  4. Update von Adaptern funktioniert nicht mehr
jscontroller adapterupdate
65 Beiträge 6 Kommentatoren 8.0k Aufrufe 5 Beobachtet
  • Mrs-BM Mrs-B
    @Thomas-Braun
    pi@Mrs-Biesly-Pi:~ $ dmesg
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 5.4.51-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1333 SMP Mon Aug 10 16:51:40 BST 2020
    [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] On node 0 totalpages: 1012736
    [    0.000000]   DMA zone: 2304 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
    [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
    [    0.000000] percpu: Embedded 20 pages/cpu s49856 r8192 d23872 u81920
    [    0.000000] pcpu-alloc: s49856 r8192 d23872 u81920 alloc=20*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010432
    [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 video=HDMI-A-1:640x480M@60 smsc95xx.macaddr=DC:A6:32:40:55:18 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x17cc0000-0x1bcc0000] (64MB)
    [    0.000000] Memory: 3655620K/4050944K available (10240K kernel code, 725K rwdata, 2740K rodata, 2048K init, 853K bss, 133180K reserved, 262144K cma-reserved, 3264512K highmem)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 30051 entries in 59 pages
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] random: get_random_bytes called from start_kernel+0x340/0x518 with crng_init=0
    [    0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
    [    0.000031] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
    [    0.000111] bcm2835: system timer (irq = 17)
    [    0.000780] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
    [    0.000800] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
    [    0.000820] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
    [    0.000837] Switching to timer-based delay loop, resolution 18ns
    [    0.001078] Console: colour dummy device 80x30
    [    0.001573] printk: console [tty1] enabled
    [    0.001635] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
    [    0.001676] pid_max: default: 32768 minimum: 301
    [    0.002000] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.002041] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.003216] Disabling memory control group subsystem
    [    0.003330] CPU: Testing write buffer coherency: ok
    [    0.003816] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.004664] Setting up static identity map for 0x200000 - 0x20003c
    [    0.004865] rcu: Hierarchical SRCU implementation.
    [    0.005501] smp: Bringing up secondary CPUs ...
    [    0.006655] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.007922] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.009132] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.009276] smp: Brought up 1 node, 4 CPUs
    [    0.009345] SMP: Total of 4 processors activated (432.00 BogoMIPS).
    [    0.009370] CPU: All CPU(s) started in HYP mode.
    [    0.009393] CPU: Virtualization extensions available.
    [    0.010178] devtmpfs: initialized
    [    0.023180] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
    [    0.023451] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.023498] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.031250] pinctrl core: initialized pinctrl subsystem
    [    0.032293] NET: Registered protocol family 16
    [    0.035888] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [    0.037551] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.037585] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.037924] Serial: AMBA PL011 UART driver
    [    0.041337] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    [    0.060892] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-09-02 21:13, variant start
    [    0.070875] raspberrypi-firmware soc:firmware: Firmware hash is 4439d2aaa6c376a2d1ef4402f142e1cf4de37c43
    [    0.123725] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
    [    0.128174] vgaarb: loaded
    [    0.128647] SCSI subsystem initialized
    [    0.128881] usbcore: registered new interface driver usbfs
    [    0.128978] usbcore: registered new interface driver hub
    [    0.129106] usbcore: registered new device driver usb
    [    0.130599] clocksource: Switched to clocksource arch_sys_counter
    [    0.881741] VFS: Disk quotas dquot_6.6.0
    [    0.881861] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    0.882047] FS-Cache: Loaded
    [    0.882246] CacheFiles: Loaded
    [    0.883058] simple-framebuffer 3ea9b000.framebuffer: framebuffer at 0x3ea9b000, 0x12c000 bytes, mapped to 0x(ptrval)
    [    0.883098] simple-framebuffer 3ea9b000.framebuffer: format=a8r8g8b8, mode=640x480x32, linelength=2560
    [    0.885073] Console: switching to colour frame buffer device 80x30
    [    0.887731] simple-framebuffer 3ea9b000.framebuffer: fb0: simplefb registered!
