  4. Zigbee Adapter v1.2.1 immer Rot
zigbee adapter cc2531zigbee v1.2.1adapterkonfiguration zigbee
76 Beiträge 5 Kommentatoren 7.1k Aufrufe 4 Beobachtet
  • M Mapio90
    @Thomas-Braun
    Auch hier beim Slave ist der Zigbee Adapter rot
    pi@second-device:~ $ iobroker list adapters
    system.adapter.admin                   : admin          - v4.1.10
    system.adapter.alexa2                  : alexa2         - v3.3.5
    system.adapter.backitup                : backitup       - v1.7.0
    system.adapter.ble                     : ble            - v0.12.0
    system.adapter.cloud                   : cloud          - v3.1.0
    system.adapter.daswetter               : daswetter      - v3.0.4
    system.adapter.digitalstrom            : digitalstrom   - v0.5.5
    system.adapter.discovery               : discovery      - v2.3.11
    system.adapter.flot                    : flot           - v1.10.4
    system.adapter.info                    : info           - v1.7.10
    system.adapter.javascript              : javascript     - v4.8.4
    system.adapter.mihome-vacuum           : mihome-vacuum  - v2.1.1
    system.adapter.mobile                  : mobile         - v1.0.1
    system.adapter.samsung                 : samsung        - v0.2.9
    system.adapter.scenes                  : scenes         - v2.3.0
    system.adapter.simple-api              : simple-api     - v2.4.8
    system.adapter.socketio                : socketio       - v3.0.13
    system.adapter.sonoff                  : sonoff         - v2.3.3
    system.adapter.telegram                : telegram       - v1.6.0
    system.adapter.terminal                : terminal       - v0.1.2
    system.adapter.text2command            : text2command   - v2.0.5
    system.adapter.tr-064                  : tr-064         - v4.2.1
    system.adapter.web                     : web            - v3.0.14
    system.adapter.zigbee                  : zigbee         - v0.10.3
    pi@second-device:~ $ iobroker list instances
    + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.admin.1                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                : alexa2                -  enabled
    + system.adapter.backitup.0              : backitup              -  enabled
    + system.adapter.backitup.1              : backitup              -  enabled
    + system.adapter.ble.0                   : ble                   -  enabled
    + system.adapter.ble.1                   : ble                   -  enabled
    + system.adapter.cloud.0                 : cloud                 -  enabled
    + system.adapter.digitalstrom.0          : digitalstrom          -  enabled
    + system.adapter.discovery.0             : discovery             -  enabled
      system.adapter.flot.0                  : flot                  -  enabled
    + system.adapter.javascript.0            : javascript            -  enabled
    + system.adapter.mihome-vacuum.0         : mihome-vacuum         -  enabled, port: 54321
      system.adapter.mobile.0                : mobile                - disabled
    + system.adapter.samsung.0               : samsung               -  enabled
    + system.adapter.scenes.0                : scenes                -  enabled
    + system.adapter.socketio.0              : socketio              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                : sonoff                -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0              : terminal              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.text2command.0          : text2command          -  enabled
    + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                : zigbee                -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0019367259-if00
      system.adapter.zigbee.1                : zigbee                -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0019361A08-if00
    + instance is alive
    pi@second-device:~ $ which nodejs && nodejs -v && which node && node -v && which        npm && npm -v && apt policy nodejs
    /usr/bin/nodejs
    v12.20.0
    /usr/bin/node
    v12.20.0
    /usr/bin/npm
    6.14.8
    nodejs:
      Installiert:           12.20.0-1nodesource1
      Installationskandidat: 12.20.0-1nodesource1
      Versionstabelle:
     *** 12.20.0-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x stretch/main armhf Packages
         8.11.1~dfsg-2~bpo9+1 500
            500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
         4.8.2~dfsg-1 500
            500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
    @Mapio90 Und auch auf dem System mal nach dem Runlevel schauen:
    who -r
      @Mapio90 Sieht wohl ähnlich aus
      sudo apt update
      sudo apt dist-upgrade
      sudo reboot
      iobroker update
      cd /opt/iobroker
      npm i iobroker.zigbee@1.3.1 --force
      iobroker upgrade
      Mapio90
      @Thomas-Braun
      also ich bin mir nicht ganz sicher, aber ich glaube mir schmiert die sd karte vom Slave gerade ab.
      habe vorher das system runter gefahren um den zigbee stick einzustecken.
      Nach dem wieder hochfahren (sudo reboot) hat das system ewig gebraucht bis der slave wieder online kam. Gerade wieder unter putty eingeloggt iobroker update eingegeben und jetzt tust sich seit 5 min garnichts mehr.
      • M Mapio90
        @Thomas-Braun
        @Mapio90
        Strg-C
        Dann
        dmesg
        anschauen.
          who -r
          Mapio90
          @Thomas-Braun sagte in Zigbee Adapter v1.2.1 immer Rot:
          who -r
          Hab ihn mal über nacht laufen lassen..und scheint soweit alles durchgelaufen zu sein.
          pi@second-device:~ $ iobroker update
          Used repository: default
          hash unchanged, use cached sources
          update done
          Adapter    "admin"         : 4.1.10   , installed 4.1.10
          Adapter    "alarm"         : 1.8.1
          Adapter    "alexa2"        : 3.3.5
          Adapter    "alpha2"        : 1.0.0
          Adapter    "amazon-dash"   : 1.1.0
          Adapter    "artnet"        : 1.2.2
          Adapter    "asterisk"      : 1.0.6
          Adapter    "asuswrt"       : 1.0.1
          Adapter    "b-control-em"  : 0.2.1
          Adapter    "backitup"      : 1.7.0    , installed 1.7.0
          Adapter    "beckhoff"      : 1.2.2
          Adapter    "benq"          : 0.2.0
          Adapter    "binance"       : 1.1.3
          Adapter    "ble"           : 0.12.0   , installed 0.12.0
          Adapter    "bmw"           : 1.3.3
          Adapter    "bosesoundtouch": 0.2.4
          Adapter    "botvac"        : 1.0.0
          Adapter    "bring"         : 1.7.3
          Adapter    "broadlink2"    : 2.0.3
          Adapter    "bsblan"        : 0.2.0
          Adapter    "bshb"          : 0.1.10
          Adapter    "chromecast"    : 2.3.1
          Adapter    "cloud"         : 3.1.0
          Adapter    "comfoair"      : 0.3.2
          Adapter    "contactid"     : 1.0.1
          Adapter    "coronavirus-statistics": 0.6.3
          Adapter    "countdown"     : 1.1.0
          Adapter    "cul"           : 1.3.3
          Adapter    "daikin"        : 1.1.2
          Adapter    "daswetter"     : 3.0.4    , installed 3.0.4
          Adapter    "deconz"        : 1.3.11
          Adapter    "denon"         : 1.7.7
          Adapter    "device-reminder": 0.5.4
          Adapter    "devices"       : 0.3.13
          Adapter    "digitalstrom"  : 0.5.5
          Adapter    "discovergy"    : 0.5.0
          Adapter    "discovery"     : 2.3.11   , installed 2.3.11
          Adapter    "doorio"        : 1.1.1
          Adapter    "ds18b20"       : 1.1.5
          Adapter    "dwd"           : 2.5.1
          Adapter    "ebus"          : 2.1.1
          Adapter    "ecovacs-deebot": 1.0.3
          Adapter    "egigeozone"    : 0.1.2
          Adapter    "ekey"          : 1.1.0
          Adapter    "email"         : 1.0.7
          Adapter    "emby"          : 1.0.2
          Adapter    "energymanager" : 1.2.3
          Adapter    "enet"          : 1.0.1
          Adapter    "epson_stylus_px830": 0.2.1
          Adapter    "exchangerates" : 0.0.13
          Adapter    "fakeroku"      : 0.2.1
