  4. Stromzähler per Sonoff ESP8266 auslesen
stromzähler auslesensonoffesp8266tasmotasmld0-schnittstellevolkszählerstromzähler
562 Beiträge 83 Kommentatoren 262.3k Aufrufe 84 Beobachtet
    MyMeyer
    schrieb am zuletzt editiert von MyMeyer
    #213
    Hallo, habe jetzt den Volkszähler zusammen gebaut und alles angeschlossen inkl. Flash.
    Ich habe folgenden Zähler: Iskra MT175 SML
    Script sieht so aus:
    >D
    >B
    ->sensor53 r
    tper=10
    >M
    +1,13,s,0,9600,SML
    1,77070100010800ff@1000,Verbrauch,KWh,DJ_TPWRIN,3
    1,77070100020800ff@1000,Einspeisung,KWh,DJ_TPWROUT,3
    1,77070100100700ff@1000,Akt. Verbrauch,W,DJ_TPWRCURR,3
    Leider kommt nichts an.
    Hier mein Log:
    16:53:25 CMD: sensor53 d1
    16:53:25 MQT: stat/Stromzähler_V2/RESULT = {"Time":"2020-08-15T16:53:25","SML":{"CMD":"dump: 1"}}
    16:53:31 MQT: tele/Stromzähler_V2/STATE = {"Time":"2020-08-15T16:53:31","Uptime":"0T00:00:59","UptimeSec":59,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":99,"MqttCount":1,"Wifi":{"AP":1,"SSId":"FRITZ-Smart","BSSId":"2A:E8:29:67:35:2D","Channel":1,"RSSI":100,"Signal":-34,"LinkCount":1,"Downtime":"0T00:00:03"}}
    16:53:31 MQT: tele/Stromzähler_V2/SENSOR = {"Time":"2020-08-15T16:53:31","SML":{"DJ_TPWRIN":0.000,"DJ_TPWROUT":0.000,"DJ_TPWRCURR":0.000}}
    16:53:41 MQT: tele/Stromzähler_V2/STATE = {"Time":"2020-08-15T16:53:41","Uptime":"0T00:01:09","UptimeSec":69,"Heap":21,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":99,"MqttCount":1,"Wifi":{"AP":1,"SSId":"FRITZ-Smart","BSSId":"2A:E8:29:67:35:2D","Channel":1,"RSSI":100,"Signal":-34,"LinkCount":1,"Downtime":"0T00:00:03"}}
    16:53:41 MQT: tele/Stromzähler_V2/SENSOR = {"Time":"2020-08-15T16:53:41","SML":{"DJ_TPWRIN":0.000,"DJ_TPWROUT":0.000,"DJ_TPWRCURR":0.000}}
    16:53:51 MQT: tele/Stromzähler_V2/STATE = {"Time":"2020-08-15T16:53:51","Uptime":"0T00:01:19","UptimeSec":79,"Heap":21,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":99,"MqttCount":1,"Wifi":{"AP":1,"SSId":"FRITZ-Smart","BSSId":"2A:E8:29:67:35:2D","Channel":1,"RSSI":100,"Signal":-33,"LinkCount":1,"Downtime":"0T00:00:03"}}
    16:53:51 MQT: tele/Stromzähler_V2/SENSOR = {"Time":"2020-08-15T16:53:51","SML":{"DJ_TPWRIN":0.000,"DJ_TPWROUT":0.000,"DJ_TPWRCURR":0.000}}
    kann ich irgentzwie die Diode testen ? Vielleicht habe ich ja beim zusammen löten nicht sauber (zu heiss) gearbeitet. :-(
    MyMeyer
    Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
    HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
    • M MyMeyer
      >D
      >B
      ->sensor53 r
      tper=10
      >M
      +1,13,s,0,9600,SML
      Hier mein Log:
      Jaschkopf
      #214
      @MyMeyer Du kannst den Lesekopf mit einem FTDI Adapter am Computer direkt testen. Wenn der Lesekopf mit 1cm Abstand über einem weißen Blatt Papier liegt und du Daten sendest, sollte er durch die Reflektion auf dem Papier den identischen Wert zurück lesen. So kannst du einen Hardwarefehler ausschließen.