    [    0.899587] thermal_sys: Registered thermal governor 'step_wise'
    [    0.899953] NET: Registered protocol family 2
    [    0.902847] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    [    0.904977] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [    0.907137] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.908285] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.909496] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    0.910660] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    0.912019] NET: Registered protocol family 1
    [    0.913848] RPC: Registered named UNIX socket transport module.
    [    0.915011] RPC: Registered udp transport module.
    [    0.916146] RPC: Registered tcp transport module.
    [    0.917248] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.918361] PCI: CLS 0 bytes, default 64
    [    0.921245] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    0.925560] Initialise system trusted keyrings
    [    0.926872] workingset: timestamp_bits=14 max_order=20 bucket_order=6
    [    0.938551] FS-Cache: Netfs 'nfs' registered for caching
    [    0.940343] NFS: Registering the id_resolver key type
    [    0.941492] Key type id_resolver registered
    [    0.942547] Key type id_legacy registered
    [    0.943576] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.945672] Key type asymmetric registered
    [    0.946705] Asymmetric key parser 'x509' registered
    [    0.947878] bounce: pool size: 64 pages
    [    0.948899] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
    [    0.951081] io scheduler mq-deadline registered
    [    0.952058] io scheduler kyber registered
    [    0.956746] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
    [    0.957731] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
    [    0.959627] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
    [    0.961640] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0000000000
    [    1.022707] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
    [    1.024059] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
    [    1.025102] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    1.026125] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
    [    1.028160] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [    1.029405] pci 0000:00:00.0: PME# supported from D0 D3hot
    [    1.033817] PCI: bus0: Fast back to back transfers disabled
    [    1.035049] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [    1.036223] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
    [    1.037661] pci 0000:01:00.0: PME# supported from D0 D3cold
    [    1.042032] PCI: bus1: Fast back to back transfers disabled
    [    1.043097] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
    [    1.044150] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
    [    1.046167] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    1.047174] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
    [    1.048484] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
    [    1.049721] pcieport 0000:00:00.0: PME: Signaling with IRQ 55
    [    1.051121] pcieport 0000:00:00.0: AER: enabled with IRQ 55
    [    1.052411] pci 0000:01:00.0: enabling device (0140 -> 0142)
    [    1.059928] iproc-rng200 fe104000.rng: hwrng registered
    [    1.061231] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    [    1.063703] vc-sm: Videocore shared memory driver
    [    1.065159] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
    [    1.078688] brd: module loaded
    [    1.091622] loop: module loaded
    [    1.093889] Loading iSCSI transport class v2.0-870.
    [    1.096718] libphy: Fixed MDIO Bus: probed
    [    1.098195] bcmgenet fd580000.ethernet: failed to get enet clock
    [    1.099142] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
    [    1.100069] bcmgenet fd580000.ethernet: failed to get enet-wol clock
    [    1.101035] bcmgenet fd580000.ethernet: failed to get enet-eee clock
    [    1.101942] bcmgenet: Skipping UMAC reset
    [    1.120633] libphy: bcmgenet MII bus: probed
    [    1.210695] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
    [    1.212596] usbcore: registered new interface driver r8152
    [    1.213546] usbcore: registered new interface driver lan78xx
    [    1.214459] usbcore: registered new interface driver smsc95xx
    [    1.215686] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    1.216533] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
    [    1.220440] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
    [    1.223463] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
    [    1.225237] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.227036] usb usb1: Product: xHCI Host Controller
    [    1.227942] usb usb1: Manufacturer: Linux 5.4.51-v7l+ xhci-hcd
    [    1.228860] usb usb1: SerialNumber: 0000:01:00.0
    [    1.230359] hub 1-0:1.0: USB hub found
    [    1.231394] hub 1-0:1.0: 1 port detected
    [    1.232831] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    1.233752] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
    [    1.235571] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
    [    1.237049] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
