  4. Neuer Adapter: SMA Wechselrichter mit sbfspot
    6.8k
248 Beiträge 26 Kommentatoren 72.0k Aufrufe 10 Beobachtet
  • T Tottbeck
    Zu früh gefreut: Der Adapter bleibt zwar jetzt "grün" hat aber doch ein Problem, siehe Log.
    Muss/Kann ich das "better-sqlite3" manuell installieren ??
    Das Verzeichnis "\opt\iobroker\node_modules\better-sqlite3" habe ich, darin ist aber kein "better_sqlite3.node", vermutlich weil die Installation nicht geklappt hat. (siehe Fehlermeldung vorheriges Posting)
    sbfspot.0	2020-05-08 14:15:08.720	info	(12319) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    sbfspot.0	2020-05-08 14:15:08.717	error	(12319) force terminate in connect
    sbfspot.0	2020-05-08 14:15:02.743	error	→ /opt/iobroker/node_modules/better-sqlite3/lib/binding/node-v64-linux-arm/better_sqlite3.node]
    sbfspot.0	2020-05-08 14:15:02.743	error	→ /opt/iobroker/node_modules/better-sqlite3/addon-build/default/install-root/better_sqlite3.node
    sbfspot.0	2020-05-08 14:15:02.743	error	→ /opt/iobroker/node_modules/better-sqlite3/addon-build/debug/install-root/better_sqlite3.node
    sbfspot.0	2020-05-08 14:15:02.743	error	→ /opt/iobroker/node_modules/better-sqlite3/addon-build/release/install-root/better_sqlite3.node
    sbfspot.0	2020-05-08 14:15:02.743	error	→ /opt/iobroker/node_modules/better-sqlite3/compiled/10.20.1/linux/arm/better_sqlite3.node
    sbfspot.0	2020-05-08 14:15:02.743	error	→ /opt/iobroker/node_modules/better-sqlite3/build/default/better_sqlite3.node
    sbfspot.0	2020-05-08 14:15:02.743	error	→ /opt/iobroker/node_modules/better-sqlite3/Release/better_sqlite3.node
    sbfspot.0	2020-05-08 14:15:02.743	error	→ /opt/iobroker/node_modules/better-sqlite3/out/Release/better_sqlite3.node
    sbfspot.0	2020-05-08 14:15:02.743	error	→ /opt/iobroker/node_modules/better-sqlite3/Debug/better_sqlite3.node
    sbfspot.0	2020-05-08 14:15:02.743	error	→ /opt/iobroker/node_modules/better-sqlite3/out/Debug/better_sqlite3.node
    sbfspot.0	2020-05-08 14:15:02.743	error	→ /opt/iobroker/node_modules/better-sqlite3/build/Release/better_sqlite3.node
    sbfspot.0	2020-05-08 14:15:02.743	error	→ /opt/iobroker/node_modules/better-sqlite3/build/Debug/better_sqlite3.node
    sbfspot.0	2020-05-08 14:15:02.743	error	→ /opt/iobroker/node_modules/better-sqlite3/build/better_sqlite3.node
    sbfspot.0	2020-05-08 14:15:02.743	error	(12319) exception in DB_Connect [Error: Could not locate the bindings file. Tried:
    sbfspot.0	2020-05-08 14:15:02.715	info	(12319) start with sqlite
    sbfspot.0	2020-05-08 14:15:02.649	info	(12319) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v10.20.1
    Auch "npm install better-sqlite3" hilft nicht.
    Rene_HMR Offline
    Rene_HMR Offline
    Rene_HM
    #186
    @Tottbeck sagte in Neuer Adapter: SMA Wechselrichter mit sbfspot:
    Im Verzeichnis /opt/iobroker/node_modules/iobroker.sbfspot musst du npm install aufrufen, um alle Abhängigkeiten zu installieren.
    • T Tottbeck
      Super, hoffentlich ist das nervige sqlite3-Problem damit bald erledigt. 👍
      Der Adapter ist ja scheinbar noch nicht offiziell verfügbar, auch unter "Bestimmte Version installieren" ist die 2.4.0 die neueste.
      Ich habe das per Konsole über "iobroker upgrade sbfspot@3.0.0" probiert, hoffe das war korrekt ?
