  4. Adapter net-tools v0.1.x
    6.4k
net-toolsnet-tools adapterpingping adpter
50 Beiträge 13 Kommentatoren 9.8k Aufrufe 18 Beobachtet
  • sigi234S sigi234
    @Jey-Cee
    Adapter bleibt Rot.
    net-tools.0	2020-09-26 00:17:43.064	info	(1196) Terminated (NO_ERROR): Without reason
    net-tools.0	2020-09-26 00:17:43.064	info	(1196) terminating
    net-tools.0	2020-09-26 00:17:42.546	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    net-tools.0	2020-09-26 00:17:42.546	error	at portScan (C:\Program Files\iobroker\Test\node_modules\iobroker.net-tools\main.js:132:15)
    net-tools.0	2020-09-26 00:17:42.546	error	(1196) TypeError: Cannot read property 'val' of null
    net-tools.0	2020-09-26 00:17:42.546	error	(1196) unhandled promise rejection: Cannot read property 'val' of null
    net-tools.0	2020-09-26 00:17:42.508	info	(1196) starting. Version 0.1.0 in C:/Program Files/iobroker/Test/node_modules/iobroker.net-tools, node: v12.18.0, js-controller: 3.1.6
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    @sigi234 sagte in Adapter net-tools v0.1.x:
    Adapter bleibt Rot.
    @Jey-Cee
    bei mir auch
    net-tools.0	2020-09-26 17:28:29.182	info	(780) Terminated (NO_ERROR): Without reason
    net-tools.0	2020-09-26 17:28:29.181	info	(780) terminating
    net-tools.0	2020-09-26 17:28:28.672	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    net-tools.0	2020-09-26 17:28:28.672	error	at portScan (/opt/iobroker/node_modules/iobroker.net-tools/main.js:132:15)
    net-tools.0	2020-09-26 17:28:28.672	error	(780) TypeError: Cannot read property 'val' of null
    net-tools.0	2020-09-26 17:28:28.671	error	(780) unhandled promise rejection: Cannot read property 'val' of null
    net-tools.0	2020-09-26 17:28:28.573	info	(780) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.net-tools, node: v12.18.3, js-controller: 3.1.6
    Geräte lassen sich auch keine anlegen.
    ° Fixer ---> iob fix
    • Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      schrieb am zuletzt editiert von Jey Cee
      @sigi234 @Negalein danke für die Meldung.
      EDIT: Fix ist auf Github.
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
      • Jey CeeJ Jey Cee
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @Jey-Cee sagte in Adapter net-tools v0.1.x:
        Danke, funktioniert!
        Wäre es noch möglich, statt der MAC die IP oder besser noch den Namen als ID in den Objekten zu verwenden?
        • NegaleinN Negalein
          Jey CeeJ Online
          Jey CeeJ Online
          Jey Cee
          @Negalein sagte in Adapter net-tools v0.1.x:
          Möglich wäre das schon, aber ich habe ganz bewusst darauf verzichtet. Die MAC ist eindeutig und verändert sich nicht, sowohl IP wie auch Name können sich ändern. Die ID sollte immer eindeutig und unveränderlich sein, das sollte bei allen Adaptern Standard sein, das wurde vor einiger Zeit auch so besprochen.
          Es gibt halt noch alt bestand wo das nicht so ist und manche neuen Entwickler sind sich dessen nicht bewusst oder es geht manchmal einfach nicht anders.
          Klar kann man das Problem mit einem Alias umgehen, für mich ist das aber ein Workaround der das ganze System nur Aufbläht.
          Für den Benutzer und die Übersichtlichkeit gibt es die Möglichkeit Objekten einen Namen zu geben, davon sollte man auch Gebrauch machen.
          • Jey CeeJ Jey Cee
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            Danke für die Info.
            Versteh ich.
              swordfisch
              Wollte den Adapter auch mal testen leider bekomme ich ihn nicht installiert
              install https://github.com/Jey-Cee/ioBroker.net-tools/tarball/37a817a9f18edaf343a20fa0709172f0b725fbf2
              NPM version: 6.8.0
              npm install https://github.com/Jey-Cee/ioBroker.net-tools/tarball/37a817a9f18edaf343a20fa0709172f0b725fbf2 --loglevel error --prefix "/opt/iobroker" (System call)
              npm ERR! cb.apply is not a function
              npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-09-26T19_21_25_087Z-debug.log
              ERROR: host.iOBroker Cannot install https://github.com/Jey-Cee/ioBroker.net-tools/tarball/37a817a9f18edaf343a20fa0709172f0b725fbf2: 1
              • liv-in-skyL Offline
                liv-in-skyL Offline
                hi @Jey-Cee
                leider beim starten des adapters
                net-tools.0	2020-09-26 21:56:48.303	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                net-tools.0	2020-09-26 21:56:48.303	error	at portScan (/opt/iobroker/node_modules/iobroker.net-tools/main.js:132:15)
                net-tools.0	2020-09-26 21:56:48.303	error	(6673) TypeError: Cannot read property 'val' of null
                net-tools.0	2020-09-26 21:56:48.302	error	(6673) unhandled promise rejection: Cannot read property 'val' of null
                Unhandled	2020-09-26 21:56:48.301	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                • S swordfisch
                  NPM version: 6.8.0
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @swordfisch sagte in Adapter net-tools v0.1.x:
                  NPM version: 6.8.0
                  Dein System scheint recht alt zu sein !
