  4. Kein Zugriff auf Port 8081 ...
port 8081
88 Beiträge 2 Kommentatoren 8.1k Aufrufe 2 Beobachtet
  • SMSS SMS
    @Thomas-Braun sorry, aber das wäre zu einfach
    Restart iobroker und komplett Neustart Pi schon ausprobiert
    @SMS
    dmesg
    SMSS 1 Antwort Letzte Antwort
      @SMS
      dmesg
      SMSS Offline
      SMSS Offline
      SMS
      @Thomas-Braun Screenshot?
      • SMSS SMS
        @SMS Nein. Text auch als solchen (in CodeTags) hier rein kopieren.
        • SMSS Offline
          SMSS Offline
          SMS
          pi@ioBroker-RasPi4:~ $ dmesg
          [    0.000000] Booting Linux on physical CPU 0x0
          [    0.000000] Linux version 4.19.97-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1294 SMP Thu Jan 30 13:21:14 GMT 2020
          [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
          [    0.000000] CPU: div instructions available: patching division code
          [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
          [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
          [    0.000000] Memory policy: Data cache writealloc
          [    0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
          [    0.000000] On node 0 totalpages: 2061312
          [    0.000000]   DMA zone: 1728 pages used for memmap
          [    0.000000]   DMA zone: 0 pages reserved
          [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
          [    0.000000]   HighMem zone: 1864704 pages, LIFO batch:63
          [    0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
          [    0.000000] percpu: Embedded 17 pages/cpu s36928 r8192 d24512 u69632
          [    0.000000] pcpu-alloc: s36928 r8192 d24512 u69632 alloc=17*4096
          [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
          [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2059584
          [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M cma=256M  smsc95xx.macaddr=DC:A6:32:B6:0D:F1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=52e4cf4c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
          [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
          [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
          [    0.000000] Memory: 7893004K/8245248K available (8192K kernel code, 687K rwdata, 2408K rodata, 2048K init, 850K bss, 90100K reserved, 262144K cma-reserved, 7458816K highmem)
          [    0.000000] Virtual kernel memory layout:
                             vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                             fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                             vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                             lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
                             pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                             modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                               .text : 0x(ptrval) - 0x(ptrval)   (10208 kB)
                               .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
                               .data : 0x(ptrval) - 0x(ptrval)   ( 688 kB)
                                .bss : 0x(ptrval) - 0x(ptrval)   ( 851 kB)
          [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
          [    0.000000] ftrace: allocating 28692 entries in 85 pages
          [    0.000000] rcu: Hierarchical RCU implementation.
          [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
          [    0.000000] GIC: Using split EOI/Deactivate mode
          [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
          [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
          [    0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
          [    0.000021] Switching to timer-based delay loop, resolution 18ns
          [    0.000245] Console: colour dummy device 80x30
          [    0.000696] console [tty1] enabled
          [    0.000753] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
          [    0.000790] pid_max: default: 32768 minimum: 301
          [    0.001072] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
          [    0.001104] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
          [    0.001864] CPU: Testing write buffer coherency: ok
          [    0.002277] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
          [    0.002925] Setting up static identity map for 0x200000 - 0x20003c
          [    0.003097] rcu: Hierarchical SRCU implementation.
          [    0.003963] smp: Bringing up secondary CPUs ...
          [    0.004759] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
          [    0.005673] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
          [    0.006544] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
          [    0.006681] smp: Brought up 1 node, 4 CPUs
          [    0.006748] SMP: Total of 4 processors activated (432.00 BogoMIPS).
          [    0.006771] CPU: All CPU(s) started in HYP mode.
          [    0.006791] CPU: Virtualization extensions available.
          [    0.007577] devtmpfs: initialized
          [    0.017829] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
          [    0.018056] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
          [    0.018097] futex hash table entries: 1024 (order: 4, 65536 bytes)
          [    0.025554] pinctrl core: initialized pinctrl subsystem
          [    0.026405] NET: Registered protocol family 16
          [    0.029087] DMA: preallocated 1024 KiB pool for atomic coherent allocations
          [    0.030524] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
          [    0.030556] hw-breakpoint: maximum watchpoint size is 8 bytes.
          [    0.030755] Serial: AMBA PL011 UART driver
          [    0.033961] bcm2835-mbox fe00b880.mailbox: mailbox enabled
          [    0.050023] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-02-12 12:36, variant start
          [    0.060038] raspberrypi-firmware soc:firmware: Firmware hash is c3c8dbdf147686fb0c3f32aece709d0653368810
          [    0.103011] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
          [    0.106215] vgaarb: loaded
          [    0.106576] SCSI subsystem initialized
          [    0.106791] usbcore: registered new interface driver usbfs
          [    0.106857] usbcore: registered new interface driver hub
          [    0.106940] usbcore: registered new device driver usb
          [    0.108161] clocksource: Switched to clocksource arch_sys_counter
          [    0.186604] VFS: Disk quotas dquot_6.6.0
          [    0.186708] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
          [    0.186865] FS-Cache: Loaded
          [    0.187048] CacheFiles: Loaded
          [    0.187574] simple-framebuffer: probe of 0.framebuffer failed with error -12
          [    0.196788] NET: Registered protocol family 2
          [    0.197460] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
          [    0.197507] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
          [    0.197587] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
          [    0.197672] TCP: Hash tables configured (established 8192 bind 8192)
          [    0.197800] UDP hash table entries: 512 (order: 2, 16384 bytes)
          [    0.197844] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
          [    0.198076] NET: Registered protocol family 1
          [    0.198661] RPC: Registered named UNIX socket transport module.
          [    0.198687] RPC: Registered udp transport module.
          [    0.198708] RPC: Registered tcp transport module.
          [    0.198730] RPC: Registered tcp NFSv4.1 backchannel transport module.
          [    0.198757] PCI: CLS 0 bytes, default 64
          [    0.201757] Initialise system trusted keyrings
          [    0.201930] workingset: timestamp_bits=14 max_order=21 bucket_order=7
          [    0.210863] FS-Cache: Netfs 'nfs' registered for caching
          [    0.211372] NFS: Registering the id_resolver key type
          [    0.211413] Key type id_resolver registered
          [    0.211435] Key type id_legacy registered
          [    0.211465] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
          [    0.213716] Key type asymmetric registered
          [    0.213741] Asymmetric key parser 'x509' registered
          [    0.213862] bounce: pool size: 64 pages
          [    0.213914] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
          [    0.214098] io scheduler noop registered
          [    0.214121] io scheduler deadline registered (default)
          [    0.214298] io scheduler cfq registered
          [    0.214321] io scheduler mq-deadline registered (default)
          [    0.214344] io scheduler kyber registered
          [    0.237993] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
          [    0.238039] brcm-pcie fd500000.pcie: could not get clock
          [    0.238112] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
          [    0.238198] brcm-pcie fd500000.pcie:   MEM 0x600000000..0x603ffffff -> 0xf8000000
          [    0.298189] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
          [    0.298472] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
          [    0.298503] pci_bus 0000:00: root bus resource [bus 00-01]
          [    0.298533] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
          [    0.298595] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
          [    0.298730] pci 0000:00:00.0: PME# supported from D0 D3hot
          [    0.301454] PCI: bus0: Fast back to back transfers disabled
          [    0.301485] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
          [    0.301706] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
          [    0.301830] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
          [    0.302141] pci 0000:01:00.0: PME# supported from D0 D3hot
          [    0.304865] PCI: bus1: Fast back to back transfers disabled
          [    0.304895] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
          [    0.304941] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
          [    0.304975] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
          [    0.305063] pci 0000:00:00.0: PCI bridge to [bus 01]
          [    0.305091] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
          [    0.305313] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
          [    0.305493] pcieport 0000:00:00.0: Signaling PME with IRQ 54
          [    0.305671] pcieport 0000:00:00.0: AER enabled with IRQ 54
          [    0.305850] pci 0000:01:00.0: enabling device (0140 -> 0142)
          [    0.361427] pci 0000:01:00.0: quirk_usb_early_handoff+0x0/0x7c8 took 54294 usecs
          [    0.364509] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
          [    0.366523] iproc-rng200 fe104000.rng: hwrng registered
          [    0.366761] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
          [    0.367278] vc-sm: Videocore shared memory driver
          [    0.367694] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
          [    0.377692] brd: module loaded
          [    0.387109] loop: module loaded
          [    0.387869] Loading iSCSI transport class v2.0-870.
