  4. Zigbee Fehler beim Pairing...
zigbee adapter cc2531
3 Beiträge 3 Kommentatoren 231 Aufrufe 3 Beobachtet
  • RoboCopR Offline
    RoboCopR Offline
    RoboCop
    zigbee.0 2020-11-11 11:48:53.759 error at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:24:58))
    zigbee.0 2020-11-11 11:48:53.759 error at Generator.next (<anonymous>)
    zigbee.0 2020-11-11 11:48:53.759 error at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:291:27)
    zigbee.0 2020-11-11 11:48:53.759 error (16177) Failed to stop zigbee (Error: SREQ '--> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":2,"opt
    zigbee.0 2020-11-11 11:48:53.666 info (16177) Zigbee: disabling joining new devices.
    zigbee.0 2020-11-11 11:48:53.660 info (16177) cleaned everything up...
    zigbee.0 2020-11-11 11:48:53.657 error at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:24:58)
    zigbee.0 2020-11-11 11:48:53.657 error at Generator.next (<anonymous>)
    zigbee.0 2020-11-11 11:48:53.657 error at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:291:27)
    zigbee.0 2020-11-11 11:48:53.657 error (16177) Error: SREQ '--> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":1,"options":0,"radius":30,"le
    zigbee.0 2020-11-11 11:48:53.656 error (16177) unhandled promise rejection: SREQ '--> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":1,"opti
    Unhandled 2020-11-11 11:48:53.654 error promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0 2020-11-11 11:48:53.605 info (16177) Zigbee: allowing new devices to join.
    zigbee.0 2020-11-11 11:48:45.165 info (16177) Zigbee started
    Wie kann ich das beheben oder wo ist der Fehler
    Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
    • RoboCopR RoboCop
      @RoboCop
      Bitte Textausgaben in CodeTags </> einbetten. Danke.
      • RoboCopR RoboCop
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @RoboCop
        Bitte im Admin das Log herunter laden und den entsprechenden Bereich heraus kopieren. Das was oben gepostet ist ist unvollständig - bei langen Zeilen fehlt das Ende und damit wichtige Informationen.
        Und wie @Thomas-Braun geschrieben hat: Logs immer in
        Code Tags
