  4. (gelöst) keine Admin-Oberfläche nach Neuinstallation
docker buanet admin
43 Beiträge 4 Kommentatoren 4.3k Aufrufe 3 Beobachtet
  • iobroker_RainerI iobroker_Rainer
    @iobroker_Rainer Im neuen Link steht im wesentlichen das gleiche. Habe noch versucht wie vorgeschlagen den Controller von Hand zu starten mit dem Ergebnis:
    root@iobroker2020:/opt/iobroker# node -v npm -v
    v12.18.4
    root@iobroker2020:/opt/iobroker# npm -v
    6.14.6
    root@iobroker2020:/opt/iobroker# node node_modules/iobroker.js-controller/controller.js --logs
    2020-09-16 18:39:30.334 - info: host.iobroker2020 iobroker.js-controller version 3.1.6 js-con
    troller starting
    2020-09-16 18:39:30.340 - info: host.iobroker2020 Copyright (c) 2014-2020 bluefox, 2014 hobby
    quaker
    2020-09-16 18:39:30.341 - info: host.iobroker2020 hostname: iobroker2020, node: v12.18.4
    2020-09-16 18:39:30.343 - info: host.iobroker2020 ip addresses: 172.17.0.2
    2020-09-16 18:39:30.427 - info: host.iobroker2020 Error inMem-objects listening on port 9001
    2020-09-16 18:39:30.443 - info: host.iobroker2020 Error inMem-states listening on port 9000
    2020-09-16 18:39:30.479 - info: host.iobroker2020 connected to Objects and States
    2020-09-16 18:39:30.694 - info: host.iobroker2020 4 instances found
    host.iobroker2020 check instance "system.adapter.admin.0" for host "iobroker2020"
    host.iobroker2020 check instance "system.adapter.discovery.0" for host "iobroker2020"
    host.iobroker2020 check instance "system.adapter.info.0" for host "iobroker2020"
    host.iobroker2020 check instance "system.adapter.admin.1" for host "iobroker2020"
    2020-09-16 18:39:30.708 - info: host.iobroker2020 starting 4 instances
    2020-09-16 18:39:30.728 - info: host.iobroker2020 instance system.adapter.admin.0 started wit
    h pid 1079
    ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process sto
    pped]
    2020-09-16 18:39:32.393 - error: host.iobroker2020 instance system.adapter.admin.0 terminated
    by request of the instance itself and will not be restarted, before user restarts it.
    2020-09-16 18:39:32.394 - info: host.iobroker2020 Do not restart adapter system.adapter.admin
    .0 because desired by instance
    ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adap
    ter.admin.0.logging]
    2020-09-16 18:39:34.716 - info: host.iobroker2020 instance system.adapter.admin.1 started wit
    h pid 1090
    GlasfaserG Offline
    GlasfaserG Offline
    @Homoran
    @iobroker_Rainer sagte in [Admin-Oberfläche nicht verfügbar nach Neuinstallation]
    da ist noch einer mit dem gleichen Fehler wie gestern
      @Glasfaser Container läuft auf meiner Syno - der angegebenen IP-Adresse. Status des Containers laut Docker: up and running ...
      GlasfaserG Offline
      GlasfaserG Offline
      @iobroker_Rainer
      Kannst du bitte einen Neustart von ioBroker machen und den Log hier posten !
      iobroker_RainerI 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        @iobroker_Rainer
        iobroker_RainerI Offline
        iobroker_Rainer
        @Glasfaser voila ...
        "2020-09-16 19:07:43.387 - info: host.iobroker2020 iobroker.js-controller version 3.1.6 js-controller starting
        2020-09-16 19:07:43.391 - info: host.iobroker2020 Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
        2020-09-16 19:07:43.392 - info: host.iobroker2020 hostname: iobroker2020, node: v12.18.4
        2020-09-16 19:07:43.394 - info: host.iobroker2020 ip addresses: 172.17.0.2
        2020-09-16 19:07:43.487 - info: host.iobroker2020 Error inMem-objects listening on port 9001
        2020-09-16 19:07:43.501 - info: host.iobroker2020 Error inMem-states listening on port 9000
        2020-09-16 19:07:43.542 - info: host.iobroker2020 connected to Objects and States
        2020-09-16 19:07:43.764 - info: host.iobroker2020 4 instances found
        2020-09-16 19:07:43.777 - info: host.iobroker2020 starting 4 instances
        2020-09-16 19:07:43.793 - info: host.iobroker2020 instance system.adapter.admin.0 started with pid 1235
        2020-09-16 19:07:44.952 - error: admin.0 (1235) admin.0 invalid process id scenario 111 vs. own ID 1235. Stopping
        2020-09-16 19:07:44.955 - info: admin.0 (1235) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2020-09-16 19:07:45.471 - error: host.iobroker2020 instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        2020-09-16 19:07:45.471 - info: host.iobroker2020 Do not restart adapter system.adapter.admin.0 because desired by instance
        2020-09-16 19:07:47.785 - info: host.iobroker2020 instance system.adapter.admin.1 started with pid 1246
        2020-09-16 19:07:48.938 - error: admin.1 (1246) admin.1 invalid process id scenario 1006 vs. own ID 1246. Stopping
        2020-09-16 19:07:48.941 - info: admin.1 (1246) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2020-09-16 19:07:49.453 - error: host.iobroker2020 instance system.adapter.admin.1 terminated by request of the instance itself and will not be restarted, before user restarts it.
