[Neuer Adapter] Xiaomi Luftfilter
Hi, ich hab den 3H bekomme ihn aber nicht in den ioBroker ...
miio.0 2020-03-13 15:20:12.571 info (26954) 282466473 becomes unavailable. miio.0 2020-03-13 15:19:42.100 info (26954) Create state object devices.282466473.illuminance miio.0 2020-03-13 15:19:42.100 info (26954) Create state object devices.282466473.motor1Speed miio.0 2020-03-13 15:19:42.099 info (26954) Create state object devices.282466473.filterUsedTime miio.0 2020-03-13 15:19:42.099 info (26954) Create state object devices.282466473.filterLife miio.0 2020-03-13 15:19:42.099 info (26954) Create state object devices.282466473.aqi miio.0 2020-03-13 15:19:42.099 info (26954) Create state object devices.282466473.ledBrightnessLevel miio.0 2020-03-13 15:19:42.099 info (26954) Create state object devices.282466473.buzzer miio.0 2020-03-13 15:19:42.099 info (26954) Create state object devices.282466473.childLock miio.0 2020-03-13 15:19:42.098 info (26954) Create state object devices.282466473.led miio.0 2020-03-13 15:19:42.098 info (26954) Create state object devices.282466473.mode miio.0 2020-03-13 15:19:42.098 info (26954) Create state object devices.282466473.power miio.0 2020-03-13 15:19:42.098 info (26954) Create state object devices.282466473.model miio.0 2020-03-13 15:19:42.097 info (26954) Create state object devices.282466473.connected miio.0 2020-03-13 15:19:42.092 info (26954) New device: zhimi.airpurifier.mb3. ID 282466473 miio.0 2020-03-13 15:19:42.031 info (26954) new airpurifier device miio.0 2020-03-13 15:19:42.012 info (26954) All defined devices are created miio.0 2020-03-13 15:19:41.995 info (26954) 192.168.1.56 added. miio.0 2020-03-13 15:19:41.752 info (26954) starting. Version 0.0.13 in /opt/iobroker/node_modules/iobroker.miio, node: v8.15.0 -
Token kannste doch auf andere Wege auch auslesen. Mit der Mi Home App
iOS = iBackupViewer
Android habe ich nicht, sollte aber einfach sein.
https://www.smarthomeassistent.de/token-auslesen-roborock-s6-roborock-s5-xiaomi-mi-robot-xiaowa/Bin jetzt Besitzer eines 2H. Würde auch bei Tests unterstützen und bei der Entwicklung helfen, wenn nötig/möglich.
Hallo zusammen
Ich habe seit heute einen Air Purifier 2H und ich würde diesen gerne über den ioBroker steuern. Leider unterstützt der Adapter derzeit nur den 2 und den 2S.
Ich Frage mich, wie man dem Entwickler dabei helfen kann auch den 2H zu unterstützen?!?
Gruß und bleibt gesund.
Tobi -
Hallo zusammen
Tobi@dontobi said in [Neuer Adapter] Xiaomi Luftfilter:
Hallo zusammen
TobiHi schon mal eine ältere Adapterversion ausprobiert? Ich habe ein Purifier Pro und der funktioniert auch nicht.
Wenn ich allersings die 0.1.4 installiere kann ich ihn problemlos ansteuern. -
Hallo zusammen
Wenn ich allersings die 0.1.4 installiere kann ich ihn problemlos ansteuern.@Mooo Danke für den Hinweis. Mit der 0.1.4 kann ich meinen AirPurifier 2h steuern. Werde das im Github Issue mal dokumentieren. Jetzt muss ich nur schauen, wie ich das Updaten des Adapters unterbinden kann. Lasse einmal in der Woche die Adapter aktualisieren (per Commandozeile).
An alle, die einen Air purifier (bei mir der Air purifier 3H) haben, der nicht vom Adapter unterstützt wird ein kleiner Tipp, wie man die Daten doch in iobroker bekommt, ohne, dass man auf irgendein Update hier noch hoffen muss:
- Installiert den iobroker-Adapter mihome-vacuum
- Tragt dort Eure Kontodaten ein und lest die Geräte aus, schon habt ihr den Token vom Air Purifier
- Installiert Euch FHEM (als VM, als LXC, nativ auf Raspi oder sonstwie), wenn ihr es, wie ich, nicht eh schon laufen habt
- Richtet den Air Purifier in FHEM ein. Im FHEM-Forum ist alles beschrieben, das meiste gleich im ersten Thread. Wichtig: Wählt den richtigen subType, bei mir z.B. Airpurifier3H. IP-Adresse solltet ihr eh haben, den Token kopiert ihr aus dem mihome-vacuum-Adapter in iobroker
- Nach kurzer Zeit ist alles in FHEM eingerichtet und die Daten zu Filter, Status, 2.5ppm usw. tauchen auf
- Weisst in FHEM dem airpurifier den Raum iobroker zu. Das ist wichtig, da nur solche Geräte nach iobroker kommen. Macht man das nicht, hat man ALLES aus FHEM anschliessend in iobroker, braucht man nicht wirklich
- Installiert in iobroker den FHEM-Adapter, tragt dort die nötigen Daten ein und schon habt ihr den Air Purifier in iobroker.
Ob zur Verbindung FHEM-iobroker zusätzliche Dinge nötig sind, weiss ich nicht, läuft bei mir seit Jahren. Im Zweifel steht das sicher beim FHEM-Adapter in iobroker irgendwo.
Viel Erfolg.
Gruss, Jürgen
Viel Erfolg.
Gruss, Jürgen
Moin!
Klasse tip...ich bin einen anderen weg gegangen.
