(0)","ack":false,"ts":1608234850974,"q":0,"from":"system.adapter.yah
                          debug Licht an, home app auf dem mac verlassen, home app gestartet. Status ist weg.
                          yahka.0	2020-12-17 20:58:15.235	debug	(22139) [ContactSensorState] set was initiated from ioBroker - exiting here
                          yahka.0	2020-12-17 20:58:15.234	debug	(22139) [ContactSensorState] got a set event, hkValue: 0
                          yahka.0	2020-12-17 20:58:15.233	debug	(22139) [ContactSensorState] forwarding value from ioBroker (0) to homekit as (0)
                          yahka.0	2020-12-17 20:58:15.233	debug	(22139) [ContactSensorState] got a change notify event, ioValue: 0
                          yahka.0	2020-12-17 20:58:15.232	debug	(22139) change event from ioBroker via [enocean.0.0582de48.CO]{"val":0,"ack":true,"ts":1608235095226,"q":0,"from":"system.adapter.enocean.0","user":"system.user.admin","lc":1607957800164}
                          yahka.0	2020-12-17 20:58:15.231	debug	(22139) got a stateChange for [enocean.0.0582de48.CO]
                          enocean.0	2020-12-17 20:58:15.218	debug	(9065) Message for ID 0582de48 has been received.
                          enocean.0	2020-12-17 20:58:15.215	debug	(9065) 55000707017ad5090582de480000ffffffff4600
                          yahka.0	2020-12-17 20:58:04.066	debug	(22139) [Brightness] forwarding value from ioBroker (100) to homekit as (100)
                          yahka.0	2020-12-17 20:58:04.065	debug	(22139) read state from ioBroker [enocean.0.0584cf05.LVL]: {"val":100,"ack":false,"ts":1607690770642,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1607690770642}
                          yahka.0	2020-12-17 20:58:04.062	debug	(22139) reading state from ioBroker [enocean.0.0584cf05.LVL]
                          yahka.0	2020-12-17 20:58:04.062	debug	(22139) [Brightness] got a get event
                          yahka.0	2020-12-17 20:58:04.042	debug	(22139) [ContactSensorState] forwarding value from ioBroker (false) to homekit as (0)
                          yahka.0	2020-12-17 20:58:04.041	debug	(22139) read state from ioBroker [enocean.0.0582de30.CO]: {"val":false,"ack":true,"ts":1608234972429,"q":0,"from":"system.adapter.enocean.0","user":"system.user.admin","lc":1608136515824}
                          yahka.0	2020-12-17 20:58:04.040	debug	(22139) [On] forwarding value from ioBroker (0) to homekit as ("false")
                          yahka.0	2020-12-17 20:58:04.039	debug	(22139) read state from ioBroker [enocean.0.0584cf05.CMD]: {"val":0,"ack":false,"ts":1607690776968,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1607690776968}
                          yahka.0	2020-12-17 20:58:04.038	debug	(22139) [On] forwarding value from ioBroker (100) to homekit as (undefined)
                          yahka.0	2020-12-17 20:58:04.037	debug	(22139) read state from ioBroker [enocean.0.0584ab24.CMD]: {"val":100,"ack":false,"ts":1608132395203,"q":0,"from":"system.adapter.iot.0","user":"system.user.admin","lc":1608054736230}
                          yahka.0	2020-12-17 20:58:04.035	debug	(22139) [On] forwarding value from ioBroker (0) to homekit as ("false")
                          yahka.0	2020-12-17 20:58:04.034	debug	(22139) read state from ioBroker [enocean.0.05838713.CMD]: {"val":0,"ack":false,"ts":1607945814260,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1607945814260}
                          yahka.0	2020-12-17 20:58:04.033	debug	(22139) [On] forwarding value from ioBroker (0) to homekit as ("false")
                          yahka.0	2020-12-17 20:58:04.032	debug	(22139) read state from ioBroker [enocean.0.0584cefb.CMD]: {"val":0,"ack":false,"ts":1608191367694,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1608191367694}
