  4. Amazon Dash Button für ioBroker nutzen
    6.7k
385 Beiträge 86 Kommentatoren 133.9k Aufrufe 1 Beobachtet
  • P Offline
    PArt
    Installiere dir auch mal Git, da dein Log meldet
    npm ERR! npm ERR! Failed using git.
    Das offizielle von GitHub sollte funktionieren https://git-for-windows.github.io/
    • PatrickP Offline
      PatrickP Offline
      Patrick
      Hallo
      Git bash ist schon installiert
      • oldi-2000O Offline
        oldi-2000O Offline
        oldi-2000
        Hallo bei mir schlägt die Installation leider auch fehl,
        $ ./iobroker add amazon-dash
        npm install iobroker.amazon-dash --production --prefix "/opt/iobroker" (System call)
        gyp
        ERR!
        configure error
         gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.
        gyp
         ERR!
        stack     at failNoPython (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:449:14)gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:353:11
        gyp ERR! stack     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:16)
        gyp ERR! stack     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
        gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
        gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
        gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
        gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:82:15)
        gyp ERR! System Linux 4.4.0-36-generic
        gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/node_modules/socketwatcher
        gyp ERR! node -v v4.5.0
        gyp ERR! node-gyp -v v3.4.0
        gyp ERR! not ok
        npm
        ERR!
         Linux 4.4.0-36-genericnpm
         ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.amazon-dash" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.5.0
        npm ERR! npm  v2.15.9
        npm
         ERR! code
         ELIFECYCLE
        npm ERR! socketwatcher@0.3.0 install: `node-gyp rebuild`
        npm
        ERR! Exit status 1npm
         ERR!
         npm ERR! Failed at the socketwatcher@0.3.0 install script 'node-gyp rebuild'.
        npm ERR! This is most likely a problem with the socketwatcher package,
        npm ERR! not with npm itself.
        npm ERR! Tell the author that this fails on your system:
        npm ERR!     node-gyp rebuild
        npm ERR! You can get information on how to open an issue for this project with:
        npm ERR!     npm bugs socketwatcher
        npm ERR! Or if that isn't available, you can get their info via:
        npm ERR!
        npm ERR!     npm owner ls socketwatcher
        npm ERR! There is likely additional logging output above.
        npm
        ERR! Please include the following file with any support request:
        npm ERR!     /npm-debug.log
        ERROR: host.iobrokerVM Cannot install iobroker.amazon-dash: 1
        hab Ubutnu 16.4 unter virtualbox alles andere funktioniert.
        Hab auch schon zwei Dash-Buttons da :?
        Hat jemand ne Lösung??
        MFG Daniel
        • PatrickP Offline
          PatrickP Offline
          Patrick
          __Zum Python problem … Siehe http://stackoverflow.com/questions/2136 ... g-with-npm
          Du brauchst python 2.7 + das muss in die environment variable eingetragen sein, da das PCAP Modul kompiliert werden muss und natürlich brauchst du PCAP für Windows!
          Dein Log sagt ja auch:
          Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR! stack at failNoPython__
          Nach dem ich auf Grund diesen Beitrags PYTHON 2.7 installiert habe und das auch in die System variablen eingetragen habe, verschwand bei mir der erste teil der Error´s (aber bei Windows)
          was ist socketwatcher@0.3.0??
          und kann das mit den anderen Fehlermeldungen zutun haben?
          • P Offline
            PArt
            socketwatcher ist teil von pcap und für das "Sniffen" der Anmeldepakete verantwortlich und ist der Teil, der eben individuell kompiliert werden muss …
              oldi-2000O Offline
              oldi-2000
              ??? [emoji20]
              Gesendet von meinem LG-H815 mit Tapatalk
                oldi-2000O Offline
                oldi-2000
                So ich habe Python jetzt nach einiger Rechereche installiert und in die configs von node-Gyp und npm eingetragen.
                Jetzt habe ich bei der Adapter Installation diesen Fehler:````
                gyp
                ERR!
