  4. fb-checkpresence Timeout-Fehler und falscher Username
@au
55 Beiträge 6 Kommentatoren 5.0k Aufrufe 5 Beobachtet
  • afuerhoffA afuerhoff
    @Elektroman
    Kommen nach einem Reboot der Fritzbox keine Fehler mehr nach Start des Adapter? Oder gibt es da noch etwas im Log
    Elektroman
    @afuerhoff
    Sorry so sauber ist der Log doch nicht, habe gerade die FB neu gestartet
    fb-checkpresence.0	2020-10-17 19:59:01.274	debug	(2731299) checkPresence first run
    fb-checkpresence.0	2020-10-17 19:59:01.269	debug	(2731299) getActive [{"Name":"Tobias","Active":"false","Kommt":"2020.10.10 00:39:24","Geht":"2020.10.09 18:18:24"},{"Name":"Imke","Active":"false","Kommt":"2020.10.10 15:00:24","Geht":"2020.10.10 10:2
    fb-checkpresence.0	2020-10-17 19:59:01.222	warn	(2731299) ipaddress 192.168.168.170 from member Imke: invalid action
    fb-checkpresence.0	2020-10-17 19:59:01.185	debug	(2731299) getActive [{"Name":"Tobias","Active":"false","Kommt":"2020.10.10 00:39:24","Geht":"2020.10.09 18:18:24"},
    fb-checkpresence.0	2020-10-17 19:59:01.097	warn	(2731299) ipaddress 192.168.168.171 from member Tobias: invalid action
    fb-checkpresence.0	2020-10-17 19:59:01.057	warn	(2731299) can not read external ip address
    fb-checkpresence.0	2020-10-17 19:59:01.056	debug	(2731299) {"status":500,"data":null,"result":false,"resultData":null,"errNo":4,"errorMsg":{"$":{"xmlns":"urn:dslforum-org:control-1-0"},"errorCode":"401","errorDescription":"invalid action"}}
    fb-checkpresence.0	2020-10-17 19:59:01.035	debug	(2731299) {"status":500,"data":null,"result":false,"resultData":null,"errNo":4,"errorMsg":{"$":{"xmlns":"urn:dslforum-org:control-1-0"},"errorCode":"401","errorDescription":"invalid action"}}
    fb-checkpresence.0	2020-10-17 19:59:01.012	error	(2731299) soapAction GetInfo status=500 errNo=4 401 invalid action
    fb-checkpresence.0	2020-10-17 19:59:01.001	error	(2731299) soapAction X_AVM-DE_GetHostListPath status=500 errNo=4 401 invalid action
    fb-checkpresence.0	2020-10-17 19:59:00.998	info	(2731299) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    fb-checkpresence.0	2020-10-17 19:59:00.997	info	(2731299) terminating
    fb-checkpresence.0	2020-10-17 19:59:00.997	info	(2731299) cleaned everything up...
    fb-checkpresence.0	2020-10-17 19:59:00.995	info	(2731299) Got terminate signal TERMINATE_YOURSELF
    fb-checkpresence.0	2020-10-17 19:59:00.991	info	(2731299) History function disabled
    fb-checkpresence.0	2020-10-17 19:59:00.987	debug	(2731299) createMemberObjects Imke
    fb-checkpresence.0	2020-10-17 19:59:00.986	info	(2731299) History function disabled
    fb-checkpresence.0	2020-10-17 19:59:00.986	debug	(2731299) createMemberObjects Tobias
    fb-checkpresence.0	2020-10-17 19:59:00.884	error	(2731299) createFbDeviceObjects -> can't read devices from fritzbox!
