  4. Test Adapter EnOcean (2) v0.3.x
    6.4k
eltakoenoceanenocean adaptertipp-funk
675 Beiträge 38 Kommentatoren 201.4k Aufrufe 35 Beobachtet
  • Tobias SchnurrT Tobias Schnurr
    @Jey-Cee
    2020-12-03 19:44:42.252 - info: enocean.0 (18087) Teachin mode de-activated
    2020-12-03 19:44:42.265 - info: enocean.0 (18087) state enocean.0.gateway.teachin deleted
    2020-12-03 19:45:03.846 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:45:16.366 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:45:56.750 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:46:32.595 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:46:55.808 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:47:15.036 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:48:10.081 - info: enocean.0 (18087) Teachin mode de-activated
    2020-12-03 19:48:10.089 - info: enocean.0 (18087) state enocean.0.gateway.teachin deleted
    2020-12-03 19:48:45.405 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:49:44.170 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:50:38.083 - info: enocean.0 (18087) Teachin mode de-activated
    2020-12-03 19:50:38.089 - info: enocean.0 (18087) state enocean.0.gateway.teachin deleted
    2020-12-03 19:54:32.809 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:54:52.811 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:56:34.823 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:57:44.683 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:57:45.281 - info: enocean.0 (18087) Teachin mode de-activated
    2020-12-03 19:57:45.285 - info: enocean.0 (18087) state enocean.0.gateway.teachin deleted
    Jey CeeJ Online
    Jey CeeJ Online
    Jey Cee
    #209
    @Tobias-Schnurr kannst du bitte noch ein log im debug machen.
    Instanz Tab -> Expertenmodus aktivieren -> Spalte Log-Stufe -> debug
    Und bitte in code tags packen:
    Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
    Tobias SchnurrT 1 Antwort Letzte Antwort
    • Jey CeeJ Jey Cee
      @guergen sagte in Test Adapter EnOcean (2) v0.1.x:
      Dort lässt sich der Adapter gar nicht erst installieren.
      Ich das bekannt?
      Wo ist das ein Problem zu suchen?
      Nein das war mir bisher nicht bekannt. Es gibt aber auch keinen Grund warum das nicht Funktionieren sollte.
      Kannst du bitte einen Issue auf Github aufmachen und das Installations log dort posten.
      guergen
      #210
      @Jey-Cee mittlerweile habe ich es hinbekommen...
      Slave läuft mit dem Adapter auf USB0
      G 1 Antwort Letzte Antwort
        Also ich habe gerade
        • die alte Instanz gelöscht
        • die neue Version installliert
        • Einlernen eine FT55 Tasters klappt wunderbar
        • Mein FUD61NPN-230V wird allerdings nicht eingelernt
        • gehe auf Gerät hinzufügen und setze den Aktor in den Lern-Modus ( Oben Stellung LRN, Unten Stellung Auto oder EC1)
        Mache ich da noch was falsch?
        guergen
        #211
        @Tobias-Schnurr das klappt bei mir mit den Geräten auch grade nicht🙄
        • Jey CeeJ Jey Cee
          Tobias SchnurrT Offline
          Tobias Schnurr
          #212
          @Jey-Cee
          enocean.0	2020-12-03 22:22:34.837	info	(23110) state enocean.0.gateway.teachin deleted
          enocean.0	2020-12-03 22:22:34.833	info	(23110) Teachin mode de-activated
          enocean.0	2020-12-03 22:22:07.327	debug	(23110) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
          enocean.0	2020-12-03 22:22:07.322	debug	(23110) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
          enocean.0	2020-12-03 22:22:07.318	debug	(23110) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
          enocean.0	2020-12-03 22:22:07.316	info	(23110) ["/dev/ttyUSB0"]
          enocean.0	2020-12-03 21:21:21.983	debug	(23110) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
          enocean.0	2020-12-03 21:21:21.979	debug	(23110) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
          enocean.0	2020-12-03 21:21:21.970	debug	(23110) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