          [    0.389574] libphy: Fixed MDIO Bus: probed
          [    0.390009] bcmgenet fd580000.genet: failed to get enet clock
          [    0.390041] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
          [    0.390071] bcmgenet fd580000.genet: failed to get enet-wol clock
          [    0.390100] bcmgenet fd580000.genet: failed to get enet-eee clock
          [    0.390136] bcmgenet: Skipping UMAC reset
          [    0.390383] unimac-mdio unimac-mdio.-19: DMA mask not set
          [    0.418188] libphy: bcmgenet MII bus: probed
          [    0.458674] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
          [    0.459585] usbcore: registered new interface driver r8152
          [    0.459665] usbcore: registered new interface driver lan78xx
          [    0.459733] usbcore: registered new interface driver smsc95xx
          [    0.460042] xhci_hcd 0000:01:00.0: xHCI Host Controller
          [    0.460086] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
          [    0.462168] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
          [    0.462498] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 55
          [    0.463359] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
          [    0.463394] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
          [    0.463423] usb usb1: Product: xHCI Host Controller
          [    0.463446] usb usb1: Manufacturer: Linux 4.19.97-v7l+ xhci-hcd
          [    0.463470] usb usb1: SerialNumber: 0000:01:00.0
          [    0.463987] hub 1-0:1.0: USB hub found
          [    0.464079] hub 1-0:1.0: 1 port detected
          [    0.464551] xhci_hcd 0000:01:00.0: xHCI Host Controller
          [    0.464587] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
          [    0.464625] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
          [    0.464971] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
          [    0.465003] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
          [    0.465032] usb usb2: Product: xHCI Host Controller
          [    0.465055] usb usb2: Manufacturer: Linux 4.19.97-v7l+ xhci-hcd
          [    0.465078] usb usb2: SerialNumber: 0000:01:00.0
          [    0.465588] hub 2-0:1.0: USB hub found
          [    0.465655] hub 2-0:1.0: 4 ports detected
          [    0.466800] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
          [    0.467011] dwc_otg: FIQ enabled
          [    0.467021] dwc_otg: NAK holdoff enabled
          [    0.467029] dwc_otg: FIQ split-transaction FSM enabled
          [    0.467042] Module dwc_common_port init
          [    0.467240] usbcore: registered new interface driver uas
          [    0.467350] usbcore: registered new interface driver usb-storage
          [    0.467534] mousedev: PS/2 mouse device common for all mice
          [    0.468765] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
          [    0.470210] sdhci: Secure Digital Host Controller Interface driver
          [    0.470235] sdhci: Copyright(c) Pierre Ossman
          [    0.470637] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
          [    0.471047] sdhci-pltfm: SDHCI platform and OF driver helper
          [    0.474026] ledtrig-cpu: registered to indicate activity on CPUs
          [    0.474196] hidraw: raw HID events driver (C) Jiri Kosina
          [    0.474328] usbcore: registered new interface driver usbhid
          [    0.474350] usbhid: USB HID core driver
          [    0.475065] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
          [    0.476356] [vc_sm_connected_init]: start
          [    0.482479] [vc_sm_connected_init]: end - returning 0
          [    0.483639] Initializing XFRM netlink socket
          [    0.483682] NET: Registered protocol family 17
          [    0.483785] Key type dns_resolver registered
          [    0.484068] Registering SWP/SWPB emulation handler
          [    0.484672] registered taskstats version 1
          [    0.484701] Loading compiled-in X.509 certificates
          [    0.491624] uart-pl011 fe201000.serial: cts_event_workaround enabled
          [    0.491703] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
          [    0.496993] console [ttyS0] disabled
          [    0.497039] fe215040.serial: ttyS0 at MMIO 0x0 (irq = 36, base_baud = 62500000) is a 16550
          [    1.672723] console [ttyS0] enabled
          [    1.676971] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
          [    1.684967] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
          [    1.693312] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
          [    1.699445] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
          [    1.731326] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.3
          [    1.738509] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.4
          [    1.764867] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
          [    1.772092] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
          [    1.779279] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
          [    1.784899] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
          [    1.794914] of_cfs_init
          [    1.795344] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
          [    1.797552] of_cfs_init: OK
          [    1.804663] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
          [    1.811748] Waiting for root device PARTUUID=52e4cf4c-02...
          [    1.860635] random: fast init done
          [    1.910450] mmc0: new ultra high speed DDR50 SDXC card at address aaaa
          [    1.919750] mmcblk0: mmc0:aaaa SR64G 59.5 GiB
          [    1.926773]  mmcblk0: p1 p2
          [    1.930412] mmc1: new high speed SDIO card at address 0001
          [    1.938217] usb 1-1: new high-speed USB device number 2 using xhci_hcd
          [    1.969272] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
          [    1.977536] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [    1.991499] devtmpfs: mounted
          [    2.002158] Freeing unused kernel memory: 2048K
          [    2.008426] Run /sbin/init as init process
          [    2.120849] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
          [    2.129205] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
          [    2.136464] usb 1-1: Product: USB2.0 Hub
          [    2.142150] hub 1-1:1.0: USB hub found
          [    2.146156] hub 1-1:1.0: 4 ports detected
          [    2.478212] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
          [    2.485240] systemd[1]: System time before build time, advancing clock.
          [    2.613489] NET: Registered protocol family 10
          [    2.619235] Segment Routing with IPv6
          [    2.626000] usb 1-1.3: New USB device found, idVendor=0403, idProduct=6015, bcdDevice=10.00
          [    2.634531] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
          [    2.641982] usb 1-1.3: Product: FT230X Basic UART
          [    2.646766] usb 1-1.3: Manufacturer: FTDI
          [    2.650870] usb 1-1.3: SerialNumber: D306MB4E
          [    2.671021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
          [    2.693556] systemd[1]: Detected architecture arm.
          [    2.712519] systemd[1]: Set hostname to <ioBroker-RasPi4>.
          [    3.500142] random: systemd: uninitialized urandom read (16 bytes read)
          [    3.515405] random: systemd: uninitialized urandom read (16 bytes read)
          [    3.522659] systemd[1]: Listening on udev Kernel Socket.
          [    3.528812] random: systemd: uninitialized urandom read (16 bytes read)
          [    3.535831] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
          [    3.544472] systemd[1]: Listening on fsck to fsckd communication Socket.
          [    3.552101] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
          [    3.560597] systemd[1]: Reached target Local Encrypted Volumes.
          [    3.567508] systemd[1]: Listening on udev Control Socket.
          [    3.574280] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
          [    3.792210] Driver for 1-wire Dallas network protocol.
          [    3.802580] gpio-4 (onewire@4): enforced open drain please flag it properly in DT/ACPI DSDT/board file
          [    4.288435] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
          [    4.376231] systemd-journald[119]: Received request to flush runtime journal from PID 1
          [    4.980061] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
          [    5.007459] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
          [    5.021523] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
          [    5.032777] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
          [    5.090975] media: Linux media interface: v0.10
          [    5.152288] videodev: Linux video capture interface: v2.00
          [    5.171883] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
          [    5.176496] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
          [    5.186766] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
          [    5.189514] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
          [    5.194880] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
          [    5.206178] [vc_sm_connected_init]: start
          [    5.238500] [vc_sm_connected_init]: installed successfully
          [    5.257256] bcm2835_audio soc:audio: card created with 8 channels
          [    5.266762] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
          [    5.268877] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
          [    5.295803] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
          [    5.323058] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
          [    5.349600] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
          [    5.358346] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
          [    5.404139] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
          [    5.425871] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
          [    5.459106] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
          [    5.463149] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
          [    5.515906] [drm] No displays found. Consider forcing hotplug if HDMI is attached
          [    5.523723] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
          [    5.551291] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
          [    5.575515] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
          [    5.582382] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
          [    5.589139] [drm] No driver support for vblank timestamp query.
          [    5.595160] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
          [    5.796475] usbcore: registered new interface driver usbserial_generic
          [    5.815088] usbserial: USB Serial support registered for generic
          [    5.936310] usbcore: registered new interface driver ftdi_sio
          [    5.943647] cfg80211: Loading compiled-in X.509 certificates for regulatory database
          [    5.945010] usbserial: USB Serial support registered for FTDI USB Serial Device
          [    5.960488] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
          [    5.968416] usb 1-1.3: Detected FT-X
          [    5.976428] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
          [    6.037897] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
          [    6.087244] brcmfmac: F1 signature read @0x18000000=0x15264345
          [    6.103223] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
          [    6.112370] usbcore: registered new interface driver brcmfmac
          [    6.366001] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
          [    6.395771] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar  2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
          [    6.483145] w1_master_driver w1_bus_master1: w1_search: max_slave_count 64 reached, will continue next search.
          [    7.775530] random: crng init done
          [    7.775543] random: 7 urandom warning(s) missed due to ratelimiting
          [    7.811940] uart-pl011 fe201000.serial: no DMA platform data
          [    7.942947] 8021q: 802.1Q VLAN Support v1.8
          [    8.083481] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
          [    8.262378] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
          [    8.262386] brcmfmac: power management disabled
          [    8.553598] bcmgenet: Skipping UMAC reset
          [    8.648646] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
          [    8.648938] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
          [    9.698288] bcmgenet fd580000.genet eth0: Link is Down
          [   13.848456] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
          [   13.848491] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
          [   14.584014] Bluetooth: Core ver 2.22
          [   14.584085] NET: Registered protocol family 31
          [   14.584096] Bluetooth: HCI device and connection manager initialized
          [   14.584116] Bluetooth: HCI socket layer initialized
          [   14.584131] Bluetooth: L2CAP socket layer initialized
          [   14.584179] Bluetooth: SCO socket layer initialized
          [   14.597286] Bluetooth: HCI UART driver ver 2.3
          [   14.597296] Bluetooth: HCI UART protocol H4 registered
          [   14.597346] Bluetooth: HCI UART protocol Three-wire (H5) registered
          [   14.597499] Bluetooth: HCI UART protocol Broadcom registered
          [   14.755071] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
          [   14.755079] Bluetooth: BNEP filters: protocol multicast
          [   14.755091] Bluetooth: BNEP socket layer initialized
          [   15.769642] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
          [   57.732514] w1_master_driver w1_bus_master1: Attaching one wire slave 00.800000000000 crc 8c
          [   57.737368] w1_master_driver w1_bus_master1: Family 0 for 00.800000000000.8c is not registered.