                UNCAUGHT EXCEPTION
                gyp
                ERR! stack Error: spawn EACCESgyp
                ERR!
                stack at exports._errnoException (util.js:907:11)gyp ERR! stack at ChildProcess.spawn (internal/child_process.js:298:11)
                gyp ERR! stack at exports.spawn (child_process.js:362:9)
                gyp ERR! stack at exports.execFile (child_process.js:151:15)
                gyp ERR! stack at checkPythonVersion (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:419:5)
                gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:361:9
                gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:88:20
                gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15)
                gyp ERR! System
                Linux 4.4.0-36-genericgyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                gyp
                gyp ERR! node -v v4.5.0gyp ERR! node-gyp -v v3.4.0
                gyp ERR! This is a bug in node-gyp.
                gyp ERR! Try to update node-gyp and file an Issue if it does not help:
                gyp ERR! <https: github.com/nodejs/node-gyp/issues="">
                npm
                ERR!
                ERR!
                npm
                ERR! npm v2.15.9npm ERR! code ELIFECYCLE
                npm ERR! socketwatcher@0.3.0 install: node-gyp rebuildnpm ERR!
                Exit status 7
                npm ERR!
                npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:
                npm ERR!
                npm
                ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
                ERROR: process exited with code 25</https:>
                Alle anderen Adapter lassen sich installieren und funktionieren.
                Mein Wissensstand reicht einfach nicht aus das zu lösen und das Internet hilft auch nicht mehr weiter. :cry:
                Hat einer ne Idee?
                MFG
                Daniel
                • PatrickP Offline
                  PatrickP Offline
                  Patrick
                  Hat sonst keiner das Problem?
                  • BluefoxB Offline
                    BluefoxB Offline
                    > This is a bug innode-gyp `
                    Versuch mal
                    npm install node-gyp –force -g
                    (Vielleicht als sudo)
                    Kann es sein, dass du node.js Version upgedated hast?
                      @oldi-2000:
                      ERR! stack Error: spawn EACCESgyp `
                      Welcher User??
                      @Bluefox:
                      Kann es sein, dass du node.js Version upgedated hast? `
                      @oldi-2000:
                      node -v v4.5.0gyp ERR! node-gyp -v v3.4.0 `
                        oldi-2000O Offline
                        oldi-2000
                        Was ist mit node, zu neu?? Und wie, welcher user??
                          sirtwist672
                          Ich hab folgendes Phänomen:
                          bei mir erscheinen in den Objekten insgesamt 3 Geräte, obwohl ich nur einen Dash habe
                          beim Nachforschen der Mac Adressen bin dann darauf gestoßen das die anderen Geräte ein Fire tv stick und ein Kindle Ebook sind.
                          kann man die irgendwie rausfiltern?
                          ist aber nicht so wichtig, macht die Sache nur etwas unübersichtlicher.
                          Wenn mans weis kann man die weiteren Geräte ja Ignorieren
                          Sirtwist
                          • C Offline
                            charlyphyro
                            Hat auf anhieb funktioniert! 1000 Dank für den Adapter!
                            Wer möchte, hab eine Vorlage gebastelt. So kann man sich sein eigenes Etikett erstellen.
                            Charly
                              Moses1989
                              Ich habe das gleiche Problem wie oldi-2000.
                              Server läuft auch mit Ubuntu 16 und ich bekomme den Dash Button Adapter auch nicht installiert.
                              Ich habe Python 2.7.12 und Node v0.10.33 drauf.