Habe den homebridge adapter installiert und dieses plugin geladen:
https://github.com/rgavril/homebridge-xiaomi-air-purifier3#readmeHabe damit Zugriff auf den Ventilator.
Leider kann ich nur zwischen auto und manual umschalten.
Die direkte Steuerung des Ventialators funktioniert leider nicht. Sehe die aktuelle Drehzahl in % aber leider kann ich diese nicht ändern.Hat jemand diesen Weg probiert?
Mr.Lee -
Viel Erfolg.
Gruss, Jürgen
@Wildbill weißt du noch mit welcher Version du das gemacht hast ? Und du hast wahrscheinlich einen Acc in der Mii Home App erstellt ?! Wir versuchen gerade den Token unserer Mi Air Puriffer 2H auszulesen... Mein Mann hat sich allerdings in der Mi Home App mit seinen Apple-Daten angemeldet.. Fürchte, dass es hierfür dann nicht klappen wird.
Danke und Gruß
Danke und Gruß
@kamikazemimmi ok - also für die Xiaomi App haben wir Acc erstellt und token wurde angezeigt. Hatten jetzt versucht damit versucht die mihome-plug zu füttern, aber unser Purifier 2H lässt sich leider nicht ansteuern...
Den Weg über FHEM finde ich etwas umständlich...Kennt noch jemand einen Weg ?Danke und Gruß
Ok... nächste Frage.. habe jetzt einfach mal versucht, den Adapter aus GIT zu installieren... Ist auch installiert, sehe aber keine Instanz... Und / oder Objekte... Hat jemand eine Idee ?
Danke und Gruß
Danke und Gruß
hab jetzt noch mal versucht, den Adapter über npm zu installieren und dabei folgende Meldungen erhalten:
:/opt/iobroker# npm install iobroker.mihome-airpurifier npm WARN babel-eslint@10.1.0 requires a peer of eslint@>= 4.12.1 but none is installed. You must install peer dependencies yourself. npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman-converters/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/zigbee-herdsman/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) + iobroker.mihome-airpurifier@0.1.8 updated 1 package in 16.065s 99 packages are looking for funding run `npm fund` for detailsMal sehen, was ich da noch so rausfinde. Dacht aber, ich poste das mal, falls jemand einen Tipp hat.
LG
@kamikazemimmi Mit der Version 0.1.4 (also einer etwas älteren) sollte der 2H direkt vom Adapter aus steuerbar sein. Steht zumindest HIER in einem Issue zum 2H.
Auf welcher Hardware/Betriebssystem hast Du iobroker laufen? Die Meldungen sind übrigens unkritisch. Der obere Bereich weisst auf mögliche optionale Abhängigkeiten in Zusammenhang mit dem Zigbee-Adapter hin, brauchst Du aber nicht zwingend. Also nach einem Fehler sieht da nichts aus.
Wenn Du manuell von Guthub installierst, musst Du unter Umständen selbst eine Instanz des Adapters anlegen. In iobroker auf der Seite Adapters ziemlich rechts das +. Vorher solltest Du aber daneben den Pfeil nach oben klicken, um einen Upload zu machen. Ist bei Github-Sachen manchmal nötig. Wenn Du das nicht siehts, musst Du oben in der Leiste den Expterenmodus einschalten.
Wobei ich mich zu erinnern meine, dass bei diesem Adapter keine alte Version zu holen war.
Da der 2H wohl nur bis 0.1.4 ging wirst Du da wenig Glück haben. Umweg über FHEM oder Homebridge ist dann wohl das kleinere Übel, bevor gar nichts geht...Gruss, Jürgen
@Wildbill Danke für die Antwort.
iobroker läuft als VM auf einem Xenserver unter debian stretch. Dann versuch ich mal manuell eine Instanz zu bekommen und suche doch mal, ob die 0.1.4 finde...
Hätte auch gedacht, dass die Meldungen unkritisch sind, aber war mir halt nicht sicher. Und da ich keine Instanz sah, wollt ich der Vollständigkeit halber lieber mal die Spezies fragen😉
Hoffe, ich werde was 🙏😉Danke und Gruß
Melanie -
MelanieMoin,moin !
Also Instanz hab ich hinzugefügt. Als ich den Link von @Wildbill folgte, bin ich darüber gestolpert, dass eine Datei "nur" ergänzt wurde: link text
(Hinweis wurde bei link text gegeben.)
Meine Patch-Zeiten sind schon etwas her, daher hab ich die Zeilen 37+38 (bei mir unter /opt/iobroker/node_modules/miio/lib/models.js) in die models.js eingefügt, Adapter neu gestartet und nun reagiert der Luftfilter erst mal auf an und ausschalten🤗
Ich teste weiter und meld mich, wenn mir noch etwas erwähnenswertes auffällt.LG
Melanie -
Moin,moin !
MelanieAch ich freu mich - scheint zu laufen🤗
Also vielleicht noch mal der Vollständigkeit halber für Interessierte: wir haben ja den 2H.
Token haben wir ausgelesen, wie in @Wildbill Beitrag erwähnt mit mihome-vacuum
dann hier die App installiert,
Instanz hinzugefügt, Daten eingetragen, (bei Version hab ich "2" ausgewählt)
unter /opt/iobroker/node_modules/miio/lib/models.js die beiden erwähnten Zeilen aus link text eingetragen,
Instanz neu gestartet und der 2H kann jetzt gesteuert werdenVielleicht noch der Hinweis, dass bei der Instanz unter "Version" nicht 2H auftaucht. Ich hab "2" gelassen und kann ihn trotzdem steuern.
LG
Melanie