          Adapter    "fb-checkpresence": 1.1.0
          Adapter    "feiertage"     : 1.0.17
          Adapter    "fhem"          : 1.5.3
          Adapter    "find-my-iphone": 0.2.15
          Adapter    "firetv"        : 0.0.27
          Adapter    "flot"          : 1.10.4
          Adapter    "foobar2000"    : 2.0.3
          Adapter    "fritzbox"      : 0.2.1
          Adapter    "fritzdect"     : 0.2.4
          Adapter    "fronius"       : 1.0.5
          Adapter    "frontier_silicon": 0.0.10
          Adapter    "fullcalendar"  : 1.1.0
          Adapter    "fullybrowser"  : 2.0.1
          Adapter    "g-homa"        : 0.5.3
          Adapter    "geofency"      : 0.3.2
          Adapter    "growatt"       : 0.0.14
          Adapter    "gruenbeck"     : 0.0.18
          Adapter    "habpanel"      : 0.4.3
          Adapter    "haier"         : 1.0.2
          Adapter    "ham"           : 1.1.2
          Adapter    "ham-wemo"      : 1.1.0
          Adapter    "harmony"       : 1.2.2
          Adapter    "heatingcontrol": 1.0.0
          Adapter    "heos"          : 1.6.1
          Adapter    "heytech"       : 1.0.0
          Adapter    "hid"           : 0.1.17
          Adapter    "history"       : 1.9.10
          Adapter    "hm-rega"       : 2.6.24
          Adapter    "hm-rpc"        : 1.14.24
          Adapter    "hmip"          : 1.5.0
          Adapter    "homeconnect"   : 0.0.30
          Adapter    "homee"         : 1.0.7
          Adapter    "homepilot"     : 1.0.3
          Adapter    "hp-ilo"        : 1.0.6
          Adapter    "hs100"         : 2.0.1
          Adapter    "hue"           : 3.3.8
          Adapter    "hue-extended"  : 2.0.0
          Adapter    "i2c"           : 1.1.1
          Adapter    "ical"          : 1.7.4
          Adapter    "icons-addictive-flavour-png": 0.1.0
          Adapter    "icons-fatcow-hosting": 0.1.0
          Adapter    "icons-icons8"  : 0.0.1
          Adapter    "icons-material-png": 0.1.0
          Adapter    "icons-material-svg": 0.1.0
          Adapter    "icons-mfd-png" : 1.0.2
          Adapter    "icons-mfd-svg" : 1.0.2
          Adapter    "icons-open-icon-library-png": 0.1.2
          Adapter    "icons-ultimate-png": 1.0.1
          Adapter    "influxdb"      : 1.9.1
          Adapter    "info"          : 1.7.10
          Adapter    "innogy-smarthome": 0.3.6
          Adapter    "iogo"          : 0.5.10
          Adapter    "iot"           : 1.5.3
          Adapter    "iqontrol"      : 1.5.0
          Adapter    "jarvis"        : 1.0.9
          Adapter    "javascript"    : 4.8.4
          Adapter    "jeelink"       : 0.1.0
          Controller "js-controller" : 3.1.6    , installed 3.1.6
          Adapter    "kecontact"     : 1.0.1
          Adapter    "klf200"        : 1.0.1
          Adapter    "km200"         : 1.1.6
          Adapter    "knmi-weather"  : 1.0.0
          Adapter    "knx"           : 1.0.39
          Adapter    "kodi"          : 2.0.4
          Adapter    "kostal-piko-ba": 1.1.3
          Adapter    "kress"         : 2.5.5
          Adapter    "lametric"      : 0.0.9
          Adapter    "landroid"      : 1.0.3
          Adapter    "lcn"           : 1.0.2
          Adapter    "legrand-ecocompteur": 1.0.0
          Adapter    "letrika_comgw" : 0.0.5
          Adapter    "lgtv"          : 1.1.10
          Adapter    "lgtv-rs"       : 0.1.0
          Adapter    "lgtv11"        : 1.0.5
          Adapter    "lifx"          : 0.1.0
          Adapter    "lightify"      : 0.2.16
          Adapter    "link"          : 0.5.9
          Adapter    "linkeddevices" : 1.2.2
          Adapter    "linux-control" : 1.0.1
          Adapter    "logparser"     : 1.1.0
          Adapter    "lovelace"      : 1.0.16
          Adapter    "loxone"        : 2.0.2
          Adapter    "luftdaten"     : 1.0.1
          Adapter    "lupusec"       : 1.2.9
          Adapter    "luxtronik1"    : 0.2.2
          Adapter    "material"      : 0.13.9
          Adapter    "maxcube"       : 1.0.2
          Adapter    "maxcul"        : 1.3.1
          Adapter    "mbus"          : 2.3.1
          Adapter    "mclighting"    : 0.1.1
          Adapter    "megad"         : 1.2.1
          Adapter    "megadd"        : 0.2.0
          Adapter    "megaesp"       : 0.1.0
          Adapter    "melcloud"      : 1.0.6
          Adapter    "mercedesme"    : 0.0.21
          Adapter    "mercury"       : 0.1.1
          Adapter    "meross"        : 1.5.0
          Adapter    "meteoalarm"    : 1.0.9
          Adapter    "midea"         : 0.0.6
          Adapter    "miele"         : 0.1.5
          Adapter    "mielecloudservice": 2.0.0
          Adapter    "mihome"        : 1.3.5
          Adapter    "mihome-lamp"   : 1.1.0
          Adapter    "mihome-plug"   : 0.2.1
          Adapter    "mihome-vacuum" : 2.1.1
          Adapter    "mikrotik"      : 1.0.11
          Adapter    "milight"       : 0.3.6
          Adapter    "milight-smart-light": 0.2.7
          Adapter    "minuvis"       : 1.0.0
          Adapter    "mobile"        : 1.0.1
          Adapter    "modbus"        : 3.1.10
          Adapter    "moma"          : 1.2.7
          Adapter    "mpd"           : 1.0.5
          Adapter    "mqtt"          : 2.1.9
          Adapter    "mqtt-client"   : 1.3.1
          Adapter    "musiccast"     : 0.1.3
          Adapter    "mydlink"       : 1.1.7
          Adapter    "mysensors"     : 2.0.1
          Adapter    "nanoleaf-lightpanels": 1.0.6
          Adapter    "nello"         : 2.0.6
          Adapter    "netatmo"       : 1.3.3
          Adapter    "netatmo-crawler": 0.3.8
          Adapter    "nibeuplink"    : 0.3.0
          Adapter    "nina"          : 0.0.22
          Adapter    "node-red"      : 2.0.1
          Adapter    "nuki"          : 1.4.2
          Adapter    "nuki-extended" : 2.3.0
          Adapter    "nut"           : 1.1.3
          Adapter    "octoprint"     : 1.0.1
          Adapter    "odl"           : 1.0.7
          Adapter    "oilfox"        : 0.0.5
          Adapter    "onkyo"         : 2.0.3
          Adapter    "onvif"         : 0.4.4
          Adapter    "openhab"       : 1.1.0
          Adapter    "openligadb"    : 1.1.0
          Adapter    "openweathermap": 0.1.0
          Adapter    "opi"           : 0.1.1
          Adapter    "oppoplayer"    : 0.2.1
          Adapter    "owfs"          : 0.6.4
          Adapter    "owntracks"     : 0.6.3
          Adapter    "panasonic-viera": 1.0.2
          Adapter    "parser"        : 1.0.7
          Adapter    "paw"           : 0.0.7
          Adapter    "phantomjs"     : 1.1.2
          Adapter    "pi-hole"       : 1.3.1
          Adapter    "piface"        : 1.0.0
          Adapter    "pimatic"       : 0.3.0
          Adapter    "ping"          : 1.4.12
          Adapter    "places"        : 1.0.0
          Adapter    "plex"          : 0.8.11
          Adapter    "plexconnect"   : 0.0.7
          Adapter    "pollenflug"    : 1.0.6
          Adapter    "proxmox"       : 1.0.1
          Adapter    "proxy"         : 1.2.1
          Adapter    "pushbullet"    : 0.0.11
          Adapter    "pushover"      : 2.0.3
          Adapter    "pushsafer"     : 0.1.8
          Adapter    "radar2"        : 1.0.9
          Adapter    "radiohead"     : 1.0.7
          Adapter    "rflink"        : 2.1.6
          Adapter    "rickshaw"      : 1.0.0
          Adapter    "ring"          : 1.1.3
          Adapter    "robonect"      : 0.1.3
          Adapter    "roomba"        : 1.1.1
          Adapter    "rpi2"          : 1.2.0
          Adapter    "s7"            : 1.1.9
          Adapter    "samsung"       : 0.2.9
          Adapter    "sayit"         : 1.12.2
          Adapter    "sbfspot"       : 4.0.2
          Adapter    "scenes"        : 2.3.0
          Adapter    "schoolfree"    : 0.7.0
          Adapter    "schwoerer-ventcube": 1.3.0
          Adapter    "shelly"        : 4.0.3
          Adapter    "shuttercontrol": 1.0.4
          Adapter    "sia"           : 1.0.4
          Adapter    "siegenia"      : 1.0.0
          Adapter    "simple-api"    : 2.4.8
          Adapter    "smappee"       : 0.2.2
          Adapter    "smartcontrol"  : 1.2.1
