  4. Zigbee Adapter v1.2.1 immer Rot
zigbee adapter cc2531zigbee v1.2.1adapterkonfiguration zigbee
76 Beiträge 5 Kommentatoren 7.1k Aufrufe 4 Beobachtet
    @Mapio90 sagte in Zigbee Adapter v1.2.1 immer Rot:
    Adapter "zigbee" updated
    iobroker list adapters | grep -i zigbee
    Mapio90
    @Thomas-Braun sagte in Zigbee Adapter v1.2.1 immer Rot:
    pi@Master:~ $ iobroker list adapters | grep -i zigbee
    system.adapter.zigbee                  : zigbee         - v0.9.2
    pi@Master:~ $
    • M Mapio90
      pi@Master:~ $
      @Mapio90
      cd /opt/iobroker
      npm i iobroker.zigbee@1.3.1 --force
        @Mapio90
        cd /opt/iobroker
        Mapio90
        schrieb am zuletzt editiert von Mapio90
        @Thomas-Braun
        Hab gerade gesehen du hast die version aktuallisiert. Aber erst nach dem Updaten.
        Nochmals mit 1.3 versuchen?
        pi@Master:/opt/iobroker $ npm i iobroker.zigbee@1.2.1 --force
        npm WARN using --force I sure hope you know what you are doing.
        > osx-temperature-sensor@1.0.7 install /opt/iobroker/node_modules/osx-temperatur
        > node-gyp rebuild
        make: Verzeichnis „/opt/iobroker/node_modules/osx-temperature-sensor/build“ wird
          SOLINK_MODULE(target) Release/obj.target/none.node
          COPY Release/none.node
        > @serialport/bindings@9.0.3 install /opt/iobroker/node_modules/serialport/node_
        > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
        prebuild-install WARN install No prebuilt binaries found (target=12.20.0 runtime
        make: Verzeichnis „/opt/iobroker/node_modules/serialport/node_modules/@serialpor
          CXX(target) Release/obj.target/bindings/src/serialport.o
          CXX(target) Release/obj.target/bindings/src/serialport_unix.o
          CXX(target) Release/obj.target/bindings/src/poller.o
          CXX(target) Release/obj.target/bindings/src/serialport_linux.o
          SOLINK_MODULE(target) Release/obj.target/bindings.node
          COPY Release/bindings.node
        > serialport@9.0.1 postinstall /opt/iobroker/node_modules/serialport
        > node thank-you.js
        Thank you for using serialport!
        If you rely on this package, please consider supporting our open collective:
        > https://opencollective.com/serialport/donate
        [            ......] \ postinstall: info lifecycle iobroker.zigbee@1.2.1~postins+ iobroker.zigbee@1.2.1
        added 27 packages from 25 contributors, removed 271 packages, updated 16 packages and moved 9 packages in 65.965s
        14 packages are looking for funding
          run `npm fund` for details
        • M Mapio90
          @Thomas-Braun
          > node-gyp rebuild
          > node thank-you.js
          @Mapio90 Sorry, hatte da eine 2 statt einer 3 drin.
          Es sollte jetzt aber auch mit dem üblichen funktionieren:
          iobroker update
          iobroker upgrade
            iobroker update
            iobroker upgrade
            Mapio90
            @Thomas-Braun
            ist das eigentlich egal wo ich den Befehl zum Updaten der Adapter ausführe?
            Kann das auch in dem Pfad cd /opt/iobroker ausführen, wenn du weißt was ich meine!?
            • M Mapio90
              @Thomas-Braun
              @Mapio90
              Ja, ist für
              iobroker ...
              egal.
              Nicht egal ist es bei
              npm ...
                @Mapio90
                Ja, ist für
                iobroker ...
                egal.
                npm ...
                Mapio90
                @Thomas-Braun
                ok, so jetzt ist folgender stand und der Adapter ist grün!
                Vielen Dank
                Habe aber dazu noch zwei Fragen..
                Das war ja jetzt eine riesige Prozedur, von Fehler beheben bis auf das ich nicht mehr auf die Weboberfläche komme. Woran lag jetzt der Fehler, kann man das eingrenzen?
                Das ganze Prozedere muss ich ja jetzt für den Slave auch anwenden, kann ich da genau so vorgehen, bzw hätte ich das zuvor machen sollen, weil wir ja den Master jetzt nochmal upgedatet haben, wobei wir zu dem entschluss kamen, dies erst bei dem Slave durch zu führen?
                pi@Master:~ $ iobroker update
                Used repository: default
                hash unchanged, use cached sources
                update done
                Adapter    "admin"         : 4.1.10   , installed 4.1.10
                Adapter    "alarm"         : 1.8.1
                Adapter    "alexa2"        : 3.3.5    , installed 3.3.5
                Adapter    "alpha2"        : 1.0.0
                Adapter    "amazon-dash"   : 1.1.0
                Adapter    "artnet"        : 1.2.2
                Adapter    "asterisk"      : 1.0.6
                Adapter    "asuswrt"       : 1.0.1
                Adapter    "b-control-em"  : 0.2.1
                Adapter    "backitup"      : 1.7.0    , installed 1.7.0
                Adapter    "beckhoff"      : 1.2.2
                Adapter    "benq"          : 0.2.0
                Adapter    "binance"       : 1.1.3
                Adapter    "ble"           : 0.12.0   , installed 0.12.0
                Adapter    "bmw"           : 1.3.3
                Adapter    "bosesoundtouch": 0.2.4
                Adapter    "botvac"        : 1.0.0
                Adapter    "bring"         : 1.7.3
                Adapter    "broadlink2"    : 2.0.3
                Adapter    "bsblan"        : 0.2.0
                Adapter    "bshb"          : 0.1.10
                Adapter    "chromecast"    : 2.3.1
                Adapter    "cloud"         : 3.1.0    , installed 3.1.0
                Adapter    "comfoair"      : 0.3.2
                Adapter    "contactid"     : 1.0.1
                Adapter    "coronavirus-statistics": 0.6.3
                Adapter    "countdown"     : 1.1.0
                Adapter    "cul"           : 1.3.3
                Adapter    "daikin"        : 1.1.2
                Adapter    "daswetter"     : 3.0.4    , installed 3.0.4
                Adapter    "deconz"        : 1.3.11
                Adapter    "denon"         : 1.7.7
                Adapter    "device-reminder": 0.5.4
                Adapter    "devices"       : 0.3.13
                Adapter    "digitalstrom"  : 0.5.5    , installed 0.5.5
                Adapter    "discovergy"    : 0.5.0
                Adapter    "discovery"     : 2.3.11   , installed 2.3.11
                Adapter    "doorio"        : 1.1.1
                Adapter    "ds18b20"       : 1.1.5
                Adapter    "dwd"           : 2.5.1
                Adapter    "ebus"          : 2.1.1
                Adapter    "ecovacs-deebot": 1.0.3
                Adapter    "egigeozone"    : 0.1.2
                Adapter    "ekey"          : 1.1.0
                Adapter    "email"         : 1.0.7
                Adapter    "emby"          : 1.0.2
                Adapter    "energymanager" : 1.2.3
                Adapter    "enet"          : 1.0.1
                Adapter    "epson_stylus_px830": 0.2.1
                Adapter    "exchangerates" : 0.0.13
                Adapter    "fakeroku"      : 0.2.1
                Adapter    "fb-checkpresence": 1.1.0
                Adapter    "feiertage"     : 1.0.17
                Adapter    "fhem"          : 1.5.3
                Adapter    "find-my-iphone": 0.2.15
                Adapter    "firetv"        : 0.0.27
                Adapter    "flot"          : 1.10.4   , installed 1.10.4
                Adapter    "foobar2000"    : 2.0.3
                Adapter    "fritzbox"      : 0.2.1
                Adapter    "fritzdect"     : 0.2.4
                Adapter    "fronius"       : 1.0.5
                Adapter    "frontier_silicon": 0.0.10
                Adapter    "fullcalendar"  : 1.1.0
                Adapter    "fullybrowser"  : 2.0.1
                Adapter    "g-homa"        : 0.5.3
                Adapter    "geofency"      : 0.3.2
                Adapter    "growatt"       : 0.0.14
                Adapter    "gruenbeck"     : 0.0.18
                Adapter    "habpanel"      : 0.4.3
                Adapter    "haier"         : 1.0.2
                Adapter    "ham"           : 1.1.2
                Adapter    "ham-wemo"      : 1.1.0
                Adapter    "harmony"       : 1.2.2
                Adapter    "heatingcontrol": 1.0.0
                Adapter    "heos"          : 1.6.1
                Adapter    "heytech"       : 1.0.0
                Adapter    "hid"           : 0.1.17
                Adapter    "history"       : 1.9.10
                Adapter    "hm-rega"       : 2.6.24
                Adapter    "hm-rpc"        : 1.14.24
                Adapter    "hmip"          : 1.5.0
                Adapter    "homeconnect"   : 0.0.30
                Adapter    "homee"         : 1.0.7
                Adapter    "homepilot"     : 1.0.3
                Adapter    "hp-ilo"        : 1.0.6
                Adapter    "hs100"         : 2.0.1
                Adapter    "hue"           : 3.3.8
                Adapter    "hue-extended"  : 2.0.0
                Adapter    "i2c"           : 1.1.1
                Adapter    "ical"          : 1.7.4
                Adapter    "icons-addictive-flavour-png": 0.1.0
                Adapter    "icons-fatcow-hosting": 0.1.0
                Adapter    "icons-icons8"  : 0.0.1
                Adapter    "icons-material-png": 0.1.0
                Adapter    "icons-material-svg": 0.1.0