      Gruß Jaschkopf
      • J Jaschkopf
        Gruß Jaschkopf
        baeri
        #215
        mein Stromzähler lief jetzt gut ein halbes Jahr ohne Probleme, nun zerhaut es aber regelmäßig meine Flot Diagramme und auch teilweise die Berechnungen des letzten Tages.
        Grund dafür: Der Zähler liefert ab und an eine 0 - die lässt sich ja im Diagramm unterdrücken, aber seit neustem sehe ich in der History auch des öfteren den Wert "1".
        Meine Frage: Kann man diese falschen Werte direkt in Tasmota unterdrücken?
        Notlösung wäre quasi ein Skript, das überprüft, ob der neue Wert > dem alten ist und in einem separaten Datenpunkt zu speichern. Falls nicht wird der Wert einfach verworfen...
        Danke euch im Voraus!
          MKMM98
          schrieb am zuletzt editiert von MKMM98
          #216
          erstmal danke für die Ausführliche Anleitung.
          Habe Tasmota auf dem NODEMCU8266 geflasht und mit dem TTL-Adapter von Jaschkopf verbunden hat alles super funktioniert.
          Leider fehlen mir die Daten im Iobroker, unter dem Sonoff Adapter unter Objekte wird das ESP8266 angezeigt.
          Der TTL-Adapter ist an 3,3V, GND, RX GPIO3 und TX an GPIO1.
          Ich bekomme ich Tasmota Menü die Verbrauchdaten angezeigt nur unter Objekte ich Iobroker nicht.
          Mein Zähler ist ein ISKRA MT175.
          Beim ersten Start des ESP8266 wurde mir OBIS angzeigt, erst als ich das Script editiert und aktiviert habe hat sich das in SML geändert. SML ist ja auch richtig. Wenn ich das Script deaktiviere bekomme ich unter Objekte im Iobroker 3 Zeilen Zähler OBIS Power_curr, Zähler Obis Total_in und Zähler OBIS Total_out diese Werte bleiben aber dauerhaft auf null da das Script deaktiviert wurde und ich ja auch SML benötige.
          Jemmanf vielleicht eine Idee, warum die SML Daten unter Objekte fehlen.
          MKMM
          Wer lesen kann.......
          Hat sich erledigt.
          Habe eine Hinweiß von Jaschkopf überlesen.
          Wichtig ist nur, dass im Adapter die drei Checkboxen „Automatische Erstellung von Zuständen“ aktiviert werden, damit die Objekte auch angelegt werden.
          MKMM
          oberfraggerO 1 Antwort Letzte Antwort
          • M MKMM98
            MKMM
            Hat sich erledigt.
            MKMM
            oberfraggerO Offline
            oberfragger
            schrieb am zuletzt editiert von oberfragger
            #217
            Sagtmal,
            gibts solche Möglichkeit auch mit einem USB-Lesekopf? Also im Zweifel irgendwie den USB an einen Sonoff, NodeMCu o.ä. anschließen? Dann spare ich mir den Smartmeter-Adapter. Das wäre eine super Sache.
            Ich habe aktuell so einen Weidmann-Opto-Kopf.
            mkrobeM 1 Antwort Letzte Antwort
            • oberfraggerO oberfragger
              Sagtmal,
              mkrobeM Offline
              mkrobeM Offline
              mkrobe
              #218
              Habe diese Script am laufen:
              >D
              >B
              =>sensor53 r
              tper=10
              >M 1
              +1,3,s,1,9600,ED300L
              1,77070100010800ff@1000,Gesamtverbrauch,kWh,DJ_Power_IN,3
              1,77070100020800ff@1000,eingespeist,kWh,DJ_Power_OUT,3
              1,77070100100700ff@1,akt. Verbrauch,W,DJ_Power_akt,0
              Ist es möglich, dem "Gesamtverbrauch" einen Wert unterzujubeln den er immer dem aktuellen addiert?
