Hilfe Admin Oberfläche
Ich warte immer noch, obwohl iobroker und admin instanz läuft.
iobroker list instances system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alexa2.0 : alexa2 - disabled system.adapter.backitup.0 : backitup - enabled system.adapter.daswetter.0 : daswetter - disabled system.adapter.discovery.0 : discovery - disabled system.adapter.enigma2.0 : enigma2 - disabled system.adapter.feiertage.0 : feiertage - disabled system.adapter.flot.0 : flot - disabled system.adapter.fritzdect.0 : fritzdect - disabled system.adapter.fullcalendar.0 : fullcalendar - disabled system.adapter.geofency.0 : geofency - disabled, port: 7999 system.adapter.habpanel.0 : habpanel - disabled system.adapter.heatingcontrol.0 : heatingcontrol - disabled system.adapter.history.0 : history - disabled system.adapter.ical.0 : ical - disabled system.adapter.ical.1 : ical - disabled system.adapter.ical.2 : ical - disabled system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png - disabled system.adapter.icons-fatcow-hosting.0 : icons-fatcow-hosting - disabled system.adapter.icons-icons8.0 : icons-icons8 - disabled system.adapter.icons-material-png.0 : icons-material-png - disabled system.adapter.icons-material-svg.0 : icons-material-svg - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png - disabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png - disabled system.adapter.influxdb.0 : influxdb - disabled, port: 8086 system.adapter.info.0 : info - disabled system.adapter.iot.0 : iot - disabled system.adapter.iqontrol.0 : iqontrol - disabled system.adapter.javascript.0 : javascript - disabled system.adapter.mihome.0 : mihome - disabled, port: 9898, bind: 0.0.0.0 system.adapter.node-red.0 : node-red - disabled, port: 1880, bind: 0.0.0.0 system.adapter.paw.0 : paw - disabled, port: 8081 system.adapter.ping.0 : ping - disabled system.adapter.pushover.0 : pushover - disabled system.adapter.sayit.0 : sayit - disabled, port: 0 system.adapter.scenes.0 : scenes - disabled system.adapter.schoolfree.0 : schoolfree - disabled system.adapter.shuttercontrol.0 : shuttercontrol - disabled system.adapter.sonoff.0 : sonoff - disabled, port: 1883, bind: 0.0.0.0 system.adapter.sonos.0 : sonos - disabled system.adapter.spotify-premium.0 : spotify-premium - disabled system.adapter.sql.0 : sql - disabled, port: 0 system.adapter.starline.0 : starline - disabled system.adapter.telegram.0 : telegram - disabled, port: 8443, bind: 0.0.0.0 system.adapter.telegram.1 : telegram - disabled, port: 8443, bind: 0.0.0.0 system.adapter.text2command.0 : text2command - disabled system.adapter.tr-064.0 : tr-064 - disabled system.adapter.tradfri.0 : tradfri - disabled system.adapter.trashschedule.0 : trashschedule - disabled system.adapter.trashschedule.1 : trashschedule - disabled system.adapter.tuya.0 : tuya - disabled system.adapter.vis-bars.0 : vis-bars - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch - disabled system.adapter.vis-google-fonts.0 : vis-google-fonts - disabled system.adapter.vis-history.0 : vis-history - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets - disabled system.adapter.vis-inventwo.0 : vis-inventwo - disabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd - disabled system.adapter.vis-justgage.0 : vis-justgage - disabled system.adapter.vis-lcars.0 : vis-lcars - disabled system.adapter.vis-map.0 : vis-map - disabled system.adapter.vis-metro.0 : vis-metro - disabled system.adapter.vis-players.0 : vis-players - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather - disabled system.adapter.vis-weather.0 : vis-weather - disabled system.adapter.vis.0 : vis - disabled system.adapter.web.0 : web - disabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.wifilight.0 : wifilight - disabled system.adapter.yahka.0 : yahka - disabled system.adapter.yahka.1 : yahka - disabled system.adapter.yahka.2 : yahka - disabled system.adapter.yr.0 : yr - disabled system.adapter.zigbee.0 : zigbee - disabled, port: /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00 + instance is aliveiobroker status iobroker is running on this host. At least one iobroker host is running. Objects type: file States type: file -
@exitus sagte in Hilfe Admin Oberfläche:
nein , das tut sie wieder nicht!
sonst wäre da ein + am Anfang der ZeileAlso nochmal
iobroker start admin -
@Homoran wieder was dazu gelernt.
