  4. ioBroker unter Windows installieren (ohne Installer)
    6.3k
händischinstallationiobrokermanuellwindowswindows-installationwindows-installer
319 Beiträge 30 Kommentatoren 187.7k Aufrufe 28 Beobachtet
  • D DasBrot
    @bahnuhr said in ioBroker unter Windows installieren (ohne Installer):
    iobroker start
    Leider das selbe Ergebnis.
    Webinterface lässt sich nicht mehr starten. :
    *** Welcome to ioBroker. ***
    *** Type 'iobroker help' for list of instructions. ***
    *** For more help see ***
    *** https://github.com/ioBroker/ioBroker.docs ***
    Your environment has been set up for using Node.js 10.17.0 (x64) and npm.
    C:\Program Files\iobroker\SmartHome8>iobroker stop
    2020-09-28 13:08:53,619 INFO - Stopping the service with id 'iobroker(SmartHome8)'
    C:\Program Files\iobroker\SmartHome8>npm i iobroker.js-controller@2.2.10
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    iobroker.js-controller@2.2.10 preinstall C:\Program Files\iobroker\SmartHome8\node_modules\iobroker.js-controller
    node lib/preinstallCheck.js
    NPM version: 6.11.3
    unix-dgram@2.0.3 install C:\Program Files\iobroker\SmartHome8\node_modules\unix-dgram
    node-gyp rebuild
    C:\Program Files\iobroker\SmartHome8\node_modules\unix-dgram>if not defined npm_config_node_gyp (node "C:\Program Files\iobroker\SmartHome8\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\....\node_modules\node-gyp\bin\node-gyp.js" rebuild ) else (node "C:\Program Files\iobroker\SmartHome8\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
    Die Projekte in dieser Projektmappe werden nacheinander erstellt. Um eine parallele Erstellung zu ermöglichen, müssen Sie den Schalter "/m" hinzufügen.
    unix_dgram.cc
    win_delay_load_hook.cc
    c:\program files\iobroker\smarthome8\node_modules\unix-dgram\src\unix_dgram.cc(9): fatal error C1083: Datei (Include) k
    ann nicht geöffnet werden: "unistd.h": No such file or directory [C:\Program Files\iobroker\SmartHome8\node_modules\uni
    x-dgram\build\unix_dgram.vcxproj]
    gyp ERR! build error
    gyp ERR! stack Error: C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe failed with exit code: 1
    gyp ERR! stack at ChildProcess.onExit (C:\Program Files\iobroker\SmartHome8\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:193:23)
    gyp ERR! stack at ChildProcess.emit (events.js:198:13)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Windows_NT 10.0.18362
    gyp ERR! command "C:\Program Files\iobroker\SmartHome8\nodejs\node.exe" "C:\Program Files\iobroker\SmartHome8\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
    gyp ERR! cwd C:\Program Files\iobroker\SmartHome8\node_modules\unix-dgram
    gyp ERR! node -v v10.17.0
    gyp ERR! node-gyp -v v5.0.3
    gyp ERR! not ok
    iobroker.js-controller@2.2.10 install C:\Program Files\iobroker\SmartHome8\node_modules\iobroker.js-controller
    node iobroker.js setup first
    object 0_userdata.0.example_state created
    The following notifications happened during sync:
    • Ignoring Directory "hm-rega" because officially not created as meta object. Please remove directory!
    • Ignoring Directory "tr-064.admin" because officially not created as meta object. Please remove directory!
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules\chokidar\node_modules\fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.3 (node_modules\unix-dgram):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.3 install: node-gyp rebuild
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    • iobroker.js-controller@2.2.10
      added 7 packages from 9 contributors, removed 1391 packages, updated 75 packages, moved 3 packages and audited 303 packages in 38.539s
      found 1 low severity vulnerability
      run npm audit fix to fix them, or npm audit for details
    C:\Program Files\iobroker\SmartHome8>iobroker start
    2020-09-28 13:11:02,447 INFO - Starting the service with id 'iobroker(SmartHome8)'
    sigi234S Online
    sigi234S Online
    #221
    @DasBrot
    Hast du das gemacht?