      Das ganze ist dann hängengeblieben s.u., nach Abbruch per STRG+C nach über einer Stunde war der iobroker wieder erreichbar und die 3.0.0 ist installiert und funktioniert? 😕 👏
      xxxx@raspberrypi:/opt/iobroker $ iobroker upgrade sbfspot
      Adapter "sbfspot"        is up to date.
      xxxx@raspberrypi:/opt/iobroker $ iobroker upgrade sbfspot@3.0.0
      Update sbfspot from @2.4.0 to @3.0.0
      NPM version: 6.14.4
      npm install iobroker.sbfspot@3.0.0 --loglevel error --prefix "/opt/iobroker" (System call)
      Package pixman-1 was not found in the pkg-config search path.
      Perhaps you should add the directory containing `pixman-1.pc'
      to the PKG_CONFIG_PATH environment variable
      No package 'pixman-1' found
      gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
      gyp ERR! configure error
      gyp ERR! stack Error: `gyp` failed with exit code: 1
      gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
      gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 4.19.97-v7+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
      gyp ERR! cwd /opt/iobroker/node_modules/canvas
      gyp ERR! node -v v10.20.1
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      node-pre-gyp ERR! System Linux 4.19.97-v7+
      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
      node-pre-gyp ERR! node -v v10.20.1
      node-pre-gyp ERR! node-pre-gyp -v v0.11.0
      node-pre-gyp ERR! not ok
      In file included from ../src/integer.hpp:3,
                       from ../src/integer.cpp:1:
      /home/iobroker/.cache/node-gyp/10.20.1/include/node/node.h:573:43: warning: cast between incompatible function types from âvoid (*)(v8::Local<v8::Object>, v8::Local<v8::Object>)â to ânode::addon_register_funcâ {aka âvoid (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)â} [-Wcast-function-type]
             (node::addon_register_func) (regfunc),                          \
      /home/iobroker/.cache/node-gyp/10.20.1/include/node/node.h:607:3: note: in expansion of macro âNODE_MODULE_Xâ
         NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      ../src/integer.cpp:408:1: note: in expansion of macro âNODE_MODULEâ
       NODE_MODULE(integer, Integer::Init);
      In file included from /home/iobroker/.cache/node-gyp/10.20.1/include/node/node.h:63,
      /home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h: In instantiation of âvoid v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]â:
      /home/iobroker/.cache/node-gyp/10.20.1/include/node/node_object_wrap.h:84:78:   required from here
      /home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from âv8::WeakCallbackInfo<node::ObjectWrap>::Callbackâ {aka âvoid (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)â} to âCallbackâ {aka âvoid (*)(const v8::WeakCallbackInfo<void>&)â} [-Wcast-function-type]
                      reinterpret_cast<Callback>(callback), type);
      Rene_HMR Offline
      Rene_HMR Offline
      Rene_HM
      #187
      Im latest repository liegt die 3.0.0 nur in stable liegt sie noch nicht...
      • Rene_HMR Rene_HM
        Tottbeck
        #188
        @Rene_HM sagte in Neuer Adapter: SMA Wechselrichter mit sbfspot:
        Danke, hat dann so geklappt. 👍
        Wobei ich das mit den Abhängigkeiten bei npm nicht wirklich durchblicke.
        Im iobroker werd mit dem Adapter better-sqlite3 installiert, bricht aber mit Problemen ab.
        Dann installiert man manuell nochmal den ganzen npm-Kram mit 471 packages nochmal im Unterordner iobroker.sbfspot. Dabei gibt es zwar auch jede Menge Warnungen aber es geht danach. Wie hätte man denn da selber drauf kommen sollen ?
        Da kannst Du zwar nichts für und ist auch kein Problem von diesem Adapter aber ist schon etwas abschreckend.