    fb-checkpresence.0	2020-10-17 19:59:00.883	error	(2731299) soapAction X_AVM-DE_GetHostListPath status=500 errNo=4 401 invalid action
    fb-checkpresence.0	2020-10-17 19:59:00.872	debug	(2731299) function fb-devices true
    fb-checkpresence.0	2020-10-17 19:59:00.871	debug	(2731299) createGlobalObjects
    fb-checkpresence.0	2020-10-17 19:59:00.869	debug	(2731299) sslPort 49443
    fb-checkpresence.0	2020-10-17 19:59:00.860	debug	(2731299) response: 0 "<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Body>\n<u:GetSecur
    fb-checkpresence.0	2020-10-17 19:59:00.847	info	(2731299) service GetInfo is supported
    fb-checkpresence.0	2020-10-17 19:59:00.811	info	2
    fb-checkpresence.0	2020-10-17 19:59:00.811	info	(2731299) service GetSpecificHostEntry is supported
    fb-checkpresence.0	2020-10-17 19:59:00.784	info	(2731299) service X_AVM-DE_GetHostListPath is supported
    fb-checkpresence.0	2020-10-17 19:59:00.755	debug	(2731299) configuration familymembers: [{"familymember":"Tobias","macaddress":"0C:2F:B0:CA:89:AC","ipaddress":"192.168.168.171","useip":true,"comment":"Tobias privates Handy","enabled":true},{"family
    fb-checkpresence.0	2020-10-17 19:59:00.755	debug	(2731299) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
    fb-checkpresence.0	2020-10-17 19:59:00.754	debug	(2731299) configuration history: <>
    fb-checkpresence.0	2020-10-17 19:59:00.753	debug	(2731299) configuration user: <admin>
    fb-checkpresence.0	2020-10-17 19:59:00.752	info	(2731299) start fb-checkpresence: ip-address: 192.168.168.99 polling interval: 3 Min.
    fb-checkpresence.0	2020-10-17 19:59:00.663	info	(2731299) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.18.3, js-controller: 3.1.6
    fb-checkpresence.0	2020-10-17 19:58:59.750	debug	(2731299) statesDB connected
    fb-checkpresence.0	2020-10-17 19:58:59.749	debug	(2731299) States connected to redis: 0.0.0.0:9000
    fb-checkpresence.0	2020-10-17 19:58:59.667	debug	(2731299) States create System PubSub Client
    fb-checkpresence.0	2020-10-17 19:58:59.652	debug	(2731299) States create User PubSub Client
    fb-checkpresence.0	2020-10-17 19:58:59.621	debug	(2731299) Redis States: Use Redis connection: 0.0.0.0:9000
    fb-checkpresence.0	2020-10-17 19:58:59.619	debug	(2731299) objectDB connected
    fb-checkpresence.0	2020-10-17 19:58:59.611	debug	(2731299) Objects connected to redis: 0.0.0.0:9001
    fb-checkpresence.0	2020-10-17 19:58:59.564	debug	(2731299) Objects client initialize lua scripts
    fb-checkpresence.0	2020-10-17 19:58:59.564	debug	(2731299) Objects create User PubSub Client
    fb-checkpresence.0	2020-10-17 19:58:59.560	debug	(2731299) Objects create System PubSub Client
    fb-checkpresence.0	2020-10-17 19:58:59.536	debug	(2731299) Objects client ready ... initialize now
    fb-checkpresence.0	2020-10-17 19:58:59.471	debug	(2731299) Redis Objects: Use Redis connection: 0.0.0.0:9001
    fb-checkpresence.0	2020-10-17 19:59:00.831	info	(2731299) service GetSecurityPort is supported
    fb-checkpresence.0	2020-10-17 19:59:00.818	info	(2731299) service X_AVM-DE_GetSpecificHostEntryByIP is supported
    fb-checkpresence.0	2020-10-17 19:59:00.755	debug	(2731299) configuration familymembers: [{"familymember":"Tobias","macaddress":"0C:2F:B0:CA:89:AC","ipaddress":"192.168.168.171","useip":true,"comment":"Tobias privates Handy","enabled":true},{"familym
    E afuerhoffA 2 Antworten Letzte Antwort
    • E Elektroman
      @afuerhoff
      Elektroman
      Adapter ist jetzt schon wieder aus
      F 1 Antwort Letzte Antwort
      • E Elektroman
        F Online
        F Online
        fastfoot
        @Elektroman in den oberen LOGS ird die 192.168.178.1 als ip gezeigt, später ist es dann 192.168.168.1, check das mal
        E 1 Antwort Letzte Antwort
        • F fastfoot
          Elektroman
          @fastfoot sagte in fb-checkpresence Timeout-Fehler und falscher Username:
          Bin ich blind
          192.168.178.1 habe ic nicht gefunfen
          • E Elektroman
            Bin ich blind
            F Online
            F Online
            fastfoot
            @Elektroman sagte in fb-checkpresence Timeout-Fehler und falscher Username:
            Bin ich blind
            Beiträge 6,8,15...