    Folgende Schritte sind bei einem Update und Neuinstallation zwingend notwendig:
    data-Ordner sichern (nur bei Update)
    Frische Installation mit dem Installer von der Webseite (2019-11-23) aufsetzen. Dabei (falls Update) den zuvor gesicherten data-Ordner durch den Installer einlesen.
    Nichts weiter tun!
    ioBroker-Konsole der neuen Installation auf
    iobroker stop
    npm i iobroker.js-controller@stable --ignore-scripts
    iobroker start
    • D DasBrot
      iobroker start
      NPM version: 6.11.3
      node-gyp rebuild
      unix_dgram.cc
      gyp ERR! not ok
      sigi234S Online
      sigi234S Online
      #222
      @DasBrot sagte in ioBroker unter Windows installieren (ohne Installer):
      Das ist Falsch!
      • sigi234S sigi234
        Das ist Falsch!
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        #223
        @sigi234 sagte in ioBroker unter Windows installieren (ohne Installer):
        Das ist Falsch!
        Das sehe ich anders.
        Bei mir hatte nur der "Versuch 2" zum Ziel geführt.
        Dein Befehl oben (stammt ja von stabilo..) funktionierte bei mir nicht.
        Nur der Umweg über 2.2.10 und dann self.
        Danke.
        D sigi234S AlCalzoneA 3 Antworten Letzte Antwort
        • bahnuhrB bahnuhr
          Das ist Falsch!
          DasBrot
          #224
          Das ist Falsch!
          Bei mir gehen beide nicht. Der erste Fehlermeldungssatz stammt von dem Befehl von stabilo.
          Dann installiere ich mal wieder neu.... oder in dem Fall besser alt :))
          • bahnuhrB bahnuhr
            Das ist Falsch!
            sigi234S Online
            sigi234S Online
            #225
            @bahnuhr
            Wie schon geschrieben, ein neuester Installer wird dringend benötig. Meine Meinung.
            • sigi234S sigi234
              @bahnuhr
              #226
              @sigi234
              @bahnuhr
              @DasBrot
              Die Änderung in der Anleitung wurde von @AlCalzone durchgeführt, weil die alte nicht mehr passt.
              Bevor jetzt wieder etwas halbgares gemacht wird, solltet ihr warten, ob er sich noch mal meldet
              PS Ich nix WIN
              • D DasBrot
                Das ist Falsch!
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                #227
                @DasBrot Verzeih mir, dass ich nicht alles gelesen habe...
                Was heißt für dich "geht nicht"? Dass die Admin-UI nicht kommt oder was anderes?
                Willst du updaten oder neu installieren? Falls Update, hat sich der Hostname zur alten Installation geändert? Das würde nämlich erklären, wenn der Admin nicht startet.
                • AlCalzoneA AlCalzone
                  DasBrot
                  schrieb am zuletzt editiert von DasBrot
                  #228
                  @AlCalzone said in ioBroker unter Windows installieren (ohne Installer):
                  Kein Problem. Wenn du von jedem alles lesen würdest, kämst du nicht zum antworten.
                  Es ist eine Neuinstallation mit Angabe eines Data ordners.
                  Die UI lässt sich nicht starten. Aber auch sämtliche Automatiken laufen nicht mehr, so wie die Alexa Sprachbefehle.
                  Daher bin ich von Totalausfall ausgegangen. Vor allem wegen der vielen Fehlermeldungen welche bei beiden Updatevarianten kamen.
                  Die vorherige Installation habe ich mittels Installer stets vorher entfernt.
                  Das Selbe mache ich aber auch wenn ich die alte Version wieder installiere. Ich gebe den vorher gesicherten Data Ordner an, und es läuft mit der alten Version wieder.