                              npm
                               ERR! not a package /tmp/npm-3186-jmsB2Zl0/github.com/mranney/node_pcap
                              npm
                               ERR! Error: ENOENT, open '/tmp/npm-3186-jmsB2Zl0/github.com/mranney/node_pcap-unpack/package.json'
                              npm
                               ERR! If you need help, you may report this *entire* log,npm ERR! including the npm and node versions, at:
                              npm ERR!     <http: github.com/npm/issues="">
                              npm
                               ERR! System Linux 4.4.0-38-genericnpm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.amazon-dash" "--production" "--prefix" "/opt/iobroker"
                              npm
                               ERR! cwd /npm ERR! node -v v0.10.33
                              npm ERR! npm -v 1.4.28
                              npm ERR! path /tmp/npm-3186-jmsB2Zl0/github.com/mranney/node_pcap-unpack/package.json
                              npm ERR! code ENOENT
                              npm ERR! errno 34
                              npm ERR! not ok code 0
                              ERROR: host.server Cannot install iobroker.amazon-dash: 34
                              ERROR: process exited with code 25</http:>
                              Hat jemand vielleicht noch eine Idee ?
                              @oldi-2000 Hast du es ans laufen bekommen?
                              grüße moses
                                oldi-2000O Offline
                                oldi-2000
                                Hallo nein leider noch nicht
                                • lobomauL Offline
                                  lobomauL Offline
                                  lobomau
                                  Hab mir grad meinen zweiten Dash Button bestellt und es wurden sofort 4,99EUR als Gutschein abgezogen! Hab ihn also umsonst :D
                                  Dazu hatte ich drei g-Tags gekauft. Keine AUhnung warum. Probiert mal aus. Ich hatte den amazon dash button universal ausgewählt (Avery Zweckform).
                                  Host: NUC8i3 mit Proxmox:
                                  • Slave: Pi4
                                  • H Online
                                    H Online
                                    holgerwolf
                                    Sorry… Der Adapter kann das ja schon längst. Kommt aus der Beschreibung nicht klar raus:
                                    Der Adapter braucht kein WLAN am Host!
                                    Holger
                                    so wie ich das hier verstanden habe, funktioniert der Adapter nur mit einem WLAN am Host. Kann man den Adapter nicht so programmieren, dass er generell das gesamte Netz nach dem Anmeldevorgang "snifft"? Selbst wenn ich meinem iobroker Banana ein WLAN spendiere, nutzt das mir im Serverkämmerchen wenig.
                                    Hier hat jemand ein Script dafür geschrieben:
                                    https://blog.thesen.eu/aktuellen-dash-b ... en-hacken/
                                    Das habe ich recht einfach zum Laufen bekommen. Reagiert auf den Knopf auch beim Anmelden über ein Router-(FritzBox)-WLAN.
                                    Jetzt müsste man daraus nur noch einen Adapter basteln...
                                    Leider bin ich mit sowas überfordert :-(
                                    Danke und Gruß
                                    Holger
                                    • BluefoxB Offline
                                      BluefoxB Offline
                                      Ich bezweifle, dass es unter Windows möglich wird.
                                        mayer
                                        Hi, ich mache das über einen kleinen Umweg:
                                        Amazon Dash Button Hack
                                        http://www.instructables.com/id/Amazon- … /?ALLSTEPS
                                        Curl für Windows -> http Kommando an den ioBroker simple-api adapter.
                                        Funzt!
                                        Gruss, mayer
                                        • lobomauL Offline
                                          lobomauL Offline
                                          lobomau
                                          @lobomau:
                                          Dazu hatte ich drei g-Tags gekauft. Keine AUhnung warum. Probiert mal aus. Ich hatte den amazon dash button universal ausgewählt (Avery Zweckform). `
                                          Ich habe eben wieder einen Dash Button geordert und sofort wurden 4,99€ als Gutschein abgezogen. Damit habe ich drei Buttons für insgesamt 4,99 :D
                                          Ist tatsächlich so. Steht als ein Kommentar unter Amazon Dash Button Hack
                                          > I strongly suggest you setup the button with the mobile app and associate it with your Amazon account though. I realized if you do that, and you push the button at least once (Even if you didn't "select a product") the next time you buy something from Amazon normally (not with the button) you will recieve a $5 credit! Doesn't matter what you buy!!!
                                          • Slave: Pi4