                Adapter    "icons-mfd-png" : 1.0.2
                Adapter    "icons-mfd-svg" : 1.0.2
                Adapter    "icons-open-icon-library-png": 0.1.2
                Adapter    "icons-ultimate-png": 1.0.1
                Adapter    "influxdb"      : 1.9.1
                Adapter    "info"          : 1.7.10   , installed 1.7.10
                Adapter    "innogy-smarthome": 0.3.6
                Adapter    "iogo"          : 0.5.10
                Adapter    "iot"           : 1.5.3
                Adapter    "iqontrol"      : 1.5.0
                Adapter    "jarvis"        : 1.0.9
                Adapter    "javascript"    : 4.8.4    , installed 4.8.4
                Adapter    "jeelink"       : 0.1.0
                Controller "js-controller" : 3.1.6    , installed 3.1.6
                Adapter    "kecontact"     : 1.0.1
                Adapter    "klf200"        : 1.0.1
                Adapter    "km200"         : 1.1.6
                Adapter    "knmi-weather"  : 1.0.0
                Adapter    "knx"           : 1.0.39
                Adapter    "kodi"          : 2.0.4
                Adapter    "kostal-piko-ba": 1.1.3
                Adapter    "kress"         : 2.5.5
                Adapter    "lametric"      : 0.0.9
                Adapter    "landroid"      : 1.0.3
                Adapter    "lcn"           : 1.0.2
                Adapter    "legrand-ecocompteur": 1.0.0
                Adapter    "letrika_comgw" : 0.0.5
                Adapter    "lgtv"          : 1.1.10
                Adapter    "lgtv-rs"       : 0.1.0
                Adapter    "lgtv11"        : 1.0.5
                Adapter    "lifx"          : 0.1.0
                Adapter    "lightify"      : 0.2.16
                Adapter    "link"          : 0.5.9
                Adapter    "linkeddevices" : 1.2.2
                Adapter    "linux-control" : 1.0.1
                Adapter    "logparser"     : 1.1.0
                Adapter    "lovelace"      : 1.0.16
                Adapter    "loxone"        : 2.0.2
                Adapter    "luftdaten"     : 1.0.1
                Adapter    "lupusec"       : 1.2.9
                Adapter    "luxtronik1"    : 0.2.2
                Adapter    "material"      : 0.13.9
                Adapter    "maxcube"       : 1.0.2
                Adapter    "maxcul"        : 1.3.1
                Adapter    "mbus"          : 2.3.1
                Adapter    "mclighting"    : 0.1.1
                Adapter    "megad"         : 1.2.1
                Adapter    "megadd"        : 0.2.0
                Adapter    "megaesp"       : 0.1.0
                Adapter    "melcloud"      : 1.0.6
                Adapter    "mercedesme"    : 0.0.21
                Adapter    "mercury"       : 0.1.1
                Adapter    "meross"        : 1.5.0
                Adapter    "meteoalarm"    : 1.0.9
                Adapter    "midea"         : 0.0.6
                Adapter    "miele"         : 0.1.5
                Adapter    "mielecloudservice": 2.0.0
                Adapter    "mihome"        : 1.3.5
                Adapter    "mihome-lamp"   : 1.1.0
                Adapter    "mihome-plug"   : 0.2.1
                Adapter    "mihome-vacuum" : 2.1.1    , installed 2.1.1
                Adapter    "mikrotik"      : 1.0.11
                Adapter    "milight"       : 0.3.6
                Adapter    "milight-smart-light": 0.2.7
                Adapter    "minuvis"       : 1.0.0
                Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                Adapter    "modbus"        : 3.1.10
                Adapter    "moma"          : 1.2.7
                Adapter    "mpd"           : 1.0.5
                Adapter    "mqtt"          : 2.1.9
                Adapter    "mqtt-client"   : 1.3.1
                Adapter    "musiccast"     : 0.1.3
                Adapter    "mydlink"       : 1.1.7
                Adapter    "mysensors"     : 2.0.1
                Adapter    "nanoleaf-lightpanels": 1.0.6
                Adapter    "nello"         : 2.0.6
                Adapter    "netatmo"       : 1.3.3
                Adapter    "netatmo-crawler": 0.3.8
                Adapter    "nibeuplink"    : 0.3.0
                Adapter    "nina"          : 0.0.22
                Adapter    "node-red"      : 2.0.1
                Adapter    "nuki"          : 1.4.2
                Adapter    "nuki-extended" : 2.3.0
                Adapter    "nut"           : 1.1.3
                Adapter    "octoprint"     : 1.0.1
                Adapter    "odl"           : 1.0.7
                Adapter    "oilfox"        : 0.0.5
                Adapter    "onkyo"         : 2.0.3
                Adapter    "onvif"         : 0.4.4
                Adapter    "openhab"       : 1.1.0
                Adapter    "openligadb"    : 1.1.0
                Adapter    "openweathermap": 0.1.0
                Adapter    "opi"           : 0.1.1
                Adapter    "oppoplayer"    : 0.2.1
                Adapter    "owfs"          : 0.6.4
                Adapter    "owntracks"     : 0.6.3
                Adapter    "panasonic-viera": 1.0.2
                Adapter    "parser"        : 1.0.7
                Adapter    "paw"           : 0.0.7
                Adapter    "phantomjs"     : 1.1.2
                Adapter    "pi-hole"       : 1.3.1
                Adapter    "piface"        : 1.0.0
                Adapter    "pimatic"       : 0.3.0
                Adapter    "ping"          : 1.4.12
                Adapter    "places"        : 1.0.0
                Adapter    "plex"          : 0.8.11
                Adapter    "plexconnect"   : 0.0.7
                Adapter    "pollenflug"    : 1.0.6
                Adapter    "proxmox"       : 1.0.1
                Adapter    "proxy"         : 1.2.1
                Adapter    "pushbullet"    : 0.0.11
                Adapter    "pushover"      : 2.0.3
                Adapter    "pushsafer"     : 0.1.8
                Adapter    "radar2"        : 1.0.9
                Adapter    "radiohead"     : 1.0.7
                Adapter    "rflink"        : 2.1.6
                Adapter    "rickshaw"      : 1.0.0
                Adapter    "ring"          : 1.1.3
                Adapter    "robonect"      : 0.1.3
                Adapter    "roomba"        : 1.1.1
                Adapter    "rpi2"          : 1.2.0
                Adapter    "s7"            : 1.1.9
                Adapter    "samsung"       : 0.2.9    , installed 0.2.9
                Adapter    "sayit"         : 1.12.2
                Adapter    "sbfspot"       : 4.0.2
                Adapter    "scenes"        : 2.3.0    , installed 2.3.0
                Adapter    "schoolfree"    : 0.7.0
                Adapter    "schwoerer-ventcube": 1.3.0
                Adapter    "shelly"        : 4.0.3
                Adapter    "shuttercontrol": 1.0.4
                Adapter    "sia"           : 1.0.4
                Adapter    "siegenia"      : 1.0.0
                Adapter    "simple-api"    : 2.4.8    , installed 2.4.8
                Adapter    "smappee"       : 0.2.2
                Adapter    "smartcontrol"  : 1.2.1
                Adapter    "smartgarden"   : 1.0.1
                Adapter    "smartmeter"    : 3.1.6
                Adapter    "snips"         : 1.5.1
                Adapter    "snmp"          : 0.5.0
                Adapter    "socketio"      : 3.0.13   , installed 3.0.13
                Adapter    "solarlog"      : 2.0.0
                Adapter    "solarviewdatareader": 0.2.1
                Adapter    "solarwetter"   : 1.0.0
                Adapter    "sonnen"        : 1.7.0
                Adapter    "sonoff"        : 2.3.3    , installed 2.3.3
                Adapter    "sonos"         : 2.1.1
                Adapter    "sony-bravia"   : 1.0.1
                Adapter    "spotify-premium": 1.0.0
                Adapter    "sql"           : 1.15.3
                Adapter    "squeezebox"    : 1.0.0
                Adapter    "squeezeboxrpc" : 1.0.0
                Adapter    "starline"      : 1.0.0
                Adapter    "statistics"    : 0.2.2
                Adapter    "stiebel-isg"   : 1.5.1
                Adapter    "sunnyportal"   : 0.1.5
                Adapter    "swiss-weather-api": 0.3.2
                Adapter    "synology"      : 0.1.18
                Adapter    "systeminfo"    : 0.3.1
                Adapter    "tahoma"        : 0.3.2
                Adapter    "tankerkoenig"  : 2.0.5
                Adapter    "telegram"      : 1.6.0    , installed 1.6.0
                Adapter    "terminal"      : 0.1.2    , installed 0.1.2
                Adapter    "tesla-motors"  : 0.2.3
                Adapter    "text2command"  : 2.0.5    , installed 2.0.5
                Adapter    "tinker"        : 1.1.0
                Adapter    "tr-064"        : 4.2.1    , installed 4.2.1
                Adapter    "tradfri"       : 2.6.3
                Adapter    "trashschedule" : 1.0.3
                Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                Adapter    "tuya"          : 3.4.1
                Adapter    "tvspielfilm"   : 1.0.4
                Adapter    "unifi"         : 0.5.8
                Adapter    "upnp"          : 1.0.16
                Adapter    "vaillant"      : 0.0.10
                Adapter    "valloxmv"      : 1.1.1
                Adapter    "vcard"         : 0.0.9
                Adapter    "velux"         : 0.0.5
                Adapter    "viessmann"     : 1.3.2
