  4. Amazon Dash Button für ioBroker nutzen
    6.7k
385 Beiträge 86 Kommentatoren 133.9k Aufrufe 1 Beobachtet
  • PatrickP Offline
    PatrickP Offline
    Patrick
    geht leider immer noch nicht
    ! $ ./iobroker url "https://github.com/PArns/ioBroker.amazon-dash" –debug
    ! install https://github.com/PArns/ioBroker.amazo ... all/master
    ! npm install https://github.com/PArns/ioBroker.amazo ... all/master --production --prefix "C:/Program Files/IO BROKER/ioBroker" (System call)
    ! > socketwatcher@0.3.0 install C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.amazon-dash\node_modules\pcap\node_modules\socketwatcher
    ! > node-gyp rebuild
    ! C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.amazon-dash\node_modules\pcap\node_modules\socketwatcher>if not
    ! defined npm_config_node_gyp (node "C:\Program Files\nodejs\node_modules\npm\bin\node-gyp-bin\....\node_modules\node-gyp\bin\node-gyp.js" rebuild ) else (node rebuild )
    ! gyp
    ! ERR! configure error
    ! gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR! stack at failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:116:14)
    ! gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:71:11gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15)
    ! gyp ERR! System Windows_NT 10.0.10586
    ! gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"gyp ERR! cwd C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.amazon-dash\node_modules\pcap\node_modules\socketwatcher
    ! gyp ERR! node -v v4.3.1
    ! gyp
    ! ERR! node-gyp -v v3.0.3gyp
    ! ERR! not ok
    ! npm
    ! ERR! Windows_NT 10.0.10586
    ! npm ERR!
    ! argv
    ! "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js" "install" "https://github.com/PArns/ioBroker.amazo ... all/master" "--production" "--prefix" "C:/Program Files/IO BROKER/ioBroker"npm ERR! node v4.3.1
    ! npm
    ! ERR! npm v2.14.12npm ERR! code ELIFECYCLE
    ! npm
    ! ERR! socketwatcher@0.3.0 install: node-gyp rebuildnpm ERR! Exit status 1
    ! npm ERR!
    ! npm ERR! Failed at the socketwatcher@0.3.0 install script 'node-gyp rebuild'.
    ! npm ERR! This is most likely a problem with the socketwatcher package,
    ! npm
    ! ERR! not with npm itself.npm
    ! ERR! Tell the author that this fails on your system:npm ERR! node-gyp rebuild
    ! npm ERR! You can get their info via:
    ! npm ERR! npm owner ls socketwatcher
    ! npm ERR! There is likely additional logging output above.
    ! npm ERR! Please include the following file with any support request:npm ERR! C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker\npm-debug.log
    ! ERROR: host.ricknetpc Cannot install https://github.com/PArns/ioBroker.amazo ... all/master: 1
    ! ERROR: process exited with code 25
    • P Offline
      PArt
      So, update ist raus … Ein state darf nicht state heißen ;) Neuer Name "switch" geht, bitte den State state löschen
      Das Paket steht nun auch über NPM zur Verfügung
      • P Offline
        PArt
        Zum Python problem … Siehe http://stackoverflow.com/questions/2136 ... g-with-npm
        Du brauchst python 2.7 + das muss in die environment variable eingetragen sein, da das PCAP Modul kompiliert werden muss und natürlich brauchst du PCAP für Windows!
        Dein Log sagt ja auch:
        • ruhr70R Offline
          ruhr70R Offline
          ruhr70
          Top Arbeit! Funktioniert auf Anhieb :-)
          Zur Info, ein Datenpunkt wird nicht gefüllt:
          amazon-dash.0.50-f5-da-xx-xx-xx.lastPressed
            mayer
            Hi, bekomme es auf dem MAC nicht installiert. Er meckert GIT an.
            npm WARN addRemoteGit Error: Command failed: git config --get remote.origin.url
            GIT ist installiert.
            Komme erst mal nicht weiter.
            Gruss, mayer
            • P Offline
              PArt
              Oh man, manchmal hab ich auch Tomaten auf den Augen … Deshalb funktionierte auch der State nicht ...