          [  121.312263] w1_master_driver w1_bus_master1: Attaching one wire slave 00.400000000000 crc 46
          [  121.317207] w1_master_driver w1_bus_master1: Family 0 for 00.400000000000.46 is not registered.
          [  172.053181] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c00000000000 crc ca
          [  172.067785] w1_master_driver w1_bus_master1: Family 0 for 00.c00000000000.ca is not registered.
          [  248.493886] w1_master_driver w1_bus_master1: Attaching one wire slave 00.200000000000 crc 23
          [  248.500946] w1_master_driver w1_bus_master1: Family 0 for 00.200000000000.23 is not registered.
          [  312.095500] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a00000000000 crc af
          [  312.104739] w1_master_driver w1_bus_master1: Family 0 for 00.a00000000000.af is not registered.
          [  350.016150] w1_master_driver w1_bus_master1: Attaching one wire slave 00.600000000000 crc 65
          [  350.025330] w1_master_driver w1_bus_master1: Family 0 for 00.600000000000.65 is not registered.
          [  390.526305] w1_master_driver w1_bus_master1: Attaching one wire slave 00.e00000000000 crc e9
          [  390.531163] w1_master_driver w1_bus_master1: Family 0 for 00.e00000000000.e9 is not registered.
          [  453.507093] w1_master_driver w1_bus_master1: Attaching one wire slave 00.100000000000 crc 9d
          [  453.514153] w1_master_driver w1_bus_master1: Family 0 for 00.100000000000.9d is not registered.
          [  492.617431] w1_master_driver w1_bus_master1: Attaching one wire slave 00.900000000000 crc 11
          [  492.624649] w1_master_driver w1_bus_master1: Family 0 for 00.900000000000.11 is not registered.
          [  567.858996] w1_master_driver w1_bus_master1: Attaching one wire slave 00.500000000000 crc db
          [  567.866252] w1_master_driver w1_bus_master1: Family 0 for 00.500000000000.db is not registered.
          [  619.820139] w1_master_driver w1_bus_master1: Attaching one wire slave 00.d00000000000 crc 57
          [  619.827385] w1_master_driver w1_bus_master1: Family 0 for 00.d00000000000.57 is not registered.
          [  646.270644] w1_master_driver w1_bus_master1: Attaching one wire slave 00.300000000000 crc be
          [  646.277624] w1_master_driver w1_bus_master1: Family 0 for 00.300000000000.be is not registered.
          [  695.661788] w1_master_driver w1_bus_master1: Attaching one wire slave 00.b00000000000 crc 32
          [  695.670899] w1_master_driver w1_bus_master1: Family 0 for 00.b00000000000.32 is not registered.
          [  734.942033] w1_master_driver w1_bus_master1: Attaching one wire slave 00.700000000000 crc f8
          [  734.949091] w1_master_driver w1_bus_master1: Family 0 for 00.700000000000.f8 is not registered.
          [  786.912717] w1_master_driver w1_bus_master1: Attaching one wire slave 00.f00000000000 crc 74
          [  786.919734] w1_master_driver w1_bus_master1: Family 0 for 00.f00000000000.74 is not registered.
          [  849.383473] w1_master_driver w1_bus_master1: Attaching one wire slave 00.080000000000 crc c2
          [  849.390499] w1_master_driver w1_bus_master1: Family 0 for 00.080000000000.c2 is not registered.
          [  902.624093] w1_master_driver w1_bus_master1: Attaching one wire slave 00.880000000000 crc 4e
          [  902.631095] w1_master_driver w1_bus_master1: Family 0 for 00.880000000000.4e is not registered.
          [  940.464498] w1_master_driver w1_bus_master1: Attaching one wire slave 00.480000000000 crc 84
          [  940.471549] w1_master_driver w1_bus_master1: Family 0 for 00.480000000000.84 is not registered.
          [  991.155187] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c80000000000 crc 08
          [  991.162307] w1_master_driver w1_bus_master1: Family 0 for 00.c80000000000.08 is not registered.
          [ 1067.826266] w1_master_driver w1_bus_master1: Attaching one wire slave 00.280000000000 crc e1
          [ 1067.833349] w1_master_driver w1_bus_master1: Family 0 for 00.280000000000.e1 is not registered.
          [ 1131.347515] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a80000000000 crc 6d
          [ 1131.354681] w1_master_driver w1_bus_master1: Family 0 for 00.a80000000000.6d is not registered.
          [ 1194.868837] w1_master_driver w1_bus_master1: Attaching one wire slave 00.680000000000 crc a7
          [ 1194.877854] w1_master_driver w1_bus_master1: Family 0 for 00.680000000000.a7 is not registered.
          [ 1235.289315] w1_master_driver w1_bus_master1: Attaching one wire slave 00.e80000000000 crc 2b
          [ 1235.296348] w1_master_driver w1_bus_master1: Family 0 for 00.e80000000000.2b is not registered.
          [ 1298.440299] w1_master_driver w1_bus_master1: Attaching one wire slave 00.180000000000 crc 5f
          [ 1298.447351] w1_master_driver w1_bus_master1: Family 0 for 00.180000000000.5f is not registered.
          [ 1337.641542] w1_master_driver w1_bus_master1: Attaching one wire slave 00.980000000000 crc d3
          [ 1337.648512] w1_master_driver w1_bus_master1: Family 0 for 00.980000000000.d3 is not registered.
          [ 1386.951603] w1_master_driver w1_bus_master1: Attaching one wire slave 00.580000000000 crc 19
          [ 1386.958745] w1_master_driver w1_bus_master1: Family 0 for 00.580000000000.19 is not registered.
          [ 1438.992327] w1_master_driver w1_bus_master1: Attaching one wire slave 00.d80000000000 crc 95
          [ 1438.999349] w1_master_driver w1_bus_master1: Family 0 for 00.d80000000000.95 is not registered.
          [ 1465.512686] w1_master_driver w1_bus_master1: Attaching one wire slave 00.380000000000 crc 7c
          [ 1465.520042] w1_master_driver w1_bus_master1: Family 0 for 00.380000000000.7c is not registered.
          [ 1514.993339] w1_master_driver w1_bus_master1: Attaching one wire slave 00.b80000000000 crc f0
          [ 1515.001369] w1_master_driver w1_bus_master1: Family 0 for 00.b80000000000.f0 is not registered.
          [ 1579.714169] w1_master_driver w1_bus_master1: Attaching one wire slave 00.780000000000 crc 3a
          [ 1579.721238] w1_master_driver w1_bus_master1: Family 0 for 00.780000000000.3a is not registered.
          [ 1631.754664] w1_master_driver w1_bus_master1: Attaching one wire slave 00.f80000000000 crc b6
          [ 1631.759575] w1_master_driver w1_bus_master1: Family 0 for 00.f80000000000.b6 is not registered.
          [ 1694.395436] w1_master_driver w1_bus_master1: Attaching one wire slave 00.040000000000 crc 61
          [ 1694.400296] w1_master_driver w1_bus_master1: Family 0 for 00.040000000000.61 is not registered.
          [ 1747.716255] w1_master_driver w1_bus_master1: Attaching one wire slave 00.840000000000 crc ed
          [ 1747.723230] w1_master_driver w1_bus_master1: Family 0 for 00.840000000000.ed is not registered.
          [ 1811.157022] w1_master_driver w1_bus_master1: Attaching one wire slave 00.440000000000 crc 27
          [ 1811.164114] w1_master_driver w1_bus_master1: Family 0 for 00.440000000000.27 is not registered.
          [ 1861.917821] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c40000000000 crc ab
          [ 1861.926494] w1_master_driver w1_bus_master1: Family 0 for 00.c40000000000.ab is not registered.
          [ 1886.847913] w1_master_driver w1_bus_master1: Attaching one wire slave 00.240000000000 crc 42
          [ 1886.854887] w1_master_driver w1_bus_master1: Family 0 for 00.240000000000.42 is not registered.
          [ 1950.448682] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a40000000000 crc ce
          [ 1950.455723] w1_master_driver w1_bus_master1: Family 0 for 00.a40000000000.ce is not registered.
          [ 1977.919000] w1_master_driver w1_bus_master1: Attaching one wire slave 00.640000000000 crc 04
          [ 1977.926034] w1_master_driver w1_bus_master1: Family 0 for 00.640000000000.04 is not registered.
          [ 2028.679594] w1_master_driver w1_bus_master1: Attaching one wire slave 00.e40000000000 crc 88
          [ 2028.686627] w1_master_driver w1_bus_master1: Family 0 for 00.e40000000000.88 is not registered.
          [ 2092.160809] w1_master_driver w1_bus_master1: Attaching one wire slave 00.140000000000 crc fc
          [ 2092.167974] w1_master_driver w1_bus_master1: Family 0 for 00.140000000000.fc is not registered.
          [ 2131.281750] w1_master_driver w1_bus_master1: Attaching one wire slave 00.940000000000 crc 70
          [ 2131.289075] w1_master_driver w1_bus_master1: Family 0 for 00.940000000000.70 is not registered.