                Adapter    "virtualpowermeter": 1.2.1
                Adapter    "vis"           : 1.3.4
                Adapter    "vis-bars"      : 0.1.4
                Adapter    "vis-canvas-gauges": 0.1.5
                Adapter    "vis-colorpicker": 1.2.0
                Adapter    "vis-fancyswitch": 1.1.0
                Adapter    "vis-google-fonts": 0.1.0
                Adapter    "vis-history"   : 1.0.0
                Adapter    "vis-hqwidgets" : 1.1.7
                Adapter    "vis-icontwo"   : 0.34.0
                Adapter    "vis-inventwo"  : 2.5.11
                Adapter    "vis-jqui-mfd"  : 1.0.12
                Adapter    "vis-justgage"  : 1.0.2
                Adapter    "vis-keyboard"  : 0.0.2
                Adapter    "vis-lcars"     : 1.0.4
                Adapter    "vis-map"       : 1.0.4
                Adapter    "vis-material-advanced": 1.3.0
                Adapter    "vis-metro"     : 1.1.2
                Adapter    "vis-players"   : 0.1.6
                Adapter    "vis-plumb"     : 1.0.2
                Adapter    "vis-rgraph"    : 0.0.2
                Adapter    "vis-timeandweather": 1.1.7
                Adapter    "vis-weather"   : 2.5.2
                Adapter    "vr200"         : 1.0.0
                Adapter    "vw-connect"    : 0.0.15
                Adapter    "weatherunderground": 3.2.1
                Adapter    "web"           : 3.0.14   , installed 3.0.14
                Adapter    "weishaupt-wem" : 0.0.8
                Adapter    "whatsapp-cmb"  : 0.1.6
                Adapter    "wiffi-wz"      : 2.2.0
                Adapter    "wifilight"     : 1.1.0
                Adapter    "windows-control": 0.1.5
                Adapter    "wled"          : 0.5.2
                Adapter    "wm-bus"        : 0.1.12
                Adapter    "wolf"          : 1.2.1
                Adapter    "worx"          : 1.2.3
                Adapter    "xbox"          : 0.6.8
                Adapter    "xs1"           : 1.0.2
                Adapter    "yahka"         : 0.11.0
                Adapter    "yamaha"        : 0.3.19
                Adapter    "yeelight-2"    : 1.0.3
                Adapter    "youtube"       : 1.0.0
                Adapter    "yr"            : 2.0.3
                Adapter    "zigbee"        : 1.3.1    , installed 1.2.1 [Updateable]
                Adapter    "zont"          : 0.5.3
                Adapter    "zwave"         : 2.0.1
                Adapter    "zwave2"        : 1.7.10
                pi@Master:~ $ iobroker upgrade
                Adapter "admin"          is up to date.
                Adapter "alarm"          is not installed.
                Adapter "alexa2"         is up to date.
                Adapter "alpha2"         is not installed.
                Adapter "amazon-dash"    is not installed.
                Adapter "artnet"         is not installed.
                Adapter "asterisk"       is not installed.
                Adapter "asuswrt"        is not installed.
                Adapter "b-control-em"   is not installed.
                Adapter "backitup"       is up to date.
                Adapter "beckhoff"       is not installed.
                Adapter "benq"           is not installed.
                Adapter "binance"        is not installed.
                Adapter "ble"            is up to date.
                Adapter "bmw"            is not installed.
                Adapter "bosesoundtouch" is not installed.
                Adapter "botvac"         is not installed.
                Adapter "bring"          is not installed.
                Adapter "broadlink2"     is not installed.
                Adapter "bsblan"         is not installed.
                Adapter "bshb"           is not installed.
                Adapter "chromecast"     is not installed.
                Adapter "cloud"          is up to date.
                Adapter "comfoair"       is not installed.
                Adapter "contactid"      is not installed.
                Adapter "coronavirus-statistics" is not installed.
                Adapter "countdown"      is not installed.
                Adapter "cul"            is not installed.
                Adapter "daikin"         is not installed.
                Adapter "daswetter"      is up to date.
                Adapter "deconz"         is not installed.
                Adapter "denon"          is not installed.
                Adapter "device-reminder" is not installed.
                Adapter "devices"        is not installed.
                Adapter "digitalstrom"   is up to date.
                Adapter "discovergy"     is not installed.
                Adapter "discovery"      is up to date.
                Adapter "doorio"         is not installed.
                Adapter "ds18b20"        is not installed.
                Adapter "dwd"            is not installed.
                Adapter "ebus"           is not installed.
                Adapter "ecovacs-deebot" is not installed.
                Adapter "egigeozone"     is not installed.
                Adapter "ekey"           is not installed.
                Adapter "email"          is not installed.
                Adapter "emby"           is not installed.
                Adapter "energymanager"  is not installed.
                Adapter "enet"           is not installed.
                Adapter "epson_stylus_px830" is not installed.
                Adapter "exchangerates"  is not installed.
                Adapter "fakeroku"       is not installed.
                Adapter "fb-checkpresence" is not installed.
                Adapter "feiertage"      is not installed.
                Adapter "fhem"           is not installed.
                Adapter "find-my-iphone" is not installed.
                Adapter "firetv"         is not installed.
                Adapter "flot"           is up to date.
                Adapter "foobar2000"     is not installed.
                Adapter "fritzbox"       is not installed.
                Adapter "fritzdect"      is not installed.
                Adapter "fronius"        is not installed.
                Adapter "frontier_silicon" is not installed.
                Adapter "fullcalendar"   is not installed.
                Adapter "fullybrowser"   is not installed.
                Adapter "g-homa"         is not installed.
                Adapter "geofency"       is not installed.
                Adapter "growatt"        is not installed.
                Adapter "gruenbeck"      is not installed.
                Adapter "habpanel"       is not installed.
                Adapter "haier"          is not installed.
                Adapter "ham"            is not installed.
                Adapter "ham-wemo"       is not installed.
                Adapter "harmony"        is not installed.
                Adapter "heatingcontrol" is not installed.
                Adapter "heos"           is not installed.
                Adapter "heytech"        is not installed.
                Adapter "hid"            is not installed.
                Adapter "history"        is not installed.
                Adapter "hm-rega"        is not installed.
                Adapter "hm-rpc"         is not installed.
                Adapter "hmip"           is not installed.
                Adapter "homeconnect"    is not installed.
                Adapter "homee"          is not installed.
                Adapter "homepilot"      is not installed.
                Adapter "hp-ilo"         is not installed.
                Adapter "hs100"          is not installed.
                Adapter "hue"            is not installed.
                Adapter "hue-extended"   is not installed.
                Adapter "i2c"            is not installed.
                Adapter "ical"           is not installed.
                Adapter "icons-addictive-flavour-png" is not installed.
                Adapter "icons-fatcow-hosting" is not installed.
                Adapter "icons-icons8"   is not installed.
                Adapter "icons-material-png" is not installed.
                Adapter "icons-material-svg" is not installed.
                Adapter "icons-mfd-png"  is not installed.
                Adapter "icons-mfd-svg"  is not installed.
                Adapter "icons-open-icon-library-png" is not installed.
                Adapter "icons-ultimate-png" is not installed.
                Adapter "influxdb"       is not installed.
                Adapter "info"           is up to date.
                Adapter "innogy-smarthome" is not installed.
                Adapter "iogo"           is not installed.
                Adapter "iot"            is not installed.
                Adapter "iqontrol"       is not installed.
                Adapter "jarvis"         is not installed.
                Adapter "javascript"     is up to date.
                Adapter "jeelink"        is not installed.
                Adapter "kecontact"      is not installed.
                Adapter "klf200"         is not installed.
                Adapter "km200"          is not installed.
                Adapter "knmi-weather"   is not installed.
                Adapter "knx"            is not installed.
                Adapter "kodi"           is not installed.
                Adapter "kostal-piko-ba" is not installed.
                Adapter "kress"          is not installed.
                Adapter "lametric"       is not installed.