    [    1.239020] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.241075] usb usb2: Product: xHCI Host Controller
    [    1.242138] usb usb2: Manufacturer: Linux 5.4.51-v7l+ xhci-hcd
    [    1.243227] usb usb2: SerialNumber: 0000:01:00.0
    [    1.244840] hub 2-0:1.0: USB hub found
    [    1.245981] hub 2-0:1.0: 4 ports detected
    [    1.248435] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [    1.249719] dwc_otg: FIQ enabled
    [    1.249731] dwc_otg: NAK holdoff enabled
    [    1.249743] dwc_otg: FIQ split-transaction FSM enabled
    [    1.249757] Module dwc_common_port init
    [    1.250190] usbcore: registered new interface driver uas
    [    1.251335] usbcore: registered new interface driver usb-storage
    [    1.252496] mousedev: PS/2 mouse device common for all mice
    [    1.255468] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [    1.258870] sdhci: Secure Digital Host Controller Interface driver
    [    1.259817] sdhci: Copyright(c) Pierre Ossman
    [    1.261327] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
    [    1.262791] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.267498] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.268769] hidraw: raw HID events driver (C) Jiri Kosina
    [    1.269943] usbcore: registered new interface driver usbhid
    [    1.270979] usbhid: USB HID core driver
    [    1.272960] vchiq: vchiq_init_state: slot_zero = (ptrval)
    [    1.275849] [vc_sm_connected_init]: start
    [    1.285071] [vc_sm_connected_init]: end - returning 0
    [    1.288021] Initializing XFRM netlink socket
    [    1.288960] NET: Registered protocol family 17
    [    1.289934] Key type dns_resolver registered
    [    1.291214] Registering SWP/SWPB emulation handler
    [    1.292401] registered taskstats version 1
    [    1.293260] Loading compiled-in X.509 certificates
    [    1.294588] Key type ._fscrypt registered
    [    1.295443] Key type .fscrypt registered
    [    1.306236] uart-pl011 fe201000.serial: cts_event_workaround enabled
    [    1.307184] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
    [    1.317791] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    [    1.320515] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [    1.321513] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [    1.373165] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [    1.375737] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.378264] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.382065] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [    1.384525] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.390047] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
    [    1.394453] of_cfs_init
    [    1.395482] of_cfs_init: OK
    [    1.397267] Waiting for root device PARTUUID=6c586e13-02...
    [    1.433011] random: fast init done
    [    1.459453] mmc1: new high speed SDIO card at address 0001
    [    1.499302] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
    [    1.501079] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
    [    1.504967]  mmcblk0: p1 p2
    [    1.520079] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    1.521884] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    1.529307] devtmpfs: mounted
    [    1.538139] Freeing unused kernel memory: 2048K
    [    1.560894] Run /sbin/init as init process
    [    1.610656] usb 1-1: new high-speed USB device number 2 using xhci_hcd
    [    1.793300] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
    [    1.795021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [    1.795924] usb 1-1: Product: USB2.0 Hub
    [    1.798973] hub 1-1:1.0: USB hub found
    [    1.800161] hub 1-1:1.0: 4 ports detected
    [    2.032251] systemd[1]: System time before build time, advancing clock.
    [    2.120673] usb 1-1.2: new high-speed USB device number 3 using xhci_hcd
    [    2.135866] NET: Registered protocol family 10
    [    2.138141] Segment Routing with IPv6
    [    2.180174] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
    [    2.185828] systemd[1]: Detected architecture arm.
    [    2.251053] systemd[1]: Set hostname to <Mrs-Biesly-Pi>.
    [    2.256707] usb 1-1.2: New USB device found, idVendor=ffff, idProduct=5678, bcdDevice= 2.00
    [    2.258779] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [    2.260908] usb 1-1.2: Product: Disk 2.0
    [    2.261972] usb 1-1.2: Manufacturer: USB
    [    2.263005] usb 1-1.2: SerialNumber: 5023781253480546570
    [    2.266630] usb-storage 1-1.2:1.0: USB Mass Storage device detected
    [    2.269532] scsi host0: usb-storage 1-1.2:1.0
    [    2.380716] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
    [    2.519899] usb 1-1.4: New USB device found, idVendor=0451, idProduct=16a8, bcdDevice= 0.09
    [    2.522211] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [    2.524354] usb 1-1.4: Product: TI CC2531 USB CDC
    [    2.525450] usb 1-1.4: Manufacturer: Texas Instruments
    [    2.526524] usb 1-1.4: SerialNumber: __0X00124B000E0EA98B
    [    3.054622] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.068668] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.073013] systemd[1]: Created slice system-getty.slice.