        Ich habe dummerweise versucht die scheinbaren Bugs bei der Installation mit better-sqlite3 und node-gyp nach er-googelten Hinweisen zu fixen und mir dabei die sudo-Rechte zerschossen. Den Besitzer von /usr/lib per chown zu ändern ist eine ganz doofe Idee. :man-facepalming:
          Tottbeck
          #189
          Moin, noch etwas anderes: Wie kann ich vermeiden dass im LOG jeder Aufruf vom sbfspot erscheint:
          Den debug-level vom sbfspot habe ich schon von "info" auf "warn" gestellt, aber diese Meldung kommt vom host.rayspberrypi
          host.raspberrypi 2020-06-14 07:15:00.026 info instance system.adapter.sbfspot.0 started with pid 22563
          host.raspberrypi 2020-06-14 07:10:05.692 info instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            Manuel_K
            schrieb am zuletzt editiert von Manuel_K
            #190
            kann mir einer bei einem Problem helfen.
            Bei SBFspot config kommt folgender Fehler.
            hab im mysql user und passwort und database mit folgenden befehlen angelegt.
            CREATE DATABASE iobroker;
            CREATE USER 'iobroker'@'%' IDENTIFIED BY 'XXXPasswortXXX';
            GRANT ALL PRIVILEGES ON iobroker.* TO 'iobroker'@'%';
            FLUSH PRIVILEGES;
            exit
            Bin nun etwas weiter.
            Tabellen sind hoffentlich richtig angelegt. Hab die Scripte in der doku übersehen.
            Bis auf das Passwort ist alles copy Paste ?
            wenn ich nun meine 2 WR über bluetoooth installieren will kommt nun folgender Fehler.
            AM WR ist der Schalter auf 2 gestellt.
            kann da einer helfen ?
            Rene_HMR 1 Antwort Letzte Antwort
            • M Manuel_K
              FLUSH PRIVILEGES;
              exit
              Rene_HMR Offline
              Rene_HMR Offline
              Rene_HM
              #191
              @Manuel_K wichtig ist wirklich, die Tabellen nach Anleitung von sbfspot anzulegen.
              Hier im log sieht man aber, dass die Bluetooth-Verbindung nicht aufgebaut wird. Ist die BT-Adresse wirklich richtig? Ist der WR erreichbar?
              Findet
              hcitool scan
              den WR?
              • Rene_HMR Rene_HM
                Findet
                hcitool scan
                den WR?
                Manuel_K
                #192
                @Rene_HM
                Habe es gerade geschafft alles einzustellen.
                Zuletzt war das Problem ein Restart des Raspberry.
                Alles TOP funktioniert alles.
                eine frage noch wie oft holt der die Daten vom WR ?
                • M Manuel_K
                  @Rene_HM
                  Rene_HMR Offline
                  Rene_HMR Offline
                  Rene_HM
                  #193
                  @Manuel_K der Adapter holt die Daten nicht vom WR. Das macht sbfspot. Die update-Rate des Adapters stellst du ein, indem du vorgibst, wann der Adapter startet
                  Hier alle 15 Minuten...
                  Wie du sbfspot diesbzeüglich einstellt findest du hier:
                  https://github.com/SBFspot/SBFspot/wiki/Installation-Linux-SQLite#️-automation
                  • Rene_HMR Rene_HM
                    Manuel_K
                    #194
                    @Rene_HM
                    OK das passt soweit.
                    Habe nun nur noch das Problem, dass Abends(wenn es dunkel ist) im IOBroker Objekt z.B. Pac1 =40W steht. Dort müsste doch 0W stehen.
                    Aufzeichnen wenn es hell ist: deaktviert.
                    mfg Manuel
                    • M Manuel_K
                      @Rene_HM
                      mfg Manuel
                      Rene_HMR Offline
                      Rene_HMR Offline
                      Rene_HM
                      #195
                      @Manuel_K da steht dann einfach der letzte Wert drin, den der Adapter aus der Datenbank geholt hat. Vielleicht aktualisiert sbfspot dann nicht mehr? Dort gibt es auch eine daylight-Funktion....
                      • Rene_HMR Rene_HM
                        Manuel_K
                        #196
                        @Rene_HM
                        ja wenn ich sbfspot nochmal händisch abfrage (mit dem Test Befehl) läd er die letzten Daten in den iobroker rein.
                        vielleicht kann man beim cronjob was ändern, das er nach dem abschalten nochmal die daten überträgt ?
                        iobroker adapter funktioniert.