                  • GlasfaserG Glasfaser
                    NPM version: 6.8.0
                    Jey CeeJ Online
                    Jey CeeJ Online
                    Jey Cee
                    @swordfisch ich würde sagen erstmal npm (und damit auch nodejs) Aktualisieren.
                    @liv-in-sky selbes Problem wie Negalein und sigi234, das habe ich behoben. Einmal Adapter löschen und nochmal neu von Github installieren.
                    liv-in-skyL S 2 Antworten Letzte Antwort
                    • Jey CeeJ Jey Cee
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      @Jey-Cee
                      erstmal danke - flutscht jetzt
                      2 fragen:
                      • ist das normal, dass keine ip in den datenpunkten angezeigt wird
                      • echo geräte werden nicht gefunden - ich hatte mal ein script gemacht, dass auch das netzwerk scannt und eine html tabelle erstellt - das script arbeitet mit nmap tool, welches unter linux und windows installiert werden muss (damit werden die echo's gefunden) - sowas kann man nicht in deinen adapter einbauen ? https://forum.iobroker.net/topic/30057/ip-devices-im-netzwerk-html-tabelle-vis-iqontrol
                      • Jey CeeJ Jey Cee
                        swordfisch
                        @Jey-Cee Node.js läuft auf version v12.18.4
                        Thomas BraunT Jey CeeJ 2 Antworten Letzte Antwort
                        • S swordfisch
                          @swordfisch Insgesamt sauber?
                          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                          • liv-in-skyL liv-in-sky
                            @Jey-Cee
                            2 fragen:
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            @liv-in-sky sagte in Adapter net-tools v0.1.x:
                            @Jey-Cee
                            wäre toll, wenn das ginge
                            • S swordfisch
                              Jey CeeJ Online
                              Jey CeeJ Online
                              Jey Cee
                              @swordfisch Ok aber warum dann die alte npm version?
                              Ja -> Erklärung
                              nmap
                              Hab ich mir angeschaut, bin nicht begeistert das man es extra installieren muss und es dann auch noch als root Ausführen muss. Aber grundsätzlich ist es so das die Discover Funktion vom discovery Adapter kommt und dadurch müsste nmap dort verwendet werden. Falls ich mal die Muse habe mich an den discovery Adapter ran zu machen wird das wohl kommen.
                              Für die Ping Funktion :man-shrugging: Auf jeden Fall müsste sie dann neu geschrieben werden, da hab ich jetzt gerade keine Lust drauf. Viellleicht in der Zukunft.
                                swordfisch
                                @Thomas-Braun
                                root@iOBroker:~# which nodejs && nodejs -v && which node && node -v && which npm                                          && npm -v && apt policy nodejs
                                /usr/bin/nodejs
                                v12.18.4
                                /usr/local/bin/node
                                v12.18.4
                                /usr/local/bin/npm
                                6.8.0
                                nodejs:
                                  Installiert:           12.18.4-1nodesource1
                                  Installationskandidat: 12.18.4-1nodesource1
                                  Versionstabelle:
                                 *** 12.18.4-1nodesource1 500
                                        500 https://deb.nodesource.com/node_12.x stretch/main amd64 Packages
                                     10.21.0~dfsg-1~deb10u1 500
                                        500 http://ftp.de.debian.org/debian buster/main amd64 Packages
                                        500 http://security.debian.org/debian-security buster/updates/main amd64                               Packages
                                @Jey-Cee Ja das weiß ich auch noch nicht habs gerade alles deinstalliert und neu installiert aber die 6.8.0 kommt immer wieder
                                • S swordfisch
                                  @Thomas-Braun
                                  /usr/bin/nodejs
                                  v12.18.4
                                  /usr/local/bin/node
                                  v12.18.4
                                  /usr/local/bin/npm
                                  6.8.0
                                  nodejs:
                                    Versionstabelle:
                                  @swordfisch Nicht richtig installiert.
                                  Schau hier:
                                  https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                                  In der nodesource.list muss auch buster stehen, nicht stretch. Und du solltest kein root sein.
                                    Schau hier:
                                    swordfisch
                                    @Thomas-Braun habe heute nacht ein neues System aufgesetzt und mein Bacjup eingespielt das neue system hat jetzt auch npm 6.14.6 keine Ahnung warum das alte "kaputt" war
                                    • S swordfisch
                                      @swordfisch
                                      Weil das 'alte' npm nicht im richtigen Pfad lag.
                                      Und 'node' auch nicht.
                                        @swordfisch
                                        swordfisch
                                        @Thomas-Braun ja aber hatte es ja auch deinstalliert und neu installiert aber danach war es halt immer noch Falsch
                                        • S swordfisch
                                          @swordfisch Aber das in /usr/local/bin liegende npm hast du bestimmt nicht deinstalliert. Und da der Pfad zuerst auf der Suche nach einem Befehl durchlaufen wird kannst du da nodejs regulär updaten wie du lustig bist.
                                          pi@raspberrypi:~ $ echo $PATH
                                          /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
                                          Basti97B 1 Antwort Letzte Antwort