                          yahka.0	2020-12-17 20:58:04.030	debug	(22139) [On] forwarding value from ioBroker ("On(1)") to homekit as ("true")
                          yahka.0	2020-12-17 20:58:04.029	debug	(22139) read state from ioBroker [enocean.0.0586f7ac.CMD]: {"val":"On(1)","ack":false,"ts":1608235055682,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1608235055682}
                          yahka.0	2020-12-17 20:58:04.027	debug	(22139) [On] forwarding value from ioBroker (1) to homekit as ("true")
                          yahka.0	2020-12-17 20:58:04.026	debug	(22139) read state from ioBroker [enocean.0.05936c86.CMD]: {"val":1,"ack":false,"ts":1608233239059,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1608233239059}
                          yahka.0	2020-12-17 20:58:04.024	debug	(22139) [On] forwarding value from ioBroker (0) to homekit as ("false")
                          yahka.0	2020-12-17 20:58:04.023	debug	(22139) read state from ioBroker [enocean.0.05936c5e.CMD]: {"val":0,"ack":false,"ts":1608215806771,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1608206319138}
                          yahka.0	2020-12-17 20:58:04.012	debug	(22139) reading state from ioBroker [enocean.0.0582de30.CO]
                          yahka.0	2020-12-17 20:58:04.011	debug	(22139) [ContactSensorState] got a get event
                          yahka.0	2020-12-17 20:58:04.010	debug	(22139) reading state from ioBroker [enocean.0.0584cf05.CMD]
                          yahka.0	2020-12-17 20:58:04.009	debug	(22139) [On] got a get event
                          yahka.0	2020-12-17 20:58:04.007	debug	(22139) reading state from ioBroker [enocean.0.0584ab24.CMD]
                          yahka.0	2020-12-17 20:58:04.006	debug	(22139) [On] got a get event
                          yahka.0	2020-12-17 20:58:04.005	debug	(22139) reading state from ioBroker [enocean.0.05838713.CMD]
                          yahka.0	2020-12-17 20:58:04.004	debug	(22139) [On] got a get event
                          yahka.0	2020-12-17 20:58:04.002	debug	(22139) reading state from ioBroker [enocean.0.0584cefb.CMD]
                          yahka.0	2020-12-17 20:58:04.001	debug	(22139) [On] got a get event
                          yahka.0	2020-12-17 20:58:03.999	debug	(22139) reading state from ioBroker [enocean.0.0586f7ac.CMD]
                          yahka.0	2020-12-17 20:58:03.998	debug	(22139) [On] got a get event
                          yahka.0	2020-12-17 20:58:03.996	debug	(22139) reading state from ioBroker [enocean.0.05936c86.CMD]
                          yahka.0	2020-12-17 20:58:03.995	debug	(22139) [On] got a get event
                          yahka.0	2020-12-17 20:58:03.993	debug	(22139) reading state from ioBroker [enocean.0.05936c5e.CMD]
                          yahka.0	2020-12-17 20:58:03.992	debug	(22139) [On] got a get event
                          yahka.0	2020-12-17 20:57:37.643	debug	(22139) [ContactSensorState] set was initiated from ioBroker - exiting here
                          yahka.0	2020-12-17 20:57:37.642	debug	(22139) [ContactSensorState] got a set event, hkValue: 0
                          yahka.0	2020-12-17 20:57:37.641	debug	(22139) [ContactSensorState] forwarding value from ioBroker (0) to homekit as (0)
                          yahka.0	2020-12-17 20:57:37.641	debug	(22139) [ContactSensorState] got a change notify event, ioValue: 0
                          yahka.0	2020-12-17 20:57:37.640	debug	(22139) change event from ioBroker via [enocean.0.05847880.CO]{"val":0,"ack":true,"ts":1608235057634,"q":0,"from":"system.adapter.enocean.0","user":"system.user.admin","lc":1608227890112}
                          yahka.0	2020-12-17 20:57:37.639	debug	(22139) got a stateChange for [enocean.0.05847880.CO]
                          enocean.0	2020-12-17 20:57:37.624	debug	(9065) Message for ID 05847880 has been received.