              Ich habe eine neue Version online gestellt, die hoffentlich auch das GIT Problem behebt
              • PatrickP Offline
                PatrickP Offline
                Patrick
                hallo
                ich glaub ich bin etwas weiter gekommen aber jetzt weis ich nicht mehr was ich noch machen kann
                kann mir da jemand bitte helfen
                npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at F (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:78:19)
                npm WARN addRemoteGit at E (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:82:29)npm WARN addRemoteGit at C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:93:16
                npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
                npm WARN addRemoteGit git+https://github.com/mranney/node_pcap.git resetting remote C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_git-remotes\https-github-com-mranney-node-pcap-git-72c55299 because of error: { [Error: not found: git] code: 'ENOGIT' }
                npm
                ERR! git clone –template=C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_git-remotes_templates --mirror https://github.com/mranney/node_pcap.git C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_git-remotes\https-github-com-mranney-node-pcap-git-72c55299: undefinednpm ERR! git clone --template=C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_git-remotes_templates --mirror https://github.com/mranney/node_pcap.git C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_git-remotes\https-github-com-mranney-node-pcap-git-72c55299: undefined
                npm
                ERR! Windows_NT 10.0.10586npm ERR! argv "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js" "install" "https://github.com/PArns/ioBroker.amazo ... all/master" "--production" "--prefix" "C:/Program Files/IO BROKER/ioBroker"
                npm ERR!
                node v4.3.1npm ERR! npm v2.14.12
                npm
                ERR! code ENOGIT
                npm ERR! not found: git
                npm ERR! npm ERR! Failed using git.
                npm ERR! This is most likely not a problem with npm itself.
                npm
                ERR! Please check if you have git installed and in your PATH.
                • P Offline
                  PArt
                  Installiere dir auch mal Git, da dein Log meldet
                  Das offizielle von GitHub sollte funktionieren https://git-for-windows.github.io/
                  • PatrickP Offline
                    PatrickP Offline
                    Patrick
                    Hallo
                    Git bash ist schon installiert
                    • oldi-2000O Offline
                      oldi-2000O Offline
                      oldi-2000
                      Hallo bei mir schlägt die Installation leider auch fehl,
                      $ ./iobroker add amazon-dash
                      npm install iobroker.amazon-dash --production --prefix "/opt/iobroker" (System call)
                      gyp
                      ERR!
                      configure error
                      gyp
                       ERR!
                      stack     at failNoPython (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:449:14)gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:353:11
                      gyp ERR! stack     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:16)
                      gyp ERR! stack     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
                      gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
                      gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
                      gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
                      gyp ERR! System Linux 4.4.0-36-generic
                      gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/node_modules/socketwatcher
                      gyp ERR! node -v v4.5.0
                      gyp ERR! node-gyp -v v3.4.0
                      gyp ERR! not ok
                      npm
                      ERR!
                       Linux 4.4.0-36-genericnpm
                       ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.amazon-dash" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.5.0
                      npm ERR! npm  v2.15.9
                      npm
                       ERR! code
                       ELIFECYCLE
                      npm ERR! socketwatcher@0.3.0 install: `node-gyp rebuild`
                      npm
                      ERR! Exit status 1npm
                       ERR!
                      npm ERR! not with npm itself.
                      npm ERR! Tell the author that this fails on your system:
                      npm ERR! You can get information on how to open an issue for this project with:
                      npm ERR!     npm bugs socketwatcher
                      npm ERR! Or if that isn't available, you can get their info via:
                      npm ERR!
                      npm
                      npm ERR!     /npm-debug.log
                      ERROR: host.iobrokerVM Cannot install iobroker.amazon-dash: 1
                      hab Ubutnu 16.4 unter virtualbox alles andere funktioniert.
                      Hab auch schon zwei Dash-Buttons da :?
                      Hat jemand ne Lösung??
                      MFG Daniel
                      • PatrickP Offline
                        PatrickP Offline
                        Patrick
                        __Zum Python problem … Siehe http://stackoverflow.com/questions/2136 ... g-with-npm
                        Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR! stack at failNoPython__
                        Nach dem ich auf Grund diesen Beitrags PYTHON 2.7 installiert habe und das auch in die System variablen eingetragen habe, verschwand bei mir der erste teil der Error´s (aber bei Windows)
                        was ist socketwatcher@0.3.0??