    [    3.075792] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.077899] systemd[1]: Created slice User and Session Slice.
    [    3.080913] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    3.084883] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    3.088059] systemd[1]: Listening on udev Kernel Socket.
    [    3.091538] systemd[1]: Listening on udev Control Socket.
    [    3.094310] systemd[1]: Reached target Swap.
    [    3.292608] scsi 0:0:0:0: Direct-Access     VendorCo ProductCode      2.00 PQ: 0 ANSI: 4
    [    3.299396] sd 0:0:0:0: [sda] 122880000 512-byte logical blocks: (62.9 GB/58.6 GiB)
    [    3.300469] sd 0:0:0:0: [sda] Write Protect is off
    [    3.302712] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
    [    3.303972] sd 0:0:0:0: [sda] No Caching mode page found
    [    3.304891] sd 0:0:0:0: [sda] Assuming drive cache: write through
    [    3.376718]  sda: sda1
    [    3.380860] sd 0:0:0:0: [sda] Attached SCSI removable disk
    [    3.999227] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    4.108011] systemd-journald[121]: Received request to flush runtime journal from PID 1
    [    4.483068] sd 0:0:0:0: Attached scsi generic sg0 type 0
    [    4.711797] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.713795] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [    4.713814] [vc_sm_connected_init]: start
    [    4.723076] [vc_sm_connected_init]: installed successfully
    [    4.749419] mc: Linux media interface: v0.10
    [    4.771164] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.798121] videodev: Linux video capture interface: v2.00
    [    4.800001] bcm2835_audio bcm2835_audio: card created with 4 channels
    [    4.808556] bcm2835_audio bcm2835_audio: card created with 4 channels
    [    4.836174] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.836179] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.869213] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.874976] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.877705] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.886053] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    [    4.886368] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [    4.886424] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [    4.887042] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    [    4.887814] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    [    4.888450] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    [    4.888474] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    [    4.888494] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    [    4.888513] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    [    4.888532] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    [    4.888750] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [    4.904585] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [    4.904624] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [    4.913680] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [    4.913721] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [    5.101372] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    5.130723] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
    [    5.136921] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
    [    5.137732] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
    [    5.144468] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
    [    5.145108] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
    [    5.228379] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
    [    5.228405] checking generic (3ea9b000 12c000) vs hw (0 ffffffffffffffff)
    [    5.228426] fb0: switching to vc4drmfb from simple
    [    5.229703] Console: switching to colour dummy device 80x30
    [    5.229929] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    5.229941] [drm] No driver support for vblank timestamp query.
    [    5.229953] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
    [    5.231821] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
    [    5.233700] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    5.234323] vc4-drm gpu: HDMI-A-1: EDID is invalid:
    [    5.234342]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    [    5.234355]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    [    5.234367]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    [    5.234378]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    [    5.234390]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    [    5.234402]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    [    5.234414]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    [    5.234425]  [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    [    5.286153] brcmfmac: F1 signature read @0x18000000=0x15264345
    [    5.300851] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [    5.301301] usbcore: registered new interface driver brcmfmac
    [    5.331088] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
    [    5.385656] Console: switching to colour frame buffer device 80x30
    [    5.403705] vc4-drm gpu: fb0: vc4drmfb frame buffer device
    [    5.486370] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
    [    5.488305] usbcore: registered new interface driver cdc_acm
    [    5.488318] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    [    5.565503] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [    5.584423] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
    [    6.655885] fuse: init (API version 7.31)
    [    7.874190] random: crng init done
    [    7.874212] random: 7 urandom warning(s) missed due to ratelimiting
    [    7.901157] uart-pl011 fe201000.serial: no DMA platform data
    [    8.127953] 8021q: 802.1Q VLAN Support v1.8
    [    8.281080] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
    [    8.506079] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
    [    8.851906] bcmgenet: Skipping UMAC reset
    [    8.853423] bcmgenet fd580000.ethernet: configuring instance for external RGMII
    [    8.853616] bcmgenet fd580000.ethernet eth0: Link is Down
    [   14.150208] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    [   15.133195] Bluetooth: Core ver 2.22
    [   15.133278] NET: Registered protocol family 31
    [   15.133291] Bluetooth: HCI device and connection manager initialized
    [   15.133315] Bluetooth: HCI socket layer initialized
    [   15.133334] Bluetooth: L2CAP socket layer initialized
    [   15.133364] Bluetooth: SCO socket layer initialized
    [   15.142755] Bluetooth: HCI UART driver ver 2.3
    [   15.142769] Bluetooth: HCI UART protocol H4 registered
    [   15.142834] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [   15.143075] Bluetooth: HCI UART protocol Broadcom registered
    [   15.327876] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   15.327883] Bluetooth: BNEP filters: protocol multicast
    [   15.327896] Bluetooth: BNEP socket layer initialized
    [   15.653975] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
    [   21.440657] broken atomic modeset userspace detected, disabling atomic
    [ 1978.286480] v3d fec00000.v3d: MMU error from client L2T (0) at 0x621000, pte invalid
    @Mrs-B
    Die Hardware / die SD-Karte ist offenbar in Ordnung.