          Adapter    "smartgarden"   : 1.0.1
          Adapter    "smartmeter"    : 3.1.6
          Adapter    "snips"         : 1.5.1
          Adapter    "snmp"          : 0.5.0
          Adapter    "socketio"      : 3.0.13
          Adapter    "solarlog"      : 2.0.0
          Adapter    "solarviewdatareader": 0.2.1
          Adapter    "solarwetter"   : 1.0.0
          Adapter    "sonnen"        : 1.7.0
          Adapter    "sonoff"        : 2.3.3
          Adapter    "sonos"         : 2.1.1
          Adapter    "sony-bravia"   : 1.0.1
          Adapter    "spotify-premium": 1.0.0
          Adapter    "sql"           : 1.15.3
          Adapter    "squeezebox"    : 1.0.0
          Adapter    "squeezeboxrpc" : 1.0.0
          Adapter    "starline"      : 1.0.0
          Adapter    "statistics"    : 0.2.2
          Adapter    "stiebel-isg"   : 1.5.1
          Adapter    "sunnyportal"   : 0.1.5
          Adapter    "swiss-weather-api": 0.3.2
          Adapter    "synology"      : 0.1.18
          Adapter    "systeminfo"    : 0.3.1
          Adapter    "tahoma"        : 0.3.2
          Adapter    "tankerkoenig"  : 2.0.5
          Adapter    "telegram"      : 1.6.0
          Adapter    "terminal"      : 0.1.2
          Adapter    "tesla-motors"  : 0.2.3
          Adapter    "text2command"  : 2.0.5
          Adapter    "tinker"        : 1.1.0
          Adapter    "tr-064"        : 4.2.1
          Adapter    "tradfri"       : 2.6.3
          Adapter    "trashschedule" : 1.0.3
          Adapter    "tunnelbroker-endpoint-updater": 0.0.1
          Adapter    "tuya"          : 3.4.1
          Adapter    "tvspielfilm"   : 1.0.4
          Adapter    "unifi"         : 0.5.8
          Adapter    "upnp"          : 1.0.16
          Adapter    "vaillant"      : 0.0.10
          Adapter    "valloxmv"      : 1.1.1
          Adapter    "vcard"         : 0.0.9
          Adapter    "velux"         : 0.0.5
          Adapter    "viessmann"     : 1.3.2
          Adapter    "virtualpowermeter": 1.2.1
          Adapter    "vis"           : 1.3.4
          Adapter    "vis-bars"      : 0.1.4
          Adapter    "vis-canvas-gauges": 0.1.5
          Adapter    "vis-colorpicker": 1.2.0
          Adapter    "vis-fancyswitch": 1.1.0
          Adapter    "vis-google-fonts": 0.1.0
          Adapter    "vis-history"   : 1.0.0
          Adapter    "vis-hqwidgets" : 1.1.7
          Adapter    "vis-icontwo"   : 0.34.0
          Adapter    "vis-inventwo"  : 2.5.11
          Adapter    "vis-jqui-mfd"  : 1.0.12
          Adapter    "vis-justgage"  : 1.0.2
          Adapter    "vis-keyboard"  : 0.0.2
          Adapter    "vis-lcars"     : 1.0.4
          Adapter    "vis-map"       : 1.0.4
          Adapter    "vis-material-advanced": 1.3.0
          Adapter    "vis-metro"     : 1.1.2
          Adapter    "vis-players"   : 0.1.6
          Adapter    "vis-plumb"     : 1.0.2
          Adapter    "vis-rgraph"    : 0.0.2
          Adapter    "vis-timeandweather": 1.1.7
          Adapter    "vis-weather"   : 2.5.2
          Adapter    "vr200"         : 1.0.0
          Adapter    "vw-connect"    : 0.0.15
          Adapter    "weatherunderground": 3.2.1
          Adapter    "web"           : 3.0.14
          Adapter    "weishaupt-wem" : 0.0.8
          Adapter    "whatsapp-cmb"  : 0.1.6
          Adapter    "wiffi-wz"      : 2.2.0
          Adapter    "wifilight"     : 1.1.0
          Adapter    "windows-control": 0.1.5
          Adapter    "wled"          : 0.5.2
          Adapter    "wm-bus"        : 0.1.12
          Adapter    "wolf"          : 1.2.1
          Adapter    "worx"          : 1.2.3
          Adapter    "xbox"          : 0.6.8
          Adapter    "xs1"           : 1.0.2
          Adapter    "yahka"         : 0.11.0
          Adapter    "yamaha"        : 0.3.19
          Adapter    "yeelight-2"    : 1.0.3
          Adapter    "youtube"       : 1.0.0
          Adapter    "yr"            : 2.0.3
          Adapter    "zigbee"        : 1.3.1    , installed 0.10.3 [Updateable]
          Adapter    "zont"          : 0.5.3
          Adapter    "zwave"         : 2.0.1
          Adapter    "zwave2"        : 1.7.10
          pi@second-device:~ $ cd /opt/iobroker
          pi@second-device:/opt/iobroker $ npm i iobroker.zigbee@1.3.1 --force
          npm WARN using --force I sure hope you know what you are doing.
          > @serialport/bindings@9.0.3 install /opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings
          > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
          prebuild-install WARN install No prebuilt binaries found (target=12.20.0 runtime=node arch=arm libc= platform=linux)
          make: Verzeichnis „/opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings/build“ wird betreten
            CXX(target) Release/obj.target/bindings/src/serialport.o
            CXX(target) Release/obj.target/bindings/src/serialport_unix.o
            CXX(target) Release/obj.target/bindings/src/poller.o
            CXX(target) Release/obj.target/bindings/src/serialport_linux.o
            SOLINK_MODULE(target) Release/obj.target/bindings.node
            COPY Release/bindings.node
          make: Verzeichnis „/opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings/build“ wird verlassen
          > serialport@9.0.2 postinstall /opt/iobroker/node_modules/serialport
          > node thank-you.js
          Thank you for using serialport!
          If you rely on this package, please consider supporting our open collective:
          > https://opencollective.com/serialport/donate
          npm WARN winston-syslog@2.4.4 requires a peer of winston@^3.0.0 but none is installed. You must install peer dependencies yourself.
          + iobroker.zigbee@1.3.1
          added 34 packages from 34 contributors, removed 252 packages, updated 18 packages and moved 5 packages in 53.452s
          13 packages are looking for funding
            run `npm fund` for details
          pi@second-device:/opt/iobroker $ iobroker upgrade
          Adapter "admin"          is up to date.
          Adapter "alarm"          is not installed.
          Adapter "alexa2"         is not installed.
          Adapter "alpha2"         is not installed.
          Adapter "amazon-dash"    is not installed.
          Adapter "artnet"         is not installed.
          Adapter "asterisk"       is not installed.
          Adapter "asuswrt"        is not installed.
          Adapter "b-control-em"   is not installed.
          Adapter "backitup"       is up to date.
          Adapter "beckhoff"       is not installed.
          Adapter "benq"           is not installed.
          Adapter "binance"        is not installed.
          Adapter "ble"            is up to date.
          Adapter "bmw"            is not installed.
          Adapter "bosesoundtouch" is not installed.
          Adapter "botvac"         is not installed.
          Adapter "bring"          is not installed.
          Adapter "broadlink2"     is not installed.
          Adapter "bsblan"         is not installed.
          Adapter "bshb"           is not installed.
          Adapter "chromecast"     is not installed.
          Adapter "cloud"          is not installed.
          Adapter "comfoair"       is not installed.
          Adapter "contactid"      is not installed.
          Adapter "coronavirus-statistics" is not installed.
          Adapter "countdown"      is not installed.
          Adapter "cul"            is not installed.
          Adapter "daikin"         is not installed.
          Adapter "daswetter"      is up to date.
          Adapter "deconz"         is not installed.
          Adapter "denon"          is not installed.
          Adapter "device-reminder" is not installed.
          Adapter "devices"        is not installed.
          Adapter "digitalstrom"   is not installed.
          Adapter "discovergy"     is not installed.
          Adapter "discovery"      is up to date.
          Adapter "doorio"         is not installed.
          Adapter "ds18b20"        is not installed.
          Adapter "dwd"            is not installed.
          Adapter "ebus"           is not installed.
          Adapter "ecovacs-deebot" is not installed.