                          enocean.0	2020-12-17 20:57:37.621	debug	(9065) 55000707017ad509058478800100ffffffff4f00
                          enocean.0	2020-12-17 20:57:35.703	debug	(9065) Packet type 2 received: 02
                          enocean.0	2020-12-17 20:57:35.702	debug	(9065) 55000100026503
                          yahka.0	2020-12-17 20:57:35.701	debug	(22139) [On] set was accepted by ioBroker (value: "On(1)")
                          yahka.0	2020-12-17 20:57:35.694	debug	(22139) [On] set was initiated from ioBroker - exiting here
                          yahka.0	2020-12-17 20:57:35.693	debug	(22139) [On] got a set event, hkValue: false
                          yahka.0	2020-12-17 20:57:35.692	debug	(22139) [On] forwarding value from ioBroker ("On(1)") to homekit as ("true")
                          yahka.0	2020-12-17 20:57:35.692	debug	(22139) [On] got a change notify event, ioValue: "On(1)"
                          yahka.0	2020-12-17 20:57:35.691	debug	(22139) change event from ioBroker via [enocean.0.0586f7ac.CMD]{"val":"On(1)","ack":false,"ts":1608235055682,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1608235055682}
                          yahka.0	2020-12-17 20:57:35.689	debug	(22139) got a stateChange for [enocean.0.0586f7ac.CMD]
                          enocean.0	2020-12-17 20:57:35.695	debug	(9065) Sent data: 550006070111a5ffef620400000586f7acff00b5
                          enocean.0	2020-12-17 20:57:35.694	warn	(9065) The data length for a 4BS telegram is incorrect. The length is 0
                          enocean.0	2020-12-17 20:57:35.686	info	(9065) state 0586f7ac.CMD changed: On(1) (ack = false) state: {"val":"On(1)","ack":false,"ts":1608235055682,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1608235055682}
                          yahka.0	2020-12-17 20:57:35.677	debug	(22139) checking value change: "Off(0)" != "On(1)" = true
                          yahka.0	2020-12-17 20:57:35.673	debug	(22139) writing state to ioBroker [enocean.0.0586f7ac.CMD]: "On(1)"
                          yahka.0	2020-12-17 20:57:35.671	debug	(22139) [On] got a set event, hkValue: true
                          yahka.0	2020-12-17 20:57:32.012	debug	(22139) [Brightness] forwarding value from ioBroker (100) to homekit as (100)
                          yahka.0	2020-12-17 20:57:32.011	debug	(22139) read state from ioBroker [enocean.0.0584cf05.LVL]: {"val":100,"ack":false,"ts":1607690770642,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1607690770642}
                          yahka.0	2020-12-17 20:57:32.009	debug	(22139) reading state from ioBroker [enocean.0.0584cf05.LVL]
                          yahka.0	2020-12-17 20:57:32.009	debug	(22139) [Brightness] got a get event
                          yahka.0	2020-12-17 20:57:31.905	debug	(22139) [ContactSensorState] forwarding value from ioBroker (false) to homekit as (0)
                          yahka.0	2020-12-17 20:57:31.905	debug	(22139) read state from ioBroker [enocean.0.0582de30.CO]: {"val":false,"ack":true,"ts":1608234972429,"q":0,"from":"system.adapter.enocean.0","user":"system.user.admin","lc":1608136515824}
                          yahka.0	2020-12-17 20:57:31.904	debug	(22139) [On] forwarding value from ioBroker (0) to homekit as ("false")
                          yahka.0	2020-12-17 20:57:31.903	debug	(22139) read state from ioBroker [enocean.0.0584cf05.CMD]: {"val":0,"ack":false,"ts":1607690776968,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1607690776968}
                          yahka.0	2020-12-17 20:57:31.898	debug	(22139) [On] forwarding value from ioBroker (100) to homekit as (undefined)
