  4. Test Adapter EnOcean (2) v0.3.x
    6.4k
eltakoenoceanenocean adaptertipp-funk
675 Beiträge 38 Kommentatoren 201.4k Aufrufe 35 Beobachtet
  • Jey CeeJ Jey Cee
    @Tobias-Schnurr was steht im Log wenn du versuchst ihn an zu lernen?
    Tobias SchnurrT Offline
    Tobias Schnurr
    #208
    @Jey-Cee
    2020-12-03 19:44:42.252 - info: enocean.0 (18087) Teachin mode de-activated
    2020-12-03 19:44:42.265 - info: enocean.0 (18087) state enocean.0.gateway.teachin deleted
    2020-12-03 19:45:03.846 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:45:16.366 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:45:56.750 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:46:32.595 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:46:55.808 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:47:15.036 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:48:10.081 - info: enocean.0 (18087) Teachin mode de-activated
    2020-12-03 19:48:10.089 - info: enocean.0 (18087) state enocean.0.gateway.teachin deleted
    2020-12-03 19:48:45.405 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:49:44.170 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:50:38.083 - info: enocean.0 (18087) Teachin mode de-activated
    2020-12-03 19:50:38.089 - info: enocean.0 (18087) state enocean.0.gateway.teachin deleted
    2020-12-03 19:54:32.809 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:54:52.811 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:56:34.823 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:57:44.683 - info: enocean.0 (18087) ["/dev/ttyUSB0"]
    2020-12-03 19:57:45.281 - info: enocean.0 (18087) Teachin mode de-activated
    2020-12-03 19:57:45.285 - info: enocean.0 (18087) state enocean.0.gateway.teachin deleted
    • Tobias SchnurrT Tobias Schnurr
      @Jey-Cee
      Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      #209
      @Tobias-Schnurr kannst du bitte noch ein log im debug machen.
      Instanz Tab -> Expertenmodus aktivieren -> Spalte Log-Stufe -> debug
      Und bitte in code tags packen:
      Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      Hier gehts zur Hilfe.
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
      Tobias SchnurrT 1 Antwort Letzte Antwort
      • Jey CeeJ Jey Cee
        @guergen sagte in Test Adapter EnOcean (2) v0.1.x:
        Dort lässt sich der Adapter gar nicht erst installieren.
        Ich das bekannt?
        Wo ist das ein Problem zu suchen?
        Nein das war mir bisher nicht bekannt. Es gibt aber auch keinen Grund warum das nicht Funktionieren sollte.
        Kannst du bitte einen Issue auf Github aufmachen und das Installations log dort posten.
        guergen
        #210
        @Jey-Cee mittlerweile habe ich es hinbekommen...
        Slave läuft mit dem Adapter auf USB0
        G 1 Antwort Letzte Antwort
          Also ich habe gerade
          • die alte Instanz gelöscht
          • die neue Version installliert
          • Einlernen eine FT55 Tasters klappt wunderbar
          • Mein FUD61NPN-230V wird allerdings nicht eingelernt
          • gehe auf Gerät hinzufügen und setze den Aktor in den Lern-Modus ( Oben Stellung LRN, Unten Stellung Auto oder EC1)
          Mache ich da noch was falsch?