          Adapter "egigeozone"     is not installed.
          Adapter "ekey"           is not installed.
          Adapter "email"          is not installed.
          Adapter "emby"           is not installed.
          Adapter "energymanager"  is not installed.
          Adapter "enet"           is not installed.
          Adapter "epson_stylus_px830" is not installed.
          Adapter "exchangerates"  is not installed.
          Adapter "fakeroku"       is not installed.
          Adapter "fb-checkpresence" is not installed.
          Adapter "feiertage"      is not installed.
          Adapter "fhem"           is not installed.
          Adapter "find-my-iphone" is not installed.
          Adapter "firetv"         is not installed.
          Adapter "flot"           is not installed.
          Adapter "foobar2000"     is not installed.
          Adapter "fritzbox"       is not installed.
          Adapter "fritzdect"      is not installed.
          Adapter "fronius"        is not installed.
          Adapter "frontier_silicon" is not installed.
          Adapter "fullcalendar"   is not installed.
          Adapter "fullybrowser"   is not installed.
          Adapter "g-homa"         is not installed.
          Adapter "geofency"       is not installed.
          Adapter "growatt"        is not installed.
          Adapter "gruenbeck"      is not installed.
          Adapter "habpanel"       is not installed.
          Adapter "haier"          is not installed.
          Adapter "ham"            is not installed.
          Adapter "ham-wemo"       is not installed.
          Adapter "harmony"        is not installed.
          Adapter "heatingcontrol" is not installed.
          Adapter "heos"           is not installed.
          Adapter "heytech"        is not installed.
          Adapter "hid"            is not installed.
          Adapter "history"        is not installed.
          Adapter "hm-rega"        is not installed.
          Adapter "hm-rpc"         is not installed.
          Adapter "hmip"           is not installed.
          Adapter "homeconnect"    is not installed.
          Adapter "homee"          is not installed.
          Adapter "homepilot"      is not installed.
          Adapter "hp-ilo"         is not installed.
          Adapter "hs100"          is not installed.
          Adapter "hue"            is not installed.
          Adapter "hue-extended"   is not installed.
          Adapter "i2c"            is not installed.
          Adapter "ical"           is not installed.
          Adapter "icons-addictive-flavour-png" is not installed.
          Adapter "icons-fatcow-hosting" is not installed.
          Adapter "icons-icons8"   is not installed.
          Adapter "icons-material-png" is not installed.
          Adapter "icons-material-svg" is not installed.
          Adapter "icons-mfd-png"  is not installed.
          Adapter "icons-mfd-svg"  is not installed.
          Adapter "icons-open-icon-library-png" is not installed.
          Adapter "icons-ultimate-png" is not installed.
          Adapter "influxdb"       is not installed.
          Adapter "info"           is not installed.
          Adapter "innogy-smarthome" is not installed.
          Adapter "iogo"           is not installed.
          Adapter "iot"            is not installed.
          Adapter "iqontrol"       is not installed.
          Adapter "jarvis"         is not installed.
          Adapter "javascript"     is not installed.
          Adapter "jeelink"        is not installed.
          Adapter "kecontact"      is not installed.
          Adapter "klf200"         is not installed.
          Adapter "km200"          is not installed.
          Adapter "knmi-weather"   is not installed.
          Adapter "knx"            is not installed.
          Adapter "kodi"           is not installed.
          Adapter "kostal-piko-ba" is not installed.
          Adapter "kress"          is not installed.
          Adapter "lametric"       is not installed.
          Adapter "landroid"       is not installed.
          Adapter "lcn"            is not installed.
          Adapter "legrand-ecocompteur" is not installed.
          Adapter "letrika_comgw"  is not installed.
          Adapter "lgtv"           is not installed.
          Adapter "lgtv-rs"        is not installed.
          Adapter "lgtv11"         is not installed.
          Adapter "lifx"           is not installed.
          Adapter "lightify"       is not installed.
          Adapter "link"           is not installed.
          Adapter "linkeddevices"  is not installed.
          Adapter "linux-control"  is not installed.
          Adapter "logparser"      is not installed.
          Adapter "lovelace"       is not installed.
          Adapter "loxone"         is not installed.
          Adapter "luftdaten"      is not installed.
          Adapter "lupusec"        is not installed.
          Adapter "luxtronik1"     is not installed.
          Adapter "material"       is not installed.
          Adapter "maxcube"        is not installed.
          Adapter "maxcul"         is not installed.
          Adapter "mbus"           is not installed.
          Adapter "mclighting"     is not installed.
          Adapter "megad"          is not installed.
          Adapter "megadd"         is not installed.
          Adapter "megaesp"        is not installed.
          Adapter "melcloud"       is not installed.
          Adapter "mercedesme"     is not installed.
          Adapter "mercury"        is not installed.
          Adapter "meross"         is not installed.
          Adapter "meteoalarm"     is not installed.
          Adapter "midea"          is not installed.
          Adapter "miele"          is not installed.
          Adapter "mielecloudservice" is not installed.
          Adapter "mihome"         is not installed.
          Adapter "mihome-lamp"    is not installed.
          Adapter "mihome-plug"    is not installed.
          Adapter "mihome-vacuum"  is not installed.
          Adapter "mikrotik"       is not installed.
          Adapter "milight"        is not installed.
          Adapter "milight-smart-light" is not installed.
          Adapter "minuvis"        is not installed.
          Adapter "mobile"         is not installed.
          Adapter "modbus"         is not installed.
          Adapter "moma"           is not installed.
          Adapter "mpd"            is not installed.
          Adapter "mqtt"           is not installed.
          Adapter "mqtt-client"    is not installed.
          Adapter "musiccast"      is not installed.
          Adapter "mydlink"        is not installed.
          Adapter "mysensors"      is not installed.
          Adapter "nanoleaf-lightpanels" is not installed.
          Adapter "nello"          is not installed.
          Adapter "netatmo"        is not installed.
          Adapter "netatmo-crawler" is not installed.
          Adapter "nibeuplink"     is not installed.
          Adapter "nina"           is not installed.
          Adapter "node-red"       is not installed.
          Adapter "nuki"           is not installed.
          Adapter "nuki-extended"  is not installed.
          Adapter "nut"            is not installed.
          Adapter "octoprint"      is not installed.
          Adapter "odl"            is not installed.
          Adapter "oilfox"         is not installed.
          Adapter "onkyo"          is not installed.
          Adapter "onvif"          is not installed.
          Adapter "openhab"        is not installed.
          Adapter "openligadb"     is not installed.
          Adapter "openweathermap" is not installed.
          Adapter "opi"            is not installed.
          Adapter "oppoplayer"     is not installed.
          Adapter "owfs"           is not installed.
          Adapter "owntracks"      is not installed.
          Adapter "panasonic-viera" is not installed.
          Adapter "parser"         is not installed.
          Adapter "paw"            is not installed.
          Adapter "phantomjs"      is not installed.
          Adapter "pi-hole"        is not installed.
          Adapter "piface"         is not installed.
          Adapter "pimatic"        is not installed.
          Adapter "ping"           is not installed.
          Adapter "places"         is not installed.
          Adapter "plex"           is not installed.
          Adapter "plexconnect"    is not installed.
          Adapter "pollenflug"     is not installed.
          Adapter "proxmox"        is not installed.
          Adapter "proxy"          is not installed.
          Adapter "pushbullet"     is not installed.
          Adapter "pushover"       is not installed.
          Adapter "pushsafer"      is not installed.
          Adapter "radar2"         is not installed.
          Adapter "radiohead"      is not installed.
          Adapter "rflink"         is not installed.
          Adapter "rickshaw"       is not installed.
          Adapter "ring"           is not installed.
          Adapter "robonect"       is not installed.
          Adapter "roomba"         is not installed.
          Adapter "rpi2"           is not installed.
          Adapter "s7"             is not installed.
          Adapter "samsung"        is not installed.
          Adapter "sayit"          is not installed.
          Adapter "sbfspot"        is not installed.
          Adapter "scenes"         is not installed.
          Adapter "schoolfree"     is not installed.
          Adapter "schwoerer-ventcube" is not installed.
          Adapter "shelly"         is not installed.
          Adapter "shuttercontrol" is not installed.
          Adapter "sia"            is not installed.
          Adapter "siegenia"       is not installed.
          Adapter "simple-api"     is not installed.
          Adapter "smappee"        is not installed.
          Adapter "smartcontrol"   is not installed.
          Adapter "smartgarden"    is not installed.
          Adapter "smartmeter"     is not installed.
