[Neuer Adapter] Xiaomi Luftfilter
Hi, ich hab den 3H bekomme ihn aber nicht in den ioBroker ...
miio.0 2020-03-13 15:20:12.571 info (26954) 282466473 becomes unavailable. miio.0 2020-03-13 15:19:42.100 info (26954) Create state object devices.282466473.illuminance miio.0 2020-03-13 15:19:42.100 info (26954) Create state object devices.282466473.motor1Speed miio.0 2020-03-13 15:19:42.099 info (26954) Create state object devices.282466473.filterUsedTime miio.0 2020-03-13 15:19:42.099 info (26954) Create state object devices.282466473.filterLife miio.0 2020-03-13 15:19:42.099 info (26954) Create state object devices.282466473.aqi miio.0 2020-03-13 15:19:42.099 info (26954) Create state object devices.282466473.ledBrightnessLevel miio.0 2020-03-13 15:19:42.099 info (26954) Create state object devices.282466473.buzzer miio.0 2020-03-13 15:19:42.099 info (26954) Create state object devices.282466473.childLock miio.0 2020-03-13 15:19:42.098 info (26954) Create state object devices.282466473.led miio.0 2020-03-13 15:19:42.098 info (26954) Create state object devices.282466473.mode miio.0 2020-03-13 15:19:42.098 info (26954) Create state object devices.282466473.power miio.0 2020-03-13 15:19:42.098 info (26954) Create state object devices.282466473.model miio.0 2020-03-13 15:19:42.097 info (26954) Create state object devices.282466473.connected miio.0 2020-03-13 15:19:42.092 info (26954) New device: zhimi.airpurifier.mb3. ID 282466473 miio.0 2020-03-13 15:19:42.031 info (26954) new airpurifier device miio.0 2020-03-13 15:19:42.012 info (26954) All defined devices are created miio.0 2020-03-13 15:19:41.995 info (26954) 192.168.1.56 added. miio.0 2020-03-13 15:19:41.752 info (26954) starting. Version 0.0.13 in /opt/iobroker/node_modules/iobroker.miio, node: v8.15.0 -
ich bekomme den Xiaomiairpurifier Adapter nicht installiert.
Installation über die Katze mit https://github.com/JoJ123/ioBroker.xiaomiairpurifier
Dann passiert erstmal ne ganze Weile nichts,
dann kommt im Log folgendes
host.IOBroker-Sted1 2020-03-19 12:37:39.224 info iobroker exit 25
host.IOBroker-Sted1 2020-03-19 12:37:38.211 error iobroker host.IOBroker-Sted1 Cannot install https://github.com/JoJ123/ioBroker.xiaomiairpurifier/tarball/eb7806dabcbcdb88d127c9f18fcd8af34357dc8a: null
Im Adapterfenster steht folgendes
Fertig mit Fehler: host.IOBroker-Sted1 Cannot install https://github.com/JoJ123/ioBroker.xiaomiairpurifier/tarball/eb7806dabcbcdb88d127c9f18fcd8af34357dc8a: null
Ist der Link falsch oder was anderes?
Beste Grüsse paul -
Beste Grüsse paul -
Hallo
Über die Katze weil im ersten Beitrag so stand, das mit der Adapterliste habe ich wohl überlesen.
Jetzt über die Adapterliste installiert. Wenn ich die Instanz über den Schraubenschlüssel
öffne, kommt File index_m.html not found
JS ist 2.2.9 , Admin ist 3.7.8
Wat issen dat.
Beste Grüsse paul -
Hallo
Wat issen dat.
Beste Grüsse paul -
Ich kriege morgen den Xiaomi Airpurifier 3H, werde dann mal testen ob ich den verbinden kann.
Welche Infos müsstetst du sonst gegebenenfalls haben, um diesen einzubinden?
@derBonsaii würde mich auch interessieren meiner kommt heute
Token kannste doch auf andere Wege auch auslesen. Mit der Mi Home App
iOS = iBackupViewer
Android habe ich nicht, sollte aber einfach sein.
https://www.smarthomeassistent.de/token-auslesen-roborock-s6-roborock-s5-xiaomi-mi-robot-xiaowa/Bin jetzt Besitzer eines 2H. Würde auch bei Tests unterstützen und bei der Entwicklung helfen, wenn nötig/möglich.