          enocean.0	2020-12-03 21:21:21.966	info	(23110) ["/dev/ttyUSB0"]
          enocean.0	2020-12-03 21:21:18.915	debug	(23110) Packet type 2 received: 02
          enocean.0	2020-12-03 21:21:18.914	debug	(23110) 5500050102db00ffe864000a
          enocean.0	2020-12-03 21:21:18.900	debug	(23110) Sent data: 5500010005700838
          enocean.0	2020-12-03 21:21:18.899	debug	(23110) Packet type 2 received: 02
          enocean.0	2020-12-03 21:21:18.898	debug	(23110) 5500030002b3000100
          enocean.0	2020-12-03 21:21:18.885	debug	(23110) Sent data: 55000100057025fb
          enocean.0	2020-12-03 21:21:18.867	debug	(23110) Packet type 2 received: 02
          enocean.0	2020-12-03 21:21:18.867	debug	(23110) 5500030002b3000001
          enocean.0	2020-12-03 21:21:18.859	debug	(23110) Sent data: 5500010005700a36
          enocean.0	2020-12-03 21:21:18.857	debug	(23110) Packet type 2 received: 02
          enocean.0	2020-12-03 21:21:18.855	debug	(23110) 55002100022600020f000002060900058cd0c8454f0103474154455741594354524c0000000000
          enocean.0	2020-12-03 21:21:18.832	debug	(23110) Sent data: 5500010005700309
          enocean.0	2020-12-03 21:21:18.553	info	(23110) starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.enocean, node: v12.19.0, js-controller: 3.1.6
          enocean.0	2020-12-03 21:21:18.326	debug	(23110) statesDB connected
          enocean.0	2020-12-03 21:21:18.325	debug	(23110) States connected to redis: 127.0.0.1:9000
          enocean.0	2020-12-03 21:21:18.318	debug	(23110) States create System PubSub Client
          enocean.0	2020-12-03 21:21:18.314	debug	(23110) States create User PubSub Client
          enocean.0	2020-12-03 21:21:18.307	debug	(23110) Redis States: Use Redis connection: 127.0.0.1:9000
          enocean.0	2020-12-03 21:21:18.305	debug	(23110) objectDB connected
          enocean.0	2020-12-03 21:21:18.298	debug	(23110) Objects connected to redis: 127.0.0.1:9001
          enocean.0	2020-12-03 21:21:18.287	debug	(23110) Objects client initialize lua scripts
          enocean.0	2020-12-03 21:21:18.286	debug	(23110) Objects create User PubSub Client
          enocean.0	2020-12-03 21:21:18.284	debug	(23110) Objects create System PubSub Client
          enocean.0	2020-12-03 21:21:18.281	debug	(23110) Objects client ready ... initialize now
          enocean.0	2020-12-03 21:21:18.235	debug	(23110) Redis Objects: Use Redis connection: 127.0.0.1:9001
          host.raspberrypi	2020-12-03 21:21:17.297	info	instance system.adapter.enocean.0 started with pid 23110
            Jey CeeJ Online
            Jey CeeJ Online
            Jey Cee
            #213
            @Tobias-Schnurr sagte in Test Adapter EnOcean (2) v0.1.x:
            Nachdem im Log kein Telegram von deinem Aktor angekommen ist hab ich mal geschaut wieviele Versionen es davon gibt. Dieses Gerät gibt es seit 2009 mit 10 Versionen.
            Das heist als erstes müssen wir mal wissen wann dein Gerät Produziert wurde, das steht entweder in der Anleitung oder ist auf dem Gerät aufgedruckt (KW 10/17 oder ähnlich).
            • T TheAriba
              @Jey-Cee super 👍 muss dann wieder alles zurückgesetzt werden oder kann einfach drüber installiert werden? Gerne Bescheid geben wenn ich was testen soll.
              Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              #214
              @EnoceanEltako sagte in Test Adapter EnOcean (2) v0.1.x:
              Sollte dann ausreichend sein die neue Version einfach drüber zu installieren.
              • Jey CeeJ Online
                Jey CeeJ Online
                Jey Cee
                #215
                Anfragen für neue Geräte bitte wenn möglich in Zukunft über Github, ich verliere Langsam etwas den Überblick. Verwendet das Template 'Device request':
                https://github.com/Jey-Cee/ioBroker.enocean/issues/new/choose
                • Jey CeeJ Jey Cee
                  Tobias Schnurr
                  #216
                  @Jey-Cee
                  Also das ist ein Neugerät dieses Jahr gekauft.Ich schaue später noch mal auf den Aufkleber aber ich meine definitv in 2020 gefertigt.