        2020-09-16 19:07:49.454 - info: host.iobroker2020 Do not restart adapter system.adapter.admin.1 because desired by instance
        2020-09-16 19:07:51.785 - info: host.iobroker2020 instance system.adapter.discovery.0 started with pid 1257
        2020-09-16 19:07:52.483 - error: discovery.0 (1257) discovery.0 invalid process id scenario 126 vs. own ID 1257. Stopping
        2020-09-16 19:07:52.486 - info: discovery.0 (1257) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2020-09-16 19:07:53.002 - error: host.iobroker2020 instance system.adapter.discovery.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        2020-09-16 19:07:53.003 - info: host.iobroker2020 Do not restart adapter system.adapter.discovery.0 because desired by instance
        2020-09-16 19:07:55.786 - info: host.iobroker2020 instance system.adapter.info.0 started with pid 1268
        2020-09-16 19:07:57.025 - error: info.0 (1268) info.0 invalid process id scenario 141 vs. own ID 1268. Stopping
        2020-09-16 19:07:57.028 - info: info.0 (1268) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2020-09-16 19:07:57.538 - error: host.iobroker2020 instance system.adapter.info.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        2020-09-16 19:07:57.539 - info: host.iobroker2020 Do not restart adapter system.adapter.info.0 because desired by instance"
          GlasfaserG Offline
          GlasfaserG Offline
          @iobroker_Rainer sagte in Admin-Oberfläche nicht verfügbar nach Neuinstallation:
          wo kommt eigentlich diese IP her !?
            iobroker_Rainer
            @Glasfaser gute Frage. Ich habe in den letzten Tagen in meiner alten - noch funktionierenden Installation mit node-red und selenium experimentiert. Da ist sie mir auch zum ersten Mal aufgefallen. War mit einer der Gründe, warum ich das System neu aufsetzen wollte, damit potentiell alter Kruscht mal wieder gelöscht wird. Ist mir ein Rätsel, woher sie kommt.
              GlasfaserG Offline
              GlasfaserG Offline
              @iobroker_Rainer
              Zeige mal ein Screenshot hiervon !
                @iobroker_Rainer
                iobroker_Rainer
                @Glasfaser ... da ist der Fehler - habs im Brigde Mode installiert
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @iobroker_Rainer
                  dann stelle mal um auf host ...
                  oder hat das ein Grund auf bridge , deshalb hast du diese IP 172.17.0.2 !
                    Docker-Container
                    Läuft der Container im Host !?
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @iobroker_Rainer
                    Genau das habe ich schon oben gefragt ... bzw. schon vermutet das es bei dir so nicht ist
                    @Glasfaser sagte in Admin-Oberfläche nicht verfügbar nach Neuinstallation:
                    Docker-Container
                      @Homoran
                      @Homoran
                      schrieb ich doch!
                      @iobroker_Rainer hat auch zwei Container.
                      Den anderen unbedingt komplett abschalten.
                      Die Ports sind noch in Gebrauch!
                        @iobroker_Rainer
                        Docker-Container
                        iobroker_Rainer
                        @Glasfaser das war es. Tut mit leid, dass ich Deine Frage nicht richtig verstanden hatte. Neuinstalliert und alles tut wie es soll :-)))))
                        Vielen Dank für die Zeit, die Ihr investiert hat!!!!!!!!!!!!!!
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @iobroker_Rainer
                          Siehe Beitrag @Homoran ;)
                            @iobroker_Rainer
                            iobroker_Rainer
                            @Glasfaser yes! Mach ich. Vielen Dank nochmal!!
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @iobroker_Rainer
                              Hier zu CodeTags ...
                              EDIT .. neuer Clip
                              iobroker_RainerI Thomas BraunT 2 Antworten Letzte Antwort
                                @iobroker_Rainer
                                EDIT .. neuer Clip
                                iobroker_Rainer
                                @Glasfaser mea culpa, Glasfaser - MACH ICH!!!!
                                  @iobroker_Rainer
                                  EDIT .. neuer Clip
                                  @Glasfaser Da hast du einen meiner Meckerposts in deinem Clip?!? 😆
                                  iobroker_RainerI GlasfaserG 2 Antworten Letzte Antwort
                                    iobroker_Rainer
                                    @Thomas-Braun Recht hat er - und du auch 😊
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @Thomas-Braun
                                      EDIT ...
                                        @Thomas-Braun
                                        EDIT ...
                                        @Glasfaser Oha. Hört sich ja wie eine Drohung an. Weiß nicht ob ich das möchte...
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @Thomas-Braun
                                          Edit gemacht ...
                                          VideoClip kommt neu 🤗
