  4. Nach Shutdown vom Raspberry ioBroker weg
rebootproblem
61 Beiträge 4 Kommentatoren 5.0k Aufrufe 3 Beobachtet
    @jmeister79
    mount | grep ^/dev
    cat /etc/fstab
    jmeister79J Offline
    jmeister79J Offline
    jmeister79
    @Thomas-Braun
    pi@iobrokerpi:~ $ mount | grep ^/dev
    /dev/sda2 on / type ext4 (rw,noatime)
    /dev/sda1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
    pi@iobrokerpi:~ $ cat /etc/fstab
    proc            /proc           proc    defaults          0       0
    PARTUUID=6c586e13-01  /boot           vfat    defaults          0       2
    PARTUUID=6c586e13-02  /               ext4    defaults,noatime  0       1
    # a swapfile is not a swap partition, no line here
    #   use  dphys-swapfile swap[on|off]  for that
    //medianas/intern /home/pi/nas_intern cifs username=iobroker,password=xxxxxxxxxxxx,vers=1.0,users,auto,user_xattr 0 0
    • GlasfaserG Glasfaser
      @jmeister79
      Zeige mal :
      cd /opt/iobroker
      iobroker status
      iobroker list adapters
      iobroker list instances
      ls -l
      und der ioBroker läuft von USB.
      [    3.192557] scsi 0:0:0:0: Direct-Access     Intenso  Micro Line       1.01 PQ: 0 ANSI:
      [    3.193622] sd 0:0:0:0: [sda] 15669248 512-byte logical blocks: (8.02 GB/7.47 GiB)
      [    3.193971] sd 0:0:0:0: [sda] Write Protect is off
      [    3.194003] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
      [    3.194374] sd 0:0:0:0: [sda] No Caching mode page found
      [    3.194407] sd 0:0:0:0: [sda] Assuming drive cache: write through
      [    3.197846]  sda: sda1 sda
      [    3.200748] sd 0:0:0:0: [sda] Attached SCSI removable disk
      [    3.236260] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      [    3.236345] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [    3.246542] devtmpfs: mounted
      [    3.254441] Freeing unused kernel memory: 2048K
      Ist das der Stick mit 8 GB !?
      EDIT :
      siehe dazu in deinem anderen Thread !
      Link Text
      jmeister79J Offline
      jmeister79J Offline
      jmeister79
      @Glasfaser said in Nach Shutdown vom Raspberry ioBroker weg:
      iobroker status
      ls -l
      pi@iobrokerpi:~ $ iobroker status
      No objects found!
      pi@iobrokerpi:~ $ iobroker list adapters
      No objects found!
      pi@iobrokerpi:~ $ iobroker list instances
      No objects found!
      pi@iobrokerpi:~ $ ls -l
      total 0
      drwxrwxrwx 12 root root 0 Aug 24 17:05 nas_intern
      • jmeister79J jmeister79
        iobroker status
        ls -l
        No objects found!
        No objects found!
        No objects found!
        total 0
        @jmeister79
        cd /opt/iobroker
        ls -la
        jmeister79J 1 Antwort Letzte Antwort
          @jmeister79
          cd /opt/iobroker
          ls -la
          jmeister79J Offline
          jmeister79J Offline
          jmeister79
          @Thomas-Braun said in Nach Shutdown vom Raspberry ioBroker weg:
          cd /opt/iobroker
          ls -la
          pi@iobrokerpi:/opt/iobroker $ ls -la
          total 308
          drwxrwxrwx+   9 iobroker iobroker   4096 Sep 16 14:19 .
          drwxr-xr-x    4 root     root       4096 Oct 21  2019 ..