          [ 2206.393257] w1_master_driver w1_bus_master1: Attaching one wire slave 00.540000000000 crc ba
          [ 2206.398120] w1_master_driver w1_bus_master1: Family 0 for 00.540000000000.ba is not registered.
          [ 2258.325080] w1_master_driver w1_bus_master1: Attaching one wire slave 00.d40000000000 crc 36
          [ 2258.332144] w1_master_driver w1_bus_master1: Family 0 for 00.d40000000000.36 is not registered.
          [ 2335.966143] w1_master_driver w1_bus_master1: Attaching one wire slave 00.340000000000 crc df
          [ 2335.973204] w1_master_driver w1_bus_master1: Family 0 for 00.340000000000.df is not registered.
          [ 2385.367116] w1_master_driver w1_bus_master1: Attaching one wire slave 00.b40000000000 crc 53
          [ 2385.375129] w1_master_driver w1_bus_master1: Family 0 for 00.b40000000000.53 is not registered.
          [ 2424.487854] w1_master_driver w1_bus_master1: Attaching one wire slave 00.740000000000 crc 99
          [ 2424.494888] w1_master_driver w1_bus_master1: Family 0 for 00.740000000000.99 is not registered.
          [ 2476.448824] w1_master_driver w1_bus_master1: Attaching one wire slave 00.f40000000000 crc 15
          [ 2476.455898] w1_master_driver w1_bus_master1: Family 0 for 00.f40000000000.15 is not registered.
          [ 2539.249958] w1_master_driver w1_bus_master1: Attaching one wire slave 00.0c0000000000 crc a3
          [ 2539.257099] w1_master_driver w1_bus_master1: Family 0 for 00.0c0000000000.a3 is not registered.
          [ 2592.490897] w1_master_driver w1_bus_master1: Attaching one wire slave 00.8c0000000000 crc 2f
          [ 2592.502233] w1_master_driver w1_bus_master1: Family 0 for 00.8c0000000000.2f is not registered.
          [ 2630.501521] w1_master_driver w1_bus_master1: Attaching one wire slave 00.4c0000000000 crc e5
          [ 2630.508591] w1_master_driver w1_bus_master1: Family 0 for 00.4c0000000000.e5 is not registered.
          [ 2681.172359] w1_master_driver w1_bus_master1: Attaching one wire slave 00.cc0000000000 crc 69
          [ 2681.179452] w1_master_driver w1_bus_master1: Family 0 for 00.cc0000000000.69 is not registered.
          [ 2706.012775] w1_master_driver w1_bus_master1: Attaching one wire slave 00.2c0000000000 crc 80
          [ 2706.020091] w1_master_driver w1_bus_master1: Family 0 for 00.2c0000000000.80 is not registered.
          [ 2769.533801] w1_master_driver w1_bus_master1: Attaching one wire slave 00.ac0000000000 crc 0c
          [ 2769.540895] w1_master_driver w1_bus_master1: Family 0 for 00.ac0000000000.0c is not registered.
          [ 2822.934673] w1_master_driver w1_bus_master1: Attaching one wire slave 00.6c0000000000 crc c6
          [ 2822.941670] w1_master_driver w1_bus_master1: Family 0 for 00.6c0000000000.c6 is not registered.
          [ 2873.615431] w1_master_driver w1_bus_master1: Attaching one wire slave 00.ec0000000000 crc 4a
          [ 2873.622407] w1_master_driver w1_bus_master1: Family 0 for 00.ec0000000000.4a is not registered.
          [ 2936.936399] w1_master_driver w1_bus_master1: Attaching one wire slave 00.1c0000000000 crc 3e
          [ 2936.943476] w1_master_driver w1_bus_master1: Family 0 for 00.1c0000000000.3e is not registered.
          [ 2976.137036] w1_master_driver w1_bus_master1: Attaching one wire slave 00.9c0000000000 crc b2
          [ 2976.144060] w1_master_driver w1_bus_master1: Family 0 for 00.9c0000000000.b2 is not registered.
          [ 3025.617928] w1_master_driver w1_bus_master1: Attaching one wire slave 00.5c0000000000 crc 78
          [ 3025.627034] w1_master_driver w1_bus_master1: Family 0 for 00.5c0000000000.78 is not registered.
          [ 3077.668497] w1_master_driver w1_bus_master1: Attaching one wire slave 00.dc0000000000 crc f4
          [ 3077.675534] w1_master_driver w1_bus_master1: Family 0 for 00.dc0000000000.f4 is not registered.
          [ 3155.059624] w1_master_driver w1_bus_master1: Attaching one wire slave 00.3c0000000000 crc 1d
          [ 3155.066649] w1_master_driver w1_bus_master1: Family 0 for 00.3c0000000000.1d is not registered.
          [ 3204.540547] w1_master_driver w1_bus_master1: Attaching one wire slave 00.bc0000000000 crc 91
          [ 3204.549472] w1_master_driver w1_bus_master1: Family 0 for 00.bc0000000000.91 is not registered.
          [ 3269.421236] w1_master_driver w1_bus_master1: Attaching one wire slave 00.7c0000000000 crc 5b
          [ 3269.428361] w1_master_driver w1_bus_master1: Family 0 for 00.7c0000000000.5b is not registered.
          [ 3321.492078] w1_master_driver w1_bus_master1: Attaching one wire slave 00.fc0000000000 crc d7
          [ 3321.499051] w1_master_driver w1_bus_master1: Family 0 for 00.fc0000000000.d7 is not registered.
          [ 3345.302473] w1_master_driver w1_bus_master1: Attaching one wire slave 00.020000000000 crc bc
          [ 3345.311525] w1_master_driver w1_bus_master1: Family 0 for 00.020000000000.bc is not registered.
          [ 3384.422867] w1_master_driver w1_bus_master1: Attaching one wire slave 00.820000000000 crc 30
          [ 3384.429788] w1_master_driver w1_bus_master1: Family 0 for 00.820000000000.30 is not registered.
          [ 3449.383755] w1_master_driver w1_bus_master1: Attaching one wire slave 00.420000000000 crc fa
          [ 3449.390739] w1_master_driver w1_bus_master1: Family 0 for 00.420000000000.fa is not registered.
          [ 3501.344474] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c20000000000 crc 76
          [ 3501.351463] w1_master_driver w1_bus_master1: Family 0 for 00.c20000000000.76 is not registered.
          [ 3589.105681] w1_master_driver w1_bus_master1: Attaching one wire slave 00.220000000000 crc 9f
          [ 3589.112739] w1_master_driver w1_bus_master1: Family 0 for 00.220000000000.9f is not registered.
          [ 3628.226195] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a20000000000 crc 13
          [ 3628.233189] w1_master_driver w1_bus_master1: Family 0 for 00.a20000000000.13 is not registered.
          [ 3667.506725] w1_master_driver w1_bus_master1: Attaching one wire slave 00.620000000000 crc d9
          [ 3667.514665] w1_master_driver w1_bus_master1: Family 0 for 00.620000000000.d9 is not registered.
          [ 3729.747569] w1_master_driver w1_bus_master1: Attaching one wire slave 00.e20000000000 crc 55
          [ 3729.754603] w1_master_driver w1_bus_master1: Family 0 for 00.e20000000000.55 is not registered.
          [ 3769.308108] w1_master_driver w1_bus_master1: Attaching one wire slave 00.120000000000 crc 21
          [ 3769.315193] w1_master_driver w1_bus_master1: Family 0 for 00.120000000000.21 is not registered.
          [ 3832.918953] w1_master_driver w1_bus_master1: Attaching one wire slave 00.920000000000 crc ad
          [ 3832.925928] w1_master_driver w1_bus_master1: Family 0 for 00.920000000000.ad is not registered.
          [ 3896.509793] w1_master_driver w1_bus_master1: Attaching one wire slave 00.520000000000 crc 67
          [ 3896.516825] w1_master_driver w1_bus_master1: Family 0 for 00.520000000000.67 is not registered.
          [ 3947.270460] w1_master_driver w1_bus_master1: Attaching one wire slave 00.d20000000000 crc eb
          [ 3947.277509] w1_master_driver w1_bus_master1: Family 0 for 00.d20000000000.eb is not registered.
          [ 3961.750661] w1_master_driver w1_bus_master1: Attaching one wire slave 00.320000000000 crc 02
          [ 3961.757699] w1_master_driver w1_bus_master1: Family 0 for 00.320000000000.02 is not registered.
          [ 4025.351514] w1_master_driver w1_bus_master1: Attaching one wire slave 00.b20000000000 crc 8e
          [ 4025.358538] w1_master_driver w1_bus_master1: Family 0 for 00.b20000000000.8e is not registered.
          [ 4063.272009] w1_master_driver w1_bus_master1: Attaching one wire slave 00.720000000000 crc 44
          [ 4063.279050] w1_master_driver w1_bus_master1: Family 0 for 00.720000000000.44 is not registered.
          [ 4114.032886] w1_master_driver w1_bus_master1: Attaching one wire slave 00.f20000000000 crc c8
          [ 4114.039840] w1_master_driver w1_bus_master1: Family 0 for 00.f20000000000.c8 is not registered.