    @Homoran Die Meldung ist per se nicht schlimm, das FS wird immer erstmal ro gemounted. Wichtig ist, dass es später im Verlauf wieder ordentlich remounted wird:
    Und keine Meldungen bezüglich 'orphaned inodes' oder gelöschter inodes kommen. Das ist hier also sauber, ich habe nichts dazu gefunden.
    Mrs-BM 1 Antwort Letzte Antwort
      @Mrs-B
      Mrs-BM Offline
      Mrs-BM Offline
      Mrs-B
      @Thomas-Braun
      Danke dir für deine Hilfe :)
      • Mrs-BM Mrs-B
        @Thomas-Braun
        GlasfaserG Offline
        GlasfaserG Offline
        @Mrs-B
        und ... wie ist jetzt das Update verlaufen !?
        • GlasfaserG Glasfaser
          @Mrs-B
          Mrs-BM Offline
          Mrs-BM Offline
          Mrs-B
          @Glasfaser
          Hab es jetzt ohne "sudo" ausgeführt. Aber die Fehlermeldung bleibt gleich
          • Mrs-BM Mrs-B
            @Glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            @Mrs-B sagte in Update von Adaptern funktioniert nicht mehr:
            bitte mal zeigen
            • Mrs-BM Offline
              Mrs-BM Offline
              Mrs-B
              Muss mich auch leider aus gesundheitlichen Gründen (Depressionen) für heute hier verabschieden...
              Ist mir gerade iwie alles zu viel... Kann mich nicht weiter konzentrieren.
              Hoffe das mein Kram hier noch ne Weile läuft bis ich wieder die Kraft habe mich damit ausführlich zu beschäftigen..
              Falls jemand noch eine Idee hat was ich machen kann damit mein iobroker wieder ordentlich läuft wäre ich sehr dankbar..
              Aber wie gesagt.. Für heute bin ich leider raus 😢
                bitte mal zeigen
                Mrs-BM Offline
                Mrs-BM Offline
                Mrs-B
                @Glasfaser
                Hier noch fix der Screenshot
                • Mrs-BM Mrs-B
                  @Glasfaser
                  @Mrs-B
                  Da dürfte eine Datei korrupt sein. Ich würde vermutlich mal probieren den ioBroker noch mal drüber zu installieren.
                    @Mrs-B
                    Mrs-BM Offline
                    Mrs-BM Offline
                    Mrs-B
                    @Thomas-Braun
                    Huhu.. Da bin ich wieder :)
                    Kannst du mir einen Link senden wo beschrieben ist wie ich den iobroker "nochmal drüber installieren" kann?
                    • Mrs-BM Mrs-B
                      @Thomas-Braun
                      @Mrs-B
                      https://forum.iobroker.net/topic/33904/js-controller-3-1-jetzt-im-stable/2
                        @Mrs-B
                        Mrs-BM Offline
                        Mrs-BM Offline
                        Mrs-B
                        @Thomas-Braun
                        Lieben Dank für deinen Link :)
                        Ich habe es geschafft meine Note.js Version zu aktualisieren.