                          yahka.0	2020-12-17 20:57:31.897	debug	(22139) read state from ioBroker [enocean.0.0584ab24.CMD]: {"val":100,"ack":false,"ts":1608132395203,"q":0,"from":"system.adapter.iot.0","user":"system.user.admin","lc":1608054736230}
                          yahka.0	2020-12-17 20:57:31.896	debug	(22139) [On] forwarding value from ioBroker (0) to homekit as ("false")
                          yahka.0	2020-12-17 20:57:31.895	debug	(22139) read state from ioBroker [enocean.0.05838713.CMD]: {"val":0,"ack":false,"ts":1607945814260,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1607945814260}
                          yahka.0	2020-12-17 20:57:31.894	debug	(22139) [On] forwarding value from ioBroker (0) to homekit as ("false")
                          yahka.0	2020-12-17 20:57:31.893	debug	(22139) read state from ioBroker [enocean.0.0584cefb.CMD]: {"val":0,"ack":false,"ts":1608191367694,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1608191367694}
                          yahka.0	2020-12-17 20:57:31.892	debug	(22139) [On] forwarding value from ioBroker ("Off(0)") to homekit as ("false")
                          yahka.0	2020-12-17 20:57:31.891	debug	(22139) read state from ioBroker [enocean.0.0586f7ac.CMD]: {"val":"Off(0)","ack":false,"ts":1608234850974,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1608234850974}
                          yahka.0	2020-12-17 20:57:31.890	debug	(22139) [On] forwarding value from ioBroker (1) to homekit as ("true")
                          yahka.0	2020-12-17 20:57:31.889	debug	(22139) read state from ioBroker [enocean.0.05936c86.CMD]: {"val":1,"ack":false,"ts":1608233239059,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1608233239059}
                          yahka.0	2020-12-17 20:57:31.887	debug	(22139) [On] forwarding value from ioBroker (0) to homekit as ("false")
                          yahka.0	2020-12-17 20:57:31.885	debug	(22139) read state from ioBroker [enocean.0.05936c5e.CMD]: {"val":0,"ack":false,"ts":1608215806771,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1608206319138}
                          yahka.0	2020-12-17 20:57:31.876	debug	(22139) reading state from ioBroker [enocean.0.0582de30.CO]
                          yahka.0	2020-12-17 20:57:31.875	debug	(22139) [ContactSensorState] got a get event
                          yahka.0	2020-12-17 20:57:31.874	debug	(22139) reading state from ioBroker [enocean.0.0584cf05.CMD]
                          yahka.0	2020-12-17 20:57:31.873	debug	(22139) [On] got a get event
                          yahka.0	2020-12-17 20:57:31.872	debug	(22139) reading state from ioBroker [enocean.0.0584ab24.CMD]
                          yahka.0	2020-12-17 20:57:31.871	debug	(22139) [On] got a get event
                          yahka.0	2020-12-17 20:57:31.870	debug	(22139) reading state from ioBroker [enocean.0.05838713.CMD]
                          yahka.0	2020-12-17 20:57:31.869	debug	(22139) [On] got a get event
                          yahka.0	2020-12-17 20:57:31.867	debug	(22139) reading state from ioBroker [enocean.0.0584cefb.CMD]
                          yahka.0	2020-12-17 20:57:31.866	debug	(22139) [On] got a get event
                          yahka.0	2020-12-17 20:57:31.865	debug	(22139) reading state from ioBroker [enocean.0.0586f7ac.CMD]
                          yahka.0	2020-12-17 20:57:31.864	debug	(22139) [On] got a get event
                          yahka.0	2020-12-17 20:57:31.863	debug	(22139) reading state from ioBroker [enocean.0.05936c86.CMD]
                          yahka.0	2020-12-17 20:57:31.862	debug	(22139) [On] got a get event
                          yahka.0	2020-12-17 20:57:31.861	debug	(22139) reading state from ioBroker [enocean.0.05936c5e.CMD]