          [ 4190.235350] w1_master_driver w1_bus_master1: Attaching one wire slave 00.0a0000000000 crc 7e
          [ 4190.242318] w1_master_driver w1_bus_master1: Family 0 for 00.0a0000000000.7e is not registered.
          [ 4229.436551] w1_master_driver w1_bus_master1: Attaching one wire slave 00.8a0000000000 crc f2
          [ 4229.443576] w1_master_driver w1_bus_master1: Family 0 for 00.8a0000000000.f2 is not registered.
          [ 4268.487700] w1_master_driver w1_bus_master1: Attaching one wire slave 00.4a0000000000 crc 38
          [ 4268.494739] w1_master_driver w1_bus_master1: Family 0 for 00.4a0000000000.38 is not registered.
          [ 4320.519156] w1_master_driver w1_bus_master1: Attaching one wire slave 00.ca0000000000 crc b4
          [ 4320.526176] w1_master_driver w1_bus_master1: Family 0 for 00.ca0000000000.b4 is not registered.
          [ 4408.361506] w1_master_driver w1_bus_master1: Attaching one wire slave 00.2a0000000000 crc 5d
          [ 4408.368476] w1_master_driver w1_bus_master1: Family 0 for 00.2a0000000000.5d is not registered.
          [ 4447.562756] w1_master_driver w1_bus_master1: Attaching one wire slave 00.aa0000000000 crc d1
          [ 4447.571855] w1_master_driver w1_bus_master1: Family 0 for 00.aa0000000000.d1 is not registered.
          [ 4512.284080] w1_master_driver w1_bus_master1: Attaching one wire slave 00.6a0000000000 crc 1b
          [ 4512.291113] w1_master_driver w1_bus_master1: Family 0 for 00.6a0000000000.1b is not registered.
          [ 4574.605515] w1_master_driver w1_bus_master1: Attaching one wire slave 00.ea0000000000 crc 97
          [ 4574.612578] w1_master_driver w1_bus_master1: Family 0 for 00.ea0000000000.97 is not registered.
          [ 4614.326517] w1_master_driver w1_bus_master1: Attaching one wire slave 00.1a0000000000 crc e3
          [ 4614.333605] w1_master_driver w1_bus_master1: Family 0 for 00.1a0000000000.e3 is not registered.
          [ 4677.857791] w1_master_driver w1_bus_master1: Attaching one wire slave 00.9a0000000000 crc 6f
          [ 4677.864889] w1_master_driver w1_bus_master1: Family 0 for 00.9a0000000000.6f is not registered.
          [ 4715.688605] w1_master_driver w1_bus_master1: Attaching one wire slave 00.5a0000000000 crc a5
          [ 4715.695627] w1_master_driver w1_bus_master1: Family 0 for 00.5a0000000000.a5 is not registered.
          [ 4766.369663] w1_master_driver w1_bus_master1: Attaching one wire slave 00.da0000000000 crc 29
          [ 4766.376621] w1_master_driver w1_bus_master1: Family 0 for 00.da0000000000.29 is not registered.
          [ 4781.089955] w1_master_driver w1_bus_master1: Attaching one wire slave 00.3a0000000000 crc c0
          [ 4781.096929] w1_master_driver w1_bus_master1: Family 0 for 00.3a0000000000.c0 is not registered.
          [ 4844.611280] w1_master_driver w1_bus_master1: Attaching one wire slave 00.ba0000000000 crc 4c
          [ 4844.618316] w1_master_driver w1_bus_master1: Family 0 for 00.ba0000000000.4c is not registered.
          [ 4908.132460] w1_master_driver w1_bus_master1: Attaching one wire slave 00.7a0000000000 crc 86
          [ 4908.139483] w1_master_driver w1_bus_master1: Family 0 for 00.7a0000000000.86 is not registered.
          [ 4958.813419] w1_master_driver w1_bus_master1: Attaching one wire slave 00.fa0000000000 crc 0a
          [ 4958.820452] w1_master_driver w1_bus_master1: Family 0 for 00.fa0000000000.0a is not registered.
          [ 5035.015002] w1_master_driver w1_bus_master1: Attaching one wire slave 00.060000000000 crc dd
          [ 5035.023949] w1_master_driver w1_bus_master1: Family 0 for 00.060000000000.dd is not registered.
          [ 5074.135566] w1_master_driver w1_bus_master1: Attaching one wire slave 00.860000000000 crc 51
          [ 5074.142601] w1_master_driver w1_bus_master1: Family 0 for 00.860000000000.51 is not registered.
          [ 5138.936726] w1_master_driver w1_bus_master1: Attaching one wire slave 00.460000000000 crc 9b
          [ 5138.943704] w1_master_driver w1_bus_master1: Family 0 for 00.460000000000.9b is not registered.
          [ 5190.897637] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c60000000000 crc 17
          [ 5190.904615] w1_master_driver w1_bus_master1: Family 0 for 00.c60000000000.17 is not registered.
          [ 5227.778326] w1_master_driver w1_bus_master1: Attaching one wire slave 00.260000000000 crc fe
          [ 5227.785397] w1_master_driver w1_bus_master1: Family 0 for 00.260000000000.fe is not registered.
          [ 5266.898976] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a60000000000 crc 72
          [ 5266.905956] w1_master_driver w1_bus_master1: Family 0 for 00.a60000000000.72 is not registered.
          [ 5306.019647] w1_master_driver w1_bus_master1: Attaching one wire slave 00.660000000000 crc b8
          [ 5306.026728] w1_master_driver w1_bus_master1: Family 0 for 00.660000000000.b8 is not registered.
          [ 5368.260695] w1_master_driver w1_bus_master1: Attaching one wire slave 00.e60000000000 crc 34
          [ 5368.267715] w1_master_driver w1_bus_master1: Family 0 for 00.e60000000000.34 is not registered.
          [ 5407.661469] w1_master_driver w1_bus_master1: Attaching one wire slave 00.160000000000 crc 40
          [ 5407.669206] w1_master_driver w1_bus_master1: Family 0 for 00.160000000000.40 is not registered.
          [ 5471.262420] w1_master_driver w1_bus_master1: Attaching one wire slave 00.960000000000 crc cc
          [ 5471.269432] w1_master_driver w1_bus_master1: Family 0 for 00.960000000000.cc is not registered.
          [ 5534.703467] w1_master_driver w1_bus_master1: Attaching one wire slave 00.560000000000 crc 06
          [ 5534.710425] w1_master_driver w1_bus_master1: Family 0 for 00.560000000000.06 is not registered.
          [ 5585.464321] w1_master_driver w1_bus_master1: Attaching one wire slave 00.d60000000000 crc 8a
          [ 5585.471350] w1_master_driver w1_bus_master1: Family 0 for 00.d60000000000.8a is not registered.
          [ 5651.785448] w1_master_driver w1_bus_master1: Attaching one wire slave 00.360000000000 crc 63
          [ 5651.792460] w1_master_driver w1_bus_master1: Family 0 for 00.360000000000.63 is not registered.
          [ 5715.386416] w1_master_driver w1_bus_master1: Attaching one wire slave 00.b60000000000 crc ef
          [ 5715.393434] w1_master_driver w1_bus_master1: Family 0 for 00.b60000000000.ef is not registered.
          [ 5753.147023] w1_master_driver w1_bus_master1: Attaching one wire slave 00.760000000000 crc 25
          [ 5753.154056] w1_master_driver w1_bus_master1: Family 0 for 00.760000000000.25 is not registered.
          [ 5803.907823] w1_master_driver w1_bus_master1: Attaching one wire slave 00.f60000000000 crc a9
          [ 5803.914805] w1_master_driver w1_bus_master1: Family 0 for 00.f60000000000.a9 is not registered.
          [ 5879.789235] w1_master_driver w1_bus_master1: Attaching one wire slave 00.0e0000000000 crc 1f
          [ 5879.798295] w1_master_driver w1_bus_master1: Family 0 for 00.0e0000000000.1f is not registered.
          [ 5918.989663] w1_master_driver w1_bus_master1: Attaching one wire slave 00.8e0000000000 crc 93
          [ 5918.996671] w1_master_driver w1_bus_master1: Family 0 for 00.8e0000000000.93 is not registered.
          [ 5958.190374] w1_master_driver w1_bus_master1: Attaching one wire slave 00.4e0000000000 crc 59
          [ 5958.197364] w1_master_driver w1_bus_master1: Family 0 for 00.4e0000000000.59 is not registered.
          [ 6020.511610] w1_master_driver w1_bus_master1: Attaching one wire slave 00.ce0000000000 crc d5
          [ 6020.520667] w1_master_driver w1_bus_master1: Family 0 for 00.ce0000000000.d5 is not registered.
          [ 6046.871686] w1_master_driver w1_bus_master1: Attaching one wire slave 00.2e0000000000 crc 3c
          [ 6046.878702] w1_master_driver w1_bus_master1: Family 0 for 00.2e0000000000.3c is not registered.
          [ 6086.072296] w1_master_driver w1_bus_master1: Attaching one wire slave 00.ae0000000000 crc b0
          [ 6086.079302] w1_master_driver w1_bus_master1: Family 0 for 00.ae0000000000.b0 is not registered.
          [ 6150.953327] w1_master_driver w1_bus_master1: Attaching one wire slave 00.6e0000000000 crc 7a
          [ 6150.960556] w1_master_driver w1_bus_master1: Family 0 for 00.6e0000000000.7a is not registered.