                        und kann das mit den anderen Fehlermeldungen zutun haben?
                        • P Offline
                          PArt
                          socketwatcher ist teil von pcap und für das "Sniffen" der Anmeldepakete verantwortlich und ist der Teil, der eben individuell kompiliert werden muss …
                            oldi-2000O Offline
                            oldi-2000
                            ??? [emoji20]
                            Gesendet von meinem LG-H815 mit Tapatalk
                              oldi-2000O Offline
                              oldi-2000
                              So ich habe Python jetzt nach einiger Rechereche installiert und in die configs von node-Gyp und npm eingetragen.
                              Jetzt habe ich bei der Adapter Installation diesen Fehler:````
                              gyp
                              ERR!
                              UNCAUGHT EXCEPTION
                              gyp
                              ERR! stack Error: spawn EACCESgyp
                              ERR!
                              stack at exports._errnoException (util.js:907:11)gyp ERR! stack at ChildProcess.spawn (internal/child_process.js:298:11)
                              gyp ERR! stack at exports.spawn (child_process.js:362:9)
                              gyp ERR! stack at exports.execFile (child_process.js:151:15)
                              gyp ERR! stack at checkPythonVersion (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:419:5)
                              gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:361:9
                              gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:88:20
                              gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15)
                              gyp ERR! System
                              Linux 4.4.0-36-genericgyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                              gyp
                              gyp ERR! node -v v4.5.0gyp ERR! node-gyp -v v3.4.0
                              gyp ERR! This is a bug in node-gyp.
                              gyp ERR! Try to update node-gyp and file an Issue if it does not help:
                              gyp ERR! <https: github.com/nodejs/node-gyp/issues="">
                              npm
                              ERR!
                              ERR!
                              npm
                              ERR! npm v2.15.9npm ERR! code ELIFECYCLE
                              npm ERR! socketwatcher@0.3.0 install: node-gyp rebuildnpm ERR!
                              Exit status 7
                              npm ERR!
                              npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:
                              npm ERR!
                              npm
                              ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
                              ERROR: process exited with code 25</https:>
                              Alle anderen Adapter lassen sich installieren und funktionieren.
                              Mein Wissensstand reicht einfach nicht aus das zu lösen und das Internet hilft auch nicht mehr weiter. :cry:
                              Hat einer ne Idee?
                              MFG
                              Daniel
                              • PatrickP Offline
                                PatrickP Offline
                                Patrick
                                Hat sonst keiner das Problem?
                                • BluefoxB Offline
                                  BluefoxB Offline
                                  > This is a bug innode-gyp `
                                  Versuch mal
                                  npm install node-gyp –force -g
                                  (Vielleicht als sudo)
                                  Kann es sein, dass du node.js Version upgedated hast?
                                    @oldi-2000:
                                    ERR! stack Error: spawn EACCESgyp `
                                    Welcher User??
                                    @Bluefox:
                                    Kann es sein, dass du node.js Version upgedated hast? `
                                    @oldi-2000:
                                    node -v v4.5.0gyp ERR! node-gyp -v v3.4.0 `
                                      oldi-2000O Offline
                                      oldi-2000
                                      Was ist mit node, zu neu?? Und wie, welcher user??
                                        sirtwist672
                                        Ich hab folgendes Phänomen:
                                        bei mir erscheinen in den Objekten insgesamt 3 Geräte, obwohl ich nur einen Dash habe
                                        beim Nachforschen der Mac Adressen bin dann darauf gestoßen das die anderen Geräte ein Fire tv stick und ein Kindle Ebook sind.
                                        kann man die irgendwie rausfiltern?
                                        ist aber nicht so wichtig, macht die Sache nur etwas unübersichtlicher.
                                        Wenn mans weis kann man die weiteren Geräte ja Ignorieren
                                        Sirtwist
                                        • C Offline
                                          charlyphyro
                                          Hat auf anhieb funktioniert! 1000 Dank für den Adapter!
                                          Wer möchte, hab eine Vorlage gebastelt. So kann man sich sein eigenes Etikett erstellen.
                                          Charly
