  4. Iobroker update -> possible EventEmitter memory leak detected
22 Beiträge 6 Kommentatoren 4.8k Aufrufe
  • N Offline
    N Offline
    nobody
    Wahrscheinlich hängt da noch was komplett schief mit der alten Installation.
    Hast du schon versucht, den js-controller komplett zu deinstallieren, das Verzeichnis zu löschen und dann manuell neu zu installieren?
    cd /opt/iobroker
    iobroker stop
    npm uninstall --save iobroker.js-controller
    rm -r /opt/iobroker/node_modules/iobroker.js-controller
    rm -rf ~/.npm
    npm cache clear
    npm install iobroker.js-controller
    • P Offline
      PArt
      Leider ebenfalls keinen Erfolg!
      Ich vermute, das das an den Fehlermeldungen liegt, die ioBroker ausspuckt, während iobroker update läuft ->
      Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/.bin/io-package.json: TypeError: Cannot read property 'test' of undefined
      Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/abbrev/io-package.json: TypeError: Cannot read property 'test' of undefined
      Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/accepts/io-package.json: TypeError: Cannot read property 'test' of undefined
      Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/after/io-package.json: TypeError: Cannot read property 'test' of undefined
      Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/amp/io-package.json: TypeError: Cannot read property 'test' of undefined
      Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/amp-message/io-package.json: TypeError: Cannot read property 'test' of undefined
      Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/ansi-regex/io-package.json: TypeError: Cannot read property 'test' of undefined
      Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/ansi-styles/io-package.json: TypeError: Cannot read property 'test' of undefined
      Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/array-flatten/io-package.json: TypeError: Cannot read property 'test' of undefined
      Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/arraybuffer.slice/io-package.json: TypeError: Cannot read property 'test' of undefined
      • P Offline
        PArt
        Jep, ich habe im Repro mal nach der Meldung gesucht, siehe da ….
        https://github.com/ioBroker/ioBroker.js ... b/tools.js
        Die Vermutung liegt nahe, dass das an Zeile 191 liegt, anscheinend ist die RegEx ungültig
        `if (regExp.test(dirs[i]) && fs.existsSync(path + 'io-package.json')) {`[/i]
        • P Offline
          PArt
          Ok, habe den fehler gefunden! Dieser behebt zwar die meldungen via iobroker update, jedoch nicht die anzeige! Ich vermute, das das der gleiche fehler im admin ist. Ich habe einen entsprechenden fork erstellt und einen pull-request ans repository erstellt. Den Admin schaue ich mir auch noch schnell an, vielleicht finde ich was..
          Ah, UPDATE: iobroker restart hat geholfen! Anscheinend hat mein fix das problem gleich mit gelöst!
          Für alle mit dem gleichen Problem und bis zum Fix: https://github.com/PArns/ioBroker.js-controller
          • N Offline
            N Offline
            nobody
            Was war der Fehler?
            • P Offline
              PArt
              Siehe https://github.com/ioBroker/ioBroker.js … /115/files
              Dort wurde eine RegEx verwendet, die aber NULL war, anscheinend hat Bluefox vergessen, die RegEx ebenfalls ein paar Zeilen tiefer richtig zu initialisieren. Typischer Copy&Paste fehler... Ich vermute, das der Fehler nicht bei jedem auftritt, da hier codestücke doppelt vorhanden sind. Ggf. sollte man da ne Funktion draus machen ;)
              • N Offline
                N Offline
                nobody
                ok, hab gesehen.
                Ich hätte sie eher vor 185 geschoben statt sie nun zweimal zu erzeugen.
                Die Fehlermeldung in 238 könnte auch noch korrigiert werden. Die hat mich in die Irre geführt.
                `console.log('Cannot read or parse ' + __dirname + '/../../../node_modules/' + dirs[i] + '/io-package.json: ' + e.toString());`[/i]
                • N Offline
                  N Offline
                  nobody
                  @PArt:
                  Ich vermute, das der Fehler nicht bei jedem auftritt, da hier codestücke doppelt vorhanden sind. Ggf. sollte man da ne Funktion draus machen ;) `
                  Ja, aber es tritt bei den meisten einfach nicht auf, weil eigentlich immer lokale Pakete unterhalb von /opt/iobroker/node_modules/js-controller/node_modules installiert werden. Sind die abhängigen Pakete bei dir alle direkt unter /opt/iobroker/node_modules oder global installiert?
                  • P Offline
                    PArt
                    Ja, die Pakete liegen bei mir unter /opt/iobroker/node_modules
                    Allerdings dachte ich bis jetzt, das diese dort standardgemäß liegen!? Ist das eine Einstellungssache?
                    An der Config habe ich nie etwas geändert
                    PS. zur RegEx, ja da gebe ich dir recht … Hab eine neue Version hochgeladen!
                    • BluefoxB Offline
                      BluefoxB Offline
                      Es gibt fix auf github (0.12.3 - js-controller) für EventEmitter problem,
                      aber ihr spricht hier über was anderes. Ist das gelöst?
                      • BluefoxB Offline
                        BluefoxB Offline
                        @nobody:
                        ok, hab gesehen.
                        Was ist mit der Zeile falsch?[/i]
                        • N Offline
                          N Offline
                          nobody
                          Im Original wird in der log Meldung in Zeile 238 da falsche Verzeichnis ausgegeben.
                          Gesendet von meinem GT-N8000 mit Tapatalk