              Hintergrund ist das der Solateur beide Zähler umklemmen musste, und mir deswegen ca 5000kWh "fehlen"
              RalfThR 1 Antwort Letzte Antwort
              • mkrobeM mkrobe
                >D
                >B
                =>sensor53 r
                tper=10
                >M 1
                RalfThR Offline
                RalfThR Offline
                RalfTh
                #219
                @mkrobe Natürlich geht das..... Siehe mein Post vom 20.Juni 2020 hier. Vorlage ist dabei Jaschkopf's Skript. Du löst das allerdings eleganter mit einem Blockly im ioBrocker. Hier berechne ich sogar den Tagespreis, Monatspreis und Jahrespreis für den aktuellen Energieversorger. Außerdem protokolliere ich das mit Influx.
                Wir haben uns verirrt, kommen aber gut voran.
                • RalfThR RalfTh
                  mkrobeM Offline
                  mkrobeM Offline
                  mkrobe
                  #220
                  @RalfTh
                  Dank Dir für den Tipp, blicke aber durch das Script nicht durch.
                  Blockly habe ich vermieden, bin froh dass ich das erstmal mit Flott soweit auf dei Reihe bekommen habe ;-) Übrigens solltest Du "kWh" schreiben, dann passt das :-)
                  • mkrobeM mkrobe
                    @RalfTh
                    da_WoodyD Offline
                    da_WoodyD Offline
                    #221
                    @mkrobe irgenwie steh ich im wald.
                    ich versuch seit 3 tagen atom und platformio zu insten. atom läuft durch, dann sag ich im packet manager platformio, installieren, der platformio menüpunkt kommt, aber es taucht ein fenster auf wo in der 3. zeile atom dependencies mit einem DL zeichen blinkt und nicht mehr verschwindet.
                    wenn ich mir die files von arendst in VSC anschaue, stimmen die zeilenangaben nicht mit der beschreibung überein bzw. finde ich dort teilweise zeilen gar nicht.
                    somit bin ich zu dämlich mir eine bin zu erstellen, die ich dann mit tasmotizer auf den D1-mini flashen könnte.
                    help needed...
                    T da_WoodyD 2 Antworten Letzte Antwort
                    • da_WoodyD da_Woody
                      help needed...
                      toki1973
                      #222
                      Ist ein Auslesen eines modernen IR Stromzählers mit einem Wemos D1 der mit ESP Easy geflashed ist und mit einer Fotodiode (Light Sensor) Modul bestückt ist welcher die Impulse aufnimmt und diese dann an den ioBroker(Meter Adapter) sendet möglich?​
                      Oder was steckt in dem Tastkopf noch drin?
                      NUC, PROXMOX, Grafana, Influx, Unify
                      • T toki1973
                        da_WoodyD Offline
                        da_WoodyD Offline
                        #223
                        @toki1973 lies dir den 1. beitrag durch...
                          toki1973
                          #224
                          @da_Woody said in Stromzähler per Sonoff ESP8266 auslesen:
                          • Lesekopf (Volkszähler oder ähnlich)
                          Meine Frage wäre was im Lesekopf enthalten ist bzw. ob das auch mit einem Fototransistor am ESP8266 möglich ist
                          • T toki1973
                            da_WoodyD Offline
                            da_WoodyD Offline
                            #225
                            @toki1973 die einfachste variante ist
                            bei den leseköpfen die @Jaschkopf hatte ist ein bisschen SMD gefrickel angesagt.
                              toki1973
                              #226
                              Danke -werde mal test
                                help needed...