          drwxrwxrwx+   2 iobroker iobroker   4096 Sep 16 13:10 backups
          drwxrwxrwx+   2 iobroker iobroker  12288 Sep 17 17:08 cache
          -rwxrwxrwx+   1 iobroker iobroker   1049 Oct 21  2019 CHANGELOG_FIXER_LINUX.md
          -rwxrwxrwx+   1 iobroker iobroker   3556 Oct 21  2019 CHANGELOG_INSTALLER_LINUX.md
          -rwxrwxrwx+   1 iobroker iobroker  23988 Oct 21  2019 fix_installation.sh
          drwxrwxrwx+   3 iobroker iobroker   4096 Oct 21  2019 install
          -rwxrwxrwx+   1 iobroker iobroker    371 Sep 16 14:19 INSTALLER_INFO.txt
          lrwxrwxrwx    1 iobroker iobroker     22 Sep 16 14:19 iob -> /opt/iobroker/iobroker
          -rwxr-xr-x+   1 iobroker iobroker    305 Sep 16 14:19 iobroker
          drwxrwxrwx+   8 iobroker iobroker   4096 Sep 15 15:57 iobroker-data
          drwxrwxrwx+   2 iobroker iobroker   4096 Oct 21  2019 lib
          -rwxrwxrwx+   1 iobroker iobroker   1137 Oct 21  2019 LICENSE
          drwxrwxrwx+   2 iobroker iobroker   4096 Sep 26 11:36 log
          drwxrwxrwx+ 805 iobroker iobroker  28672 Sep 15 16:14 node_modules
          -rwxrwxrwx+   1 iobroker iobroker    109 Sep 16 14:18 .npmrc
          -rwxrwxrwx+   1 iobroker iobroker   1861 Sep 15 16:14 package.json
          -rwxrwxrwx+   1 iobroker iobroker 169201 Oct 21  2019 package-lock.json
          -rwxrwxrwx+   1 iobroker iobroker   6101 Oct 21  2019 README.md
          -rwxrwxrwx+   1 iobroker iobroker   5728 Sep 16 15:31 reinstall.js
          Thomas BraunT GlasfaserG 3 Antworten Letzte Antwort
            cd /opt/iobroker
            ls -la
            total 308
            @jmeister79
            ./iobroker status
              cd /opt/iobroker
              ls -la
              total 308
              GlasfaserG Offline
              GlasfaserG Offline
              @jmeister79
              Oben in meiner Anfrage war
              cd /opt/iobroker
              und dann die Befehle
                @jmeister79
                cd /opt/iobroker
                jmeister79J Offline
                jmeister79J Offline
                jmeister79
                @Glasfaser hab das selbe ergebnis
                  @jmeister79
                  which iobroker
                  ls -la /usr/bin/iobroker
                  ls -la /opt/iobroker/iobroker
                    @jmeister79
                    which iobroker
                    jmeister79J Offline
                    jmeister79J Offline
                    jmeister79
                    @Thomas-Braun
                    Thomas, zunächst einmal danke dass du dir die Zeit nimmst.
                    Wonach suchst Du genau? Bin bei Linux leider nur soweit bewandert wie ich es immer brauche. Vielleicht kannst du ein zwei worte dazu sagen. Danke Dir
                    Nils
                    pi@iobrokerpi:~ $ which iobroker
                    /usr/bin/iobroker
                    pi@iobrokerpi:~ $ ls -la /usr/bin/iobroker
                    lrwxrwxrwx 1 root root 22 Sep 16 14:19 /usr/bin/iobroker -> /opt/iobroker/iobroker
                    pi@iobrokerpi:~ $ ls -la /opt/iobroker/iobroker
                    -rwxr-xr-x+ 1 iobroker iobroker 305 Sep 16 14:19 /opt/iobroker/iobroker
                    pi@iobrokerpi:~ $
                    • jmeister79J Offline
                      jmeister79J Offline
                      jmeister79
                      in htop ist kein iobroker aufgelistet.
                        cd /opt/iobroker
                        ls -la
                        total 308
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @jmeister79 sagte in Nach Shutdown vom Raspberry ioBroker weg:
                        das ist das letzte Lebenszeichen ....