                Adapter "landroid"       is not installed.
                Adapter "lcn"            is not installed.
                Adapter "legrand-ecocompteur" is not installed.
                Adapter "letrika_comgw"  is not installed.
                Adapter "lgtv"           is not installed.
                Adapter "lgtv-rs"        is not installed.
                Adapter "lgtv11"         is not installed.
                Adapter "lifx"           is not installed.
                Adapter "lightify"       is not installed.
                Adapter "link"           is not installed.
                Adapter "linkeddevices"  is not installed.
                Adapter "linux-control"  is not installed.
                Adapter "logparser"      is not installed.
                Adapter "lovelace"       is not installed.
                Adapter "loxone"         is not installed.
                Adapter "luftdaten"      is not installed.
                Adapter "lupusec"        is not installed.
                Adapter "luxtronik1"     is not installed.
                Adapter "material"       is not installed.
                Adapter "maxcube"        is not installed.
                Adapter "maxcul"         is not installed.
                Adapter "mbus"           is not installed.
                Adapter "mclighting"     is not installed.
                Adapter "megad"          is not installed.
                Adapter "megadd"         is not installed.
                Adapter "megaesp"        is not installed.
                Adapter "melcloud"       is not installed.
                Adapter "mercedesme"     is not installed.
                Adapter "mercury"        is not installed.
                Adapter "meross"         is not installed.
                Adapter "meteoalarm"     is not installed.
                Adapter "midea"          is not installed.
                Adapter "miele"          is not installed.
                Adapter "mielecloudservice" is not installed.
                Adapter "mihome"         is not installed.
                Adapter "mihome-lamp"    is not installed.
                Adapter "mihome-plug"    is not installed.
                Adapter "mihome-vacuum"  is up to date.
                Adapter "mikrotik"       is not installed.
                Adapter "milight"        is not installed.
                Adapter "milight-smart-light" is not installed.
                Adapter "minuvis"        is not installed.
                Adapter "mobile"         is up to date.
                Adapter "modbus"         is not installed.
                Adapter "moma"           is not installed.
                Adapter "mpd"            is not installed.
                Adapter "mqtt"           is not installed.
                Adapter "mqtt-client"    is not installed.
                Adapter "musiccast"      is not installed.
                Adapter "mydlink"        is not installed.
                Adapter "mysensors"      is not installed.
                Adapter "nanoleaf-lightpanels" is not installed.
                Adapter "nello"          is not installed.
                Adapter "netatmo"        is not installed.
                Adapter "netatmo-crawler" is not installed.
                Adapter "nibeuplink"     is not installed.
                Adapter "nina"           is not installed.
                Adapter "node-red"       is not installed.
                Adapter "nuki"           is not installed.
                Adapter "nuki-extended"  is not installed.
                Adapter "nut"            is not installed.
                Adapter "octoprint"      is not installed.
                Adapter "odl"            is not installed.
                Adapter "oilfox"         is not installed.
                Adapter "onkyo"          is not installed.
                Adapter "onvif"          is not installed.
                Adapter "openhab"        is not installed.
                Adapter "openligadb"     is not installed.
                Adapter "openweathermap" is not installed.
                Adapter "opi"            is not installed.
                Adapter "oppoplayer"     is not installed.
                Adapter "owfs"           is not installed.
                Adapter "owntracks"      is not installed.
                Adapter "panasonic-viera" is not installed.
                Adapter "parser"         is not installed.
                Adapter "paw"            is not installed.
                Adapter "phantomjs"      is not installed.
                Adapter "pi-hole"        is not installed.
                Adapter "piface"         is not installed.
                Adapter "pimatic"        is not installed.
                Adapter "ping"           is not installed.
                Adapter "places"         is not installed.
                Adapter "plex"           is not installed.
                Adapter "plexconnect"    is not installed.
                Adapter "pollenflug"     is not installed.
                Adapter "proxmox"        is not installed.
                Adapter "proxy"          is not installed.
                Adapter "pushbullet"     is not installed.
                Adapter "pushover"       is not installed.
                Adapter "pushsafer"      is not installed.
                Adapter "radar2"         is not installed.
                Adapter "radiohead"      is not installed.
                Adapter "rflink"         is not installed.
                Adapter "rickshaw"       is not installed.
                Adapter "ring"           is not installed.
                Adapter "robonect"       is not installed.
                Adapter "roomba"         is not installed.
                Adapter "rpi2"           is not installed.
                Adapter "s7"             is not installed.
                Adapter "samsung"        is up to date.
                Adapter "sayit"          is not installed.
                Adapter "sbfspot"        is not installed.
                Adapter "scenes"         is up to date.
                Adapter "schoolfree"     is not installed.
                Adapter "schwoerer-ventcube" is not installed.
                Adapter "shelly"         is not installed.
                Adapter "shuttercontrol" is not installed.
                Adapter "sia"            is not installed.
                Adapter "siegenia"       is not installed.
                Adapter "simple-api"     is up to date.
                Adapter "smappee"        is not installed.
                Adapter "smartcontrol"   is not installed.
                Adapter "smartgarden"    is not installed.
                Adapter "smartmeter"     is not installed.
                Adapter "snips"          is not installed.
                Adapter "snmp"           is not installed.
                Adapter "socketio"       is up to date.
                Adapter "solarlog"       is not installed.
                Adapter "solarviewdatareader" is not installed.
                Adapter "solarwetter"    is not installed.
                Adapter "sonnen"         is not installed.
                Adapter "sonoff"         is up to date.
                Adapter "sonos"          is not installed.
                Adapter "sony-bravia"    is not installed.
                Adapter "spotify-premium" is not installed.
                Adapter "sql"            is not installed.
                Adapter "squeezebox"     is not installed.
                Adapter "squeezeboxrpc"  is not installed.
                Adapter "starline"       is not installed.
                Adapter "statistics"     is not installed.
                Adapter "stiebel-isg"    is not installed.
                Adapter "sunnyportal"    is not installed.
                Adapter "swiss-weather-api" is not installed.
                Adapter "synology"       is not installed.
                Adapter "systeminfo"     is not installed.
                Adapter "tahoma"         is not installed.
                Adapter "tankerkoenig"   is not installed.
                Adapter "telegram"       is up to date.
                Adapter "terminal"       is up to date.
                Adapter "tesla-motors"   is not installed.
                Adapter "text2command"   is up to date.
                Adapter "tinker"         is not installed.
                Adapter "tr-064"         is up to date.
                Adapter "tradfri"        is not installed.
                Adapter "trashschedule"  is not installed.
                Adapter "tunnelbroker-endpoint-updater" is not installed.
                Adapter "tuya"           is not installed.
                Adapter "tvspielfilm"    is not installed.
                Adapter "unifi"          is not installed.
                Adapter "upnp"           is not installed.
                Adapter "vaillant"       is not installed.
                Adapter "valloxmv"       is not installed.
                Adapter "vcard"          is not installed.
                Adapter "velux"          is not installed.
                Adapter "viessmann"      is not installed.
                Adapter "virtualpowermeter" is not installed.
                Adapter "vis"            is not installed.
                Adapter "vis-bars"       is not installed.
                Adapter "vis-canvas-gauges" is not installed.
                Adapter "vis-colorpicker" is not installed.
                Adapter "vis-fancyswitch" is not installed.
                Adapter "vis-google-fonts" is not installed.
                Adapter "vis-history"    is not installed.
                Adapter "vis-hqwidgets"  is not installed.
                Adapter "vis-icontwo"    is not installed.
                Adapter "vis-inventwo"   is not installed.
                Adapter "vis-jqui-mfd"   is not installed.
                Adapter "vis-justgage"   is not installed.
                Adapter "vis-keyboard"   is not installed.
                Adapter "vis-lcars"      is not installed.
                Adapter "vis-map"        is not installed.
                Adapter "vis-material-advanced" is not installed.
                Adapter "vis-metro"      is not installed.
                Adapter "vis-players"    is not installed.
                Adapter "vis-plumb"      is not installed.
                Adapter "vis-rgraph"     is not installed.
                Adapter "vis-timeandweather" is not installed.
                Adapter "vis-weather"    is not installed.
                Adapter "vr200"          is not installed.
                Adapter "vw-connect"     is not installed.
                Adapter "weatherunderground" is not installed.
                Adapter "web"            is up to date.
                Adapter "weishaupt-wem"  is not installed.
                Adapter "whatsapp-cmb"   is not installed.
                Adapter "wiffi-wz"       is not installed.
                Adapter "wifilight"      is not installed.
                Adapter "windows-control" is not installed.
                Adapter "wled"           is not installed.
                Adapter "wm-bus"         is not installed.
                Adapter "wolf"           is not installed.
                Adapter "worx"           is not installed.
                Adapter "xbox"           is not installed.
                Adapter "xs1"            is not installed.
                Adapter "yahka"          is not installed.
                Adapter "yamaha"         is not installed.
                Adapter "yeelight-2"     is not installed.
                Adapter "youtube"        is not installed.
                Adapter "yr"             is not installed.