                                da_WoodyD Offline
                                da_WoodyD Offline
                                #227
                                ich gestehe, ich geb W.O. wie schon weiter oben geschrieben,
                                atom lässt sich hier nicht insten, warum auch immer. mit VCS bring ich auch nichts zusammen.
                                hab zwar heute auf dem laptop geschafft atom mit platformio zu insten, aber auch da bekomme ich kein .bin zusammen.
                                mit den ganzen topics die ich so finde, wird die verwirrung auch nicht besser...
                                den d1mini hatte ich schon fertig, DPs stehn noch im sonoff drinnen. die ganzen OBIS-werte und co.
                                dann meinte harrym, er will da was anderes draufspielen, dazu kam es aber nicht mehr, der d1mini wurde nur überschrieben. harrym ist auch nicht mehr erreichbar für mich.
                                auf den d1mini hab ich jetzt mal tasmota 9.1 geflasht, ist auch erreichbar. weis aber absolut nicht weiter, wie, was ,wo ich was einstellen muss.
                                so wars damals mit tasmotizer über com3 geflasht.
                                könnte sich eventuell jemand erbarmen und mir trottel eine passende .bin zur verfügung stellen? danke!
                                • T toki1973
                                  toki1973
                                  #228
                                  So habe einen Wemos geflashed und Skipt aktiviert. Wo finde ich denn nun Informtionen zu meinem Itron Zähler (Dieser Link funktioniert nicht mehr. https://github.com/arendst/Tasmota/wiki/smart-meter-interface)
                                  Mein Zähler sendet auch scon fleissig IR Impulse. Da ich keinen Lesekopf habe wollte ich vorerst mal mit einem IR Sensor Modul KY-022 experimentiern. Hat da jemand Erfahrungen damit? Gibt es eigentlich einen Schaltplan im Netz für den Selbstbau des Kopfes mit integriertem Schmitt-Trigger?
                                  T da_WoodyD K 3 Antworten Letzte Antwort
                                  • T toki1973
                                    toki1973
                                    #229
                                    @Jaschkopf
                                    Inwischen bin ich auf einen IR Transistor gewechselt und kann tatsächlich Daten auslesen. Leider habe ich kein passendes Script für meine Itron Zähler gefunden. Wie gehe ich denn am besten vor wenn ich das hier auswerten will?
                                    16:20:27.109 : 1b 1b 1b 1b
                                    16:20:27.153 : 01 01 01 01 76 09 73 07 00 00 04 25 2c d8 62 00 62 00 72 65 00 00 01 01 76 01 01 09 00 00 00 00 01 61 c1 10 0b 0a 01 49 54 52
                                    16:20:27.193 : 00 03 4b a8 1e 72 62 01 65 01 61 c2 1d 01 63 de d0 00 76 09 73 07 00 00 04 25 2c d9 62 00 62 00 72 65 00 00 07 01
                                    16:20:27.223 : 77 01 0b 0a 01 49 54 52 00 03 4b a8 1e 07 01 00 62 0a ff ff 72 62 01 65 01 61 c2 1d 73
                                    16:20:27.241 : 77 07 01 00 60 32 01 01 01 01 01 01 04 49 54 52 01
                                    16:20:27.266 : 77 07 01 00 60 01 00 ff 01 01 01 01 0b 0a 01 49 54 52 00 03 4b a8 1e 01
                                    16:20:27.310 : 77 07 01 00 01 08 00 ff 65 00 1c 01 04 01 62 1e 52 03 69 00 00 00 00 00 00 0c dd 01 01 01 63 de 95 00 76 09 73 07 00 00 04 25 2c
                                    16:20:27.355 : da 62 00 62 00 72 65 00 00 02 01 71 01 63 3d 40 00 00 00 1b 1b 1b 1b 1a 02 0c 1d
                                    16:20:28.110 : 1b 1b 1b 1b 01 01 01 01