                  • D DasBrot
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    #229
                    Ich vermute hier eher, dass die Instanzen dabei nicht dem richtigen Host zugeordnet sind. Hat sich der Hostname der ioBroker-Instanz beim Update geändert im Vergleich zur alten (importierten) Instanz?
                    • bahnuhrB bahnuhr
                      Das ist Falsch!
                      AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      #230
                      @bahnuhr Ich teste gerade nochmal in einer Windows VM:
                      Variante 1: OHNE Migration, ganz frische Installation, nach meiner Anleitung
                      1. Installer genutzt
                      2. Konsole auf
                      3. iobroker stop
                      4. npm i iobroker.js-controller@stable --ignore-scripts
                      5. iobroker start -> Läuft!
                      6. Adapter aus Oberfläche installiert -> Läuft! ✔
                      7. Adapter aus Oberfläche geupdated -> Läuft! ✔
                      8. Adapter von Konsole aktualisiert -> Läuft! ✔
                      Bei allen Installationsbefehlen konnte ich in der Konsolenausgabe sehen, dass der problematische Parameter --prefix nicht verwendet wurde ✔
                      Variante 2: MIT Migration, ebenfalls nach meiner Anleitung
                      1. "alte Test-Installation" mit Installer 1.4 aufgesetzt. Stand nach Installation: Admin 3.6.0, JS-Controller 1.4.2
                      2. Adapter installiert und aktualisiert -> Läuft!
                      3. Alte Installation gestoppt, iobroker-data rauskopiert
                      4. Neuen Installer gestartet, Option zur Migration ausgewählt, rauskopierten Data-Ordner gewählt
                      5. vorher installierte Instanzen fehlen ❌
                      6. ioBroker-Konsole der neuen Installation auf
                      7. iobroker stop
                      8. npm i iobroker.js-controller@stable --ignore-scripts
                      9. gesicherten data-Ordner in neue Installation kopiert --> Das fehlt in der Anleitung!
                      10. iobroker start -> Läuft (aber unter altem Port)! ✔
                      11. Adapter-Update (auch Admin) über Web-UI -> Läuft! ✔
                      12. iobroker stop
                      13. iobroker start --> Läuft! ✔
                      Ich werde den Workaround anpassen, dass das Data-Ordner-Kopieren wieder drin steht. Ansonsten hatte ich keine Probleme.
                        2. Konsole auf
                        3. iobroker stop
                        7. iobroker stop
                        12. iobroker stop
                        DasBrot
                        #231
                        Also Variante zwei hat nun funktioniert. Ich habe diesmal nachdem ich den Data Ordner der alten Installation kopiert habe die alte Installation mittels Installer gelöscht, so das ich den gleichen Namen verwenden konnte. Danach nach der deutlich detailierteren Anleitung, (Danke) und siehe das, es hat funktioniert. Jetzt ist nur noch Node JS 10.17.0 alt. Aber das ist ja eine andere Baustelle.
                        Vielen Dank.
                        • D DasBrot
                          Vielen Dank.
                          klassisch
                          #232
                          Ist bei mir auch so. Das funktioniert und hat keine Nachteile
                          https://forum.iobroker.net/post/453751
                          https://forum.iobroker.net/post/453942
                          Also so lassen und freuen!
                          • K klassisch
                            JB_SullivanJ Offline
                            JB_Sullivan
                            #233
                            @klassisch
                            Nur so als Anmerkung - ich hatte unter Win mit der 12er Node, dann Probleme mit Canvas (keine Saugroboter Karten mehr). Bin dann wieder zurück auf 10.17 und damit funktioniert auch Canvas wieder - also, ist die Frage ob die neueste Node unbedingt sein muss ;)
                            Thomas BraunT K 2 Antworten Letzte Antwort
                            • JB_SullivanJ JB_Sullivan
                              @klassisch
                              #234
                              @JB_Sullivan
                              Canvas muss dann gegen die aktuelle node-Version gebaut werden.