                        Und ich habe die Kommandos im Link abgearbeitet...
                        Doch leider kann ich immer noch keine Updates an Adaptern machen und auch der js-Controller geht nicht upzudaten...
                        HILFE 😞
                        • Mrs-BM Mrs-B
                          @Thomas-Braun
                          HILFE 😞
                          @Mrs-B
                          So ohne zu wissen was da bei dir nun der Wasserstand ist kann man dir auch nicht helfen.
                          Konsolenausgaben?
                            @Mrs-B
                            Konsolenausgaben?
                            Mrs-BM Offline
                            Mrs-BM Offline
                            Mrs-B
                            @Thomas-Braun
                            $ ./iobroker upgrade alexa2
                            Update alexa2 from @3.3.0 to @3.3.1
                            NPM version: 6.14.8
                            npm install iobroker.alexa2@3.3.1 --loglevel error --prefix "/opt/iobroker" (System call)
                            npm
                             ERR! Unexpected end of JSON input while parsing near '...mGYCbgkC/010kVXLGoixn'
                            npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-10-07T15_16_05_339Z-debug.log
                            upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
                            upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
                            upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
                            upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
                            upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
                            upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
                            upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
                            upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
                            upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
                            upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
                            upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
                            upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
                            upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
                            upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
                            upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
                            upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot.png icons/echo_dot.png image/png
                            upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo2.png icons/echo2.png image/png
                            upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo.png icons/echo.png image/png
                            upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo-input.png icons/echo-input.png image/png
                            upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/apps.png icons/apps.png image/png
                            upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
                            Adapter "alexa2" updated
                            process exited with code 0
                            Mrs-BM GlasfaserG 2 Antworten Letzte Antwort
                            • Mrs-BM Mrs-B
                              @Thomas-Braun
                              NPM version: 6.14.8
                              npm
                              Mrs-BM Offline
                              Mrs-BM Offline
                              Mrs-B
                              schrieb am zuletzt editiert von Mrs-B
                              @Mrs-B
                              Das bekomme ich in der GUI wenn ich den Adapter aktualisieren will..
                              Sag mir bitte was du benötigst um mir weiterhelfen zu können...
                              • Mrs-BM Mrs-B
                                @Mrs-B
                                @Mrs-B
                                Da ist immer noch eine Datei 'kaputt', würde ich sagen.
                                  @Mrs-B
                                  Mrs-BM Offline
                                  Mrs-BM Offline
                                  Mrs-B
                                  @Thomas-Braun Hab es auch mit iobroker fix schon probiert. Läuft ordentlich durch..
                                  Und auch sonst läuft ER noch.. Wenn ich per Alexa Scripte abfrage bekomme ich antwort...
                                  • Mrs-BM Mrs-B
                                    @Thomas-Braun
                                    NPM version: 6.14.8
                                    npm
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Kannst du uns mal das Log dazu geben .
                                    Der Adapter wurden aber geupdate !
                                      Mrs-BM Offline
                                      Mrs-BM Offline
                                      Mrs-B
                                      @Glasfaser
                                      SCHÄM...
                                      Leider hab ich von Linux nicht wirkklich nen Plan.. Wird ja ne Log-Datei auf der SD-Karte sein.. Oder??
                                      Wenn ja... Wie komm ich da mal eben so ran?? (PS... bin halt ein Windows-Mensch..)
                                      • Mrs-BM Mrs-B
                                        @Glasfaser
                                        SCHÄM...
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @Mrs-B
                                        Warte mal :
                                        Mach mal das
                                        cd /opt/iobroker
                                        iobroker stop
                                        npm cache clean --force
                                        iobroker start
                                          @Mrs-B
                                          Warte mal :
                                          Mach mal das
                                          cd /opt/iobroker
                                          iobroker stop
                                          iobroker start
                                          Mrs-BM Offline
                                          Mrs-BM Offline
                                          Mrs-B
                                          @Glasfaser
                                          Hab ich gemacht. Danach den Browser auf meinem System aktualisiert...
                                          Aber er zeigt mir noch immer das 12 Adapter zu aktualisieren sind (einschließlich Alexa... und Js-controller...)