          Adapter "snips"          is not installed.
          Adapter "snmp"           is not installed.
          Adapter "socketio"       is not installed.
          Adapter "solarlog"       is not installed.
          Adapter "solarviewdatareader" is not installed.
          Adapter "solarwetter"    is not installed.
          Adapter "sonnen"         is not installed.
          Adapter "sonoff"         is not installed.
          Adapter "sonos"          is not installed.
          Adapter "sony-bravia"    is not installed.
          Adapter "spotify-premium" is not installed.
          Adapter "sql"            is not installed.
          Adapter "squeezebox"     is not installed.
          Adapter "squeezeboxrpc"  is not installed.
          Adapter "starline"       is not installed.
          Adapter "statistics"     is not installed.
          Adapter "stiebel-isg"    is not installed.
          Adapter "sunnyportal"    is not installed.
          Adapter "swiss-weather-api" is not installed.
          Adapter "synology"       is not installed.
          Adapter "systeminfo"     is not installed.
          Adapter "tahoma"         is not installed.
          Adapter "tankerkoenig"   is not installed.
          Adapter "telegram"       is not installed.
          Adapter "terminal"       is not installed.
          Adapter "tesla-motors"   is not installed.
          Adapter "text2command"   is not installed.
          Adapter "tinker"         is not installed.
          Adapter "tr-064"         is not installed.
          Adapter "tradfri"        is not installed.
          Adapter "trashschedule"  is not installed.
          Adapter "tunnelbroker-endpoint-updater" is not installed.
          Adapter "tuya"           is not installed.
          Adapter "tvspielfilm"    is not installed.
          Adapter "unifi"          is not installed.
          Adapter "upnp"           is not installed.
          Adapter "vaillant"       is not installed.
          Adapter "valloxmv"       is not installed.
          Adapter "vcard"          is not installed.
          Adapter "velux"          is not installed.
          Adapter "viessmann"      is not installed.
          Adapter "virtualpowermeter" is not installed.
          Adapter "vis"            is not installed.
          Adapter "vis-bars"       is not installed.
          Adapter "vis-canvas-gauges" is not installed.
          Adapter "vis-colorpicker" is not installed.
          Adapter "vis-fancyswitch" is not installed.
          Adapter "vis-google-fonts" is not installed.
          Adapter "vis-history"    is not installed.
          Adapter "vis-hqwidgets"  is not installed.
          Adapter "vis-icontwo"    is not installed.
          Adapter "vis-inventwo"   is not installed.
          Adapter "vis-jqui-mfd"   is not installed.
          Adapter "vis-justgage"   is not installed.
          Adapter "vis-keyboard"   is not installed.
          Adapter "vis-lcars"      is not installed.
          Adapter "vis-map"        is not installed.
          Adapter "vis-material-advanced" is not installed.
          Adapter "vis-metro"      is not installed.
          Adapter "vis-players"    is not installed.
          Adapter "vis-plumb"      is not installed.
          Adapter "vis-rgraph"     is not installed.
          Adapter "vis-timeandweather" is not installed.
          Adapter "vis-weather"    is not installed.
          Adapter "vr200"          is not installed.
          Adapter "vw-connect"     is not installed.
          Adapter "weatherunderground" is not installed.
          Adapter "web"            is not installed.
          Adapter "weishaupt-wem"  is not installed.
          Adapter "whatsapp-cmb"   is not installed.
          Adapter "wiffi-wz"       is not installed.
          Adapter "wifilight"      is not installed.
          Adapter "windows-control" is not installed.
          Adapter "wled"           is not installed.
          Adapter "wm-bus"         is not installed.
          Adapter "wolf"           is not installed.
          Adapter "worx"           is not installed.
          Adapter "xbox"           is not installed.
          Adapter "xs1"            is not installed.
          Adapter "yahka"          is not installed.
          Adapter "yamaha"         is not installed.
          Adapter "yeelight-2"     is not installed.
          Adapter "youtube"        is not installed.
          Adapter "yr"             is not installed.
          Adapter "zigbee"         is up to date.
          Adapter "zont"           is not installed.
          Adapter "zwave"          is not installed.
          Adapter "zwave2"         is not installed.
          pi@second-device:/opt/iobroker $ who -r
                   Runlevel 3   2020-12-05 00:16
            @Mapio90
            Strg-C
            Dann
            dmesg
            anschauen.
            Mapio90
            schrieb am zuletzt editiert von Mapio90
            dmesg
            Momentan habe ich das Gefühl er läuft wieder flüssiger
            pi@second-device:/opt/iobroker $ dmesg
            [    0.000000] Booting Linux on physical CPU 0x0
            [    0.000000] Linux version 4.19.66-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1253 SMP Thu Aug 15 11:49:46 BST 2019
            [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
            [    0.000000] CPU: div instructions available: patching division code
            [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
            [    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
            [    0.000000] Memory policy: Data cache writealloc
            [    0.000000] cma: Reserved 8 MiB at 0x3ac00000
            [    0.000000] On node 0 totalpages: 242688
            [    0.000000]   Normal zone: 2133 pages used for memmap
            [    0.000000]   Normal zone: 0 pages reserved
            [    0.000000]   Normal zone: 242688 pages, LIFO batch:63
            [    0.000000] random: get_random_bytes called from start_kernel+0xac/0x4b4 with crng_init=0
            [    0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
            [    0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
            [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
            [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
            [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=b63917fa-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
            [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
            [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
            [    0.000000] Memory: 939088K/970752K available (8192K kernel code, 629K rwdata, 2176K rodata, 1024K init, 821K bss, 23472K reserved, 8192K cma-reserved)
            [    0.000000] Virtual kernel memory layout:
                               vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                               fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                               vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
                               lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
                               modules : 0x7f000000 - 0x80000000   (  16 MB)
                                 .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)
                                 .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
                                 .data : 0x(ptrval) - 0x(ptrval)   ( 630 kB)
                                  .bss : 0x(ptrval) - 0x(ptrval)   ( 822 kB)
            [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
            [    0.000000] ftrace: allocating 26394 entries in 78 pages
            [    0.000000] rcu: Hierarchical RCU implementation.
            [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
            [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
            [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
            [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
            [    0.000023] Switching to timer-based delay loop, resolution 52ns
            [    0.000291] Console: colour dummy device 80x30
            [    0.000912] console [tty1] enabled
            [    0.000971] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
            [    0.001016] pid_max: default: 32768 minimum: 301
            [    0.001375] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
            [    0.001411] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
            [    0.002347] CPU: Testing write buffer coherency: ok
            [    0.002835] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
            [    0.003503] Setting up static identity map for 0x100000 - 0x10003c
            [    0.003668] rcu: Hierarchical SRCU implementation.
            [    0.004483] smp: Bringing up secondary CPUs ...
            [    0.005347] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
            [    0.006275] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
            [    0.007138] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
            [    0.007258] smp: Brought up 1 node, 4 CPUs
            [    0.007340] SMP: Total of 4 processors activated (153.60 BogoMIPS).
            [    0.007364] CPU: All CPU(s) started in HYP mode.
            [    0.007385] CPU: Virtualization extensions available.
            [    0.008377] devtmpfs: initialized
            [    0.021391] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
            [    0.021666] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
            [    0.021714] futex hash table entries: 1024 (order: 4, 65536 bytes)
            [    0.022322] pinctrl core: initialized pinctrl subsystem
            [    0.023192] NET: Registered protocol family 16
            [    0.026148] DMA: preallocated 1024 KiB pool for atomic coherent allocations
            [    0.031851] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
            [    0.031887] hw-breakpoint: maximum watchpoint size is 8 bytes.
            [    0.032108] Serial: AMBA PL011 UART driver
            [    0.034417] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
            [    0.069287] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
            [    0.071214] SCSI subsystem initialized
            [    0.071460] usbcore: registered new interface driver usbfs
            [    0.071541] usbcore: registered new interface driver hub
            [    0.071654] usbcore: registered new device driver usb
            [    0.090306] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-08-15 12:06, variant start
            [    0.100133] raspberrypi-firmware soc:firmware: Firmware hash is 0e6daa5106dd4164474616408e0dc24f997ffcf3
            [    0.111763] clocksource: Switched to clocksource arch_sys_counter
            [    0.200898] VFS: Disk quotas dquot_6.6.0
            [    0.201009] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
            [    0.201187] FS-Cache: Loaded
            [    0.201411] CacheFiles: Loaded
            [    0.211409] NET: Registered protocol family 2
            [    0.212232] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
            [    0.212296] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
            [    0.212428] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
            [    0.212632] TCP: Hash tables configured (established 8192 bind 8192)
            [    0.212792] UDP hash table entries: 512 (order: 2, 16384 bytes)
            [    0.212859] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
            [    0.213188] NET: Registered protocol family 1
            [    0.213759] RPC: Registered named UNIX socket transport module.