          guergen
          #211
          @Tobias-Schnurr das klappt bei mir mit den Geräten auch grade nicht🙄
          • Jey CeeJ Jey Cee
            Tobias Schnurr
            #212
            @Jey-Cee
            enocean.0	2020-12-03 22:22:34.837	info	(23110) state enocean.0.gateway.teachin deleted
            enocean.0	2020-12-03 22:22:34.833	info	(23110) Teachin mode de-activated
            enocean.0	2020-12-03 22:22:07.327	debug	(23110) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
            enocean.0	2020-12-03 22:22:07.322	debug	(23110) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
            enocean.0	2020-12-03 22:22:07.318	debug	(23110) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
            enocean.0	2020-12-03 22:22:07.316	info	(23110) ["/dev/ttyUSB0"]
            enocean.0	2020-12-03 21:21:21.983	debug	(23110) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
            enocean.0	2020-12-03 21:21:21.979	debug	(23110) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
            enocean.0	2020-12-03 21:21:21.970	debug	(23110) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
            enocean.0	2020-12-03 21:21:21.966	info	(23110) ["/dev/ttyUSB0"]
            enocean.0	2020-12-03 21:21:18.915	debug	(23110) Packet type 2 received: 02
            enocean.0	2020-12-03 21:21:18.914	debug	(23110) 5500050102db00ffe864000a
            enocean.0	2020-12-03 21:21:18.900	debug	(23110) Sent data: 5500010005700838
            enocean.0	2020-12-03 21:21:18.899	debug	(23110) Packet type 2 received: 02
            enocean.0	2020-12-03 21:21:18.898	debug	(23110) 5500030002b3000100
            enocean.0	2020-12-03 21:21:18.885	debug	(23110) Sent data: 55000100057025fb
            enocean.0	2020-12-03 21:21:18.867	debug	(23110) Packet type 2 received: 02
            enocean.0	2020-12-03 21:21:18.867	debug	(23110) 5500030002b3000001
            enocean.0	2020-12-03 21:21:18.859	debug	(23110) Sent data: 5500010005700a36
            enocean.0	2020-12-03 21:21:18.857	debug	(23110) Packet type 2 received: 02
            enocean.0	2020-12-03 21:21:18.855	debug	(23110) 55002100022600020f000002060900058cd0c8454f0103474154455741594354524c0000000000
            enocean.0	2020-12-03 21:21:18.832	debug	(23110) Sent data: 5500010005700309
            enocean.0	2020-12-03 21:21:18.553	info	(23110) starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.enocean, node: v12.19.0, js-controller: 3.1.6
            enocean.0	2020-12-03 21:21:18.326	debug	(23110) statesDB connected
            enocean.0	2020-12-03 21:21:18.325	debug	(23110) States connected to redis: 127.0.0.1:9000
            enocean.0	2020-12-03 21:21:18.318	debug	(23110) States create System PubSub Client
            enocean.0	2020-12-03 21:21:18.314	debug	(23110) States create User PubSub Client
            enocean.0	2020-12-03 21:21:18.307	debug	(23110) Redis States: Use Redis connection: 127.0.0.1:9000
            enocean.0	2020-12-03 21:21:18.305	debug	(23110) objectDB connected
            enocean.0	2020-12-03 21:21:18.298	debug	(23110) Objects connected to redis: 127.0.0.1:9001
            enocean.0	2020-12-03 21:21:18.287	debug	(23110) Objects client initialize lua scripts
            enocean.0	2020-12-03 21:21:18.286	debug	(23110) Objects create User PubSub Client
            enocean.0	2020-12-03 21:21:18.284	debug	(23110) Objects create System PubSub Client
            enocean.0	2020-12-03 21:21:18.281	debug	(23110) Objects client ready ... initialize now
            enocean.0	2020-12-03 21:21:18.235	debug	(23110) Redis Objects: Use Redis connection: 127.0.0.1:9001
            host.raspberrypi	2020-12-03 21:21:17.297	info	instance system.adapter.enocean.0 started with pid 23110
              Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              #213
              @Tobias-Schnurr sagte in Test Adapter EnOcean (2) v0.1.x:
              Nachdem im Log kein Telegram von deinem Aktor angekommen ist hab ich mal geschaut wieviele Versionen es davon gibt. Dieses Gerät gibt es seit 2009 mit 10 Versionen.
              Das heist als erstes müssen wir mal wissen wann dein Gerät Produziert wurde, das steht entweder in der Anleitung oder ist auf dem Gerät aufgedruckt (KW 10/17 oder ähnlich).
              • T TheAriba
                @Jey-Cee super 👍 muss dann wieder alles zurückgesetzt werden oder kann einfach drüber installiert werden? Gerne Bescheid geben wenn ich was testen soll.
                Jey CeeJ Online
                Jey CeeJ Online
                Jey Cee
                #214
                @EnoceanEltako sagte in Test Adapter EnOcean (2) v0.1.x:
                Sollte dann ausreichend sein die neue Version einfach drüber zu installieren.