          [ 6213.305014] w1_master_driver w1_bus_master1: Attaching one wire slave 00.ee0000000000 crc f6
          [ 6213.310194] w1_master_driver w1_bus_master1: Family 0 for 00.ee0000000000.f6 is not registered.
          • SMSS SMS
            @SMS
            sudo apt update
            sudo apt dist-upgrade
            sudo reboot
              @SMS
              sudo apt update
              sudo reboot
              SMSS Offline
              SMSS Offline
              SMS
              @Thomas-Braun woran sieht man das bzw. was ist passiert?
              • SMSS SMS
                @SMS
                Was meinst du?
                Ich vermute, dass das System schon geraume Zeit keine Updates mehr gesehen hat.
                Und der Treiber für onewire läuft da etwas aus dem Ruder. Brauchst du den?
                Was ist das überhaupt da für Hardware?
                  @SMS
                  Was meinst du?
                  SMSS Offline
                  SMSS Offline
                  SMS
                  @Thomas-Braun
                  Leider unverändert.
                  Welche Hardware meinst du? Ich habe teilweise Adapter ausprobiert, aber nicht am laufen da sich nicht funktioniert haben.
                  Onewire brauche ich nicht mehr.
                  SMSS Thomas BraunT 2 Antworten Letzte Antwort
                  • SMSS SMS
                    @Thomas-Braun
                    Leider unverändert.
                    SMSS Offline
                    SMSS Offline
                    SMS
                    [    0.000000] Linux version 5.4.72-v7l+ (dom@buildbot) (gcc version 9.3.0 (Ubun        tu 9.3.0-17ubuntu1~20.04)) #1356 SMP Thu Oct 22 13:57:51 BST 2020
                    [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, s        ize 256 MiB
                    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id share        d-dma-pool
                    [    0.000000]   DMA zone: 2304 pages used for memmap
                    [    0.000000] percpu: Embedded 20 pages/cpu s49804 r8192 d23924 u81920
                    [    0.000000] pcpu-alloc: s49804 r8192 d23924 u81920 alloc=20*4096
                    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2059008
                    [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835        .enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1        smsc95xx.macaddr=DC:A6:32:B6:0D:F1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0        x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=        52e4cf4c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes,        linear)
                    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, li        near)
                    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
                    [    0.000000] software IO TLB: mapped [mem 0x14c00000-0x18c00000] (64MB)
                    [    0.000000] Memory: 7800748K/8245248K available (10240K kernel code, 745K rwd        ata, 2836K rodata, 2048K init, 856K bss, 182356K reserved, 262144K cma-reserved,        7458816K highmem)
                    [    0.000000] ftrace: allocating 31086 entries in 61 pages
                    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jif        fies.
                    [    0.000000] random: get_random_bytes called from start_kernel+0x338/0x520 wit        h crng_init=0
                    [    0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2        147483647500ns
                    [    0.000031] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_        idle_ns: 1911260446275 ns
                    [    0.000110] bcm2835: system timer (irq = 17)
                    [    0.000757] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                    [    0.000776] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:        0xc743ce346, max_idle_ns: 440795203123 ns
                    [    0.000795] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 43980        46511102ns
                    [    0.000811] Switching to timer-based delay loop, resolution 18ns
                    [    0.001044] Console: colour dummy device 80x30
                    [    0.001547] printk: console [tty1] enabled
                    [    0.001613] Calibrating delay loop (skipped), value calculated using timer fr        equency.. 108.00 BogoMIPS (lpj=540000)
                    [    0.001655] pid_max: default: 32768 minimum: 301
                    [    0.001817] LSM: Security Framework initializing
                    [    0.002016] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linea        r)
                    [    0.002056] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes,        linear)
                    [    0.003302] Disabling memory control group subsystem
                    [    0.003439] CPU: Testing write buffer coherency: ok
                    [    0.003947] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                    [    0.004861] Setting up static identity map for 0x200000 - 0x20003c
                    [    0.005080] rcu: Hierarchical SRCU implementation.
                    [    0.005757] smp: Bringing up secondary CPUs ...
                    [    0.006920] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                    [    0.008194] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                    [    0.009415] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                    [    0.009571] smp: Brought up 1 node, 4 CPUs
                    [    0.009643] SMP: Total of 4 processors activated (432.00 BogoMIPS).
                    [    0.009670] CPU: All CPU(s) started in HYP mode.
                    [    0.009694] CPU: Virtualization extensions available.
                    [    0.010510] devtmpfs: initialized
                    [    0.024036] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8        rev 0
                    [    0.024317] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma        x_idle_ns: 19112604462750000 ns
                    [    0.024367] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                    [    0.031059] pinctrl core: initialized pinctrl subsystem
                    [    0.032067] NET: Registered protocol family 16
                    [    0.035690] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                    [    0.036298] audit: initializing netlink subsys (disabled)
                    [    0.036562] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=        0 res=1
                    [    0.037637] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint        registers.
                    [    0.037673] hw-breakpoint: maximum watchpoint size is 8 bytes.
                    [    0.038000] Serial: AMBA PL011 UART driver
                    [    0.041725] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                    [    0.060833] raspberrypi-firmware soc:firmware: Attached to firmware from 2020        -10-22 13:59, variant start
                    [    0.070849] raspberrypi-firmware soc:firmware: Firmware hash is 74e754ff8947c        58d2773253f77f6f68a303188f8
                    [    0.126033] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                    [    0.131003] vgaarb: loaded
                    [    0.131473] SCSI subsystem initialized
                    [    0.131690] usbcore: registered new interface driver usbfs
                    [    0.131774] usbcore: registered new interface driver hub
                    [    0.131909] usbcore: registered new device driver usb
                    [    0.132256] usb_phy_generic phy: phy supply vcc not found, using dummy regula        tor
                    [    0.134039] clocksource: Switched to clocksource arch_sys_counter
                    [    0.840057] VFS: Disk quotas dquot_6.6.0
                    [    0.840179] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                    [    0.840370] FS-Cache: Loaded
                    [    0.840583] CacheFiles: Loaded
                    [    0.850821] thermal_sys: Registered thermal governor 'step_wise'
                    [    0.851176] NET: Registered protocol family 2
                    [    0.851943] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144        bytes, linear)
                    [    0.851997] TCP established hash table entries: 8192 (order: 3, 32768 bytes,        linear)
                    [    0.852073] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
                    [    0.852154] TCP: Hash tables configured (established 8192 bind 8192)
                    [    0.852306] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
                    [    0.852358] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
                    [    0.852627] NET: Registered protocol family 1
                    [    0.853351] RPC: Registered named UNIX socket transport module.
                    [    0.853381] RPC: Registered udp transport module.
                    [    0.853406] RPC: Registered tcp transport module.
                    [    0.853431] RPC: Registered tcp NFSv4.1 backchannel transport module.
                    [    0.853466] PCI: CLS 0 bytes, default 64
                    [    0.855569] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counte        rs available
                    [    0.857755] Initialise system trusted keyrings
                    [    0.858044] workingset: timestamp_bits=14 max_order=21 bucket_order=7
                    [    0.868762] FS-Cache: Netfs 'nfs' registered for caching
                    [    0.869537] NFS: Registering the id_resolver key type
                    [    0.869587] Key type id_resolver registered
                    [    0.869613] Key type id_legacy registered
                    [    0.869649] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                    [    0.870778] Key type asymmetric registered
                    [    0.870807] Asymmetric key parser 'x509' registered
                    [    0.871010] bounce: pool size: 64 pages
                    [    0.871074] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2        49)
                    [    0.871314] io scheduler mq-deadline registered
                    [    0.871343] io scheduler kyber registered
                    [    0.875291] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                    [    0.875335] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500        000, using [bus 00-ff]
                    [    0.875427] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x0603ffffff -> 0        x00f8000000
                    [    0.875518] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0        x0000000000
                    [    0.936160] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
                    [    0.936492] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                    [    0.936526] pci_bus 0000:00: root bus resource [bus 00-ff]
                    [    0.936561] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff]        (bus address [0xf8000000-0xfbffffff])
                    [    0.936640] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                    [    0.936920] pci 0000:00:00.0: PME# supported from D0 D3hot
                    [    0.940215] PCI: bus0: Fast back to back transfers disabled
                    [    0.940460] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                    [    0.940623] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                    [    0.941071] pci 0000:01:00.0: PME# supported from D0 D3hot
                    [    0.944412] PCI: bus1: Fast back to back transfers disabled
                    [    0.944487] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                    [    0.944525] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64        bit]
                    [    0.944625] pci 0000:00:00.0: PCI bridge to [bus 01]
                    [    0.944663] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                    [    0.944989] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                    [    0.945260] pcieport 0000:00:00.0: PME: Signaling with IRQ 56
                    [    0.945657] pcieport 0000:00:00.0: AER: enabled with IRQ 56
                    [    0.946011] pci 0000:01:00.0: enabling device (0140 -> 0142)
                    [    0.990964] pci 0000:01:00.0: quirk_usb_early_handoff+0x0/0x7dc took 43920 us        ecs
                    [    0.995382] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
                    [    0.998468] iproc-rng200 fe104000.rng: hwrng registered
                    [    0.998829] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000        000(1024 MiB)
                    [    0.999500] vc-sm: Videocore shared memory driver
                    [    1.000116] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe2        00000
                    [    1.012051] brd: module loaded
                    [    1.024198] loop: module loaded
                    [    1.025632] Loading iSCSI transport class v2.0-870.