Was sind meine nächsten schritte ??Plattmachen ;-)
Wenn dein ioBroker nicht von selber startet ist irgendetwas faul, was wir hier nicht sehen!
Mach bitte mal ein
sudo reboot
wenn danach der iobroker wieder nicht von selber hochfährt müssen wir uns was einfallen lassen -
Mach bitte mal ein
sudo reboot
Mach bitte mal ein
sudo reboot
wenn danach der iobroker wieder nicht von selber hochfährt müssen wir uns was einfallen lassen@Homoran
So, da bin ich wieder und habe wohl nicht viel verpasst.
Ja, wenn der nicht von sich aus startet, ist was faul und da @exitus nicht wie gewünscht nach der Anleitung von raspifun.de den Pi installiert hat, zusehen an der falschen Systemzeit, ist das die beste Idee und wenn nicht beim ersten mal schon geschehen, bitte das lite Image verwenden. -
@Homoran
@Jan1 ok ich installiere frisch.
soll ich den hier nehmen.
Raspberry Pi OS Lite
Release date: December 2nd 2020
Kernel version: 5.4
Ja das minimal, da ein Desktop hier nicht gewünscht ist und Du mit Deinen 77! Intanzen selbst beim Pi 4 schon hart dran bist.
Zum Thema Runlevel wird Dir später Thomas noch was sagen. Da die Kiste so wenig wie möglich unnötige Ressourcen für die Basis verballern sollte um den IOBroker rund laufen zu lassen.Also alles noch mal auf null und wenn wir schon dabei sind. Lief das schon auf SSD wie Du es wolltest, oder noch auf SD Karte? Wenn auf SD, wie groß und wie alt ist die?
@exitus
@Jan1 von ssd bootet es die sd ist neu 32 gb.
bevor ich hier schrieb lief es auf ssd, ich hate nur den fehler mit admin oberfläsche, sonst lief alles.
wie iot scripte telegramm unsw. auf ssd -
@exitus
Eigentlich sollte dann alles auf SSD sein und gar keine SD mehr benötigt werden damit das Sinn macht. Aber egal und 32GB ist ok, die macht wesentlich länger mit als ne 8 oder 16GB Karte. -
@Jan1 ich kann raspi auch auf ssd starten brauche ja nur den sd auf ssd clonen oder soll ich erst auf sd alles installieren und später auf ssd
@exitus
Wenn Du es schaffst gleich alles auf SSD zu bekommen, dann kannst das machen, wobei ich mich damit beim Pi nie beschäftigt habe und somit nicht weiß, ob und was da zu beachten wäre.Wie gehabt, nach Updates suchen mit sudo apt update && sudo apt upgrade, reboot und IOBroker über Script installieren. Wenn das geklappt hat mal die Node Version prüfen (sollte ja über das Script gleich mit drauf sein).
@exitus
@exitus
@Jan1 so was habe ich gemacht
- busterlite letzte version 2020-12-02-raspios-buster-armhf-lite auf die sd
2.sudo apt update && sudo apt upgrade - sudo raspi-config feste ip und systemzeit geändert
- sd karte auf ssd geklont erfolgreich gebootet mit ssd und warte auf weitere Befehle
nach dem wiederherstellen startet es nicht
Hast du noch die gleiche Hardware, die gleiche IP-Adresse und den gleichen Hostnamen, wie bei dem System, von dem das Backup stammt?
@exitus
So, da wir soweit heute ja schon mal waren, bevor Du los galoppiert bist, diesmal eins nach dem anderen ;)- IObroker und Backitup Adapter instllieren
- Meldung wenn es fertig ist
@Jan1
1.curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
2. curl -sL https://iobroker.net/install.sh | bash -
das hier? -
@Jan1
das hier? -
@Jan1
das hier?