                Update zigbee from @1.2.1 to @1.3.1
                host.Master Adapter "system.adapter.zigbee.0" is stopped.
                NPM version: 6.14.8
                npm install iobroker.zigbee@1.3.1 --loglevel error --prefix "/opt/iobroker" (System call)
                Update "system.adapter.zigbee.0"
                upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_rb280.png img/tuya_rb280.png image/png
                upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_gu10_color.png img/philips_hue_gu10_color.png image/png
                upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lumi_router.png img/lumi_router.png image/png
                upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_recessed_spot_light.png img/ikea_recessed_spot_light.png image/png
                upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_bulb_E27.png img/ikea_bulb_E27.png image/png
                upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
                upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gira_4_buttons.png img/gira_4_buttons.png image/png
                upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ewelink_DS01.png img/ewelink_DS01.png image/png
                upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_neutral1.png img/ctrl_neutral1.png image/png
                upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_902010_24.png img/bitron_902010_24.png image/png
                upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZHS15.png img/ZHS15.png image/png
                upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/NAS-AB02B0.png img/NAS-AB02B0.png image/png
                upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Moes_Wall_Thermostat.png img/Moes_Wall_Thermostat.png image/png
                upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Ikea_fyrtur.png img/Ikea_fyrtur.png image/png
                upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HY08WE.png img/HY08WE.png image/png
                upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
                upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_R8_8.png img/DIYRuZ_R8_8.png image/png
                upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Geiger.png img/DIYRuZ_Geiger.png image/png
                upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
                upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Flower.png img/DIYRuZ_Flower.png image/png
                upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
                upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
                upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
                upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
                upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
                upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                host.Master Adapter "system.adapter.zigbee.0" is started
                Adapter "zont"           is not installed.
                Adapter "zwave"          is not installed.
                Adapter "zwave2"         is not installed.
                • M Mapio90
                  @Thomas-Braun
                  Vielen Dank
                  update done
                  NPM version: 6.14.8
                  Jein, das liegt halt daran, wenn man das System länger nicht anfasst. Dann muss man da halt dann mehr Zeit für die diversen 'dreckigen' Ecken investieren. Wenn man das regelmäßiger macht sind auch die Baustellen nicht so groß.
                  Den slave würde ich mir dann an deiner Stelle auch vorknöpfen. Bei dem kann aber die Gemengelage wieder ganz anders aussehen. Muss man sich dann halt mal genauer anschauen, was da der Stand ist.
                  • M Mapio90
                    @Thomas-Braun
                    Vielen Dank
                    update done
                    NPM version: 6.14.8
                    @Mapio90
                    Welchen Fehler meinst du genau? Das waren ja jetzt mehrere falsche/veraltete Einstellungen.
                      Mapio90
                      @Thomas-Braun
                      okay dann stell ich da auch mal so viele informationen hier rein wie oben beschrieben. Aber im Endeffekt ist der gleich konfiguriert wie der Master, nur anders benannt.
                        @Mapio90
                        Mapio90
                        @Thomas-Braun
                        okay, das reicht mir schon. Macht es Sinn einen neuen Thread für den Slave zu öffnen? Habe beim Slave zwar das gleiche Problem, dass der Zigbee rot ist aber das sind ja Probleme von veralteten EInstellungen!?
                        • M Mapio90
                          @Thomas-Braun
                          Möglich. Kann man halt so ohne Meldungen vom System nix zu sagen.
                          Prinzipiell läuft das immer gleich ab:
                          Grundsystem auf Stand bringen, auf Serverbetrieb umstellen wenn möglich, nodeJS auf Stand bringen, iobroker auf Stand bringen.
                          • M Mapio90
                            Hallo Zusammen, ich bräuchte Hilfe, mein Zigbee Adapter ist nach dem Update von Nodejs, npm und Admin die ganze zeit auf rot.
                            Das Einzige was von den dreien grün ist, ist "Verbunden mit Zigbee"
                            Update scheitert auch... habe im obigen Post gelesen einfach mal aktuallisieren aber das geht schon nicht, bei mir zumindest.
                            Ich habe vor erstmal den Zigbee Adapter des Masters zu aktuallisieren.
                            Hier mein Log dazu.
                            host.Master	2020-12-04 19:55:37.134	info	Rebuild for adapter system.adapter.zigbee.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                            host.Master	2020-12-04 19:55:37.133	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.Master	2020-12-04 19:55:37.132	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
                            host.Master	2020-12-04 19:55:37.132	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                            host.Master	2020-12-04 19:55:37.131	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
                            host.Master	2020-12-04 19:55:37.131	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
                            host.Master	2020-12-04 19:55:37.131	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:81:44)
                            host.Master	2020-12-04 19:55:37.130	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
                            host.Master	2020-12-04 19:55:37.130	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
                            host.Master	2020-12-04 19:55:37.130	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                            host.Master	2020-12-04 19:55:37.129	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
                            host.Master	2020-12-04 19:55:37.129	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1057:18)
                            host.Master	2020-12-04 19:55:37.128	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                            host.Master	2020-12-04 19:55:37.128	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                            host.Master	2020-12-04 19:55:37.128	error	Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
                            host.Master	2020-12-04 19:55:37.127	error	Caught by controller[0]: was compiled against a different Node.js version using
                            host.Master	2020-12-04 19:55:37.127	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node'
                            host.Master	2020-12-04 19:55:37.127	error	Caught by controller[0]: ^
                            host.Master	2020-12-04 19:55:37.126	error	Caught by controller[0]: throw e
                            host.Master	2020-12-04 19:55:37.125	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:88
                            host.Master	2020-12-04 19:55:35.768	info	instance system.adapter.zigbee.0 started with pid 15801
                            host.Master	2020-12-04 19:55:35.699	info	"system.adapter.zigbee.0" enabled
                            host.Master	2020-12-04 19:55:09.247	info	iobroker exit 0
                            host.Master	2020-12-04 19:55:08.217	info	iobroker Adapter "zigbee" updated
                            host.Master	2020-12-04 19:55:08.155	info	iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                            host.Master	2020-12-04 19:55:08.094	info	iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                            host.Master	2020-12-04 19:55:08.032	info	iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                            host.Master	2020-12-04 19:55:07.963	info	iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                            host.Master	2020-12-04 19:55:07.888	info	iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                            host.Master	2020-12-04 19:55:07.814	info	iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
                            host.Master	2020-12-04 19:55:07.739	info	iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TRADFRI.bulb.E27.png img/TRADFRI.bulb.E27.png image/png
                            host.Master	2020-12-04 19:55:07.667	info	iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TRADFRI.remote.control.png img/TRADFRI.remote.control.png image/png
                            host.Master	2020-12-04 19:55:07.596	info	iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara.switch.png img/aqara.switch.png image/png
                            host.Master	2020-12-04 19:55:07.498	info	iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_bulb.png img/aqara_bulb.png image/png
                            host.Master	2020-12-04 19:55:07.413	info	iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_numan_body_sensor.png img/aqara_numan_body_sensor.png image/png
                            host.Master	2020-12-04 19:55:07.340	info	iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_temperature_sensor.png img/aqara_temperature_sensor.png image/png
                            host.Master	2020-12-04 19:55:07.267	info	iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_p.png img/battery_p.png image/png
                            host.Master	2020-12-04 19:55:07.191	info	iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_v.png img/battery_v.png image/png
                            host.Master	2020-12-04 19:55:07.119	info	iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_plug.png img/bitron_plug.png image/png
                            host.Master	2020-12-04 19:55:07.048	info	iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/contact.png img/contact.png image/png
                            host.Master	2020-12-04 19:55:06.972	info	iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln1.png img/ctrl_ln1.png image/png
                            host.Master	2020-12-04 19:55:06.897	info	iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln2.png img/ctrl_ln2.png image/png
                            host.Master	2020-12-04 19:55:06.825	info	iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_neutral1.png img/ctrl_neutral1.png image/png
                            host.Master	2020-12-04 19:55:06.756	info	iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_neutral2.png img/ctrl_neutral2.png image/png
                            host.Master	2020-12-04 19:55:06.694	info	iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/cube.png img/cube.png image/png
                            host.Master	2020-12-04 19:55:05.114	info	iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_bulb.png img/gledopto_bulb.png image/png
                            host.Master	2020-12-04 19:55:04.412	info	iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/innr.png img/innr.png image/png
                            host.Master	2020-12-04 19:55:03.727	info	iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lumi_lock_v1.png img/lumi_lock_v1.png image/png
                            host.Master	2020-12-04 19:55:03.049	info	iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/osram_surface_light_tw.png img/osram_surface_light_tw.png image/png
                            host.Master	2020-12-04 19:55:02.313	info	iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_rwl021.png img/philips_hue_rwl021.png image/png
                            host.Master	2020-12-04 19:55:01.586	info	iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_motion_aq2.png img/sensor_motion_aq2.png image/png
                            host.Master	2020-12-04 19:55:00.942	info	iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
                            host.Master	2020-12-04 19:55:00.120	info	iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-12-04T18_55_00_014Z-debug.log
                            host.Master	2020-12-04 19:54:59.933	info	iobroker ERR! notsup Unsupported engine for dissolve@0.3.3: wanted: {"node":"~0.10.0"} (current: {"node":"12.20.0","npm":"6.14.8"})npm ERR! notsup Not compatible with your version of node/npm: disso