                    [    1.027598] libphy: Fixed MDIO Bus: probed
                    [    1.028232] bcmgenet fd580000.ethernet: failed to get enet clock
                    [    1.028268] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                    [    1.028305] bcmgenet fd580000.ethernet: failed to get enet-wol clock
                    [    1.028342] bcmgenet fd580000.ethernet: failed to get enet-eee clock
                    [    1.028384] bcmgenet: Skipping UMAC reset
                    [    1.044081] libphy: bcmgenet MII bus: probed
                    [    1.124159] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                    [    1.125175] usbcore: registered new interface driver r8152
                    [    1.125254] usbcore: registered new interface driver lan78xx
                    [    1.125341] usbcore: registered new interface driver smsc95xx
                    [    1.125778] xhci_hcd 0000:01:00.0: xHCI Host Controller
                    [    1.125827] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe        r 1
                    [    1.128321] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 qu        irks 0x0000001000000890
                    [    1.129626] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc        dDevice= 5.04
                    [    1.129666] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
                    [    1.129700] usb usb1: Product: xHCI Host Controller
                    [    1.129728] usb usb1: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
                    [    1.129757] usb usb1: SerialNumber: 0000:01:00.0
                    [    1.130374] hub 1-0:1.0: USB hub found
                    [    1.130486] hub 1-0:1.0: 1 port detected
                    [    1.131057] xhci_hcd 0000:01:00.0: xHCI Host Controller
                    [    1.131099] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe        r 2
                    [    1.131142] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                    [    1.131657] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bc        dDevice= 5.04
                    [    1.131695] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
                    [    1.131729] usb usb2: Product: xHCI Host Controller
                    [    1.131757] usb usb2: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
                    [    1.131786] usb usb2: SerialNumber: 0000:01:00.0
                    [    1.132380] hub 2-0:1.0: USB hub found
                    [    1.132465] hub 2-0:1.0: 4 ports detected
                    [    1.133954] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                    [    1.134332] dwc_otg: FIQ enabled
                    [    1.134345] dwc_otg: NAK holdoff enabled
                    [    1.134358] dwc_otg: FIQ split-transaction FSM enabled
                    [    1.134373] Module dwc_common_port init
                    [    1.134806] usbcore: registered new interface driver uas
                    [    1.134925] usbcore: registered new interface driver usb-storage
                    [    1.135144] mousedev: PS/2 mouse device common for all mice
                    [    1.137026] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                    [    1.140480] sdhci: Secure Digital Host Controller Interface driver
                    [    1.140510] sdhci: Copyright(c) Pierre Ossman
                    [    1.141148] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
                    [    1.141745] sdhci-pltfm: SDHCI platform and OF driver helper
                    [    1.145533] ledtrig-cpu: registered to indicate activity on CPUs
                    [    1.145856] hidraw: raw HID events driver (C) Jiri Kosina
                    [    1.146065] usbcore: registered new interface driver usbhid
                    [    1.146093] usbhid: USB HID core driver
                    [    1.147086] vchiq: vchiq_init_state: slot_zero = (ptrval)
                    [    1.148629] [vc_sm_connected_init]: start
                    [    1.154809] [vc_sm_connected_init]: end - returning 0
                    [    1.157056] Initializing XFRM netlink socket
                    [    1.157110] NET: Registered protocol family 17
                    [    1.157242] Key type dns_resolver registered
                    [    1.157643] Registering SWP/SWPB emulation handler
                    [    1.157956] registered taskstats version 1
                    [    1.157989] Loading compiled-in X.509 certificates
                    [    1.158550] Key type ._fscrypt registered
                    [    1.158577] Key type .fscrypt registered
                    [    1.169116] uart-pl011 fe201000.serial: cts_event_workaround enabled
                    [    1.169219] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud        = 0) is a PL011 rev2
                    [    1.175778] printk: console [ttyS0] disabled
                    [    1.175872] fe215040.serial: ttyS0 at MMIO 0x0 (irq = 30, base_baud = 6250000        0) is a 16550
                    [    2.401175] printk: console [ttyS0] enabled
                    [    2.407455] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains drive        r
                    [    2.415815] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                    [    2.421931] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                    [    2.478339] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                    [    2.485602] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                    [    2.492845] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                    [    2.498500] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using A        DMA
                    [    2.509184] of_cfs_init
                    [    2.511790] of_cfs_init: OK
                    [    2.516877] Waiting for root device PARTUUID=52e4cf4c-02...
                    [    2.525239] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                    [    2.532540] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                    [    2.581674] random: fast init done
                    [    2.632858] mmc1: new high speed SDIO card at address 0001
                    [    2.650522] mmc0: new ultra high speed DDR50 SDXC card at address aaaa
                    [    2.658023] mmcblk0: mmc0:aaaa SR64G 59.5 GiB
                    [    2.664097] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                    [    2.670937]  mmcblk0: p1 p2
                    [    2.706254] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O        pts: (null)
                    [    2.714586] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                    [    2.728174] devtmpfs: mounted
                    [    2.739895] Freeing unused kernel memory: 2048K
                    [    2.744833] Run /sbin/init as init process
                    [    2.856708] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcd        Device= 4.21
                    [    2.865099] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                    [    2.872360] usb 1-1: Product: USB2.0 Hub
                    [    2.878555] hub 1-1:1.0: USB hub found
                    [    2.883100] hub 1-1:1.0: 4 ports detected
                    [    3.214279] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
                    [    3.243009] systemd[1]: System time before build time, advancing clock.
                    [    3.369143] NET: Registered protocol family 10
                    [    3.372114] usb 1-1.3: New USB device found, idVendor=0403, idProduct=6015, b        cdDevice=10.00
                    [    3.382214] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber        =3
                    [    3.384816] Segment Routing with IPv6
                    [    3.389676] usb 1-1.3: Product: FT230X Basic UART
                    [    3.398199] usb 1-1.3: Manufacturer: FTDI
                    [    3.402284] usb 1-1.3: SerialNumber: D306MB4E
                    [    3.447079] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SEL        INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +        XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybr        id)
                    [    3.476198] systemd[1]: Detected architecture arm.
                    [    3.550582] systemd[1]: Set hostname to <ioBroker-RasPi4>.
                    [    4.484277] random: systemd: uninitialized urandom read (16 bytes read)
                    [    4.502139] random: systemd: uninitialized urandom read (16 bytes read)
                    [    4.509592] systemd[1]: Listening on Journal Audit Socket.
                    [    4.515973] random: systemd: uninitialized urandom read (16 bytes read)
                    [    4.523295] systemd[1]: Listening on Journal Socket (/dev/log).
                    [    4.529916] systemd[1]: Reached target Swap.
                    [    4.535281] systemd[1]: Started Dispatch Password Requests to Console Directo        ry Watch.
                    [    4.544587] systemd[1]: Listening on udev Control Socket.
                    [    4.551011] systemd[1]: Listening on udev Kernel Socket.
                    [    4.560042] systemd[1]: Created slice system-getty.slice.
                    [    4.652205] Driver for 1-wire Dallas network protocol.
                    [    4.673267] gpio-4 (onewire@4): enforced open drain please flag it properly i        n DT/ACPI DSDT/board file
                    [    5.263355] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                    [    5.365588] systemd-journald[122]: Received request to flush runtime journal        from PID 1
                    [    5.939778] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Reg        isters at 0xfeb00000 length 0x00010000
                    [    5.965219] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised        : Registers at 0xfeb10000 length 0x00001000
                    [    6.015331] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Reg        isters at 0xfeb20000 length 0x00010000
                    [    6.020383] vc_sm_cma: module is from the staging directory, the quality is u        nknown, you have been warned.
                    [    6.041925] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Regis        ters at 0xfeb30000 length 0x00010000
                    [    6.053947] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                    [    6.100100] mc: Linux media interface: v0.10
                    [    6.161305] snd_bcm2835: module is from the staging directory, the quality is        unknown, you have been warned.
                    [    6.170163] videodev: Linux video capture interface: v2.00
                    [    6.181696] [vc_sm_connected_init]: start
                    [    6.229889] vc_sm_cma: module is from the staging directory, the quality is u        nknown, you have been warned.
                    [    6.244679] [vc_sm_connected_init]: installed successfully
                    [    6.264081] bcm2835_audio bcm2835_audio: card created with 8 channels
                    [    6.338944] bcm2835_mmal_vchiq: module is from the staging directory, the qua        lity is unknown, you have been warned.
                    [    6.346752] bcm2835_mmal_vchiq: module is from the staging directory, the qua        lity is unknown, you have been warned.
                    [    6.362358] bcm2835_mmal_vchiq: module is from the staging directory, the qua        lity is unknown, you have been warned.
                    [    6.365620] cfg80211: Loading compiled-in X.509 certificates for regulatory d        atabase
                    [    6.445731] bcm2835_isp: module is from the staging directory, the quality is        unknown, you have been warned.
                    [    6.461227] bcm2835_codec: module is from the staging directory, the quality        is unknown, you have been warned.