            [    0.213787] RPC: Registered udp transport module.
            [    0.213809] RPC: Registered tcp transport module.
            [    0.213830] RPC: Registered tcp NFSv4.1 backchannel transport module.
            [    0.215531] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
            [    0.218572] Initialise system trusted keyrings
            [    0.218779] workingset: timestamp_bits=14 max_order=18 bucket_order=4
            [    0.228775] FS-Cache: Netfs 'nfs' registered for caching
            [    0.229375] NFS: Registering the id_resolver key type
            [    0.229421] Key type id_resolver registered
            [    0.229443] Key type id_legacy registered
            [    0.229475] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
            [    0.231831] Key type asymmetric registered
            [    0.231862] Asymmetric key parser 'x509' registered
            [    0.231930] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
            [    0.232111] io scheduler noop registered
            [    0.232136] io scheduler deadline registered (default)
            [    0.232327] io scheduler cfq registered
            [    0.232351] io scheduler mq-deadline registered (default)
            [    0.232375] io scheduler kyber registered
            [    0.234557] bcm2708_fb soc:fb: FB found 1 display(s)
            [    0.244048] Console: switching to colour frame buffer device 82x26
            [    0.250859] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
            [    0.257580] bcm2835-rng 3f104000.rng: hwrng registered
            [    0.260249] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
            [    0.265563] vc-sm: Videocore shared memory driver
            [    0.268313] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
            [    0.284199] brd: module loaded
            [    0.296887] loop: module loaded
            [    0.299924] Loading iSCSI transport class v2.0-870.
            [    0.303104] libphy: Fixed MDIO Bus: probed
            [    0.305611] usbcore: registered new interface driver lan78xx
            [    0.308070] usbcore: registered new interface driver smsc95xx
            [    0.310423] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
            [    0.340728] dwc_otg 3f980000.usb: base=(ptrval)
            [    0.543352] Core Release: 2.80a
            [    0.545735] Setting default values for core params
            [    0.548177] Finished setting default values for core params
            [    0.750922] Using Buffer DMA mode
            [    0.753331] Periodic Transfer Interrupt Enhancement - disabled
            [    0.755756] Multiprocessor Interrupt Enhancement - disabled
            [    0.758126] OTG VER PARAM: 0, OTG VER FLAG: 0
            [    0.760462] Dedicated Tx FIFOs mode
            [    0.763211] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = bad14000 dma = 0xfad14000 len=9024
            [    0.767782] FIQ FSM acceleration enabled for :
                           Non-periodic Split Transactions
                           Periodic Split Transactions
                           High-Speed Isochronous Endpoints
                           Interrupt/Control Split Transaction hack enabled
            [    0.778689] dwc_otg: Microframe scheduler enabled
            [    0.778743] WARN::hcd_init_fiq:457: FIQ on core 1
            [    0.780962] WARN::hcd_init_fiq:458: FIQ ASM at 80654f4c length 36
            [    0.783173] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
            [    0.785454] dwc_otg 3f980000.usb: DWC OTG Controller
            [    0.787711] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
            [    0.790032] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
            [    0.792362] Init: Port Power? op_state=1
            [    0.794601] Init: Power Port (0)
            [    0.797016] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
            [    0.801518] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
            [    0.803959] usb usb1: Product: DWC OTG Controller
            [    0.806328] usb usb1: Manufacturer: Linux 4.19.66-v7+ dwc_otg_hcd
            [    0.808748] usb usb1: SerialNumber: 3f980000.usb
            [    0.811680] hub 1-0:1.0: USB hub found
            [    0.813989] hub 1-0:1.0: 1 port detected
            [    0.816735] dwc_otg: FIQ enabled
            [    0.816741] dwc_otg: NAK holdoff enabled
            [    0.816747] dwc_otg: FIQ split-transaction FSM enabled
            [    0.816757] Module dwc_common_port init
            [    0.817033] usbcore: registered new interface driver usb-storage
            [    0.819479] mousedev: PS/2 mouse device common for all mice
            [    0.822641] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
            [    0.825264] bcm2835-cpufreq: min=600000 max=1400000
            [    0.828067] sdhci: Secure Digital Host Controller Interface driver
            [    0.830477] sdhci: Copyright(c) Pierre Ossman
            [    0.833275] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
            [    0.836189] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
            [    0.838858] sdhci-pltfm: SDHCI platform and OF driver helper
            [    0.842948] ledtrig-cpu: registered to indicate activity on CPUs
            [    0.845671] hidraw: raw HID events driver (C) Jiri Kosina
            [    0.848413] usbcore: registered new interface driver usbhid
            [    0.851037] usbhid: USB HID core driver
            [    0.854355] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
            [    0.858430] [vc_sm_connected_init]: start
            [    0.867115] [vc_sm_connected_init]: end - returning 0
            [    0.870646] Initializing XFRM netlink socket
            [    0.873106] NET: Registered protocol family 17
            [    0.875607] Key type dns_resolver registered
            [    0.878445] Registering SWP/SWPB emulation handler
            [    0.881505] registered taskstats version 1
            [    0.883936] Loading compiled-in X.509 certificates
            [    0.893541] uart-pl011 3f201000.serial: cts_event_workaround enabled
            [    0.896066] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
            [    0.902781] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
            [    0.905308] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
            [    0.932537] sdhost: log_buf @ (ptrval) (fad13000)
            [    0.969926] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
            [    0.973923] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
            [    0.977780] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
            [    0.982785] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
            [    0.984906] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
            [    0.988262] of_cfs_init
            [    0.990400] of_cfs_init: OK
            [    0.992931] Waiting for root device PARTUUID=b63917fa-02...
            [    1.041886] Indeed it is in host mode hprt0 = 00021501
            [    1.108822] random: fast init done
            [    1.127286] mmc0: host does not support reading read-only switch, assuming write-enable
            [    1.135321] mmc0: new high speed SDHC card at address aaaa
            [    1.138774] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
            [    1.145250] mmc1: new high speed SDIO card at address 0001
            [    1.148032]  mmcblk0: p1 p2
            [    1.185288] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
            [    1.189589] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [    1.199995] devtmpfs: mounted
            [    1.207518] Freeing unused kernel memory: 1024K
            [    1.212191] Run /sbin/init as init process
            [    1.251812] usb 1-1: new high-speed USB device number 2 using dwc_otg
            [    1.254480] Indeed it is in host mode hprt0 = 00001101
            [    1.492116] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
            [    1.497449] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
            [    1.501002] hub 1-1:1.0: USB hub found
            [    1.503961] hub 1-1:1.0: 4 ports detected
            [    1.674572] systemd[1]: System time before build time, advancing clock.
            [    1.821854] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
            [    1.826255] NET: Registered protocol family 10
            [    1.830252] Segment Routing with IPv6
            [    1.861332] random: systemd: uninitialized urandom read (16 bytes read)
            [    1.866558] random: systemd: uninitialized urandom read (16 bytes read)
            [    1.875267] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
            [    1.884066] systemd[1]: Detected architecture arm.
            [    1.907721] systemd[1]: Set hostname to <second-device>.
            [    1.952378] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
            [    1.958310] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
            [    1.967141] hub 1-1.1:1.0: USB hub found
            [    1.970356] hub 1-1.1:1.0: 3 ports detected
            [    1.979922] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
            [    2.291831] usb 1-1.1.2: new full-speed USB device number 4 using dwc_otg
            [    2.394023] systemd[1]: Listening on fsck to fsckd communication Socket.
            [    2.426542] systemd[1]: Reached target Swap.
            [    2.432897] systemd[1]: Listening on udev Control Socket.
            [    2.439623] usb 1-1.1.2: New USB device found, idVendor=0451, idProduct=16a8, bcdDevice= 0.09
            [    2.440023] systemd[1]: Created slice System Slice.
            [    2.445224] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
            [    2.445233] usb 1-1.1.2: Product: TI CC2531 USB CDC
            [    2.445241] usb 1-1.1.2: Manufacturer: Texas Instruments
            [    2.445255] usb 1-1.1.2: SerialNumber: __0X00124B0019361A08
            [    2.469088] systemd[1]: Mounting RPC Pipe File System...