                • Jey CeeJ Online
                  Jey CeeJ Online
                  Jey Cee
                  #215
                  Anfragen für neue Geräte bitte wenn möglich in Zukunft über Github, ich verliere Langsam etwas den Überblick. Verwendet das Template 'Device request':
                  https://github.com/Jey-Cee/ioBroker.enocean/issues/new/choose
                  • Jey CeeJ Jey Cee
                    Tobias Schnurr
                    #216
                    @Jey-Cee
                    Also das ist ein Neugerät dieses Jahr gekauft.Ich schaue später noch mal auf den Aufkleber aber ich meine definitv in 2020 gefertigt.
                    Laut Bedienungsanleitungen bei Eltako ist die neuste Version ab ab KW 46/17.
                    Falls ich die Signal sonst noch mit irgendeinem Tool "belauschen" kann und die der Output weiter hilft gerne melden.
                    • G guergen
                      guergen
                      #217
                      Mittlerweile habe ich mit die Info´s von den FUD61NPN-230V zusammengesucht:
                      die Dimmwerte und An/Aus wird auch übergeben, aber steuern kann ich es noch nicht.
                      Das mit den Base-ID´s hab ich noch nicht raus...
                      • G guergen
                        Jey CeeJ Online
                        Jey CeeJ Online
                        Jey Cee
                        #218
                        @guergen es wäre gut wenn du erklärst wie du den Fud61 angelernt hast, dann hilft das vielleicht auch @Tobias-Schnurr weiter.
                        @guergen sagte in Test Adapter EnOcean (2) v0.2.x:
                        Das musst du auch nicht verstehen wenn du keine Geräte aus der Serie 14 hast.
                        Aktuell gibt es hier nur das Problem das du maximal den ersten angelernten Aktor steuern kannst, das ist ein Problem im Zusammenhang mit den Eltako Geräten.
                        • Jey CeeJ Jey Cee
                          guergen
                          #219
                          @Jey-Cee @Tobias-Schnurr
                          Ich habe die FUD zu Fuß eingetragen:
                          Zuerst einen DP angelegt mit folgenden RAW-Daten:
                            "type": "device",
                            "common": {
                              "name": "Licht Wohnzimmer"
                            "native": {
                              "id": "018d0a0a",
                              "manufacturer": "Enocean GmbH",
                              "eep": [
                                "TF-13-07",
                                "TF-13-05",
                                "TF-13-06"
                            "from": "system.adapter.enocean.0",
                            "user": "system.user.admin",
                            "ts": 1607017427335,
                            "_id": "enocean.0.018d0a0a",
                            "acl": {
                              "object": 1636,
                              "owner": "system.user.admin",
                          Anschliessend habe ich mir die DP-Formate aus der.json kopiert und alles eingetragen:
                          Level:
                            "type": "state",
                            "common": {
                              "name": "Level",
                              "role": "value.level",
                              "type": "number",
                              "read": true,
                              "write": true,
                              "unit": "%",
                              "def": 0
                            "native": {},
                            "ts": 1607016375019,
                            "_id": "enocean.0.018d0a0a.LVL",
                            "acl": {
                              "object": 1636,
                              "state": 1636
                          rssi:
                            "type": "state",
                            "common": {
                              "name": "Signal Strength",
                              "role": "value.rssi",
                              "type": "number",
                              "read": true,
                              "write": false,
                              "unit": "dBm"
                            "native": {},
                            "_id": "enocean.0.018d0a0a.rssi",
                            "acl": {
                              "object": 1636,
                              "state": 1636
                          und ON:
                            "type": "state",
                            "common": {
                              "name": "On",
                              "role": "state",
                              "type": "boolean",
                              "read": true,
                              "write": false,
                              "states": "0:false; 1:true",
                              "def": 0
                            "native": {},
                            "_id": "enocean.0.018d0a0a.ON",
                            "acl": {
                              "object": 1636,
                              "state": 1636
                          Command, Dimming Speed und Blocklevel ebenfalls, aber da kommen keine Info´s rein Zumindest kann ich die Beleuchtung schon einmal visualisieren und kann so langsam mein FHEM in Rente schicken.
                          Meine Enocean PTM215 werden automatisch erkannt als F6-02-02.