                            host.Master	2020-12-04 19:54:59.928	info	iobroker npm
                            host.Master	2020-12-04 19:54:59.880	info	iobroker npm ERR! code ENOTSUP
                            host.Master	2020-12-04 19:54:17.956	info	iobroker npm install iobroker.zigbee@1.3.1 --loglevel error --prefix "/opt/iobroker" (System call)
                            host.Master	2020-12-04 19:54:17.952	info	iobroker NPM version: 6.14.8
                            host.Master	2020-12-04 19:54:16.918	info	iobroker Update zigbee from @0.9.2 to @1.3.1
                            host.Master	2020-12-04 19:54:13.711	info	iobroker upgrade zigbee
                            Zusätzliche Infos
                            system.adapter.admin                   : admin          - v4.1.10
                            system.adapter.alexa2                  : alexa2         - v3.3.1
                            system.adapter.backitup                : backitup       - v1.7.0
                            system.adapter.ble                     : ble            - v0.12.0
                            system.adapter.cloud                   : cloud          - v3.1.0
                            system.adapter.daswetter               : daswetter      - v3.0.4
                            system.adapter.digitalstrom            : digitalstrom   - v0.5.5
                            system.adapter.discovery               : discovery      - v2.3.11
                            system.adapter.flot                    : flot           - v1.10.4
                            system.adapter.info                    : info           - v1.7.10
                            system.adapter.javascript              : javascript     - v4.1.12
                            system.adapter.mihome-vacuum           : mihome-vacuum  - v1.1.5
                            system.adapter.mobile                  : mobile         - v0.5.0
                            system.adapter.samsung                 : samsung        - v0.2.9
                            system.adapter.scenes                  : scenes         - v2.3.0
                            system.adapter.socketio                : socketio       - v3.0.13
                            system.adapter.sonoff                  : sonoff         - v2.2.2
                            system.adapter.telegram                : telegram       - v1.6.0
                            system.adapter.terminal                : terminal       - v0.1.2
                            system.adapter.text2command            : text2command   - v1.2.5
                            system.adapter.tr-064                  : tr-064         - v0.4.18
                            system.adapter.web                     : web            - v2.4.1
                            pi@Master:~ $ iobroker list instances
                            + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              system.adapter.admin.1                 : admin                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.alexa2.0                : alexa2                -  enabled
                            + system.adapter.backitup.0              : backitup              -  enabled
                              system.adapter.backitup.1              : backitup              - disabled
                            + system.adapter.ble.0                   : ble                   -  enabled
                              system.adapter.ble.1                   : ble                   - disabled
                            + system.adapter.cloud.0                 : cloud                 -  enabled
                            + system.adapter.digitalstrom.0          : digitalstrom          -  enabled
                            + system.adapter.discovery.0             : discovery             -  enabled
                              system.adapter.flot.0                  : flot                  -  enabled
                            + system.adapter.javascript.0            : javascript            -  enabled
                            + system.adapter.mihome-vacuum.0         : mihome-vacuum         -  enabled, port: 54321
                              system.adapter.mobile.0                : mobile                - disabled
                            + system.adapter.samsung.0               : samsung               -  enabled
                            + system.adapter.scenes.0                : scenes                -  enabled
                            + system.adapter.socketio.0              : socketio              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                            + system.adapter.sonoff.0                : sonoff                -  enabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
                            + system.adapter.terminal.0              : terminal              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                            + system.adapter.text2command.0          : text2command          -  enabled
                            + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              system.adapter.zigbee.0                : zigbee                -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0019367259-if00
                              system.adapter.zigbee.1                : zigbee                - disabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0019361A08-if00
                            + instance is alive
                            Mapio90
                            @Thomas-Braun
                            Auch hier beim Slave ist der Zigbee Adapter rot
                            pi@second-device:~ $ iobroker list adapters
                            system.adapter.alexa2                  : alexa2         - v3.3.5
                            system.adapter.javascript              : javascript     - v4.8.4
                            system.adapter.mihome-vacuum           : mihome-vacuum  - v2.1.1
                            system.adapter.mobile                  : mobile         - v1.0.1
                            system.adapter.simple-api              : simple-api     - v2.4.8
                            system.adapter.sonoff                  : sonoff         - v2.3.3
                            system.adapter.text2command            : text2command   - v2.0.5
                            system.adapter.tr-064                  : tr-064         - v4.2.1
                            system.adapter.web                     : web            - v3.0.14
                            system.adapter.zigbee                  : zigbee         - v0.10.3
                            pi@second-device:~ $ iobroker list instances
                            + system.adapter.admin.1                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.backitup.1              : backitup              -  enabled
                            + system.adapter.ble.1                   : ble                   -  enabled
                            + system.adapter.zigbee.0                : zigbee                -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0019367259-if00
                              system.adapter.zigbee.1                : zigbee                -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0019361A08-if00
                            + instance is alive
                            pi@second-device:~ $ which nodejs && nodejs -v && which node && node -v && which        npm && npm -v && apt policy nodejs
                            /usr/bin/nodejs
                            v12.20.0
                            /usr/bin/node
                            v12.20.0
                            /usr/bin/npm
                            6.14.8
                            nodejs:
                              Installiert:           12.20.0-1nodesource1
                              Installationskandidat: 12.20.0-1nodesource1
                              Versionstabelle:
                             *** 12.20.0-1nodesource1 500
                                    500 https://deb.nodesource.com/node_12.x stretch/main armhf Packages
                                 8.11.1~dfsg-2~bpo9+1 500
                                    500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
                                 4.8.2~dfsg-1 500
                                    500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                            • M Mapio90
                              @Thomas-Braun
                              + instance is alive
                              /usr/bin/nodejs
                              v12.20.0
                              /usr/bin/node
                              v12.20.0
                              /usr/bin/npm
                              6.14.8
                              nodejs:
                                Versionstabelle:
                                   4.8.2~dfsg-1 500
                              @Mapio90 Sieht wohl ähnlich aus
                              sudo apt update
                              sudo apt dist-upgrade
                              sudo reboot
                              iobroker update
                              cd /opt/iobroker
                              iobroker upgrade
                              • M Mapio90
                                @Thomas-Braun
                                + instance is alive
                                /usr/bin/nodejs
                                v12.20.0
                                /usr/bin/node
                                v12.20.0
                                /usr/bin/npm
                                6.14.8
                                nodejs:
                                  Versionstabelle:
                                     4.8.2~dfsg-1 500
                                @Mapio90 Und auch auf dem System mal nach dem Runlevel schauen:
                                who -r
                                  sudo apt update
                                  sudo reboot
                                  iobroker update
                                  cd /opt/iobroker
                                  iobroker upgrade
                                  Mapio90
                                  @Thomas-Braun
                                  also ich bin mir nicht ganz sicher, aber ich glaube mir schmiert die sd karte vom Slave gerade ab.
                                  habe vorher das system runter gefahren um den zigbee stick einzustecken.
                                  Nach dem wieder hochfahren (sudo reboot) hat das system ewig gebraucht bis der slave wieder online kam. Gerade wieder unter putty eingeloggt iobroker update eingegeben und jetzt tust sich seit 5 min garnichts mehr.
                                  • M Mapio90
                                    @Thomas-Braun
                                    @Mapio90
                                    Strg-C
                                    Dann
                                    dmesg
                                    anschauen.
                                      who -r
                                      Mapio90
                                      who -r
                                      Hab ihn mal über nacht laufen lassen..und scheint soweit alles durchgelaufen zu sein.
                                      pi@second-device:~ $ iobroker update
                                      update done
                                      Adapter    "zigbee"        : 1.3.1    , installed 0.10.3 [Updateable]
                                      pi@second-device:~ $ cd /opt/iobroker
                                      pi@second-device:/opt/iobroker $ npm i iobroker.zigbee@1.3.1 --force
                                      > @serialport/bindings@9.0.3 install /opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings
                                      prebuild-install WARN install No prebuilt binaries found (target=12.20.0 runtime=node arch=arm libc= platform=linux)
                                      make: Verzeichnis „/opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings/build“ wird betreten
                                      make: Verzeichnis „/opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings/build“ wird verlassen
                                      > serialport@9.0.2 postinstall /opt/iobroker/node_modules/serialport
                                      > node thank-you.js
                                      npm WARN winston-syslog@2.4.4 requires a peer of winston@^3.0.0 but none is installed. You must install peer dependencies yourself.
                                      + iobroker.zigbee@1.3.1
                                      added 34 packages from 34 contributors, removed 252 packages, updated 18 packages and moved 5 packages in 53.452s
                                      13 packages are looking for funding
                                      pi@second-device:/opt/iobroker $ iobroker upgrade
                                      Adapter "alexa2"         is not installed.