                    [    6.481145] bcm2835_v4l2: module is from the staging directory, the quality i        s unknown, you have been warned.
                    [    6.531622] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev        /video13
                    [    6.544382] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                    [    6.585964] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                    [    6.593129] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                    [    6.621091] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /de        v/video14
                    [    6.629517] brcmfmac: F1 signature read @0x18000000=0x15264345
                    [    6.661119] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f        or chip BCM4345/6
                    [    6.664879] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                    [    6.677912] usbcore: registered new interface driver brcmfmac
                    [    6.687488] [drm] No displays found. Consider forcing hotplug if HDMI is atta        ched
                    [    6.695274] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                    [    6.710396] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455        -sdio.raspberrypi,4-model-b.txt failed with error -2
                    [    6.724373] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /de        v/video15
                    [    6.743306] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                    [    6.753233] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
                    [    6.760073] [drm] No driver support for vblank timestamp query.
                    [    6.766148] [drm] Setting vblank_disable_immediate to false because get_vblan        k_timestamp == NULL
                    [    6.767426] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/        video16
                    [    6.781229] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                    [    6.806658] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                    [    6.817237] bcm2835-isp bcm2835-isp: Register output node 0 with media contro        ller
                    [    6.817566] usbcore: registered new interface driver usbserial_generic
                    [    6.825142] bcm2835-isp bcm2835-isp: Register capture node 1 with media contr        oller
                    [    6.850696] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                    [    6.861557] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                    [    6.877234] usbserial: USB Serial support registered for generic
                    [    6.880450] bcm2835-isp bcm2835-isp: Register capture node 2 with media contr        oller
                    [    6.918811] bcm2835-isp bcm2835-isp: Register capture node 3 with media contr        oller
                    [    6.938751] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                    [    6.950678] usbcore: registered new interface driver ftdi_sio
                    [    6.972582] usbserial: USB Serial support registered for FTDI USB Serial Devi        ce
                    [    6.985361] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
                    [    7.009288] usb 1-1.3: Detected FT-X
                    [    7.027134] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUS        B0
                    [    7.083222] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f        or chip BCM4345/6
                    [    7.111347] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23        2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
                    [    7.579095] w1_master_driver w1_bus_master1: w1_search: max_slave_count 64 re        ached, will continue next search.
                    [    9.027446] random: crng init done
                    [    9.027462] random: 7 urandom warning(s) missed due to ratelimiting
                    [    9.038941] uart-pl011 fe201000.serial: no DMA platform data
                    [    9.186302] 8021q: 802.1Q VLAN Support v1.8
                    [    9.355016] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:1        02396k SSFS
                    [    9.603570] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                    [    9.911299] bcmgenet: Skipping UMAC reset
                    [    9.913268] bcmgenet fd580000.ethernet: configuring instance for external RGM        II
                    [    9.913560] bcmgenet fd580000.ethernet eth0: Link is Down
                    [   15.114255] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow c        ontrol rx/tx
                    [   15.114300] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                    [   15.930575] Bluetooth: Core ver 2.22
                    [   15.930651] NET: Registered protocol family 31
                    [   15.930665] Bluetooth: HCI device and connection manager initialized
                    [   15.930689] Bluetooth: HCI socket layer initialized
                    [   15.930709] Bluetooth: L2CAP socket layer initialized
                    [   15.930740] Bluetooth: SCO socket layer initialized
                    [   15.938964] Bluetooth: HCI UART driver ver 2.3
                    [   15.938983] Bluetooth: HCI UART protocol H4 registered
                    [   15.939064] Bluetooth: HCI UART protocol Three-wire (H5) registered
                    [   15.939387] Bluetooth: HCI UART protocol Broadcom registered
                    [   16.114167] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                    [   16.114174] Bluetooth: BNEP filters: protocol multicast
                    [   16.114189] Bluetooth: BNEP socket layer initialized
                    [   16.245847] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net        .ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
                    [   58.318649] w1_master_driver w1_bus_master1: Attaching one wire slave 00.8000        00000000 crc 8c
                    [   58.327396] w1_master_driver w1_bus_master1: Family 0 for 00.800000000000.8c        is not registered.
                    [  121.919016] w1_master_driver w1_bus_master1: Attaching one wire slave 00.4000        00000000 crc 46
                    [  121.925391] w1_master_driver w1_bus_master1: Family 0 for 00.400000000000.46        is not registered.
                    [  172.678259] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c000        00000000 crc ca
                    [  172.686642] w1_master_driver w1_bus_master1: Family 0 for 00.c00000000000.ca        is not registered.
                    [  249.117560] w1_master_driver w1_bus_master1: Attaching one wire slave 00.2000        00000000 crc 23
                    [  249.126138] w1_master_driver w1_bus_master1: Family 0 for 00.200000000000.23        is not registered.
                    [  312.717173] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a000        00000000 crc af
                    [  312.725734] w1_master_driver w1_bus_master1: Family 0 for 00.a00000000000.af        is not registered.
                    [  350.637422] w1_master_driver w1_bus_master1: Attaching one wire slave 00.6000        00000000 crc 65
                    [  350.649718] w1_master_driver w1_bus_master1: Family 0 for 00.600000000000.65        is not registered.
                    • SMSS SMS
                      @Thomas-Braun
                      Leider unverändert.
                      @SMS
                      Dann mach den 1Wire-Kram in
                      sudo raspi-config
                      aus.
                      Und bitte poste mal die Rückmeldungen aus der Konsole.
                      sudo apt update
                      lsb_release -a
                      SMSS 1 Antwort Letzte Antwort
                        @SMS
                        sudo raspi-config
                        aus.
                        sudo apt update
                        lsb_release -a
                        SMSS Offline
                        SMSS Offline
                        SMS
                        @Thomas-Braun
                        pi@ioBroker-RasPi4:~ $ sudo apt update
                        OK:1 http://archive.raspberrypi.org/debian buster InRelease
                        OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        OK:3 https://deb.nodesource.com/node_10.x buster InRelease
                        Ign:4 http://webmin.mirror.somersettechsolutions.co.uk/repository sarge InRelease
                        OK:5 http://webmin.mirror.somersettechsolutions.co.uk/repository sarge Release
                        Ign:6 http://download.webmin.com/download/respository sarge InRelease
                        Fehl:7 http://download.webmin.com/download/respository sarge Release
                          404  Not Found [IP: 108.60.199.109 80]
                        E: Das Depot »http://download.webmin.com/download/respository sarge Release« enthält keine Release-Datei.
                        N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                        N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                        pi@ioBroker-RasPi4:~ $ lsb_release -a
                        No LSB modules are available.
                        Distributor ID: Raspbian
                        Description:    Raspbian GNU/Linux 10 (buster)
                        Release:        10
                        Codename:       buster
                        • SMSS SMS
                          @Thomas-Braun
                          Release:        10
                          Codename:       buster
                          @SMS sagte in Kein Zugriff auf Port 8081 ...:
                          Was ist denn das für ein Quatsch? sarge ist 15 Jahre alt!
                          Raus mit dem Krempel!
                            SMSS Offline
                            SMSS Offline
                            SMS
                            @Thomas-Braun
                            keine Ahnung was das sein soll?!
                            wie entfernen?
                            • SMSS SMS
                              @Thomas-Braun
                              wie entfernen?
                              @SMS
                              find /etc/apt -name "*.list"
                              In einer der Dateien muss der Quatsch drin stehen. Musst du mal durchschauen.
                                @SMS
                                SMSS Offline
                                SMSS Offline
                                SMS
                                schrieb am zuletzt editiert von SMS
                                @Thomas-Braun
                                pi@ioBroker-RasPi4:~ $ find /etc/apt -name "*.list"
                                /etc/apt/sources.list
                                /etc/apt/sources.list.d/raspi.list
                                /etc/apt/sources.list.d/nodesource.list
                                • SMSS SMS
                                  @Thomas-Braun
                                  Häh? Die Datein werden über find gefunden, also existieren die auch.
                                  Musst halt mit
                                  sudo nano /pfad/zur/datei.list
                                  ran. Ich vermute den Kram in der sources.list. Die Zeilen mit 'sarge' dann löschen
                                    Musst halt mit
                                    SMSS Offline
                                    SMSS Offline
                                    SMS
                                    @Thomas-Braun
                                    hatte /.../apt/... vergessen
                                    deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
                                    # Uncomment line below then 'apt-get update' to enable 'apt-get source'
                                    #deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
                                    # Webmin
                                    deb http://download.webmin.com/download/respository sarge contrib
                                    deb http://webmin.mirror.somersettechsolutions.co.uk/repository sarge contrib
                                    reicht es wenn ich ein # davor mache?
                                    • SMSS SMS
                                      @Thomas-Braun
                                      # Webmin
                                      @SMS
                                      Ja, # würde reichen. Da die Zeilen aber kompletter Quark sind würde ich die auch komplett löschen.
                                        @SMS
                                        SMSS Offline
                                        SMSS Offline
                                        SMS
                                        @Thomas-Braun
                                        das nur :
                                        drin steht?
                                        • SMSS SMS
                                          @Thomas-Braun
                                          das nur :
                                          drin steht?
                                          @SMS
                                          Ja.
                                          SMSS 2 Antworten Letzte Antwort