            • F fastfoot
              Bin ich blind
              Beiträge 6,8,15...
              Elektroman
              @fastfoot
              6 fb-checkpresence.0 2020-10-17 19:59:01.057 warn (2731299) can not read external ip address
              8 fb-checkpresence.0 2020-10-17 19:59:01.035 debug (2731299) {"status":500,"data":null,"result":false,"resultData":null,"errNo":4,"errorMsg":{"$":{"xmlns":"urn:dslforum-org:control-1-0"},"errorCode":"401","errorDescription":"invalid action"}}
              15 fb-checkpresence.0 2020-10-17 19:59:00.991 info (2731299) History function disabled
              F afuerhoffA 2 Antworten Letzte Antwort
              • E Elektroman
                @fastfoot
                F Online
                F Online
                fastfoot
                @fastfoot
                Da sind auch noch mehr Zeilen zum Durchsehen! Auch wenn du sie nicht findest, check deine Settings und warum da Unterschiede sind. Die 192.168.168.x wie zuletzt gezeigt ist zumindest ungewöhnlich
                fb-checkpresence.0 2020-08-19 21:07:18.189 debug (21128) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
                fb-checkpresence.0 2020-08-19 21:07:18.189 debug (21128) configuration history: <>
                fb-checkpresence.0 2020-08-19 21:07:18.188 debug (21128) configuration user: <iobroker>
                fb-checkpresence.0 2020-08-19 21:07:18.187 info (21128) start fb-checkpresence: ip-address: 192.168.178.1 polling interval: 1 Min.
                fb-checkpresence.0 2020-08-19 21:07:18.137 info (21128) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v10.20.1, js-controller: 3.1.6
                • F fastfoot
                  @fastfoot
                  F Online
                  F Online
                  fastfoot
                  Sorry, die waren gar nicht von Dir!
                  • E Elektroman
                    @fastfoot
                    afuerhoffA Offline
                    afuerhoffA Offline
                    afuerhoff
                    @Elektroman
                    Es ist auch kein History Adapter in der Konfiguration ausgewählt.
                    • E Elektroman
                      @afuerhoff
                      afuerhoffA Offline
                      afuerhoffA Offline
                      afuerhoff
                      @Elektroman
                      Sind die IP-Adressen bei den Family-Membern korrekt? Du könntest ja auch die Mac-Adresse benutzen. Funktioniert im Konfigurationsdialog der Button "Familienmitglied hinzufügen"?
                        @Elektroman
                        Elektroman
                        @afuerhoff
                        ok 😊
                        habe schon gedacht ich bekomme nichts mehr hin
                        habe MAC und ip eingetragen!
                        Aber auch wenn ich da was falsches eingebe, der Adapter sollte sich doch nicht ganz abschalten, oder ?
                        von grün auf gelb ok , aber abschalten ?
                        • E Elektroman
                          @afuerhoff
                          ok 😊
                          afuerhoffA Offline
                          afuerhoffA Offline
                          afuerhoff
                          @Elektroman
                          Hallo, ich glaube, dass da noch irgendetwas in der Konfiguration nicht korrekt ist.
                          Der aktualisiert dann entsprechend die Mac- und IP-Adresse der Familienmitgliedern.
                          Warum hast du keinen History Adapter ausgewählt?
                          Bitte alles nochmal prüfen. Auch User und Passwort.
                          Es könnte auch sein, dass sich bei einer falschen Einstellung die Fritzbox schon wieder aufgehängt hat. Der Adapter läuft bei dir nicht sauber durch.
                            @Elektroman
                            Elektroman
                            @afuerhoff
                            ich habe jetzt noch mal alles neu eingegeben
                            Jetzt funktioniert wieder alles. Fragt sich nur wie lange!
                            Aber erst mal vielen Dank für die Hilfe!!!!!!