                  Laut Bedienungsanleitungen bei Eltako ist die neuste Version ab ab KW 46/17.
                  Falls ich die Signal sonst noch mit irgendeinem Tool "belauschen" kann und die der Output weiter hilft gerne melden.
                  • G guergen
                    guergen
                    #217
                    Mittlerweile habe ich mit die Info´s von den FUD61NPN-230V zusammengesucht:
                    die Dimmwerte und An/Aus wird auch übergeben, aber steuern kann ich es noch nicht.
                    Das mit den Base-ID´s hab ich noch nicht raus...
                    • G guergen
                      Jey CeeJ Online
                      Jey CeeJ Online
                      Jey Cee
                      #218
                      @guergen es wäre gut wenn du erklärst wie du den Fud61 angelernt hast, dann hilft das vielleicht auch @Tobias-Schnurr weiter.
                      @guergen sagte in Test Adapter EnOcean (2) v0.2.x:
                      Das musst du auch nicht verstehen wenn du keine Geräte aus der Serie 14 hast.
                      Aktuell gibt es hier nur das Problem das du maximal den ersten angelernten Aktor steuern kannst, das ist ein Problem im Zusammenhang mit den Eltako Geräten.
                      • Jey CeeJ Jey Cee
                        guergen
                        #219
                        @Jey-Cee @Tobias-Schnurr
                        Ich habe die FUD zu Fuß eingetragen:
                        Zuerst einen DP angelegt mit folgenden RAW-Daten:
                          "type": "device",
                          "common": {
                            "name": "Licht Wohnzimmer"
                          "native": {
                            "id": "018d0a0a",
                            "manufacturer": "Enocean GmbH",
                            "eep": [
                              "TF-13-07",
                              "TF-13-05",
                              "TF-13-06"
                          "from": "system.adapter.enocean.0",
                          "user": "system.user.admin",
                          "ts": 1607017427335,
                          "_id": "enocean.0.018d0a0a",
                          "acl": {
                            "object": 1636,
                            "owner": "system.user.admin",
                        Anschliessend habe ich mir die DP-Formate aus der.json kopiert und alles eingetragen:
                        Level:
                          "type": "state",
                          "common": {
                            "name": "Level",
                            "role": "value.level",
                            "type": "number",
                            "read": true,
                            "write": true,
                            "unit": "%",
                            "def": 0
                          "native": {},
                          "ts": 1607016375019,
                          "_id": "enocean.0.018d0a0a.LVL",
                          "acl": {
                            "object": 1636,
                            "state": 1636
                        rssi:
                          "type": "state",
                          "common": {
                            "name": "Signal Strength",
                            "role": "value.rssi",
                            "type": "number",
                            "read": true,
                            "write": false,
                            "unit": "dBm"
                          "native": {},
                          "_id": "enocean.0.018d0a0a.rssi",
                          "acl": {
                            "object": 1636,
                            "state": 1636
                        und ON:
                          "type": "state",
                          "common": {
                            "name": "On",
                            "role": "state",
                            "type": "boolean",
                            "read": true,
                            "write": false,
                            "states": "0:false; 1:true",
                            "def": 0
                          "native": {},
                          "_id": "enocean.0.018d0a0a.ON",
                          "acl": {
                            "object": 1636,
                            "state": 1636
                        Command, Dimming Speed und Blocklevel ebenfalls, aber da kommen keine Info´s rein Zumindest kann ich die Beleuchtung schon einmal visualisieren und kann so langsam mein FHEM in Rente schicken.
                        Meine Enocean PTM215 werden automatisch erkannt als F6-02-02.