            [    2.475704] systemd[1]: Listening on udev Kernel Socket.
            [    2.483298] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
            [    2.771896] usb 1-1.1.1: new high-speed USB device number 5 using dwc_otg
            [    2.902452] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
            [    2.902466] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
            [    3.081690] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
            [    3.169123] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
            [    3.170424] libphy: lan78xx-mdiobus: probed
            [    3.192176] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
            [    3.225773] systemd-journald[115]: Received request to flush runtime journal from PID 1
            [    3.667378] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
            [    3.669832] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
            [    3.669846] [vc_sm_connected_init]: start
            [    3.684505] [vc_sm_connected_init]: installed successfully
            [    3.764715] media: Linux media interface: v0.10
            [    3.799831] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
            [    3.802412] videodev: Linux video capture interface: v2.00
            [    3.832662] bcm2835_audio soc:audio: card created with 8 channels
            [    3.875478] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
            [    3.875491] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
            [    3.886157] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
            [    3.890716] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
            [    3.913608] cdc_acm 1-1.1.2:1.0: ttyACM0: USB ACM device
            [    3.915787] usbcore: registered new interface driver cdc_acm
            [    3.915798] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
            [    3.922499] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
            [    3.922513] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
            [    3.928420] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
            [    3.928435] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
            [    3.936024] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
            [    3.936038] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
            [    3.998460] cfg80211: Loading compiled-in X.509 certificates for regulatory database
            [    4.074413] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
            [    4.169460] brcmfmac: F1 signature read @0x18000000=0x15264345
            [    4.178149] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
            [    4.179370] usbcore: registered new interface driver brcmfmac
            [    4.471522] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
            [    4.486040] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
            [    5.226489] uart-pl011 3f201000.serial: no DMA platform data
            [    5.426578] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
            [    5.462044] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
            [    5.462080] brcmfmac: power management disabled
            [    5.739342] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
            [    6.768813] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
            [   11.681158] Bluetooth: Core ver 2.22
            [   11.681255] NET: Registered protocol family 31
            [   11.681262] Bluetooth: HCI device and connection manager initialized
            [   11.681285] Bluetooth: HCI socket layer initialized
            [   11.681299] Bluetooth: L2CAP socket layer initialized
            [   11.681338] Bluetooth: SCO socket layer initialized
            [   11.697990] Bluetooth: HCI UART driver ver 2.3
            [   11.698005] Bluetooth: HCI UART protocol H4 registered
            [   11.698136] Bluetooth: HCI UART protocol Three-wire (H5) registered
            [   11.698367] Bluetooth: HCI UART protocol Broadcom registered
            [   11.901134] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
            [   11.901141] Bluetooth: BNEP filters: protocol multicast
            [   11.901153] Bluetooth: BNEP socket layer initialized
            [  538.220402] random: crng init done
            [  538.220413] random: 7 urandom warning(s) missed due to ratelimiting
            • M Mapio90
              dmesg
              @Mapio90
              Das System ist auf Stand?
              sudo apt update
                @Mapio90
                sudo apt update
                Mapio90
                @Thomas-Braun
                ja scheint so.
                pi@second-device:/opt/iobroker $ sudo apt update
                Holen:1 http://archive.raspberrypi.org/debian stretch InRelease [25,4 kB]
                Holen:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15,0 kB]
                Holen:3 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages [11,7 MB]
                OK:4 https://deb.nodesource.com/node_12.x stretch InRelease
                Es wurden 11,7 MB in 8 s geholt (1.325 kB/s).
                Alle Pakete sind aktuell.
                • M Mapio90
                  @Thomas-Braun
                  ja scheint so.
                  @Mapio90
                  Okay, dann dürfte da ja jetzt alles laufen.
                  iobroker list adapters | grep -i zigbee
                    @Mapio90
                    Mapio90
                    Adapter wurde auch wieder nicht aktuallisioert 😖
                    pi@second-device:/opt/iobroker $ iobroker list adapters | grep -i zigbee
                    Thomas BraunT M 2 Antworten Letzte Antwort
                    • M Mapio90
                      @Mapio90
                      iobroker stop
                      iobroker update
                      cd /opt/iobroker
                      iobroker upload all
                      iobroker start
                      • M Mapio90
                        Mapio90
                        Wäre jetzt mal so vorgegangen!?
                        iobroker update
                        cd /opt/iobroker
                        iobroker upgrade
                          @Mapio90
                          iobroker stop
                          iobroker update
                          cd /opt/iobroker
                          iobroker upload all
                          iobroker start
                          Mapio90
                          @Thomas-Braun
                          Schaut nicht schlecht aus.
                          pi@second-device:/opt/iobroker $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                          /usr/bin/nodejs
                          v12.20.0
                          /usr/bin/node
                          v12.20.0
                          /usr/bin/npm
                          6.14.8
                          nodejs:
                            Versionstabelle:
                               4.8.2~dfsg-1 500
                          pi@second-device:~ $ iobroker stop
                          hash changed or no sources cached => force download of new sources
                          update done
                          Adapter    "daikin"        : 1.1.3
                          Adapter    "zigbee"        : 1.3.1    , installed 1.3.1
                          updated 1 package in 23.789s
                          12 packages are looking for funding
                          pi@second-device:/opt/iobroker $ iobroker upload all
                          upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_rb280.png img/tuya_rb280.png image/png
                          upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_gu10_color.png img/philips_hue_gu10_color.png image/png
                          upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lumi_router.png img/lumi_router.png image/png
                          upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_recessed_spot_light.png img/ikea_recessed_spot_light.png image/png
                          upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_bulb_E27.png img/ikea_bulb_E27.png image/png
                          upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
                          upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gira_4_buttons.png img/gira_4_buttons.png image/png
                          upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ewelink_DS01.png img/ewelink_DS01.png image/png
                          upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_neutral1.png img/ctrl_neutral1.png image/png
                          upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_902010_24.png img/bitron_902010_24.png image/png
                          upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZHS15.png img/ZHS15.png image/png
                          upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/NAS-AB02B0.png img/NAS-AB02B0.png image/png
                          upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Moes_Wall_Thermostat.png img/Moes_Wall_Thermostat.png image/png
                          upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Ikea_fyrtur.png img/Ikea_fyrtur.png image/png
                          upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HY08WE.png img/HY08WE.png image/png
                          upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
                          upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                          upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_R8_8.png img/DIYRuZ_R8_8.png image/png
                          upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Geiger.png img/DIYRuZ_Geiger.png image/png
                          upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
                          upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Flower.png img/DIYRuZ_Flower.png image/png
                          upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
                          upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
                          upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                          upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
                          upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
                          upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
                          upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                          upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                          upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                          upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                          upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                          Update "system.adapter.zigbee.1"
                          No alive host found which has the adapter web installed! No upload possible. Skipped.
                          No alive host found which has the adapter tr-064 installed! No upload possible. Skipped.
                          No alive host found which has the adapter text2command installed! No upload possible. Skipped.
                          No alive host found which has the adapter terminal installed! No upload possible. Skipped.
                          No alive host found which has the adapter telegram installed! No upload possible. Skipped.
                          No alive host found which has the adapter sonoff installed! No upload possible. Skipped.
                          No alive host found which has the adapter socketio installed! No upload possible. Skipped.
                          No alive host found which has the adapter simple-api installed! No upload possible. Skipped.
                          No alive host found which has the adapter scenes installed! No upload possible. Skipped.
                          No alive host found which has the adapter samsung installed! No upload possible. Skipped.
                          No alive host found which has the adapter mobile installed! No upload possible. Skipped.
                          No alive host found which has the adapter mihome-vacuum installed! No upload possible. Skipped.
                          No alive host found which has the adapter javascript installed! No upload possible. Skipped.
                          No alive host found which has the adapter info installed! No upload possible. Skipped.
                          No alive host found which has the adapter flot installed! No upload possible. Skipped.
                          upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                          upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                          upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                          upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                          upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                          upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                          upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                          No alive host found which has the adapter digitalstrom installed! No upload possible. Skipped.