                        Zeige mal :
                        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                          @jmeister79
                          Und jag den Fixer mal über das System:
                          curl -sL https://iobroker.net/fix.sh | bash -
                            Zeige mal :
                            jmeister79J Offline
                            jmeister79J Offline
                            jmeister79
                            Hatte letzte woche einmal komplett geupdatet. also müsste es recht frisch sein.
                            Der Stick ist von letzter Woche Komplett gesichert. Und gestern nacht lief ein backitup. also sind hopfen und malz nicht verloren. Aber wäre mal interessant zu wissen was nun wieder schief gelaufen ist...
                            pi@iobrokerpi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                            /usr/bin/nodejs
                            v12.18.4
                            /usr/bin/node
                            v12.18.4
                            /usr/bin/npm
                            6.14.6
                            nodejs:
                              Installed: 12.18.4-1nodesource1
                              Candidate: 12.18.4-1nodesource1
                              Version table:
                             *** 12.18.4-1nodesource1 500
                                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                                 10.21.0~dfsg-1~deb10u1+rpi1 500
                            pi@iobrokerpi:~ $
                              @jmeister79
                              jmeister79J Offline
                              jmeister79J Offline
                              jmeister79
                              @Thomas-Braun
                                  Welcome to the ioBroker installation fixer!
                                  Script version: 2020-06-15
                                  You might need to enter your password a couple of times.
                                  Installing prerequisites (1/3)
                              Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
                              Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
                              Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
                              Get:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [331 kB]
                              Get:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
                              Get:6 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages [58.7 kB]
                              Fetched 13.4 MB in 13s (1,007 kB/s)
                              Reading package lists... Done
                              Installed gcc-c++
                                  Checking ioBroker user and directory permissions (2/3)
                              chown: changing ownership of '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/jest-resolve-dependencies/node_modules/ansi-styles/readme.md': Structure needs cleaning
                              This system does not support setting default permissions.
                              Do not use npm to manually install adapters unless you know what you are doing!
                                  Checking autostart (3/3)
                              Enabling autostart...
                              Autostart enabled!
                                  Your installation was fixed successfully
                                  Run iobroker start to start ioBroker again!
                              GlasfaserG HomoranH 2 Antworten Letzte Antwort
                                @Thomas-Braun
                                Installed gcc-c++
                                Autostart enabled!
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @jmeister79
                                und jetzt :
                                cd /opt/iobroker
                                iobroker start
                                iobroker status
                                  @jmeister79
                                  und jetzt :
                                  cd /opt/iobroker
                                  iobroker start
                                  iobroker status
                                  jmeister79J Offline
                                  jmeister79J Offline
                                  jmeister79
                                  @Glasfaser
                                  pi@iobrokerpi:~ $ cd /opt/iobroker
                                  pi@iobrokerpi:/opt/iobroker $ iobroker start
                                  pi@iobrokerpi:/opt/iobroker $ iobroker status
                                  No objects found!
                                  pi@iobrokerpi:/opt/iobroker $ iobroker list instances
                                  No objects found!
                                    @Thomas-Braun
                                    Installed gcc-c++
                                    Autostart enabled!
                                    das habt ihr aber gesehen?
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @Homoran
                                      Ja ..
                                      ist bei mir auch ( Syn Docker ) , deshalb nicht beachtet :
                                      sudo: Hostname iobroker kann nicht aufgelöst werden: Der Name oder der Dienst ist nicht bekannt
                                        @Homoran
                                        Ja ..
                                        @Glasfaser sagte in Nach Shutdown vom Raspberry ioBroker weg:
                                        Syn Docker
                                        dann bin ich wieder ganz still 😴
                                          Syn Docker
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @Homoran sagte in Nach Shutdown vom Raspberry ioBroker weg:
                                          Eingentlich nicht ... er hat eine PI