                                    16:20:28.155 : 76 09 73 07 00 00 04 25 2c db 62 00 62 00 72 65 00 00 01 01 76 01 01 09 00 00 00 00 01 61 c1 11 0b 0a 01 49 54 52 00 03 4b a8 1e 72
                                    16:20:28.189 : 62 01 65 01 61 c2 1e 01 63 96 7d 00 76 09 73 07 00 00 04 25 2c dc 62 00 62 00 72 65 00 00 07 01
                                    16:20:28.219 : 77 01 0b 0a 01 49 54 52 00 03 4b a8 1e 07 01 00 62 0a ff ff 72 62 01 65 01 61 c2 1e 73
                                    16:20:28.237 : 77 07 01 00 60 32 01 01 01 01 01 01 04 49 54 52 01
                                    16:20:28.262 : 77 07 01 00 60 01 00 ff 01 01 01 01 0b 0a 01 49 54 52 00 03 4b a8 1e 01
                                    16:20:28.308 : 77 07 01 00 01 08 00 ff 65 00 1c 01 04 01 62 1e 52 03 69 00 00 00 00 00 00 0c dd 01 01 01 63 58 ea 00 76 09 73 07 00 00 04 25 2c dd
                                    16:20:28.353 : 62 00 62 00 72 65 00 00 02 01 71 01 63 7e 58 00 00 00 1b 1b 1b 1b 1a 02 4a 08
                                    16:20:29.126 : 1b 1b 1b 1b 01 01 01 01 76 09 73 07 00 00 04 25 2c de 62 00 62 00 72 65 00 00 01 01 76
                                    16:20:29.170 : 01 01 09 00 00 00 00 01 61 c1 12 0b 0a 01 49 54 52 00 03 4b a8 1e 72 62 01 65 01 61 c2 1f 01 63 3f e5 00 76 09 73 07 00 00 04
                                    16:20:29.184 : 25 2c df 62 00 62 00 72 65 00 00 07 01
                                    Steffen DemminS 1 Antwort Letzte Antwort
                                    • T toki1973
                                      da_WoodyD Offline
                                      da_WoodyD Offline
                                      #230
                                      @toki1973 könntst du mir das .bin zukommen lassen? ich bin einfach zu dämlich dazu... mit wemos meinst du ja einen d1mini nehm ich an...
                                      • T toki1973
                                        klassisch
                                        #231
                                        @toki1973 sagte in Stromzähler per Sonoff ESP8266 auslesen:
                                        Den gibt es sogar hier im Forum: https://forum.iobroker.net/topic/36936/guide-zwangsumstellung-auf-smartmeter-freut-euch-drauf?page=1 Guide runterladen. Da habe ich einen Schaltplan und Umbauanleitung eines Moduls mit drin. Und vieles mehr, besonders, falls die ESP Lösung nicht funktionieren sollte. In meinem Fall an einem itron Zähler und mit dem Smartmeter-Adapter.
                                        Habe einen scharfen Watschdog drauf. Der schlägt aber nur bei Updates des ioBroke an. Rocksolid.
                                        • K klassisch
                                          toki1973
                                          #232
                                          @klassisch Vielen Dank für die Rückmeldung und deinen Guide!
                                          Bisher komme ich ohne den Schmitt Trigger aus und habe infach ein IR Fototransistor angeschlossen. Signal bekomme ich ja nun.
                                          Nun habe ich auch verstanden das der Smart Meter Adapter auf eine serielle Quelle zugrifft. Meine aktuelle Lösung besteht aber auf den Weg Tasmota Auswetung und MQTT an ioBroker übermitteln. Somit kann ich den Smart Meter Adapter wohl nicht verwenden.
                                          Ausser, ich setze den Wemos D1 mini als Web-Server auf und ziehe von dort die Daten. Das ist der Weg den du mit deiner Bastellösung mit wlan Modul und UART beschreibst. Gibt es dazu etwas "fertiges"?
                                          Ich schau mal ob ich das Script für den Itron Zähler auf Tasmota hinbekomme.