                          upload [450] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/75.png icons/viento-wind/galeria2-Beaufort/75.png image/png
                          upload [400] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/3.png icons/viento-wind/galeria2-Beaufort/3.png image/png
                          upload [350] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria1/16.png icons/viento-wind/galeria1/16.png image/png
                          upload [300] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/60.png icons/viento-wind/Beaufort-White/60.png image/png
                          upload [250] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/15.png icons/viento-wind/Beaufort-White/15.png image/png
                          upload [200] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria6/11.svg icons/tiempo-weather/galeria6/11.svg image/svg+xml
                          upload [150] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria5/PNG/White/9.png icons/tiempo-weather/galeria5/PNG/White/9.png image/png
                          upload [100] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria4/3.png icons/tiempo-weather/galeria4/3.png image/png
                          upload [90] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria4/11.png icons/tiempo-weather/galeria4/11.png image/png
                          upload [80] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria3/2.png icons/tiempo-weather/galeria3/2.png image/png
                          upload [70] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria3/10.png icons/tiempo-weather/galeria3/10.png image/png
                          upload [60] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria2/19.png icons/tiempo-weather/galeria2/19.png image/png
                          upload [50] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria2/1.png icons/tiempo-weather/galeria2/1.png image/png
                          upload [40] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria1/18.png icons/tiempo-weather/galeria1/18.png image/png
                          upload [30] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/9.png icons/luna-moon/9.png image/png
                          upload [20] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/26.png icons/luna-moon/26.png image/png
                          upload [19] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/25.png icons/luna-moon/25.png image/png
                          upload [18] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/24.png icons/luna-moon/24.png image/png
                          upload [17] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/23.png icons/luna-moon/23.png image/png
                          upload [16] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/22.png icons/luna-moon/22.png image/png
                          upload [15] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/21.png icons/luna-moon/21.png image/png
                          upload [14] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/20.png icons/luna-moon/20.png image/png
                          upload [13] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/2.png icons/luna-moon/2.png image/png
                          upload [12] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/19.png icons/luna-moon/19.png image/png
                          upload [11] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/18.png icons/luna-moon/18.png image/png
                          upload [10] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/17.png icons/luna-moon/17.png image/png
                          upload [9] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/16.png icons/luna-moon/16.png image/png
                          upload [8] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/15.png icons/luna-moon/15.png image/png
                          upload [7] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/14.png icons/luna-moon/14.png image/png
                          upload [6] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/13.png icons/luna-moon/13.png image/png
                          upload [5] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/12.png icons/luna-moon/12.png image/png
                          upload [4] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/11.png icons/luna-moon/11.png image/png
                          upload [3] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/10.png icons/luna-moon/10.png image/png
                          upload [2] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/1.png icons/luna-moon/1.png image/png
                          upload [1] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/0.png icons/luna-moon/0.png image/png
                          upload [0] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/daswettercom.png daswettercom.png image/png
                          No alive host found which has the adapter cloud installed! No upload possible. Skipped.
                          upload [7] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/words.js words.js application/javascript
                          upload [6] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/style.css style.css text/css
                          upload [5] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index_m.html index_m.html text/html
                          upload [4] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index.html index.html text/html
                          upload [3] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.map build/index.map application/json
                          upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js.map build/index.js.map application/json
                          upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js build/index.js application/javascript
                          upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/ble.png ble.png image/png
                          upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                          upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                          upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                          upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                          No alive host found which has the adapter alexa2 installed! No upload possible. Skipped.
                          upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                          upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                          upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                          upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                          pi@second-device:/opt/iobroker $ iobroker start
                          • M Mapio90
                            @Thomas-Braun
                            /usr/bin/nodejs
                            v12.20.0
                            /usr/bin/node
                            v12.20.0
                            /usr/bin/npm
                            6.14.8
                            nodejs:
                              Versionstabelle:
                                 4.8.2~dfsg-1 500
                            update done
                            @Mapio90 sagte in Zigbee Adapter v1.2.1 immer Rot:
                            winston-syslog
                            Das sieht jetzt bezüglich zigbee gut aus. Aber mit winston klemmt da noch irgendwas.
                            cd /opt/iobroker
                            npm list winston
                            npm list winston-syslog
                              winston-syslog
                              cd /opt/iobroker
                              npm list winston
                              Mapio90
                              pi@second-device:/opt/iobroker $ cd /opt/iobroker
                              pi@second-device:/opt/iobroker $ npm list winston
                              iobroker.inst@2.0.2 /opt/iobroker
                              ├─┬ iobroker.js-controller@3.1.6
                              │ ├─┬ prompt@1.0.0
                              │ │ └── winston@2.1.1
                              │ └── UNMET PEER DEPENDENCY winston@3.3.3
                              └── winston@2.4.4  extraneous
                              npm ERR! extraneous: winston@2.4.4 /opt/iobroker/node_modules/winston
                              npm ERR! peer dep missing: winston@^3.0.0, required by winston-syslog@2.4.4
                              pi@second-device:/opt/iobroker $ npm list winston-syslog
                              └─┬ iobroker.js-controller@3.1.6
                                └── winston-syslog@2.4.4
                              • M Mapio90
                                │ ├─┬ prompt@1.0.0
                                #66
                                @Mapio90
                                Da ist eine Version von winston auf dem System, die zu alt ist.
                                Schaut bei mir so aus:
                                pi@raspberrypi:/opt/iobroker $ npm list winston
                                iobroker.inst@2.0.3 /opt/iobroker
                                  ├─┬ prompt@1.0.0
                                  │ └── winston@2.1.1
                                  ├─┬ winston-daily-rotate-file@4.5.0
                                  │ └── winston@3.3.3 deduped
                                  ├─┬ winston-syslog@2.4.4
                                  └── winston@3.3.3
                                Backup am Start?
                                cd /opt/iobroker
                                iobroker stop
                                npm i winston@latest
                                iobroker fix
                                iobroker start
                                  winston-syslog
                                  cd /opt/iobroker
                                  npm list winston
                                  Mapio90
                                  #67
                                  @Thomas-Braun
                                  Mir scheint auch so, als würde da was mit der Ordnerstruktur nicht stimmen.
                                  Der Slave war falsch konfiguriert, da lag nodejs auf /usr/local/bin. Habe dann alles berichtigt, dass es auf /usr/bin ist.
                                  Greifen die Pfade von BLE und Zigbee noch auf die alten Pfade, weil wenn ich auf Objekte gehe, dann kommt folgendes.....
                                  Error: Error while starting zigbee-shepherd!. Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0019361A08-if00
                                  • M Mapio90
                                    @Thomas-Braun
                                    #68
                                    @Mapio90
                                    Das hat mit node nix zu tun. Ist das vielleicht an ander Stick da nun? Mit einer anderen ID?
                                    ls -la /dev/serial*
                                      @Mapio90
                                        ├─┬ prompt@1.0.0
                                        │ └── winston@2.1.1
                                        └── winston@3.3.3
                                      Backup am Start?
                                      cd /opt/iobroker
                                      iobroker stop
                                      iobroker fix
                                      iobroker start
                                      Mapio90
                                      #69
                                      @Thomas-Braun
                                      Habe von gestern abend ein Backup, ja.
                                      Werde aber nochmals kurz eins machen.
                                        @Mapio90
                                        ls -la /dev/serial*
                                        Mapio90
                                        #70
                                        @Thomas-Braun
                                        pi@second-device:/opt/iobroker $ ls -la /dev/serial*
                                        lrwxrwxrwx 1 root root  7 Dez  5 00:16 /dev/serial1 -> ttyAMA0
                                        /dev/serial:
                                        insgesamt 0
                                        drwxr-xr-x  4 root root   80 Dez  5 00:16 .
                                        drwxr-xr-x 16 root root 3560 Dez  5 00:16 ..
                                        drwxr-xr-x  2 root root   60 Dez  5 00:16 by-id
                                        drwxr-xr-x  2 root root   60 Dez  5 00:16 by-path
                                        Habe eigentlich nur einen für den Master und einen für den Slave. Insgesamt also zwei. Vertauscht haben, kann ich sie nicht, weil der auf dem Master schon seit anfang an steckt.
                                        Das einzige was war, ich hab den Slave runter gefahren, vom strom getrennt und dann das nächste mal versehentlich ohne den zigbee stick wieder gestartet. Habe gestern den Slave wieder runtergefahren, vom strom genommen und den stick eingesteckt. Dann wieder hochgefahren.
                                        EInzige was sein könnte, dass ich ihn nicht wieder in den gleichen usb port , der 4 vorhandenen gesteckt habe. Darauf habe ich, wenn ich erhlich bin nicht drauf geachtet. Sollte das immer in den gleichen usb port?
                                        • M Mapio90
                                          @Thomas-Braun
                                          /dev/serial:
                                          insgesamt 0
                                          #71
                                          ls -la /dev/serial/by-id*