                          • G guergen
                              "type": "device",
                              "common": {
                              "native": {
                                "id": "018d0a0a",
                                "eep": [
                                  "TF-13-07",
                                  "TF-13-05",
                                  "TF-13-06"
                              "acl": {
                                "object": 1636,
                            Level:
                              "type": "state",
                              "common": {
                                "name": "Level",
                                "type": "number",
                                "read": true,
                                "write": true,
                                "unit": "%",
                                "def": 0
                              "native": {},
                              "acl": {
                                "object": 1636,
                                "state": 1636
                            rssi:
                              "type": "state",
                              "common": {
                                "type": "number",
                                "read": true,
                                "write": false,
                                "unit": "dBm"
                              "native": {},
                              "acl": {
                                "object": 1636,
                                "state": 1636
                            und ON:
                              "type": "state",
                              "common": {
                                "name": "On",
                                "role": "state",
                                "type": "boolean",
                                "read": true,
                                "write": false,
                                "def": 0
                              "native": {},
                              "acl": {
                                "object": 1636,
                                "state": 1636
                            Jey CeeJ Online
                            Jey CeeJ Online
                            Jey Cee
                            #220
                            @guergen jetzt ist klar warum du den Aktor nicht steuern kannst, du hast ihn gar nicht angelernt.
                            Von wann ist dein Aktor?
                            • Jey CeeJ Jey Cee
                              guergen
                              #221
                              @Jey-Cee 23/14 & 27/14
                              Angelernt hab ich sie ja gar nicht bekommen.... daher zu Fuß
                              • G guergen
                                guergen
                                #222
                                Unter FHEM wird mir der FUD als A5-38-08 angezeigt, vielleicht hilft das!
                                Und der PT210 als F6-02-01.
                                ein weiterer PT210 als F6-10-00
                                G Jey CeeJ 2 Antworten Letzte Antwort
                                • G guergen
                                  guergen
                                  #223
                                  Die FUD sind Version 8 habe ich grade herausgefunden
                                  • G guergen
                                    Jey CeeJ Online
                                    Jey CeeJ Online
                                    Jey Cee
                                    #224
                                    In Fhem oder im Adapter?
                                    • Jey CeeJ Jey Cee
                                      guergen
                                      #225
                                      @Jey-Cee In Fhem wurde er als PTM210 mit F6-10-00 erkannt. Im EnOcean-Adapter wurden alle 4 Taster (PTM215) als F6-02-02 automatisch erkannt.
                                      • Jey CeeJ Jey Cee
                                        0.1.4 ist auf Github.
                                        • Für Geräte die mehr als einen Kanal haben, wie Eltako FSR14, kann es nötig sein das die Sender (Base) ID von ioBroker für jeden Kanal eine eigene sein muss. Deswegen habe ich einen Base ID Offset eingebaut.
                                          Das Video auf Youtbe zum Anlernen der Eltako Geräte mit PCT14 habe ich Angepasst.
                                        • Außerdem habe ich die Profile, TF-13-03 (Sender) & TF-13-04 (Empfänger), für Eltako FSB61NP-230V und ähnliche integriert. Hier muss bitte jemand Testen ob die so Funktionieren, bin mir nicht sicher ob ich die Spezifikation richtig interpretiert habe.
                                        teddy
                                        schrieb am zuletzt editiert von teddy
                                        #226
                                        @Jey-Cee said in Test Adapter EnOcean (2) v0.2.x:
                                        FSR14 ... die Sender (Base) ID von ioBroker für jeden Kanal eine eigene sein muss
                                        Hi Jey-Cee, diese Base ID kann man sich aussuchen (einfach 4 hex bytes und los) oder ist die schon irgendwo abgespeichert? Vielen Dank
                                        • Jey CeeJ Online
                                          Jey CeeJ Online
                                          Jey Cee
                                          #227
                                          @Tobias-Schnurr @guergen bitte mal von Github neu installieren, die Version bleibt gleich. Für die FUD habe ich jetzt ein zweites Gerät angelegt für manuelles Teachin.
                                          @teddy diese Frage erübrigt sich von selbst wenn du die Anweisungen im Adapter befolgst.
                                          G T 2 Antworten Letzte Antwort