Hallo zusammen
Ich habe seit heute einen Air Purifier 2H und ich würde diesen gerne über den ioBroker steuern. Leider unterstützt der Adapter derzeit nur den 2 und den 2S.
Ich Frage mich, wie man dem Entwickler dabei helfen kann auch den 2H zu unterstützen?!?
Gruß und bleibt gesund.
Tobi -
Hallo zusammen
Tobi@dontobi said in [Neuer Adapter] Xiaomi Luftfilter:
Hallo zusammen
TobiHi schon mal eine ältere Adapterversion ausprobiert? Ich habe ein Purifier Pro und der funktioniert auch nicht.
Wenn ich allersings die 0.1.4 installiere kann ich ihn problemlos ansteuern. -
Hallo zusammen
Wenn ich allersings die 0.1.4 installiere kann ich ihn problemlos ansteuern.@Mooo Danke für den Hinweis. Mit der 0.1.4 kann ich meinen AirPurifier 2h steuern. Werde das im Github Issue mal dokumentieren. Jetzt muss ich nur schauen, wie ich das Updaten des Adapters unterbinden kann. Lasse einmal in der Woche die Adapter aktualisieren (per Commandozeile).
An alle, die einen Air purifier (bei mir der Air purifier 3H) haben, der nicht vom Adapter unterstützt wird ein kleiner Tipp, wie man die Daten doch in iobroker bekommt, ohne, dass man auf irgendein Update hier noch hoffen muss:
- Installiert den iobroker-Adapter mihome-vacuum
- Tragt dort Eure Kontodaten ein und lest die Geräte aus, schon habt ihr den Token vom Air Purifier
- Installiert Euch FHEM (als VM, als LXC, nativ auf Raspi oder sonstwie), wenn ihr es, wie ich, nicht eh schon laufen habt
- Richtet den Air Purifier in FHEM ein. Im FHEM-Forum ist alles beschrieben, das meiste gleich im ersten Thread. Wichtig: Wählt den richtigen subType, bei mir z.B. Airpurifier3H. IP-Adresse solltet ihr eh haben, den Token kopiert ihr aus dem mihome-vacuum-Adapter in iobroker
- Nach kurzer Zeit ist alles in FHEM eingerichtet und die Daten zu Filter, Status, 2.5ppm usw. tauchen auf
- Weisst in FHEM dem airpurifier den Raum iobroker zu. Das ist wichtig, da nur solche Geräte nach iobroker kommen. Macht man das nicht, hat man ALLES aus FHEM anschliessend in iobroker, braucht man nicht wirklich
- Installiert in iobroker den FHEM-Adapter, tragt dort die nötigen Daten ein und schon habt ihr den Air Purifier in iobroker.
Ob zur Verbindung FHEM-iobroker zusätzliche Dinge nötig sind, weiss ich nicht, läuft bei mir seit Jahren. Im Zweifel steht das sicher beim FHEM-Adapter in iobroker irgendwo.
Viel Erfolg.
Gruss, Jürgen
Viel Erfolg.
Gruss, Jürgen
Moin!
Klasse tip...ich bin einen anderen weg gegangen.
Habe den homebridge adapter installiert und dieses plugin geladen:
https://github.com/rgavril/homebridge-xiaomi-air-purifier3#readmeHabe damit Zugriff auf den Ventilator.
Leider kann ich nur zwischen auto und manual umschalten.
Die direkte Steuerung des Ventialators funktioniert leider nicht. Sehe die aktuelle Drehzahl in % aber leider kann ich diese nicht ändern.Hat jemand diesen Weg probiert?
Mr.Lee -
Viel Erfolg.
Gruss, Jürgen
@Wildbill weißt du noch mit welcher Version du das gemacht hast ? Und du hast wahrscheinlich einen Acc in der Mii Home App erstellt ?! Wir versuchen gerade den Token unserer Mi Air Puriffer 2H auszulesen... Mein Mann hat sich allerdings in der Mi Home App mit seinen Apple-Daten angemeldet.. Fürchte, dass es hierfür dann nicht klappen wird.
Danke und Gruß
Danke und Gruß
@kamikazemimmi ok - also für die Xiaomi App haben wir Acc erstellt und token wurde angezeigt. Hatten jetzt versucht damit versucht die mihome-plug zu füttern, aber unser Purifier 2H lässt sich leider nicht ansteuern...
Den Weg über FHEM finde ich etwas umständlich...Kennt noch jemand einen Weg ?Danke und Gruß