                                      Adapter "cloud"          is not installed.
                                      Adapter "digitalstrom"   is not installed.
                                      Adapter "flot"           is not installed.
                                      Adapter "info"           is not installed.
                                      Adapter "javascript"     is not installed.
                                      Adapter "mihome-vacuum"  is not installed.
                                      Adapter "mobile"         is not installed.
                                      Adapter "samsung"        is not installed.
                                      Adapter "scenes"         is not installed.
                                      Adapter "simple-api"     is not installed.
                                      Adapter "socketio"       is not installed.
                                      Adapter "sonoff"         is not installed.
                                      Adapter "telegram"       is not installed.
                                      Adapter "terminal"       is not installed.
                                      Adapter "text2command"   is not installed.
                                      Adapter "tr-064"         is not installed.
                                      Adapter "web"            is not installed.
                                      Adapter "zigbee"         is up to date.
                                      pi@second-device:/opt/iobroker $ who -r
                                               Runlevel 3   2020-12-05 00:16
                                        @Mapio90
                                        Strg-C
                                        Dann
                                        dmesg
                                        anschauen.
                                        Mapio90
                                        dmesg
                                        Momentan habe ich das Gefühl er läuft wieder flüssiger
                                        pi@second-device:/opt/iobroker $ dmesg
                                        [    0.000000] Booting Linux on physical CPU 0x0
                                        [    0.000000] Linux version 4.19.66-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1253 SMP Thu Aug 15 11:49:46 BST 2019
                                        [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
                                        [    0.000000] CPU: div instructions available: patching division code
                                        [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
                                        [    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
                                        [    0.000000] Memory policy: Data cache writealloc
                                        [    0.000000] cma: Reserved 8 MiB at 0x3ac00000
                                        [    0.000000] On node 0 totalpages: 242688
                                        [    0.000000]   Normal zone: 2133 pages used for memmap
                                        [    0.000000]   Normal zone: 0 pages reserved
                                        [    0.000000]   Normal zone: 242688 pages, LIFO batch:63
                                        [    0.000000] random: get_random_bytes called from start_kernel+0xac/0x4b4 with crng_init=0
                                        [    0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
                                        [    0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
                                        [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                                        [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
                                        [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=b63917fa-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                                        [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
                                        [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
                                        [    0.000000] Memory: 939088K/970752K available (8192K kernel code, 629K rwdata, 2176K rodata, 1024K init, 821K bss, 23472K reserved, 8192K cma-reserved)
                                        [    0.000000] Virtual kernel memory layout:
                                                           vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                                                           fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                                                           vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
                                                           lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
                                                           modules : 0x7f000000 - 0x80000000   (  16 MB)
                                                             .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)
                                                             .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
                                                             .data : 0x(ptrval) - 0x(ptrval)   ( 630 kB)
                                                              .bss : 0x(ptrval) - 0x(ptrval)   ( 822 kB)
                                        [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                                        [    0.000000] ftrace: allocating 26394 entries in 78 pages
                                        [    0.000000] rcu: Hierarchical RCU implementation.
                                        [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                                        [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
                                        [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
                                        [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
                                        [    0.000023] Switching to timer-based delay loop, resolution 52ns
                                        [    0.000291] Console: colour dummy device 80x30
                                        [    0.000912] console [tty1] enabled
                                        [    0.000971] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
                                        [    0.001016] pid_max: default: 32768 minimum: 301
                                        [    0.001375] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
                                        [    0.001411] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
                                        [    0.002347] CPU: Testing write buffer coherency: ok
                                        [    0.002835] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                                        [    0.003503] Setting up static identity map for 0x100000 - 0x10003c
                                        [    0.003668] rcu: Hierarchical SRCU implementation.
                                        [    0.004483] smp: Bringing up secondary CPUs ...
                                        [    0.005347] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                                        [    0.006275] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                                        [    0.007138] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                                        [    0.007258] smp: Brought up 1 node, 4 CPUs
                                        [    0.007340] SMP: Total of 4 processors activated (153.60 BogoMIPS).
                                        [    0.007364] CPU: All CPU(s) started in HYP mode.
                                        [    0.007385] CPU: Virtualization extensions available.
                                        [    0.008377] devtmpfs: initialized
                                        [    0.021391] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
                                        [    0.021666] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                                        [    0.021714] futex hash table entries: 1024 (order: 4, 65536 bytes)
                                        [    0.022322] pinctrl core: initialized pinctrl subsystem
                                        [    0.023192] NET: Registered protocol family 16
                                        [    0.026148] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                                        [    0.031851] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                                        [    0.031887] hw-breakpoint: maximum watchpoint size is 8 bytes.
                                        [    0.032108] Serial: AMBA PL011 UART driver
                                        [    0.034417] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
                                        [    0.069287] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
                                        [    0.071214] SCSI subsystem initialized
                                        [    0.071460] usbcore: registered new interface driver usbfs
                                        [    0.071541] usbcore: registered new interface driver hub
                                        [    0.071654] usbcore: registered new device driver usb
                                        [    0.090306] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-08-15 12:06, variant start
                                        [    0.100133] raspberrypi-firmware soc:firmware: Firmware hash is 0e6daa5106dd4164474616408e0dc24f997ffcf3
                                        [    0.111763] clocksource: Switched to clocksource arch_sys_counter
                                        [    0.200898] VFS: Disk quotas dquot_6.6.0
                                        [    0.201009] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                                        [    0.201187] FS-Cache: Loaded
                                        [    0.201411] CacheFiles: Loaded
                                        [    0.211409] NET: Registered protocol family 2
                                        [    0.212232] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
                                        [    0.212296] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
                                        [    0.212428] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
                                        [    0.212632] TCP: Hash tables configured (established 8192 bind 8192)
                                        [    0.212792] UDP hash table entries: 512 (order: 2, 16384 bytes)
                                        [    0.212859] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
                                        [    0.213188] NET: Registered protocol family 1
                                        [    0.213759] RPC: Registered named UNIX socket transport module.
                                        [    0.213787] RPC: Registered udp transport module.
                                        [    0.213809] RPC: Registered tcp transport module.
                                        [    0.213830] RPC: Registered tcp NFSv4.1 backchannel transport module.
                                        [    0.215531] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
                                        [    0.218572] Initialise system trusted keyrings
                                        [    0.218779] workingset: timestamp_bits=14 max_order=18 bucket_order=4
                                        [    0.228775] FS-Cache: Netfs 'nfs' registered for caching
                                        [    0.229375] NFS: Registering the id_resolver key type
                                        [    0.229421] Key type id_resolver registered
                                        [    0.229443] Key type id_legacy registered
                                        [    0.229475] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                                        [    0.231831] Key type asymmetric registered
                                        [    0.231862] Asymmetric key parser 'x509' registered
                                        [    0.231930] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
                                        [    0.232111] io scheduler noop registered
                                        [    0.232136] io scheduler deadline registered (default)
                                        [    0.232327] io scheduler cfq registered
                                        [    0.232351] io scheduler mq-deadline registered (default)
                                        [    0.232375] io scheduler kyber registered
                                        [    0.234557] bcm2708_fb soc:fb: FB found 1 display(s)
                                        [    0.244048] Console: switching to colour frame buffer device 82x26
                                        [    0.250859] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
                                        [    0.257580] bcm2835-rng 3f104000.rng: hwrng registered
                                        [    0.260249] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                                        [    0.265563] vc-sm: Videocore shared memory driver
                                        [    0.268313] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
                                        [    0.284199] brd: module loaded
                                        [    0.296887] loop: module loaded
                                        [    0.299924] Loading iSCSI transport class v2.0-870.