                        BastelritiusB 1 Antwort Letzte Antwort
                        • M Manuel_K
                          @Rene_HM
                          BastelritiusB Offline
                          Bastelritius
                          #197
                          ich versuche auch gerade meine Wechselrichter mit sbfspot zu verbinden. Gibt es eine Möglichkeit den Adapter zu nutzen wenn sbfspot und die Datenbank auf einem anderen RaPi läuft als der Iobroker? Bei mir geht es aus Reichweitegründen nicht anders. Der RaPi der die Daten per BT von den WR holt ist zwar im WLAN aber es ist nicht der gleiche RaPi wo meine Iobroker installation läuft.
                          • BastelritiusB Bastelritius
                            wendy2702W Offline
                            wendy2702W Offline
                            #198
                            @bastelritius
                            Installiere doch iobroker auf dem Raspi und mache ein Master Slave System daraus.
                            Weiß nicht welchen WR genau du hast aber vielleicht kannst du ihn dann auch über Modbus abfragen.
                            • wendy2702W wendy2702
                              @bastelritius
                              Bastelritius
                              #199
                              @wendy2702, danke für die schnelle Antwort. Ich denke Iobroker auf dem zweiten RaPi zu installieren sollte kein Problem sein. Wie ich das mit dem Master slave system machen muss, weiß ich bis jetzt noch nicht. Aber das kann ja noch werden.
                              Ich habe in meinen WR nur BT Module drin. Es sind zwei SB5000TL-20 und ein SB3300.
                                wendy2702W Offline
                                wendy2702W Offline
                                #200
                                @bastelritius OK.
                                ich weiß leider nicht ob der iobroker SBF Spot Adapter mit Bluetooth kann. Das müsste jemand anderes beantworten. Wenn er das nicht kann nützt der Master Slave erstmal nicht soviel.
                                  @bastelritius OK.
                                  Bastelritius
                                  #201
                                  @wendy2702 Ich werde es mal probieren. Ich hatte es so verstanden das der Adapter sbfspot nutzt und nur auf die DB zugreift. Die Datensammlung übernimmt ja sbfspot selbst. Das sollte meines Wissens, zumindest so wie ich es verstanden habe, auch mit BT funktionieren. Ich werde das mal testen. Kann es aber erst testen wenn ich mal mein BT PW in den WR zurückgestezt habe 😖 Mal sehen wie schnell der SMA support da ist.
                                  wendy2702W Rene_HMR 2 Antworten Letzte Antwort
                                    wendy2702W Offline
                                    wendy2702W Offline
                                    #202
                                    @bastelritius OK. Viel Erfolg.
                                    Kann man das PW nicht selber ändern oder kannst du dich nicht als Installateur anmelden?
                                      Rene_HMR Offline
                                      Rene_HMR Offline
                                      Rene_HM
                                      #203
                                      @bastelritius sagte in Neuer Adapter: SMA Wechselrichter mit sbfspot:
                                      genau so betreibe ich mein System: RPi mit sbfspot über BT und auf dem gleichen RPi eine Instanz vom ioBroker als Slave...
                                        Bastelritius
                                        #204
                                        @wendy2702 Ja, kann man eigentlich schon. Aber leider hatte mich der Sunnyexplorer aufgefordert mein Passwort zu ändern. Das habe ich blöderweise getan und dann kam es bei der Übertragung zum Timeout-Fehler. Seitdem kann ich mich nicht mehr einloggen. Hätte ich es mal beim Standardpasswort gelassen. Naja, nun ist es so. Ich warte immer noch. SMA support hat meiner Erfahrung nach eine lange response time :(
                                        @Rene_HM: Na dann werde ich das mal probieren. Ich bin schon ganz gespannt :)
                                        • BastelritiusB Offline
                                          Bastelritius
                                          #205
                                          ich habe sbfspot soweit installiert. Ich denke auch erfolgreich soweit. Es läuft auf dem zweiten Raspi, der als slave läuft.
                                          Anscheinend läuft der Adapter aber noch nicht richtig. Ich sehe im LOG folgende Fehlermeldung:
                                          8788) exception in DB_Connect [Error: /opt/iobroker/node_modules/better-sqlite3/build/Release/better_sqlite3.node: undefined symbol: _ZN7Stateme/tIteratorD1Ev]
                                          Hat jemand eine Idee was das bedeutet?