                                @JB_Sullivan
                                JB_Sullivan
                                schrieb am zuletzt editiert von JB_Sullivan
                                #235
                                @Thomas-Braun Habe ich versucht - keine Chance. Irgendwo in der Node Community gab es auch ein Issue zu einer der 12 er Node Versionen und Canvas. Vielleicht habe ich da auch genau ins Klo gegriffen ;)
                                  @klassisch
                                  klassisch
                                  #236
                                  @JB_Sullivan Danke für die Info. Vor den ganzen Versionen habe ich ziemlichen Respekt. Schon mal weil ich nichts davon verstehe und weil es ganze Threads gibt, die sich damit beschäftigen.
                                    #237
                                    @JB_Sullivan
                                    Kann sein.
                                    Bei mir läuft node14 + canvas.
                                    Mit node12 ist mir aber auch nix aufgefallen.
                                    • P P-A-L-A-D-I-N
                                      @bahnuhr
                                      Wie hast Du den alten gelöscht? Mithilfe des Installers, mit dem Du ihn zuvor installiert hast?
                                      Falls Du es händisch gemacht haben solltest: Hast Du nicht nur den Ordner, sondern auch die ganzen Eintragungen des ioBroker (Dienste, Firewall, Registry) gelöscht?
                                      Ich könnte mir vorstellen, daß das Problem auftritt, weil sich die alte Installation (also irgendwelche Überreste davon) und die neue an irgendeiner Stelle in die Quere gekommen sind. Ist aber nur eine Vermutung.
                                      Die Tests habe ich selbst mit einem sauberen System gemacht. Da hat dann auch alles geklappt.
                                      Gleiches Ergebnis bei Hansi (der ebenfalls mit einem sauberen System gearbeitet hat), bei dem auch nach dem Neustart noch alles sauber läuft.
                                      Ich würde daher immer die Installation in einem sauberen Umfeld empfehlen oder, wenn es nicht anders geht, den alten ioBroker mit dem gleichen Installer deinstallieren, mit dem er zuvor aufgesetzt worden ist. Soweit ich weiß, entfernt der Installer die alte Installation wirklich restlos - was heutzutage ja selbst bei professioneller Software oft nicht einmal der Fall ist.
                                      michaelborowicz
                                      #238
                                      @p-a-l-a-d-i-n
                                      hi,
                                      ich konnte am Samstag den ganzen Prozess (Post 1) Problemlos durchführen. Leider nach dem Laptop Neustart kann ich den IOBroker nicht mehr starten. Ich bekomme folgende Meldung:
                                      und unter Dienste ist es so:
                                      ich bin mir nicht sicher wo ich den Fehler gemacht habe...
                                      Ich habe: Node.js 12.16.3
                                      Vielen Dank
                                      Viele Grüße
                                      Michael
                                      Vielen Dank
                                      Thomas BraunT P 2 Antworten Letzte Antwort
                                      • M michaelborowicz
                                        @p-a-l-a-d-i-n
                                        hi,
                                        Vielen Dank
                                        Viele Grüße
                                        Michael
                                        Vielen Dank
                                        #239
                                        @michaelborowicz
                                        P-A-L-A-D-I-N sagte:
                                        Wie gesagt, ich bin hier raus und werde keine weitere Zeit und Energie in diese Sache mehr stecken.
                                          @michaelborowicz
                                          michaelborowicz
                                          #240
                                          Danke Dir, jetzt habe ich etwas mehr zu dem Zitat von dir gefunden... ich habe hier auch ein Paar Stunden gesteckt um die Lösung zu finden... wie geschrieben Erfolglos, auch über YT; Google, neu Installation, etc.
                                          hast du Idee was so ein Anfänger wie ich in der Situation machen kann? ich konnte eventuell mich mit RasPi auseinander setzen...
                                          Wäre Dankbar für jeder Hilfe!
                                          Danke!