                        • G guergen
                            "type": "device",
                            "common": {
                            "native": {
                              "id": "018d0a0a",
                              "eep": [
                                "TF-13-07",
                                "TF-13-05",
                                "TF-13-06"
                            "acl": {
                              "object": 1636,
                          Level:
                            "type": "state",
                            "common": {
                              "name": "Level",
                              "type": "number",
                              "read": true,
                              "write": true,
                              "unit": "%",
                              "def": 0
                            "native": {},
                            "acl": {
                              "object": 1636,
                              "state": 1636
                          rssi:
                            "type": "state",
                            "common": {
                              "type": "number",
                              "read": true,
                              "write": false,
                              "unit": "dBm"
                            "native": {},
                            "acl": {
                              "object": 1636,
                              "state": 1636
                          und ON:
                            "type": "state",
                            "common": {
                              "name": "On",
                              "role": "state",
                              "type": "boolean",
                              "read": true,
                              "write": false,
                              "def": 0
                            "native": {},
                            "acl": {
                              "object": 1636,
                              "state": 1636
                          Jey CeeJ Online
                          Jey CeeJ Online
                          Jey Cee
                          #220
                          @guergen jetzt ist klar warum du den Aktor nicht steuern kannst, du hast ihn gar nicht angelernt.
                          Von wann ist dein Aktor?
                          • Jey CeeJ Jey Cee
                            guergen
                            #221
                            @Jey-Cee 23/14 & 27/14
                            Angelernt hab ich sie ja gar nicht bekommen.... daher zu Fuß
                            • G guergen
                              guergen
                              #222
                              Unter FHEM wird mir der FUD als A5-38-08 angezeigt, vielleicht hilft das!
                              Und der PT210 als F6-02-01.
                              ein weiterer PT210 als F6-10-00
                              G Jey CeeJ 2 Antworten Letzte Antwort
                              • G guergen
                                guergen
                                #223
                                Die FUD sind Version 8 habe ich grade herausgefunden
                                • G guergen
                                  Jey CeeJ Online
                                  Jey CeeJ Online
                                  Jey Cee
                                  #224
                                  In Fhem oder im Adapter?
                                  • Jey CeeJ Jey Cee
                                    guergen
                                    #225
                                    @Jey-Cee In Fhem wurde er als PTM210 mit F6-10-00 erkannt. Im EnOcean-Adapter wurden alle 4 Taster (PTM215) als F6-02-02 automatisch erkannt.
                                    • Jey CeeJ Jey Cee
                                      0.1.4 ist auf Github.
                                      • Für Geräte die mehr als einen Kanal haben, wie Eltako FSR14, kann es nötig sein das die Sender (Base) ID von ioBroker für jeden Kanal eine eigene sein muss. Deswegen habe ich einen Base ID Offset eingebaut.
                                        Das Video auf Youtbe zum Anlernen der Eltako Geräte mit PCT14 habe ich Angepasst.
                                      • Außerdem habe ich die Profile, TF-13-03 (Sender) & TF-13-04 (Empfänger), für Eltako FSB61NP-230V und ähnliche integriert. Hier muss bitte jemand Testen ob die so Funktionieren, bin mir nicht sicher ob ich die Spezifikation richtig interpretiert habe.
                                      teddy
                                      schrieb am zuletzt editiert von teddy
                                      #226
                                      @Jey-Cee said in Test Adapter EnOcean (2) v0.2.x:
                                      FSR14 ... die Sender (Base) ID von ioBroker für jeden Kanal eine eigene sein muss
                                      Hi Jey-Cee, diese Base ID kann man sich aussuchen (einfach 4 hex bytes und los) oder ist die schon irgendwo abgespeichert? Vielen Dank
                                      • Jey CeeJ Online
                                        Jey CeeJ Online
                                        Jey Cee
                                        #227
                                        @Tobias-Schnurr @guergen bitte mal von Github neu installieren, die Version bleibt gleich. Für die FUD habe ich jetzt ein zweites Gerät angelegt für manuelles Teachin.
                                        @teddy diese Frage erübrigt sich von selbst wenn du die Anweisungen im Adapter befolgst.
                                        G T 2 Antworten Letzte Antwort
                                        • Jey CeeJ Jey Cee
                                          guergen
                                          #228
                                          @Jey-Cee Installiert habe ich es von git.
                                          Jetzt aber mal eine ganz doofe Frage: Wie lernt men den egtl richtig an? In der Anleitung steht nicht wirklich hochdeutsch...
                                          Bestätigungstelegramme hab ich an, sonst würden im Broker ja keine Daten aktualisiert.
                                          Ich habe es mit einer Brücke zwischen L und an(hoch)/aus(runter) versucht.
                                          Wahrscheinlich muss ich den Broker als Sensor anlernen mit Auto/LRN, oder?
                                          Jey CeeJ G 2 Antworten Letzte Antwort