                          yahka.0	2020-12-17 20:57:31.860	debug	(22139) [On] got a get event
                          yahka.0	2020-12-17 20:57:31.830	debug	(22139) [ContactSensorState] set was initiated from ioBroker - exiting here
                          yahka.0	2020-12-17 20:57:31.829	debug	(22139) [ContactSensorState] got a set event, hkValue: 0
                          yahka.0	2020-12-17 20:57:31.829	debug	(22139) [ContactSensorState] forwarding value from ioBroker (0) to homekit as (0)
                          yahka.0	2020-12-17 20:57:31.828	debug	(22139) [ContactSensorState] got a change notify event, ioValue: 0
                          yahka.0	2020-12-17 20:57:31.828	debug	(22139) change event from ioBroker via [enocean.0.0583fc82.CO]{"val":0,"ack":true,"ts":1608235051822,"q":0,"from":"system.adapter.enocean.0","user":"system.user.admin","lc":1608227874216}
                          yahka.0	2020-12-17 20:57:31.826	debug	(22139) got a stateChange for [enocean.0.0583fc82.CO]
                          Also wenn ich in Homekit die Lampe anschalte ändert sich der Wert im Datenpunkt auf 1. Wenn ich in Homekit jetzt ausschalte, ändert sich der Wert im Datenpunkt auf Off(0)
                          aber die Lampe bleibt an. Ich vermute tatsächlich nun auch dass es mit den Datenpunkten zusammenhängt.
                          Wenn ich das Mapping auf folgendes ändere kann ich wieder ohne Probleme an/aus schalten.
                          Allerdings bleibt weiterhin das Status Thema :D
                          • T TheAriba
                            @el_malto @loverz
                            siehe:
                            an:
                            aus:
                            loverz
                            schrieb am zuletzt editiert von loverz
                            #1110
                            @EnoceanEltako also wenn du in Homekit anschaltest, dann schreibt Homekit eine „1“ ins Objekt. Enocea . Kommt wohl mit dieser „1“ klar und schaltet das Licht. Das Objekt hleibt aber auf „1“.
                            Wenn du nun die Home-App schließt und öffnest, versucht diese den Status zu ziehen. Im Objekt steht aber noch immer diese „1“ oder hat Enocean diese zwischenzeitlich als „1(On)“ geändert?
                            Zeig uns mal die Eigenschaften von deinem CMD-Objekt (hinten mit dem Stift bearbeiten)
                            • L loverz
                              TheAriba
                              #1111
                              @loverz meinst du das hier?
                              Der Entwickler des Enocean Adapters, Jey-Cee sagt dass das On(1) und Off(0) nur eine Hilfe für die Oberfläche ist. Der YAHKA Adapter sollte eigentlich 0 und 1 rauslesen können.
                              Dann check ich es echt nicht wieso die Stati nicht passen... oh man das nervt echt :)
                              Edit: wenn ich einen Datenpunkt auswähle welcher mir true anzeigt, dann wird der Status korrekt angezeigt. Also liegt es ganz klar am Datenpunkt.
                              Kann mir jemand helfen damit ich quasi aus meinem cmd Datenpunkt und den Werten 1 und 2 ein true und false in einen Datenpunkt reingeschrieben bekomme?
                              Oder gibt es die Möglichkeit soetwas direkt über ein Skript zu lösen? (habe ja mein ganzes Haus voll mit Lichtaktoren :) c633668d-4d56-4fb9-bbf9-fea012470281-image.png
                              L AsgothianA 2 Antworten Letzte Antwort
                              • T TheAriba
                                loverz
                                #1112
                                @EnoceanEltako Der Datenpunkt ist ganz klar merkwürdig 🐶 Rolle Zahl für ein Schalt-Objekt?!