                                        [    0.303104] libphy: Fixed MDIO Bus: probed
                                        [    0.305611] usbcore: registered new interface driver lan78xx
                                        [    0.308070] usbcore: registered new interface driver smsc95xx
                                        [    0.310423] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                                        [    0.340728] dwc_otg 3f980000.usb: base=(ptrval)
                                        [    0.543352] Core Release: 2.80a
                                        [    0.545735] Setting default values for core params
                                        [    0.548177] Finished setting default values for core params
                                        [    0.750922] Using Buffer DMA mode
                                        [    0.753331] Periodic Transfer Interrupt Enhancement - disabled
                                        [    0.755756] Multiprocessor Interrupt Enhancement - disabled
                                        [    0.758126] OTG VER PARAM: 0, OTG VER FLAG: 0
                                        [    0.760462] Dedicated Tx FIFOs mode
                                        [    0.763211] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = bad14000 dma = 0xfad14000 len=9024
                                        [    0.767782] FIQ FSM acceleration enabled for :
                                                       Non-periodic Split Transactions
                                                       Periodic Split Transactions
                                                       High-Speed Isochronous Endpoints
                                                       Interrupt/Control Split Transaction hack enabled
                                        [    0.778689] dwc_otg: Microframe scheduler enabled
                                        [    0.778743] WARN::hcd_init_fiq:457: FIQ on core 1
                                        [    0.780962] WARN::hcd_init_fiq:458: FIQ ASM at 80654f4c length 36
                                        [    0.783173] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
                                        [    0.785454] dwc_otg 3f980000.usb: DWC OTG Controller
                                        [    0.787711] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
                                        [    0.790032] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
                                        [    0.792362] Init: Port Power? op_state=1
                                        [    0.794601] Init: Power Port (0)
                                        [    0.797016] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
                                        [    0.801518] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                        [    0.803959] usb usb1: Product: DWC OTG Controller
                                        [    0.806328] usb usb1: Manufacturer: Linux 4.19.66-v7+ dwc_otg_hcd
                                        [    0.808748] usb usb1: SerialNumber: 3f980000.usb
                                        [    0.811680] hub 1-0:1.0: USB hub found
                                        [    0.813989] hub 1-0:1.0: 1 port detected
                                        [    0.816735] dwc_otg: FIQ enabled
                                        [    0.816741] dwc_otg: NAK holdoff enabled
                                        [    0.816747] dwc_otg: FIQ split-transaction FSM enabled
                                        [    0.816757] Module dwc_common_port init
                                        [    0.817033] usbcore: registered new interface driver usb-storage
                                        [    0.819479] mousedev: PS/2 mouse device common for all mice
                                        [    0.822641] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                                        [    0.825264] bcm2835-cpufreq: min=600000 max=1400000
                                        [    0.828067] sdhci: Secure Digital Host Controller Interface driver
                                        [    0.830477] sdhci: Copyright(c) Pierre Ossman
                                        [    0.833275] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
                                        [    0.836189] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
                                        [    0.838858] sdhci-pltfm: SDHCI platform and OF driver helper
                                        [    0.842948] ledtrig-cpu: registered to indicate activity on CPUs
                                        [    0.845671] hidraw: raw HID events driver (C) Jiri Kosina
                                        [    0.848413] usbcore: registered new interface driver usbhid
                                        [    0.851037] usbhid: USB HID core driver
                                        [    0.854355] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
                                        [    0.858430] [vc_sm_connected_init]: start
                                        [    0.867115] [vc_sm_connected_init]: end - returning 0
                                        [    0.870646] Initializing XFRM netlink socket
                                        [    0.873106] NET: Registered protocol family 17
                                        [    0.875607] Key type dns_resolver registered
                                        [    0.878445] Registering SWP/SWPB emulation handler
                                        [    0.881505] registered taskstats version 1
                                        [    0.883936] Loading compiled-in X.509 certificates
                                        [    0.893541] uart-pl011 3f201000.serial: cts_event_workaround enabled
                                        [    0.896066] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
                                        [    0.902781] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
                                        [    0.905308] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
                                        [    0.932537] sdhost: log_buf @ (ptrval) (fad13000)
                                        [    0.969926] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                                        [    0.973923] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                                        [    0.977780] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                                        [    0.982785] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                                        [    0.984906] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
                                        [    0.988262] of_cfs_init
                                        [    0.990400] of_cfs_init: OK
                                        [    0.992931] Waiting for root device PARTUUID=b63917fa-02...
                                        [    1.041886] Indeed it is in host mode hprt0 = 00021501
                                        [    1.108822] random: fast init done
                                        [    1.127286] mmc0: host does not support reading read-only switch, assuming write-enable
                                        [    1.135321] mmc0: new high speed SDHC card at address aaaa
                                        [    1.138774] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
                                        [    1.145250] mmc1: new high speed SDIO card at address 0001
                                        [    1.148032]  mmcblk0: p1 p2
                                        [    1.185288] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                        [    1.189589] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                        [    1.199995] devtmpfs: mounted
                                        [    1.207518] Freeing unused kernel memory: 1024K
                                        [    1.212191] Run /sbin/init as init process
                                        [    1.251812] usb 1-1: new high-speed USB device number 2 using dwc_otg
                                        [    1.254480] Indeed it is in host mode hprt0 = 00001101
                                        [    1.492116] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
                                        [    1.497449] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                                        [    1.501002] hub 1-1:1.0: USB hub found
                                        [    1.503961] hub 1-1:1.0: 4 ports detected
                                        [    1.674572] systemd[1]: System time before build time, advancing clock.
                                        [    1.821854] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
                                        [    1.826255] NET: Registered protocol family 10
                                        [    1.830252] Segment Routing with IPv6
                                        [    1.861332] random: systemd: uninitialized urandom read (16 bytes read)
                                        [    1.866558] random: systemd: uninitialized urandom read (16 bytes read)
                                        [    1.875267] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
                                        [    1.884066] systemd[1]: Detected architecture arm.
                                        [    1.907721] systemd[1]: Set hostname to <second-device>.
                                        [    1.952378] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
                                        [    1.958310] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                                        [    1.967141] hub 1-1.1:1.0: USB hub found
                                        [    1.970356] hub 1-1.1:1.0: 3 ports detected
                                        [    1.979922] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
                                        [    2.291831] usb 1-1.1.2: new full-speed USB device number 4 using dwc_otg
                                        [    2.394023] systemd[1]: Listening on fsck to fsckd communication Socket.
                                        [    2.426542] systemd[1]: Reached target Swap.
                                        [    2.432897] systemd[1]: Listening on udev Control Socket.
                                        [    2.439623] usb 1-1.1.2: New USB device found, idVendor=0451, idProduct=16a8, bcdDevice= 0.09
                                        [    2.440023] systemd[1]: Created slice System Slice.
                                        [    2.445224] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                        [    2.445233] usb 1-1.1.2: Product: TI CC2531 USB CDC
                                        [    2.445241] usb 1-1.1.2: Manufacturer: Texas Instruments
                                        [    2.445255] usb 1-1.1.2: SerialNumber: __0X00124B0019361A08
                                        [    2.469088] systemd[1]: Mounting RPC Pipe File System...
                                        [    2.475704] systemd[1]: Listening on udev Kernel Socket.
                                        [    2.483298] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
                                        [    2.771896] usb 1-1.1.1: new high-speed USB device number 5 using dwc_otg
                                        [    2.902452] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
                                        [    2.902466] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                                        [    3.081690] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                        [    3.169123] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
                                        [    3.170424] libphy: lan78xx-mdiobus: probed
                                        [    3.192176] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
                                        [    3.225773] systemd-journald[115]: Received request to flush runtime journal from PID 1
                                        [    3.667378] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                                        [    3.669832] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                                        [    3.669846] [vc_sm_connected_init]: start
                                        [    3.684505] [vc_sm_connected_init]: installed successfully
                                        [    3.764715] media: Linux media interface: v0.10
                                        [    3.799831] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                                        [    3.802412] videodev: Linux video capture interface: v2.00
                                        [    3.832662] bcm2835_audio soc:audio: card created with 8 channels
                                        [    3.875478] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                                        [    3.875491] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                                        [    3.886157] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                                        [    3.890716] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                                        [    3.913608] cdc_acm 1-1.1.2:1.0: ttyACM0: USB ACM device
                                        [    3.915787] usbcore: registered new interface driver cdc_acm
                                        [    3.915798] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
                                        [    3.922499] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                                        [    3.922513] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                                        [    3.928420] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                                        [    3.928435] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                                        [    3.936024] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                                        [    3.936038] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                                        [    3.998460] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                                        [    4.074413] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                                        [    4.169460] brcmfmac: F1 signature read @0x18000000=0x15264345
                                        [    4.178149] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                                        [    4.179370] usbcore: registered new interface driver brcmfmac
                                        [    4.471522] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                                        [    4.486040] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
                                        [    5.226489] uart-pl011 3f201000.serial: no DMA platform data
                                        [    5.426578] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
                                        [    5.462044] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
                                        [    5.462080] brcmfmac: power management disabled
                                        [    5.739342] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
                                        [    6.768813] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                                        [   11.681158] Bluetooth: Core ver 2.22
                                        [   11.681255] NET: Registered protocol family 31
                                        [   11.681262] Bluetooth: HCI device and connection manager initialized
                                        [   11.681285] Bluetooth: HCI socket layer initialized
                                        [   11.681299] Bluetooth: L2CAP socket layer initialized
                                        [   11.681338] Bluetooth: SCO socket layer initialized
                                        [   11.697990] Bluetooth: HCI UART driver ver 2.3
                                        [   11.698005] Bluetooth: HCI UART protocol H4 registered
                                        [   11.698136] Bluetooth: HCI UART protocol Three-wire (H5) registered
                                        [   11.698367] Bluetooth: HCI UART protocol Broadcom registered
                                        [   11.901134] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                                        [   11.901141] Bluetooth: BNEP filters: protocol multicast
                                        [   11.901153] Bluetooth: BNEP socket layer initialized
                                        [  538.220402] random: crng init done
                                        [  538.220413] random: 7 urandom warning(s) missed due to ratelimiting
                                        • M Mapio90
                                          @Thomas-Braun sagte in Zigbee Adapter v1.2.1 immer Rot:
                                          dmesg
                                          @Mapio90
                                          Das System ist auf Stand?
                                          sudo apt update