                                Normal sollte da Rolle State stehen, dann gibt es nur true und false, alles wäre klar geregelt.
                                Man könnte ein Blockly basteln:
                                Wenn sich der Status ändert und = On(1) ist, dann schreibe ein anderes Objekt (mit der oben genannten State Rolle) auf True.
                                Das gleiche natürlich umgekehrt falls false...
                                Vielleicht geht es auch direkt in Yahka, da kenne ich mich leider nicht aus. Vielleicht kann hier @Asgothian weiterhelfen.
                                • T TheAriba
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  #1113
                                  @EnoceanEltako
                                  assuming 1 = true, 2 = false.
                                  toHomekit:
                                  return (value == 1);
                                  fromHomekit
                                  if (value) return 1;
                                  return 2;
                                    @EnoceanEltako
                                    toHomekit:
                                    fromHomekit
                                    return 2;
                                    TheAriba
                                    #1114
                                    @loverz @Asgothian
                                    Cool also damit funktioniert es schonmal wenn ich aus der Home App schalte. HomeKit bekommt es aber nicht mit wenn ich extern bspw. über einen Taster schalte.
                                    E L 2 Antworten Letzte Antwort
                                    • T TheAriba
                                      @loverz @Asgothian
                                      el_malto
                                      #1115
                                      @EnoceanEltako funktioniert das "extern" schalten und den richtigen Status in HomeKit denn mit anderen Geräten?
                                      • T TheAriba
                                        @loverz @Asgothian
                                        loverz
                                        #1116
                                        @EnoceanEltako Ich kann dir mit den beiden kleinen Skripts leider nicht weiterhelfen, da ich sie nicht verstehe. Sorry.
                                        Ich für meinen Teil würde ein Blockly schreiben, das kann ich.
                                        • E Offline
                                          el_malto
                                          schrieb am zuletzt editiert von el_malto
                                          #1117
                                          Ich denke die beste Lösung wäre, wenn es über die Yahka Funktionen nicht funktioniert, vielleicht das @Jey-Cee (sorry für die Verlinkung :P ) die Datenpunkte des Enocean Adapters richtig deklariert und auch nur "true" oder "false" und nicht "On(1)" und "Off(0)" dort angibt. Ich denke jeder der ioBroker benutzt braucht das als "Hilfe für die Oberfläche"nicht. Falls das überhaupt möglich ist, weil es ja auch einen Wert "2 Teach-In" gibt wie im Bild zu sehen:
                                          Bild Text
                                          Man kann es über eigene Datenpunkte und Skripte machen. Aber wenn du dein ganzes Haus damit voll hast ist das nicht so toll bzw. zielführend.
                                          Ansonsten @EnoceanEltako :
                                          https://www.smarthome-tricks.de/software-iobroker/eigene-datenpunkte-in-iobroker-anlegen/
                                          Die angelegten Datenpunkte einfach "Standard" lassen. Also den "Datenpunkttyp" als "Logikwert" lassen. Dann musst du gucken auf was du triggern musst. Werden die CMD Datenpunkte AUSSCHLIEßLICH vom ioBroker beschrieben oder hat das Gerät vielleicht einen "Hardware Schalter" der direkt den CMD Datenpunkt beschreibt?
                                          Wenn die CMD Datenpunkte nur durch ioBroker geschaltet werden ein Skipt schreiben welches auf deine angelegten Datenpunkte triggert und dann die CMD Datenpunkte entsprechend mit "On(1)" oder "Off(0)" beschreibt. Für die Steuerung darfst du dann aber nur noch deine angelegten Datenpunkte benutzen.
                                          Quick and dirty (geht schöner ich weiß, das Prinzip soll nur verstaden werden):
                                          Oder nur mit 1 und 0 oder true und false bechreiben, je nachdem auf was der CMD Datenpunkt "hört".
                                          Jey CeeJ T 2 Antworten Letzte Antwort
